  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 406.4k Views 39 Watching
  • AndurilA Anduril
    Is it possible to set a fixed IP adress and bypass DHCP? My router sometimes messes up his DHCP-table and reassigns all adresses. Then I would have to correct the IP in my controller which I want to avoid.
    @Anduril The ESP8266 Arduino port uses the same API as the standard Arduino WiFi library.
    This means you should be able to use WiFi.config() to set a fixed IP address.
    Change the following line in Esp8266Gateway.ino
      (void)WiFi.begin(ssid, pass);
    into something like (untested!):
      IPAddress ip(192, 168, 0, 123);  /* Set to whatever IP address you'd like the gateway to have */
      WiFi.config(ip);
    Please report back your experience!
    • sowardS
      sowardS
      soward
      I got this working on an 0.9 version of the nodeMCU ( the Yellow board ). It has some code upload issues, which are slightly worse on OS X than Linux, but usually a couple of tries with holding down the button as @hek mentioned usually does the trick. I do not have any TCP/IP clients pointed at it currently, but I also get lots of watch dog timer resets, which seem somewhat random, as it will run and log messages for somewhere between 15 mins and 10 hours.
      It is just being powered by USB and I have not swapped NRF modules yet, so one of those may likely be the culprit, but just wanted to chime in with a (mostly) successful setup.
      thanx
      • K
        K
        kimnguu204
        wrote on last edited by kimnguu204
        #83
        Hello all,
        is there anybody setup MQTT gateway and it's working fine? how many node wifi gateway can handle?
        Could you please share me Wifi MQTT Gateway code.
        Thank you all and have a nice day
        • K kimnguu204
          Hello all,
          Currently there is no MQTT WiFi gateway, but it shouldn't be very hard to create one by combining the WiFi Gateway with the MQTT gateway.
          The same as any other MySensors gateway (around 250).
          • R
            R
            ridge
            I will report a successful first experience with MySensors using the esp8266 WiFi Gateway and a digital switch nRF24L01+ MySensors node.
            Thank you Yveaux and hek! nRF24L01+ nodes are the only way to go for battery power!
            I look forward to learning more about the MySensors architecture.
            I am currently using openHAB as my controller.
            For the MQTT library, I will vote for the https://github.com/Imroy/pubsubclient library if you decide to create a MQTT version of the WiFi Gateway. I have this library installed on 8 esp8266 nodes operating for over two months without any problems.
            The knolleary version has had some recent updates since I installed the lmroy version, so it may work fine with Mosquitto MQTT 3.1.1 instead of MQTT 3.1 only.
            • V
              V
              vickey
              wrote on last edited by vickey
              #86
              Hi Friends
              I am having an issue with my NRF24L01+. If I change gw.begin() to anything like below,
              I get an error "radio init fail"
              And I am now trying ESP-8266 12E module along with nrf24L01+ (genuine) transceiver to built wifi gateway, which I'll later use as gateway for openhab. I am having a similar issue, Here is the log I get through serial monitor.
              **Connecting to Ahmed
              ...........Connected!
              IP: 192.168.0.31
              0;0;3;0;9;radio init fail
              ctx: cont
              sp: 3ffebdf0 end: 3ffec010 offset: 01b0
              stack>>>
              3ffebfa0: 0000007f 3ffec03c 40201cac 3ffeaff0
              3ffebfb0: 40202320 00000001 00000000 40201d4f
              3ffebfc0: 1f00a8c0 00ffffff 0100a8c0 3ffec03c
              3ffebfd0: 3ffe9328 3ffead34 3ffec070 402026ef
              3ffebfe0: 3ffe98a8 1f00a8c0 00000000 00000000
              3ffebff0: 3fffdc20 00000000 3ffec034 40201d1f
              3ffec000: 00000000 00000000 3ffeaff0 40100398
              <<<stack<<<
              ets Jan 8 2013,rst cause:1, boot mode:(3,3)
              tail 0
              chksum 0x42
              csum 0x42
              ~ld**
              This information runs in a loop again and again. I am using latest library from https://github.com/mysensors/Arduino/tree/master without editing the sample Esp8266Gateway sktech except user name and password. I have followed the connection instruction specified in sample sketch and sketch was successfully uploaded. I am using 101nf capacitors and 10K resistances as specified by https://www.youtube.com/watch?v=JA-0hs5rpMY.
              Everything is working fine except that error. May anyone help me out?
              • V vickey
                Hi Friends
                IP: 192.168.0.31
                ctx: cont
                stack>>>
                <<<stack<<<
                tail 0
                chksum 0x42
                csum 0x42
                ~ld**
                @vickey the resets you're experiencing are caused by the failure to init the radio. This will cause the MySensors library to enter an endless loop. This will cause the watchdog to trigger and reset the ESP.
                Please try connecting the radio exactly as stated on the MySensors build page (when using NodeMcu hardware) or connect the same way as I did (see first post in this topic).
                Double check your radio connections.
                • V
                  V
                  vickey
                  #88
                  I have checked all the wires and every thing is according to as par advised. I am using 2 separate 3.3 v voltage regulator to power up ESP-8266 12E and nrf24L01+ having common ground, using ESP-8266 breakout board without voltage regulator and nrf24l01+ breakout board with 3.3 v regulator powered by 5v supply.
                  GPIO15 connected via 10K pulldown resistor to GND and also connected with CSN of nrf24l016, is this connection correct?
                  Moreover, I am using USB to TTL adapter in place of FTDI and TX of ESP-8266 is connected with RX of TTL serial adapter and vice versa, GND of TTL serial adapter is also connected common GND. It's all the difference from your mentioned procedure.
                  • V vickey
                    @vickey could the nrf24 be defective?
                    Did you obtain the gateway & MySensors code from my github repository or from MySensors repository?
                    • V
                      V
                      vickey
                      #90
                      Sorry When I investigate the wiring throughly, MOSI and MISO was interchanged. Now it has started working but error has changed
                      ESP8266 MySensors Gateway
                      Connecting to Ahmed
                      .......Connected!
                      IP: 192.168.0.31
                      0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                      0;0;3;0;9;ver mismatch
                      I obtained the code for gateway & MySensors from MySensors repository on github.
                      what would be the problem now?
                      • R
                        R
                        ridge
                        wrote on last edited by ridge
                        #91
                        I would like to use this tutorial for MySensors in the openHAB program:
                        http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
                        I have the ESP8266 WiFi gateway working over a telnet session in Putty.
                        Is there a way to have openHAB communicate over telnet like a hardwired serial interface?
                        Has anyone used this yet?
                        https://github.com/openhab/openhab/pull/2832
                        • R ridge
                          @ridge sorry, can't help with that. Everything's MQTT over here :-)
                          • R
                            R
                            ridge
                            Thanks! Are you using this gateway with a controller or is it a proof of concept?
                            It is fun to watch the states respond in a telnet session. I am having trouble finding any mention on how to use this with a controller.
                            • R ridge
                              @ridge its use should be no different then when using the Ethernet gateway (because it is an Ethernet gateway :-) )
                              I'm using it with OpenHab through MQTT and NodeRed through MQTT.
                              • R
                                R
                                ridge
                                Is your setup using this gateway like:
                                MySensors network <=>Gateway <=> Format conversion program <=> MQTT broker <=> openHAB
                                For some reason, I had assumed that the results of the gateway could be used directly in openHAB.
                                hekH YveauxY 2 Replies Last reply
                                • R ridge
                                  @ridge
                                  Tried this?
                                  http://forum.mysensors.org/topic/1598/openhab-2-0-binding
                                  • R
                                    R
                                    ridge
                                    Thanks hek, OpenHAB 1.7.1 is stable for me. I will probably wait for openHAB 2.0 to get closer to production status before wading in.
                                    I understand serial binding.
                                    I understand MQTT binding.
                                    I am missing something stupid easy in understanding ethernet binding.
                                    Do I include the http binding in the addons folder?
                                    A serial connected device is defined in an openHAB items file like:
                                    Switch HardwareButton "Bell" (Entrance) { serial="/dev/ttyS0" }
                                    I just cannot find an example of what an ethernet connected device would use in place of the "serial" definition.
                                    hekH 1 Reply Last reply
                                    • R ridge
                                      #98
                                      Yes. Production gateway is currently (cabled) ethernet gateway, "Format conversion program" is this perl script and MQTT broker is Mosquitto.
                                      Perl script, Mosquitto and OpenHab run on Ubuntu 12.04LTS server PC.
                                      • R ridge
                                        @ridge
                                        You could always use ser2net to emulate a serial port connected to the ethernet gateway from you openhab box.
                                        • R
                                          R
                                          ridge
                                          Thank you hek and Yveaux. I thought I had missed something obvious. For the present with openHAB 1.7.1, a small piece of the wireless sensor data super highway of the future is still under construction! In that case I will certainly study the MySensors gateway to MQTT broker examples closely.
