  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
  • J
    J
    jeti
    wrote on last edited by jeti
    @AWI thanks again!
    I am using your sketches with only one S0 Meter (the 2000pulse/kwh one).
    *One thing i just found out, that as long as the master arduino is connected to the serial port of my pc it is running fine but when its not, it does not send.I have checked the voltage at the radio and it is the same... I also do not have any display or rotary encoder, as I do the visualisation with FHEM.
    Do you know why this is the case? * -> Voltage was to low... but the secon question remains:
    Any idea to use differen pulses/kwh S0 meters? for example one 2000pulse/kwh and one 800 pulse/kwh.
    thanks in advance!
    AWIA 1 Reply Last reply
      marten
      Arduino: 1.6.5 (Windows 7), Board:"Arduino Nano, ATmega328"
      sketch_oct03e:128: error: 'V_TEXT' was not declared in this scope
      sketch_oct03e.ino: In function 'void setup()':
      sketch_oct03e:162: error: 'S_INFO' was not declared in this scope
      sketch_oct03e.ino: In function 'void loop()':
      sketch_oct03e:337: error: 'V_TEXT' was not declared in this scope
      sketch_oct03e.ino: In function 'void incomingMessage(const MyMessage&)':
      sketch_oct03e:364: error: 'V_TEXT' was not declared in this scope
      Dit rapport zou meer informatie hebben met
      "Tijdens de compilatie uitgebreide uitvoer weergeven"
      ingeschakeld in Bestand > Voorkeuren.
      M AWIA 2 Replies Last reply
      • M marten
        marten
        this is what i'll get when trying to upload the master sketch
        • M marten
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          #22
          @marten You need to use the "Development" branch of MySensors until the production version gets updated -or- you can uncomment the lines with "const int ..."
          // new V_TEXT variable type (development 20150905)
          //const int V_TEXT = 47 ;
          // new S_INFO sensor type (development 20150905)
          //const int S_INFO = 36 ;
          • J
            J
            jeti
            • J jeti
              @AWI thanks again!
              thanks in advance!
              AWIA
              AWIA
              AWI
              @jeti as mentioned in a previous post..
              There are a few ways of getting it changed:
              You can keep/ leave most as it is and when you send/ or display the values divide the pulses by two and double the Watt values in the routines "LCD_local_display" and "sendPowerUpdate"
              or: make the necessary calculations when the data comes in. This is a little more complicated in routine "storeMeterJSON" but if you understand the logic (including error corrrection) should be not too hard.
              I don't have the time at this moment to do it for you...
              J 1 Reply Last reply
              • AWIA AWI
                J
                J
                jeti
                @AWI: :smiley: nevermind I will start workin on it
                Thanks again for the great work!
                • J jeti
                  J
                  J
                  jeti
                  #26
                  was not that much work :smiley:
                  this is the modified master-sketch from AWI i am starting to use. The changes i made:
                  -deletion of LCD and rotray part
                  -deletion of accumulation part
                  -modified meterType to meter800, meter1000 and meter2000 this reflects meters with 800imp/khw;1000imp/kwh;2000imp/kwh
                  I am using this with only one meter (2000imp/kwh) for now and works pretty nicly second different meter type is on the way.
                  As I am a beginner please be gentle with comments :-)
                  #include <MySensor.h>                   // MySensors network
                  #include <Time.h>
                  #include <ArduinoJson.h>                // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
                  // Constants & globals
                  const int NO_METERS = 1 ;               // actual meters used (max 12)
                  const int NODE_ID = 152 ;                // fixed MySensors node ID
                  const int JSON_LENGHT = 80 ;            // Maximum json string length
                  char lastLCD1[21] = "--                  "; // LCD message line
                  typedef enum meterTypes: int8_t {meter800, meter1000, meter2000} ;             // metertype meter800, meter1000, meter2000;
                  const char METER_NAMES[NO_METERS][4] = {"PC"} ; // meter names
                  const meterTypes METER_TYPES[NO_METERS] = {meter2000};
                  const unsigned long idleTime = 10000 ;  // Delay time for any of the states to return to idle
                  unsigned long idleTimer ;               // Delay timer for idleTime
                  union {                                 // used to convert long to bytes for EEPROM storage
                      long kWhLongInt;
                      uint8_t kWhLongByte[4];
                      } kWhLong ;
                  // Possible states for the state machine.
                  // Idle: default state, show totals for in/out nett
                  // Browse: dive into meter details
                  // Update: update meter value (Wh total)
                  // Reset: reset day values
                  enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
                  uint8_t State = IDLE;                   // current state machine state
                  // meter class, store all relevant meter data (equivalent to struct)
                  class pulseMeter
                  public:
                      long UsageWh;                       // last (current) usage (in W) from pulse counter
                      long UsageAccumWh;                  // usage accumulator (to keep in sync) from pulse counter
                      long PowerW;                        // actual power, calculated from pulse "rate"
                      long DayUsageWh;                    // daily usage for display
                      meterTypes Type;                    // metertype for addition in totals: meter800, meter1000, meter2000;
                      char Name[4] ;                      // meter name for display
                  pulseMeter pulseMeters[NO_METERS] ;     // define power meters
                  //pulseMeter meter800, meter1000, meter2000; //  pulse/kWh
                  unsigned long tempUsageWh ;             // temporary store while manually updating (state UPDATE)
                  // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
                  // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
                  char json[JSON_LENGHT] ;        // Storage for serial JSON string (init for example)
                  // flags & counters
                  bool timeReceived = false;              // controller time
                  bool newDay = false;                    // reset at 00:00:00
                  unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
                  int updateMeter = 0;                    // current meter for update
                  bool updateDisplayFlag = true ;         // indicate that display needs to be updated
                  int currentMeter = 0;                   // active meter for update & check, cycles through meters (0..NO_METERS-1)
                  int lastRotary = 0;                     // last rotary encoder position
                  int updateIncrement = 1000 ;            // Interval multiplier for Update
                  int errCount = 0 ;                      // error counter
                  // *** Definition and initialisation
                  // define the MySensor network
                  MySensor gw;                            // pins used RFX24(default 9,10)
                  // Initialize messages for sensor network
                  MyMessage powerMsg(0,V_WATT);           // message to send power in W
                  MyMessage usageMsg(0,V_KWH);            // message to send usage in kWH
                  MyMessage textMsg(0,V_TEXT);            // message to send/receive text
                  // function to reset the Arduino (jump to 0 address)
                  void(* resetFunc) (void) = 0;//declare reset function at address 0
                  void setup(void)
                      gw.begin(incomingMessage, NODE_ID, false);              // this node is fixed, no repeat
                      //Send the sensor node sketch version information to the gateway
                      gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
                      // Initialize the meter names
                      // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                      for (int x = 0; x < NO_METERS; x++){
                          gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
                          delay(10);                                          // give it some time to process
                      delay(100);
                      for (int x = 0; x < NO_METERS; x++){                    // initialize previous kWh values from EEPROM and init
                          for (int y = 0; y < 4 ; y++){                       // convert from bytes
                              kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
                              }                                               // controller is updated later automatically
                          pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
                          strcpy(pulseMeters[x].Name, METER_NAMES[x] );       // copy string for meter names
                          pulseMeters[x].Type = METER_TYPES[x];               // Set type
                  void loop(void)
                      // Before specific states, perform generic tasks
                      unsigned long now = millis();                           // Timer in loop for "once in a while" events
                      gw.process() ;                                          // process incoming messages
                      // If no time has been received yet, request it every 10 second from controller
                      if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                          (now-lastRequest > 3600000UL)){                     // request update every hour to keep in sync
                          Serial.println(F("requesting time"));               // Request time from controller.
                          gw.requestTime(receiveTime);
                          lastRequest = now;
                      // Check if new day has started (hour == 0) and reset day usage counters of meters
                      if (hour()==0 && !newDay){
                          newDay = true;
                              pulseMeters[x].DayUsageWh = 0 ;                 // reset daily counters
                              saveMeters(x);                                  // save meter values to EEPROM
                      } else if(hour() != 0 && newDay)                        // reset newday flag if hour != 0
                          { newDay = false;}
                      // Every 10 seconds update one meter to controller to avoid traffic jams
                      if (now-lastSyncKWH > 10000){
                      //    printPulsemeter(updateMeter);
                          sendPowerUpdate(updateMeter);                               // update the values for currentMeter
                          updateMeter++ ;
                          if (updateMeter >= NO_METERS){                              // increment and wrap current meter
                              updateMeter = 0 ;}
                          lastSyncKWH = now ;
                      // Update sensors every 10 secs
                      if (now-lastUpdate > 10000) {
                          // get values to be displayed from controller
                          lastUpdate = now;
                      // get readings from serial (sent every 10s)
                      // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                      // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                      if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){        //dummySerial(), Serial.read()
                      // if(readLineJSON(dummySerial(), json, 80) > 0 ){              //dummySerial(), Serial.read()
                          Serial.println(json);
                          storeMeterJSON(json);                                       //store the meter reading
                          //calcMeterTotals();                                          // update totals
                      // Ok, set incoming time
                      Serial.print(F("Time value received: "));
                      setTime(controllerTime);                                        // set the clock to the time from controller
                      timeReceived = true ;
                  // This is called when a message is received
                    // Expect few types of messages from controller, V_VAR1 for messages
                      if (message.type==V_TEXT) {
                          // if message comes in, update the kWH reading for meter with value since last update
                          //Serial.print("Last reading for sensor: ");
                          //Serial.print(message.sensor);
                          //Serial.print(", Message: ");
                          //Serial.println(message.getString());
                  // save Meter to EEPROM when needed
                  void saveMeters(int8_t meterNo){
                      kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ;                     // convert to separate bytes via struct
                          gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;            // EEPROM position = meter number * 4 bytes
                  void sendPowerUpdate(int meterNo)
                  // Sends update to controller for current meter
                      gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));            // meterNo * 100 ));
                      gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
                  int storeMeterJSON(char *json)
                  /* convert JSON to values and store in corresponding meter (if used)
                   input: JSON string (can be wrong formatted), with length
                   output: changed meter record number or -1 if error
                   use JsonParser
                    StaticJsonBuffer<50> jsonBuffer;                          // 4 object  -> 4 + 4*10 = 44
                    // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                      JsonObject& root = jsonBuffer.parseObject(json);
                    if (!root.success())
                          Serial.println(F("JsonParser.parse() failed"));
                          errCount++ ;
                          return -1;
                    int m = (long)root["m"];
                    if (m > NO_METERS){                                       // meter value out of range for used meters (m starts at 1)
                      return -1 ;
                    } else {                                                  // update meter values, Power is momentary, Usage is cumulative
                      long newAccumWh = (long)root["cA"] ;
                      long newWh = (long)root["c"] ;
                      long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh;  // check for missed pulses by comparing cA with last stored value
                      if (diffAccumWh >= newWh){                              // no difference or missed pulses -> correct: add difference
                          pulseMeters[m-1].UsageWh += diffAccumWh;
                          pulseMeters[m-1].DayUsageWh += diffAccumWh;
                      else {                                                  // negative diff, out of sync -> add pulses only (can be out of range or restart)
                          pulseMeters[m-1].UsageWh += newWh;
                          pulseMeters[m-1].DayUsageWh += newWh;
                      pulseMeters[m-1].UsageAccumWh = newAccumWh;             // always update sync counter (only for sync and error correction(serial))
                      if ((long)root["r"] == 0){                              // calculate power from pulse rate (ms) and truncate to whole Watts
                        pulseMeters[m-1].PowerW = 0;                          // if overflow assume no Usage
                      } else if (pulseMeters[m-1].Type == meter800){
                        pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]*0.8); // rate in microseconds for 800 pulse/kWh
                        else if (pulseMeters[m-1].Type == meter1000){
                        pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds for 1000 pulse/kWh
                         else if (pulseMeters[m-1].Type == meter2000){
                         pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]/2); // rate in microseconds for 2000 pulse/kWh
                        else {
                          Serial.println("geht nicht");
                      return m ;
                  int readLineJSON(int readch, char *buffer, int len)
                  /* checks for JSON and when started append char tot buffer and checks for line completion
                  usage:
                    static char buffer[80];
                    if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
                    returns simple JSON
                    static int pos = 0;
                    int rpos;
                    if (readch > 0) {
                      switch (readch) {
                        case '\n':                // Ignore new-lines
                        case '\r':                // Return on CR
                          rpos = pos;
                          pos = 0;                  // Reset position index ready for next time
                          return rpos;
                        default:
                          if (pos < len-1) {
                            buffer[pos++] = readch;
                            buffer[pos] = 0;
                    // No end of line has been found, so return -1.
                    return -1;
                  int dummySerial()
                  // Acts as a dummy JSON serial character generator for debugging
                  // input: none
                  // output: preset JSON string
                    static int pos = 0;
                    char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
                    if (pos++ >= strlen(json)){
                      pos = 0;
                    return json[pos] ;
                  void printPulsemeter(int meter)
                  // prints the Pulsemeter record to serial out
                    Serial.print("m:");
                    Serial.print(meter);
                    Serial.print("type:");
                    Serial.print(pulseMeters[meter].Type);
                    Serial.print(", power: ");
                    Serial.print(pulseMeters[meter].PowerW);
                    Serial.print(", usage: ");
                    Serial.print(pulseMeters[meter].UsageWh);
                    Serial.print(", day usage: ");
                    Serial.println(pulseMeters[meter].DayUsageWh );
                  //  Serial.print(", Ca: ");
                  //  Serial.println(pulseMeters[meter].UsageAccumWh);
                    MarkV
                    Good evening,
                    After a couple of weeks, again i'm busy with my arduino's, but now i have a rasberry with domoticz near my arduino, so i don't need to send it wireless.
                    Is there a possibility to connect the master or slave arduino directly to my rasberry and read out the pulse meters???
                    • mfalkviddM
                      With MySensors version 1.6 (currently in development) you can connect the Arduino to the Raspberry Pi's USB port using a FTDI or CH340G. That type of connection is called a serial gateway. Before 1.6, the gateways do not support local sensors.
                        MarkV
                        wrote on last edited by MarkV
                        #29
                        So with 1.6 i can install the master software and connect my arduino master directly through usb without the rf24''s? ?
                        • mfalkviddM
                          I am not entirely sure what a master is, but yes, I think you can.
                            MarkV
                            #31
                            I meen the master sketch like written above.
                            I'd want to build a gateway but without the wireless RF part, just connect the master arduino directly through usb to the RasberryPi and readout the measurements.
                            So in general:
                            Kwh Meters -- cable --> Slave arduino <-- serial --> Master arduino <-- USB --> RasberryPi
                            • M MarkV
                              So in general:
                              AWIA
                              AWIA
                              AWI
                              @MarkV If you don't want it to be MySensors enabled and not used the display etc. it's easier to readout the slave with the raspberry. The protocol is a simple Json and if you use a nano for the slave you can connect it with usb..
                                MarkV
                                #33
                                Last weeks i'm trying to get it to work but without luck. Could you give a manual on how to get it working with json? What should we do? And how? On my rasberry, on the arduino and in domoticz??
                                • AWIA AWI
                                  @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
                                  MarkV
                                  #34
                                  @AWI
                                  Goodmorning,
                                  I've got a question, are you planning to re-write the script for the main and slave Arduino to the new MySensors 2.0 structuur?
                                  I've also tryed to look on github if there's a page from you, but didn't find it...
                                  • M MarkV
                                    @AWI
                                    Goodmorning,
                                    AWIA
                                    AWIA
                                    AWI
                                    #35
                                    @MarkV I updated the sketch for main a few months ago to development (pre-2.0). Also changed it a little for stability and removed the (complicated) JSON library The slave has no MySensors dependency.
                                      MarkV
                                      Super.
                                      I've updated everything and it's up and running.
                                      But my Master arduino (UNO clone) gives this readout on the USB port:
                                      0;255;3;0;11;AWI-12ChannelPulse
                                      0;255;3;0;12;2.0
                                      0;0;0;0;13;Groep 1
                                      0;1;0;0;13;Groep 2
                                      0;2;0;0;13;Groep 3
                                      0;3;0;0;13;Groep 4
                                      0;4;0;0;13;Groep 5
                                      0;5;0;0;13;Groep 6
                                      0;20;0;0;36;Usage meter LCD
                                      0;20;1;0;47;-
                                      0;255;3;0;1;
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;1;1;0;17;0
                                      0;1;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;2;1;0;17;0
                                      0;2;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;3;1;0;17;0
                                      0;3;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;4;1;0;17;0
                                      0;4;1;0;18;-0.001
                                      0;20;2;0;47;
                                      0;255;3;0;1;
                                      0;5;1;0;17;0
                                      0;5;1;0;18;-0.001
                                      0;255;3;0;1;
                                      0;0;1;0;17;0
                                      0;0;1;0;18;-0.001
                                      Is this correct?
                                      Because Domoticz doesn't change the values.
                                      Also this is not the format, wich is past through in the JSON code from the slave to master duino??
                                      • AWIA AWI
                                        MarkV
                                        @AWI
                                        How is it that i get the readings like above? And after a while the sensor also stops with sending data, last connection stays on that time and date.
                                        I've uploaded your github sketch and done a serial readout of the measuring arduino and that one functions proberbly. No faulty low voltage errors etc.
                                        • M MarkV
                                          @AWI
                                          AWIA
                                          AWIA
                                          AWI
                                          @MarkV Ok, one step at a time.. the output looks like the output of your (serial) gateway. Have you tried to switch on the "Master node" debug Serial.print() statements?
