  3. Power/ Usage sensor - multi channel - local display
41 Posts 6 Posters 24.8k Views 7 Watching
  • M MarkV
    Tonight i checked the wires and changed them and i believe your wright, the output is:
    But it keeps giving a error, so i hangt them near each other with approx. 10cm space in between, why does it stil say fail after a good startup with ok and after 10a20sec it starts saying fail..
    Is the readout correct?
    And what more could cause the fail error?
    AWIA
    AWIA
    AWI
    @MarkV In most of the cases "fail" is related to the power supply of the radio. Did you follow the instructions for connection of the radio?
    • AWIA AWI
      the code for the measurement device::
      // Arduino Pulse Counting Sketch for counting pulses from up to 12 pulse output meters.
      // uses direct port manipulation to read from each register of 6 digital inputs simultaneously
      // Licence: GNU GPL
      // part of the openenergymonitor.org project
      // Author: Trystan Lea
      // AWI: adapted to produce JSON and error checking at client side.
      // Pulse Counting Class - could be placed in seperate library...
      class PulseOutput
      public:                                 		 //AWI: access to all
        boolean pulse(int,int,unsigned long);                  //Detects pulses, in pulseLib.ino
        unsigned long rate( unsigned long );                   //Calculates rate
        unsigned long count;                                   //pulse count accumulator
        unsigned long countAccum;                              //pulse count total accumulator for extended error checking (only resets at startup)
        unsigned long prate;                                   //pulse width in time
        unsigned long prateAccum;                              //pulse rate accumulator for calculating mean.
      private:
        boolean ld,d;                                          //used to determine pulse edge
        unsigned long lastTime,time;                           //used to calculate rate
      // Variable declaration
      //CHANGE THIS TO VARY RATE AT WHICH PULSE COUNTING ARDUINO SPITS OUT PULSE COUNT+RATE DATA
      //time in seconds;
      const unsigned long printTime = 1000000;	// delay between serial outputs in us (one meter at a time)
      const int lastMeter = 7 ; 	 	// is number of meters + 1
      byte curMeter = 2 ;				// current meter for serial output, wraps from 2 to lastMeter
      PulseOutput p[14];            //Pulse output objects
      int a,b,la,lb;                //Input register variables
      unsigned long ltime, time;    //time variables
       // take care: pull-up inverses state! line 155
      	//setup input pins here with pull_up, else (default) float
      	pinMode( 2, INPUT_PULLUP);
      	pinMode( 3, INPUT_PULLUP);
      	pinMode( 4, INPUT_PULLUP);
      	pinMode( 5, INPUT_PULLUP);
      	pinMode( 6, INPUT_PULLUP);
      	pinMode( 7, INPUT_PULLUP);
      	pinMode( 8, INPUT_PULLUP);
      	pinMode( 9, INPUT_PULLUP);
      	pinMode(10, INPUT_PULLUP);
      	pinMode(11, INPUT_PULLUP);
      	pinMode(12, INPUT_PULLUP);
      	pinMode(13, INPUT_PULLUP);
        Serial.begin(115200);       //standard serial
        DDRD = DDRD | B00000000;
        DDRB = DDRD | B00000000;
        la = a;                    //last register a used to detect input change
        lb = b;                    //last register b used to detect input change
        // Read from input registers
        a = PIND >> 2;             //read digital inputs 2 to 7 really fast
        b = PINB;                  //read digital inputs 8 to 13 really fast
        time = micros();
        if (la!=a || lb!=b)
          // Detect pulses from register A
          p[2].pulse(0,a,time);                //digital input 2
          p[3].pulse(1,a,time);                //    ''        3
          p[4].pulse(2,a,time);                //    ''        etc
          p[5].pulse(3,a,time);
          p[6].pulse(4,a,time);
          p[7].pulse(5,a,time);
          // Detect pulses from register B
          p[8].pulse(0,b,time);                //digital input 8
          p[9].pulse(1,b,time);                //etc
          p[10].pulse(2,b,time);
          p[11].pulse(3,b,time);
          p[12].pulse(4,b,time);
          p[13].pulse(5,b,time);
        // Spit out data every printTime sec (time here is in microseconds)
        // build JSON: for all counters print Count (W), Count Accum(W), Average ms
        // Format {"m":meter,"c":count,"r":rate, "cA":countAccum}
        if ((time-ltime)>(printTime))
          ltime = time;                          	//Print timer
            Serial.print("{\"m\":");
            Serial.print(curMeter-1);           	//Print meter number
            Serial.print(",\"c\":");
            Serial.print(p[curMeter].count);    	//Print pulse count
            Serial.print(",\"r\":");
            Serial.print(p[curMeter].rate(time));	//Print pulse rate
      	  p[curMeter].countAccum += p[curMeter].count;	//Increment and print count accumulator to allow for error checking at client side;
      	  Serial.print(",\"cA\":");
            Serial.print(p[curMeter].countAccum);
            Serial.println("}");
            p[curMeter].count = 0;                //Reset count (we just send count increment)
            p[curMeter].prateAccum = 0;       	//Reset accum so that we can calculate a new average
      	curMeter++ ;
      	if (curMeter > lastMeter){				// wrap a around if passed last meter
      		curMeter = 2;}
      // library for pulse, originally in separate file
      //Gets a particular input state from the register binary value
      // A typical register binary may look like this:
      // B00100100
      // in this case if the right most bit is digital pin 0
      // digital 2 and 5 are high
      // The method below extracts this from the binary value
      #define BIT_TST(REG, bit, val)( ( (REG & (1UL << (bit) ) ) == ( (val) << (bit) ) ) )
      // Method detects a pulse, counts it, finds its rate, Class: PulseOutput
      boolean PulseOutput::pulse(int pin, int a, unsigned long timeIn)
         ld = d;                                    //last digital state = digital state
         if (BIT_TST(a,pin,1)) d = 1; else d = 0;   //Get current digital state from pin number
         // if (ld==0 && d==1)                      // no internal pull_up if state changed from 0 to 1: internal pull-up inverts state
      	if (ld==1 && d==0)                         //pull_up f state changed from 0 to 1: internal pull-up inverts state
           count++;                                 //count the pulse
           // Rate calculation
           lastTime = time;
           time = timeIn ;						// correction to allow for processing
           prate = (time-lastTime);// - 400;          //rate based on last 2 pulses
                                                      //-190 is an offset that may not be needed...??
           prateAccum += prate - 2000;                     //accumulate rate for average calculation
           return 1;
         return 0;
      // Method calculates the average rate based on multiple pulses (if there are 2 or more pulses)
      unsigned long PulseOutput::rate(unsigned long timeIn)
       if (count > 1)
         prate = prateAccum / count;                          //Calculate average
       } else
       if ((timeIn - lastTime)>(prate*2)) prate = 0;}         //Decrease rate if no pulses are received
                                                              //in the expected time based on the last
                                                              //pulse width.
       return prate;
      FotoFieberF
      FotoFieberF
      FotoFieber
      @AWI
      Your measurement sketch is really nice. There is one line I do not understand.
      Is this prateAccum needed or couldn't it be left away? What is the meaning of 2000 in this context?
      Cu,
      FotoFieber
      AWIA 1 Reply Last reply
      • FotoFieberF FotoFieber
        @AWI
        Cu,
        FotoFieber
        AWIA
        AWIA
        AWI
        @FotoFieber To be honest .. a left over from some experiments. Just leave it out... you won't notice the difference.
        • J
          J
          jeti
          wrote on last edited by jeti
          @AWI thanks again!
          I am using your sketches with only one S0 Meter (the 2000pulse/kwh one).
          *One thing i just found out, that as long as the master arduino is connected to the serial port of my pc it is running fine but when its not, it does not send.I have checked the voltage at the radio and it is the same... I also do not have any display or rotary encoder, as I do the visualisation with FHEM.
          Do you know why this is the case? * -> Voltage was to low... but the secon question remains:
          Any idea to use differen pulses/kwh S0 meters? for example one 2000pulse/kwh and one 800 pulse/kwh.
          thanks in advance!
            marten
            Arduino: 1.6.5 (Windows 7), Board:"Arduino Nano, ATmega328"
            sketch_oct03e:128: error: 'V_TEXT' was not declared in this scope
            sketch_oct03e.ino: In function 'void setup()':
            sketch_oct03e:162: error: 'S_INFO' was not declared in this scope
            sketch_oct03e.ino: In function 'void loop()':
            sketch_oct03e:337: error: 'V_TEXT' was not declared in this scope
            sketch_oct03e.ino: In function 'void incomingMessage(const MyMessage&)':
            sketch_oct03e:364: error: 'V_TEXT' was not declared in this scope
            Dit rapport zou meer informatie hebben met
            "Tijdens de compilatie uitgebreide uitvoer weergeven"
            ingeschakeld in Bestand > Voorkeuren.
            M AWIA 2 Replies Last reply
            • M marten
              marten
              this is what i'll get when trying to upload the master sketch
              • M marten
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #22
                @marten You need to use the "Development" branch of MySensors until the production version gets updated -or- you can uncomment the lines with "const int ..."
                // new V_TEXT variable type (development 20150905)
                //const int V_TEXT = 47 ;
                // new S_INFO sensor type (development 20150905)
                //const int S_INFO = 36 ;
                • J
                  J
                  jeti
                  • J jeti
                    @AWI thanks again!
                    thanks in advance!
                    AWIA
                    AWIA
                    AWI
                    @jeti as mentioned in a previous post..
                    There are a few ways of getting it changed:
                    You can keep/ leave most as it is and when you send/ or display the values divide the pulses by two and double the Watt values in the routines "LCD_local_display" and "sendPowerUpdate"
                    or: make the necessary calculations when the data comes in. This is a little more complicated in routine "storeMeterJSON" but if you understand the logic (including error corrrection) should be not too hard.
                    I don't have the time at this moment to do it for you...
                    J 1 Reply Last reply
                    • AWIA AWI
                      J
                      J
                      jeti
                      @AWI: :smiley: nevermind I will start workin on it
                      Thanks again for the great work!
                      • J jeti
                        J
                        J
                        jeti
                        #26
                        was not that much work :smiley:
                        this is the modified master-sketch from AWI i am starting to use. The changes i made:
                        -deletion of LCD and rotray part
                        -deletion of accumulation part
                        -modified meterType to meter800, meter1000 and meter2000 this reflects meters with 800imp/khw;1000imp/kwh;2000imp/kwh
                        I am using this with only one meter (2000imp/kwh) for now and works pretty nicly second different meter type is on the way.
                        As I am a beginner please be gentle with comments :-)
                        #include <MySensor.h>                   // MySensors network
                        #include <Time.h>
                        #include <ArduinoJson.h>                // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
                        // Constants & globals
                        const int NO_METERS = 1 ;               // actual meters used (max 12)
                        const int NODE_ID = 152 ;                // fixed MySensors node ID
                        const int JSON_LENGHT = 80 ;            // Maximum json string length
                        char lastLCD1[21] = "--                  "; // LCD message line
                        typedef enum meterTypes: int8_t {meter800, meter1000, meter2000} ;             // metertype meter800, meter1000, meter2000;
                        const char METER_NAMES[NO_METERS][4] = {"PC"} ; // meter names
                        const meterTypes METER_TYPES[NO_METERS] = {meter2000};
                        const unsigned long idleTime = 10000 ;  // Delay time for any of the states to return to idle
                        unsigned long idleTimer ;               // Delay timer for idleTime
                        union {                                 // used to convert long to bytes for EEPROM storage
                            long kWhLongInt;
                            uint8_t kWhLongByte[4];
                            } kWhLong ;
                        // Possible states for the state machine.
                        // Idle: default state, show totals for in/out nett
                        // Browse: dive into meter details
                        // Update: update meter value (Wh total)
                        // Reset: reset day values
                        enum States: int8_t {IDLE, BROWSE, UPDATE, RST} ;
                        uint8_t State = IDLE;                   // current state machine state
                        // meter class, store all relevant meter data (equivalent to struct)
                        class pulseMeter
                        public:
                            long UsageWh;                       // last (current) usage (in W) from pulse counter
                            long UsageAccumWh;                  // usage accumulator (to keep in sync) from pulse counter
                            long PowerW;                        // actual power, calculated from pulse "rate"
                            long DayUsageWh;                    // daily usage for display
                            meterTypes Type;                    // metertype for addition in totals: meter800, meter1000, meter2000;
                            char Name[4] ;                      // meter name for display
                        pulseMeter pulseMeters[NO_METERS] ;     // define power meters
                        //pulseMeter meter800, meter1000, meter2000; //  pulse/kWh
                        unsigned long tempUsageWh ;             // temporary store while manually updating (state UPDATE)
                        // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
                        // example: "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}"
                        char json[JSON_LENGHT] ;        // Storage for serial JSON string (init for example)
                        // flags & counters
                        bool timeReceived = false;              // controller time
                        bool newDay = false;                    // reset at 00:00:00
                        unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
                        int updateMeter = 0;                    // current meter for update
                        bool updateDisplayFlag = true ;         // indicate that display needs to be updated
                        int currentMeter = 0;                   // active meter for update & check, cycles through meters (0..NO_METERS-1)
                        int lastRotary = 0;                     // last rotary encoder position
                        int updateIncrement = 1000 ;            // Interval multiplier for Update
                        int errCount = 0 ;                      // error counter
                        // *** Definition and initialisation
                        // define the MySensor network
                        MySensor gw;                            // pins used RFX24(default 9,10)
                        // Initialize messages for sensor network
                        MyMessage powerMsg(0,V_WATT);           // message to send power in W
                        MyMessage usageMsg(0,V_KWH);            // message to send usage in kWH
                        MyMessage textMsg(0,V_TEXT);            // message to send/receive text
                        // function to reset the Arduino (jump to 0 address)
                        void(* resetFunc) (void) = 0;//declare reset function at address 0
                        void setup(void)
                            gw.begin(incomingMessage, NODE_ID, false);              // this node is fixed, no repeat
                            //Send the sensor node sketch version information to the gateway
                            gw.sendSketchInfo("AWI-12ChannelPulse", "2.0");
                            // Initialize the meter names
                            // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                            for (int x = 0; x < NO_METERS; x++){
                                gw.present(x, S_POWER, METER_NAMES[x]);             // present power meters to gateway
                                delay(10);                                          // give it some time to process
                            delay(100);
                            for (int x = 0; x < NO_METERS; x++){                    // initialize previous kWh values from EEPROM and init
                                for (int y = 0; y < 4 ; y++){                       // convert from bytes
                                    kWhLong.kWhLongByte[y]= gw.loadState(x *4 + y) ;// EEPROM position = meter number * 4 bytes
                                    }                                               // controller is updated later automatically
                                pulseMeters[x].UsageWh = kWhLong.kWhLongInt;
                                strcpy(pulseMeters[x].Name, METER_NAMES[x] );       // copy string for meter names
                                pulseMeters[x].Type = METER_TYPES[x];               // Set type
                        void loop(void)
                            // Before specific states, perform generic tasks
                            unsigned long now = millis();                           // Timer in loop for "once in a while" events
                            gw.process() ;                                          // process incoming messages
                            // If no time has been received yet, request it every 10 second from controller
                            if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                                (now-lastRequest > 3600000UL)){                     // request update every hour to keep in sync
                                Serial.println(F("requesting time"));               // Request time from controller.
                                gw.requestTime(receiveTime);
                                lastRequest = now;
                            // Check if new day has started (hour == 0) and reset day usage counters of meters
                            if (hour()==0 && !newDay){
                                newDay = true;
                                    pulseMeters[x].DayUsageWh = 0 ;                 // reset daily counters
                                    saveMeters(x);                                  // save meter values to EEPROM
                            } else if(hour() != 0 && newDay)                        // reset newday flag if hour != 0
                                { newDay = false;}
                            // Every 10 seconds update one meter to controller to avoid traffic jams
                            if (now-lastSyncKWH > 10000){
                            //    printPulsemeter(updateMeter);
                                sendPowerUpdate(updateMeter);                               // update the values for currentMeter
                                updateMeter++ ;
                                if (updateMeter >= NO_METERS){                              // increment and wrap current meter
                                    updateMeter = 0 ;}
                                lastSyncKWH = now ;
                            // Update sensors every 10 secs
                            if (now-lastUpdate > 10000) {
                                // get values to be displayed from controller
                                lastUpdate = now;
                            // get readings from serial (sent every 10s)
                            // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                            // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                            if(readLineJSON(Serial.read(), json, JSON_LENGHT) > 0 ){        //dummySerial(), Serial.read()
                            // if(readLineJSON(dummySerial(), json, 80) > 0 ){              //dummySerial(), Serial.read()
                                Serial.println(json);
                                storeMeterJSON(json);                                       //store the meter reading
                                //calcMeterTotals();                                          // update totals
                            // Ok, set incoming time
                            Serial.print(F("Time value received: "));
                            setTime(controllerTime);                                        // set the clock to the time from controller
                            timeReceived = true ;
                        // This is called when a message is received
                          // Expect few types of messages from controller, V_VAR1 for messages
                            if (message.type==V_TEXT) {
                                // if message comes in, update the kWH reading for meter with value since last update
                                //Serial.print("Last reading for sensor: ");
                                //Serial.print(message.sensor);
                                //Serial.print(", Message: ");
                                //Serial.println(message.getString());
                        // save Meter to EEPROM when needed
                        void saveMeters(int8_t meterNo){
                            kWhLong.kWhLongInt = pulseMeters[meterNo].UsageWh ;                     // convert to separate bytes via struct
                                gw.saveState(meterNo * 4 + y, kWhLong.kWhLongByte[y])  ;            // EEPROM position = meter number * 4 bytes
                        void sendPowerUpdate(int meterNo)
                        // Sends update to controller for current meter
                            gw.send(powerMsg.setSensor(meterNo).set((long)pulseMeters[meterNo].PowerW));            // meterNo * 100 ));
                            gw.send(usageMsg.setSensor(meterNo).set((float)pulseMeters[meterNo].UsageWh/1000L ,3)); // send in kWh!
                        int storeMeterJSON(char *json)
                        /* convert JSON to values and store in corresponding meter (if used)
                         input: JSON string (can be wrong formatted), with length
                         output: changed meter record number or -1 if error
                         use JsonParser
                          StaticJsonBuffer<50> jsonBuffer;                          // 4 object  -> 4 + 4*10 = 44
                          // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                            JsonObject& root = jsonBuffer.parseObject(json);
                          if (!root.success())
                                Serial.println(F("JsonParser.parse() failed"));
                                errCount++ ;
                                return -1;
                          int m = (long)root["m"];
                          if (m > NO_METERS){                                       // meter value out of range for used meters (m starts at 1)
                            return -1 ;
                          } else {                                                  // update meter values, Power is momentary, Usage is cumulative
                            long newAccumWh = (long)root["cA"] ;
                            long newWh = (long)root["c"] ;
                            long diffAccumWh = newAccumWh - pulseMeters[m-1].UsageAccumWh;  // check for missed pulses by comparing cA with last stored value
                            if (diffAccumWh >= newWh){                              // no difference or missed pulses -> correct: add difference
                                pulseMeters[m-1].UsageWh += diffAccumWh;
                                pulseMeters[m-1].DayUsageWh += diffAccumWh;
                            else {                                                  // negative diff, out of sync -> add pulses only (can be out of range or restart)
                                pulseMeters[m-1].UsageWh += newWh;
                                pulseMeters[m-1].DayUsageWh += newWh;
                            pulseMeters[m-1].UsageAccumWh = newAccumWh;             // always update sync counter (only for sync and error correction(serial))
                            if ((long)root["r"] == 0){                              // calculate power from pulse rate (ms) and truncate to whole Watts
                              pulseMeters[m-1].PowerW = 0;                          // if overflow assume no Usage
                            } else if (pulseMeters[m-1].Type == meter800){
                              pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]*0.8); // rate in microseconds for 800 pulse/kWh
                              else if (pulseMeters[m-1].Type == meter1000){
                              pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]); // rate in microseconds for 1000 pulse/kWh
                               else if (pulseMeters[m-1].Type == meter2000){
                               pulseMeters[m-1].PowerW = long( 3600000000L / (long)root["r"]/2); // rate in microseconds for 2000 pulse/kWh
                              else {
                                Serial.println("geht nicht");
                            return m ;
                        int readLineJSON(int readch, char *buffer, int len)
                        /* checks for JSON and when started append char tot buffer and checks for line completion
                        usage:
                          static char buffer[80];
                          if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
                          returns simple JSON
                          static int pos = 0;
                          int rpos;
                          if (readch > 0) {
                            switch (readch) {
                              case '\n':                // Ignore new-lines
                              case '\r':                // Return on CR
                                rpos = pos;
                                pos = 0;                  // Reset position index ready for next time
                                return rpos;
                              default:
                                if (pos < len-1) {
                                  buffer[pos++] = readch;
                                  buffer[pos] = 0;
                          // No end of line has been found, so return -1.
                          return -1;
                        int dummySerial()
                        // Acts as a dummy JSON serial character generator for debugging
                        // input: none
                        // output: preset JSON string
                          static int pos = 0;
                          char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
                          if (pos++ >= strlen(json)){
                            pos = 0;
                          return json[pos] ;
                        void printPulsemeter(int meter)
                        // prints the Pulsemeter record to serial out
                          Serial.print("m:");
                          Serial.print(meter);
                          Serial.print("type:");
                          Serial.print(pulseMeters[meter].Type);
                          Serial.print(", power: ");
                          Serial.print(pulseMeters[meter].PowerW);
                          Serial.print(", usage: ");
                          Serial.print(pulseMeters[meter].UsageWh);
                          Serial.print(", day usage: ");
                          Serial.println(pulseMeters[meter].DayUsageWh );
                        //  Serial.print(", Ca: ");
                        //  Serial.println(pulseMeters[meter].UsageAccumWh);
                          MarkV
                          Good evening,
                          After a couple of weeks, again i'm busy with my arduino's, but now i have a rasberry with domoticz near my arduino, so i don't need to send it wireless.
                          Is there a possibility to connect the master or slave arduino directly to my rasberry and read out the pulse meters???
                          • mfalkviddM
                            With MySensors version 1.6 (currently in development) you can connect the Arduino to the Raspberry Pi's USB port using a FTDI or CH340G. That type of connection is called a serial gateway. Before 1.6, the gateways do not support local sensors.
                              MarkV
                              wrote on last edited by MarkV
                              #29
                              So with 1.6 i can install the master software and connect my arduino master directly through usb without the rf24''s? ?
                              • mfalkviddM
                                I am not entirely sure what a master is, but yes, I think you can.
                                  MarkV
                                  #31
                                  I meen the master sketch like written above.
                                  I'd want to build a gateway but without the wireless RF part, just connect the master arduino directly through usb to the RasberryPi and readout the measurements.
                                  So in general:
                                  Kwh Meters -- cable --> Slave arduino <-- serial --> Master arduino <-- USB --> RasberryPi
                                  • M MarkV
                                    So in general:
                                    AWIA
                                    AWIA
                                    AWI
                                    @MarkV If you don't want it to be MySensors enabled and not used the display etc. it's easier to readout the slave with the raspberry. The protocol is a simple Json and if you use a nano for the slave you can connect it with usb..
                                      MarkV
                                      #33
                                      Last weeks i'm trying to get it to work but without luck. Could you give a manual on how to get it working with json? What should we do? And how? On my rasberry, on the arduino and in domoticz??
                                      • AWIA AWI
                                        MarkV
                                        #34
                                        @AWI
                                        Goodmorning,
                                        I've got a question, are you planning to re-write the script for the main and slave Arduino to the new MySensors 2.0 structuur?
                                        I've also tryed to look on github if there's a page from you, but didn't find it...
                                        • M MarkV
                                          @AWI
                                          Goodmorning,
                                          AWIA
                                          AWIA
                                          AWI
                                          #35
                                          @MarkV I updated the sketch for main a few months ago to development (pre-2.0). Also changed it a little for stability and removed the (complicated) JSON library The slave has no MySensors dependency.
