  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
  • snowS snow
    I have one battery powered node build on Arduino Mini Pro 3.3V with combined 2 sensors DHT11 and BH1750. The node is working OK and give me correct values from sensors on Arduino serial console.
    The output from this node connected to Serial gateway is also OK.
    And this is the output from the same node connected to ESP8266 gateway. As You can see, only the first output of LIGHT_LEVEL is correct.
    Could anyone check this?
    @snow Could be a 8 (ATMega32) vs. 32 bit (ESP8266) issue.
    1032       = 0x0000 0408
    1107297279 = 0x4200 03FF
    The lower 16 bits are more or less equal.
    Could you post the serial output of the ESP8266 gateway for such a set of LIGHT_LEVELs and a screenshot of MYSController as you did before ?
    snowS 1 Reply Last reply
    • DwaltD
      DwaltD
      Dwalt
      Why does MsgID#32 provide Heater_sw as the subtype? Something strange going on with the data flowing through the esp...
      • DwaltD Dwalt
        MsgID#32 is from the serial gateway, as I understand it...
        • YveauxY Yveaux
          1032       = 0x0000 0408
          snowS
          snowS
          snow
          @Yveaux I have made another test on two gateways at the same time. Here is the results.
          Serial gateway (Arduino NANO)
          ESP8266 gateway (ESP-07)
          Console output from ESP gateway
          ESP8266 MySensors Gateway
          Connecting to 00000000
          ...................Connected!
          IP: 192.168.0.30
          Client 0 connected
          0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
          1;255;0;0;17;1.5
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
          1;255;3;0;6;0
          Client 0: 1;255;3;0;6;M
          0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:Lux/Temp/Humidity
          1;255;3;0;11;Lux/Temp/Humidity +Bat
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          1;255;3;0;12;1.0
          0;0;3;0;9;read: 1-1-0 s=0,c=0,t=16,pt=0,l=0,sg=0:
          1;0;0;0;16;
          0;0;3;0;9;read: 1-1-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
          1;1;0;0;7;
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:101
          1;255;3;0;0;101
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:46
          1;0;1;0;23;46
          0;0;3;0;9;read: 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:23.0
          1;2;1;0;0;23.0
          0;0;3;0;9;read: 1-1-0 s=1,c=1,t=1,pt=7,l=5,sg=0:33.0
          1;1;1;0;1;33.0
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:93
          1;255;3;0;0;93
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296452
          1;0;1;0;23;1107296452
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296619
          1;0;1;0;23;1107296619
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296632
          1;0;1;0;23;1107296632
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296315
          1;0;1;0;23;1107296315
          0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:92
          1;255;3;0;0;92
          1;255;3;0;0;93
          1;255;3;0;0;92
          1;255;3;0;0;93
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296724
          1;0;1;0;23;1107296724
          0;0;3;0;9;read: 1-1-0 s=255,c=2,t=0,pt=1,l=1,sg=0:92
          1;255;2;0;0;92
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296536
          1;0;1;0;23;1107296536
          1;255;3;0;0;93
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=22,pt=3,l=2,sg=0:1107296631
          1;0;1;0;22;1107296631
          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296622
          1;0;1;0;23;1107296622
          I suspect a problem with the length or definition of variables, but I'm not a good programmer. ;)
          1107296631 - 383 = 0x4200000
          1107296622 - 366 = 0x4200000
          • DwaltD
            DwaltD
            Dwalt
            Msg54 again shows subtype 22, which is for V_HVAC_SPEED. It occurred on both the serial gateway example (top of thread) and the ESP. It seems to mess up the message at the node level. Perhaps not a problem with the gateway.
            • snowS snow
              IP: 192.168.0.30
              Client 0 connected
              1;255;0;0;17;1.5
              1;255;3;0;6;0
              1;255;3;0;12;1.0
              1;0;0;0;16;
              1;1;0;0;7;
              1;255;3;0;0;101
              1;0;1;0;23;46
              1;2;1;0;0;23.0
              1;1;1;0;1;33.0
              1;255;3;0;0;93
              1;255;3;0;0;92
              1;255;3;0;0;93
              1;255;3;0;0;92
              1;255;3;0;0;93
              1;255;2;0;0;92
              1;255;3;0;0;93
              Agree. Possibly a variable somewhere that has a different size on ESP.
              Hopefully tonight I can have a better look.
              • YveauxY Yveaux
                Pretty sure I found the cause: the messages exchanged between sensor and gateway contain int types.
                These have a size of 2 bytes on Arduino and 4 bytes on ESP.
                An int sent from the Arduino is sent as 2 bytes, but the ESP expects 4. The upper 2 will be filled with garbage.
                Still a hypothesis which has to be verified & fixed.
                To be continued!
                • snowS snow
                  @snow Please try the code in the development branch , where hek did an excellent job to standardize on datatypes being exchanged between nodes.
                  This will probably solve your issue.
                  • snowS
                    snowS
                    snow
                    The development version is working OK :satisfied:
                    Thanks guys for your hard work.
                    • snowS snow
                      @snow great to hear!
                      Glad I could help (and my hunch was correct :-) )
                      • HoffanH
                        HoffanH
                        Hoffan
                        @snow
                        Did you use the Development version of the ESP8266 Wifi gatewavy or for the sensor
                          @Hoffan
                          You should probably use it on both sides to be sure to get the same size on the data types.
                          • HoffanH
                            HoffanH
                            Hoffan
                            wrote on last edited by Hoffan
                            All the sensors that i have include before i upgrade the ESP8266 Wifi GW is now working
                            But its not working to include more, Nothing happens in Veran when i press start
                            but the gateway say this
                            0;0;3;0;9Client 0: 0;0;3;0;5;1t version
                            every time i press start
                            hekH 1 Reply Last reply
                            • HoffanH Hoffan
                              @snow
                              snowS
                              snowS
                              snow
                              wrote on last edited by snow
                              At the moment I only changed the gateway. It's already solved my problem with incorrect values.
                              HoffanH 1 Reply Last reply
                              • snowS snow
                                HoffanH
                                HoffanH
                                Hoffan
                                @snow
                                But is your include button working now?
                                Or maybe you don't use Vera as a controller
                                • HoffanH Hoffan
                                  @Hoffan
                                  The print looks a bit weird. I'll have to do some tests.
                                  • HoffanH Hoffan
                                    @snow
                                    snowS
                                    snowS
                                    snow
                                    @Hoffan No. I'm using DomoticZ
                                      @Hoffan
                                      HoffanH
                                      HoffanH
                                      Hoffan
                                      @hek
                                      That sounds good, Just ask if you want me to test something..
                                      • HoffanH
                                        HoffanH
                                        Hoffan
                                        @hek
                                        Any News here ?
                                        • snowS
                                          snowS
                                          snow
                                          Having another problem with a ESP8266 running as the gateway. Sensor build on Arduino Mini Pro loaded with example sketch DimmableLightWithRotaryEncoderButton.ino. Sensor and gateway firmware compiled from latest development branch v1.6 library.
                                          The controller is a domoticz.
                                          This is a output on the gateway console when I turn rotary encoder on the sensor.
                                          0;0;3;0;2;1.6.0-beta
                                          3;1;1;0;3;0
                                          3;1;1;0;3;8
                                          3;1;1;0;3;12
                                          3;1;1;0;3;16
                                          3;1;1;0;3;24
                                          3;1;1;0;3;30
                                          3;1;1;0;3;36
                                          3;1;1;0;3;44
                                          3;1;1;0;3;58
                                          3;1;1;0;3;76
                                          3;1;1;0;3;96
                                          3;1;1;0;3;100
                                          This is the output from gateway console when I move dimmer slider on the Domoticz
                                          3;1;1;1;3;87t Version
                                          3;1;1;1;3;80t Version
                                          3;1;1;1;3;53t Version
                                          3;1;1;1;3;47t Version
                                          3;1;1;1;3;33t Version
                                          3;1;1;1;3;20t Version
                                          3;1;1;1;3;13t Version
                                          3;1;1;1;3;73t Version
                                          The problem is that the ESP8266 gateway append unnecessary characters t Version at the end of each line.
                                          Also when dimmer slider is on the position 6%, gateway output is 3;1;1;1;3;73t Version Correct value should be 7 not 73
