  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
  • snowS
    snowS
    snow
    I have one battery powered node build on Arduino Mini Pro 3.3V with combined 2 sensors DHT11 and BH1750. The node is working OK and give me correct values from sensors on Arduino serial console.
    The output from this node connected to Serial gateway is also OK.
    And this is the output from the same node connected to ESP8266 gateway. As You can see, only the first output of LIGHT_LEVEL is correct.
    Could anyone check this?
    YveauxY 2 Replies Last reply
    • snowS snow
      @snow Could be a 8 (ATMega32) vs. 32 bit (ESP8266) issue.
      1032       = 0x0000 0408
      1107297279 = 0x4200 03FF
      The lower 16 bits are more or less equal.
      Could you post the serial output of the ESP8266 gateway for such a set of LIGHT_LEVELs and a screenshot of MYSController as you did before ?
      snowS 1 Reply Last reply
      • DwaltD
        DwaltD
        Dwalt
        Why does MsgID#32 provide Heater_sw as the subtype? Something strange going on with the data flowing through the esp...
        • DwaltD Dwalt
          MsgID#32 is from the serial gateway, as I understand it...
          • YveauxY Yveaux
            1032       = 0x0000 0408
            snowS
            snowS
            snow
            @Yveaux I have made another test on two gateways at the same time. Here is the results.
            Serial gateway (Arduino NANO)
            ESP8266 gateway (ESP-07)
            Console output from ESP gateway
            ESP8266 MySensors Gateway
            Connecting to 00000000
            ...................Connected!
            IP: 192.168.0.30
            Client 0 connected
            0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
            1;255;0;0;17;1.5
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            1;255;3;0;6;0
            Client 0: 1;255;3;0;6;M
            0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:Lux/Temp/Humidity
            1;255;3;0;11;Lux/Temp/Humidity +Bat
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            1;255;3;0;12;1.0
            0;0;3;0;9;read: 1-1-0 s=0,c=0,t=16,pt=0,l=0,sg=0:
            1;0;0;0;16;
            0;0;3;0;9;read: 1-1-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
            1;1;0;0;7;
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:101
            1;255;3;0;0;101
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:46
            1;0;1;0;23;46
            0;0;3;0;9;read: 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:23.0
            1;2;1;0;0;23.0
            0;0;3;0;9;read: 1-1-0 s=1,c=1,t=1,pt=7,l=5,sg=0:33.0
            1;1;1;0;1;33.0
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:93
            1;255;3;0;0;93
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296452
            1;0;1;0;23;1107296452
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296619
            1;0;1;0;23;1107296619
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296632
            1;0;1;0;23;1107296632
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296315
            1;0;1;0;23;1107296315
            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:92
            1;255;3;0;0;92
            1;255;3;0;0;93
            1;255;3;0;0;92
            1;255;3;0;0;93
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296724
            1;0;1;0;23;1107296724
            0;0;3;0;9;read: 1-1-0 s=255,c=2,t=0,pt=1,l=1,sg=0:92
            1;255;2;0;0;92
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296536
            1;0;1;0;23;1107296536
            1;255;3;0;0;93
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=22,pt=3,l=2,sg=0:1107296631
            1;0;1;0;22;1107296631
            0;0;3;0;9;read: 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:1107296622
            1;0;1;0;23;1107296622
            I suspect a problem with the length or definition of variables, but I'm not a good programmer. ;)
            1107296631 - 383 = 0x4200000
            1107296622 - 366 = 0x4200000
            • DwaltD
              DwaltD
              Dwalt
              Msg54 again shows subtype 22, which is for V_HVAC_SPEED. It occurred on both the serial gateway example (top of thread) and the ESP. It seems to mess up the message at the node level. Perhaps not a problem with the gateway.
              • snowS snow
                IP: 192.168.0.30
                Client 0 connected
                1;255;0;0;17;1.5
                1;255;3;0;6;0
                1;255;3;0;12;1.0
                1;0;0;0;16;
                1;1;0;0;7;
                1;255;3;0;0;101
                1;0;1;0;23;46
                1;2;1;0;0;23.0
                1;1;1;0;1;33.0
                1;255;3;0;0;93
                1;255;3;0;0;92
                1;255;3;0;0;93
                1;255;3;0;0;92
                1;255;3;0;0;93
                1;255;2;0;0;92
                1;255;3;0;0;93
                Agree. Possibly a variable somewhere that has a different size on ESP.
                Hopefully tonight I can have a better look.
                • YveauxY Yveaux
                  Pretty sure I found the cause: the messages exchanged between sensor and gateway contain int types.
                  These have a size of 2 bytes on Arduino and 4 bytes on ESP.
                  An int sent from the Arduino is sent as 2 bytes, but the ESP expects 4. The upper 2 will be filled with garbage.
                  Still a hypothesis which has to be verified & fixed.
                  To be continued!
                  • snowS snow
                    @snow Please try the code in the development branch , where hek did an excellent job to standardize on datatypes being exchanged between nodes.
                    This will probably solve your issue.
                    • snowS
                      snowS
                      snow
                      The development version is working OK :satisfied:
                      Thanks guys for your hard work.
                      • snowS snow
                        @snow great to hear!
                        Glad I could help (and my hunch was correct :-) )
                        • HoffanH
                          HoffanH
                          Hoffan
                          @snow
                          Did you use the Development version of the ESP8266 Wifi gatewavy or for the sensor
                            @Hoffan
                            You should probably use it on both sides to be sure to get the same size on the data types.
                            • HoffanH
                              HoffanH
                              Hoffan
                              wrote on last edited by Hoffan
                              All the sensors that i have include before i upgrade the ESP8266 Wifi GW is now working
                              But its not working to include more, Nothing happens in Veran when i press start
                              but the gateway say this
                              0;0;3;0;9Client 0: 0;0;3;0;5;1t version
                              every time i press start
                              hekH 1 Reply Last reply
                              • HoffanH Hoffan
                                @snow
                                snowS
                                snowS
                                snow
                                wrote on last edited by snow
                                At the moment I only changed the gateway. It's already solved my problem with incorrect values.
                                HoffanH 1 Reply Last reply
                                • snowS snow
                                  HoffanH
                                  HoffanH
                                  Hoffan
                                  @snow
                                  But is your include button working now?
                                  Or maybe you don't use Vera as a controller
                                  • HoffanH Hoffan
                                    @Hoffan
                                    The print looks a bit weird. I'll have to do some tests.
                                    • HoffanH Hoffan
                                      @snow
                                      snowS
                                      snowS
                                      snow
                                      @Hoffan No. I'm using DomoticZ
                                        @Hoffan
                                        HoffanH
                                        HoffanH
                                        Hoffan
                                        @hek
                                        That sounds good, Just ask if you want me to test something..
                                        • HoffanH
                                          HoffanH
                                          Hoffan
                                          @hek
                                          Any News here ?
