  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
  • YveauxY Yveaux
    @snow said:
    I suspect a problem with the length or definition of variables,
    Agree. Possibly a variable somewhere that has a different size on ESP.
    Hopefully tonight I can have a better look.
    Pretty sure I found the cause: the messages exchanged between sensor and gateway contain int types.
    These have a size of 2 bytes on Arduino and 4 bytes on ESP.
    An int sent from the Arduino is sent as 2 bytes, but the ESP expects 4. The upper 2 will be filled with garbage.
    Still a hypothesis which has to be verified & fixed.
    To be continued!
    • snowS snow
      I have one battery powered node build on Arduino Mini Pro 3.3V with combined 2 sensors DHT11 and BH1750. The node is working OK and give me correct values from sensors on Arduino serial console.
      The output from this node connected to Serial gateway is also OK.
      And this is the output from the same node connected to ESP8266 gateway. As You can see, only the first output of LIGHT_LEVEL is correct.
      Could anyone check this?
      @snow Please try the code in the development branch , where hek did an excellent job to standardize on datatypes being exchanged between nodes.
      This will probably solve your issue.
      • snowS
        snowS
        snow
        The development version is working OK :satisfied:
        Thanks guys for your hard work.
        • snowS snow
          @snow great to hear!
          Glad I could help (and my hunch was correct :-) )
          • HoffanH
            HoffanH
            Hoffan
            @snow
            Did you use the Development version of the ESP8266 Wifi gatewavy or for the sensor
            snowS 1 Reply Last reply
              @Hoffan
              You should probably use it on both sides to be sure to get the same size on the data types.
              • HoffanH
                HoffanH
                Hoffan
                wrote on last edited by Hoffan
                All the sensors that i have include before i upgrade the ESP8266 Wifi GW is now working
                But its not working to include more, Nothing happens in Veran when i press start
                but the gateway say this
                0;0;3;0;9Client 0: 0;0;3;0;5;1t version
                every time i press start
                hekH 1 Reply Last reply
                • HoffanH Hoffan
                  @snow
                  snowS
                  snowS
                  snow
                  wrote on last edited by snow
                  At the moment I only changed the gateway. It's already solved my problem with incorrect values.
                  HoffanH 1 Reply Last reply
                  • snowS snow
                    HoffanH
                    HoffanH
                    Hoffan
                    @snow
                    But is your include button working now?
                    Or maybe you don't use Vera as a controller
                    • HoffanH Hoffan
                      @Hoffan
                      The print looks a bit weird. I'll have to do some tests.
                      • HoffanH Hoffan
                        @snow
                        snowS
                        snowS
                        snow
                        @Hoffan No. I'm using DomoticZ
                          @Hoffan
                          HoffanH
                          HoffanH
                          Hoffan
                          @hek
                          That sounds good, Just ask if you want me to test something..
                          • HoffanH
                            HoffanH
                            Hoffan
                            @hek
                            Any News here ?
                            • snowS
                              snowS
                              snow
                              Having another problem with a ESP8266 running as the gateway. Sensor build on Arduino Mini Pro loaded with example sketch DimmableLightWithRotaryEncoderButton.ino. Sensor and gateway firmware compiled from latest development branch v1.6 library.
                              The controller is a domoticz.
                              This is a output on the gateway console when I turn rotary encoder on the sensor.
                              0;0;3;0;2;1.6.0-beta
                              3;1;1;0;3;0
                              3;1;1;0;3;8
                              3;1;1;0;3;12
                              3;1;1;0;3;16
                              3;1;1;0;3;24
                              3;1;1;0;3;30
                              3;1;1;0;3;36
                              3;1;1;0;3;44
                              3;1;1;0;3;58
                              3;1;1;0;3;76
                              3;1;1;0;3;96
                              3;1;1;0;3;100
                              This is the output from gateway console when I move dimmer slider on the Domoticz
                              3;1;1;1;3;87t Version
                              3;1;1;1;3;80t Version
                              3;1;1;1;3;53t Version
                              3;1;1;1;3;47t Version
                              3;1;1;1;3;33t Version
                              3;1;1;1;3;20t Version
                              3;1;1;1;3;13t Version
                              3;1;1;1;3;73t Version
                              The problem is that the ESP8266 gateway append unnecessary characters t Version at the end of each line.
                              Also when dimmer slider is on the position 6%, gateway output is 3;1;1;1;3;73t Version Correct value should be 7 not 73
                                wrote on last edited by hek
                                #22
                                @snow
                                Could you perhaps enable "#define MY_DEBUG" in the gateway sketch?
                                Would alos be interesting to see the result when you add
                                Serial.println(inputString);
                                Here:
                                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyProtocolMySensors.cpp#L36
                                • snowS
                                  snowS
                                  snow
                                  #23
                                  Here is the output from the gateway console when I rotate knob on the encoder.
                                  connected with 00000000, channel 6
                                  ip:192.168.0.110,mask:255.255.255.0,gw:192.168.0.1
                                  .IP: 192.168.0.110
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:24
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:24
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:26
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:26
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:28
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:28
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:30
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:30
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:32
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:32
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:34
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:34
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:36
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:36
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:38
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:38
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:40
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:40
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:42
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:42
                                  Here is output from the gateway console, when I slide down dimmer on the Domoticz
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:03M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;93M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:93M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:93M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;87M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:87M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:87M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;2;03M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:03M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;2;13M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=2,pt=0,l=11,sg=0,st=ok:13M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=2,pt=0,l=11,sg=0:13M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=2,l=2,sg=0:93
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:93
                                  0;0;3;0;9;read: 3-3-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                                  0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  0;0;3;0;9;Client 0: 3;255;3;0;6;M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=9,sg=0,st=ok:M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
                                  0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
                                  0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=1,l=1,sg=0:93
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;80M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;73M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;67M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;60M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;53M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;47M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
                                  0;0;3;0;9;Client 0: 3;1;1;1;3;40M Version
                                  0;0;3;0;9;send: 0-0-3-3 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
                                  0;0;3;0;9;read: 3-3-0 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
                                  The output from sensor console
                                  Starting...
                                  send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
                                  send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                  read: 0-0-3 s=255,c=3,t=6,pt=0,l=9,sg=0:M Version
                                  send: 3-3-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                                  send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
                                  send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
                                  Sending in last known light level to controller: 93
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:93
                                  Ready to receive messages...
                                  read: 0-0-3 s=1,c=1,t=3,pt=1,l=1,sg=0:93
                                  New light level received: 93
                                  Fading level: 1
                                  Fading level: 2
                                  Fading level: 3
                                  Fading level: 4
                                  Fading level: 5
                                  Fading level: 6
                                  Fading level: 7
                                  Fading level: 8
                                  Fading level: 9
                                  Fading level: 10
                                  Fading level: 11
                                  Fading level: 12
                                  Fading level: 13
                                  Fading level: 14
                                  Fading level: 15
                                  Fading level: 16
                                  Fading level: 17
                                  Fading level: 18
                                  Fading level: 19
                                  Fading level: 20
                                  Fading level: 21
                                  Fading level: 22
                                  Fading level: 23
                                  Fading level: 24
                                  Fading level: 25
                                  Fading level: 26
                                  Fading level: 27
                                  Fading level: 28
                                  Fading level: 29
                                  Fading level: 30
                                  Fading level: 31
                                  Fading level: 32
                                  Fading level: 33
                                  Fading level: 34
                                  Fading level: 35
                                  Fading level: 36
                                  Fading level: 37
                                  Fading level: 38
                                  Fading level: 39
                                  Fading level: 40
                                  Fading level: 41
                                  Fading level: 42
                                  Fading level: 43
                                  Fading level: 44
                                  Fading level: 45
                                  Fading level: 46
                                  Fading level: 47
                                  Fading level: 48
                                  Fading level: 49
                                  Fading level: 50
                                  Fading level: 51
                                  Fading level: 52
                                  Fading level: 53
                                  Fading level: 54
                                  Fading level: 55
                                  Fading level: 56
                                  Fading level: 57
                                  Fading level: 58
                                  Fading level: 59
                                  Fading level: 60
                                  Fading level: 61
                                  Fading level: 62
                                  Fading level: 63
                                  Fading level: 64
                                  Fading level: 65
                                  Fading level: 66
                                  Fading level: 67
                                  Fading level: 68
                                  Fading level: 69
                                  Fading level: 70
                                  Fading level: 71
                                  Fading level: 72
                                  Fading level: 73
                                  Fading level: 74
                                  Fading level: 75
                                  Fading level: 76
                                  Fading level: 77
                                  Fading level: 78
                                  Fading level: 79
                                  Fading level: 80
                                  Fading level: 81
                                  Fading level: 82
                                  Fading level: 83
                                  Fading level: 84
                                  Fading level: 85
                                  Fading level: 86
                                  Fading level: 87
                                  Fading level: 88
                                  Fading level: 89
                                  Fading level: 90
                                  Fading level: 91
                                  Fading level: 92
                                  Fading level: 93
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:80M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:80M Version
                                  New light level received: 80
                                  Fading level: 92
                                  Fading level: 91
                                  Fading level: 90
                                  Fading level: 89
                                  Fading level: 88
                                  Fading level: 87
                                  Fading level: 86
                                  Fading level: 85
                                  Fading level: 84
                                  Fading level: 83
                                  Fading level: 82
                                  Fading level: 81
                                  Fading level: 80
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:73M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:73M Version
                                  New light level received: 73
                                  Fading level: 79
                                  Fading level: 78
                                  Fading level: 77
                                  Fading level: 76
                                  Fading level: 75
                                  Fading level: 74
                                  Fading level: 73
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:67M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:67M Version
                                  New light level received: 67
                                  Fading level: 72
                                  Fading level: 71
                                  Fading level: 70
                                  Fading level: 69
                                  Fading level: 68
                                  Fading level: 67
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:60M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:60M Version
                                  New light level received: 60
                                  Fading level: 66
                                  Fading level: 65
                                  Fading level: 64
                                  Fading level: 63
                                  Fading level: 62
                                  Fading level: 61
                                  Fading level: 60
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:53M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:53M Version
                                  New light level received: 53
                                  Fading level: 59
                                  Fading level: 58
                                  Fading level: 57
                                  Fading level: 56
                                  Fading level: 55
                                  Fading level: 54
                                  Fading level: 53
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:47M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:47M Version
                                  New light level received: 47
                                  Fading level: 52
                                  Fading level: 51
                                  Fading level: 50
                                  Fading level: 49
                                  Fading level: 48
                                  Fading level: 47
                                  read: 0-0-3 s=1,c=1,t=3,pt=0,l=11,sg=0:40M Version
                                  send: 3-3-0-0 s=1,c=1,t=3,pt=0,l=11,sg=0,st=ok:40M Version
                                  New light level received: 40
                                  Fading level: 46
                                  Fading level: 45
                                  Fading level: 44
                                  Fading level: 43
                                  Fading level: 42
                                  Fading level: 41
                                  Fading level: 40
                                  I hope it will be helpful
                                    It almost looks like Domoticz sends the "Version" stuff. Is it possible to see what Domoticz sends? Anot logs over there?
                                    • snowS
                                      snowS
                                      snow
                                      Output from RPi console. pi@domoticz ~/domoticz $ sudo ./domoticz -verbose 1
                                      2015-11-08 15:06:57.916  MySensors: connected to: 192.168.0.110:5003
                                      2015-11-08 15:06:57.916  MySensors: Gateway Ready...
                                      2015-11-08 15:06:58.917  MySensors: Gateway Version: 1.6.0-beta
                                      2015-11-08 15:07:12.928  MySensors: Node: 3, Sketch Name: DimmableLED /w button
                                      2015-11-08 15:07:13.932  MySensors: Node: 3, Sketch Version: 1.2
                                      subtype       = AC
                                      Sequence nbr  = 0
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = On
                                      2015-11-08 15:07:13.936  (MySensors) Lighting 2 (LED Dimmer)
                                      subtype       = AC
                                      Sequence nbr  = 0
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = Set Level: 12
                                      2015-11-08 15:07:32.010  (MySensors) Lighting 2 (LED Dimmer)
                                      subtype       = AC
                                      Sequence nbr  = 1
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = Set Level: 11
                                      2015-11-08 15:07:33.981  (MySensors) Lighting 2 (LED Dimmer)
                                      subtype       = AC
                                      Sequence nbr  = 2
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = Set Level: 10
                                      2015-11-08 15:07:35.984  (MySensors) Lighting 2 (LED Dimmer)
                                      subtype       = AC
                                      Sequence nbr  = 3
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = Set Level: 9
                                      2015-11-08 15:07:38.055  (MySensors) Lighting 2 (LED Dimmer)
                                      subtype       = AC
                                      Sequence nbr  = 4
                                      ID            = 0000003
                                      Unit          = 1
                                      Command       = Set Level: 8
                                      I'll try to build Serial Gateway and do the same test
                                      • GizMoCuzG
                                        GizMoCuzG
                                        GizMoCuz
                                        There is a small problem with domoticz regarding the light level (fixed in beta #3563)
                                        When the slider was set to 100%, around 93% was send to the node
                                        BUT, what domoticz sends, is OK, there is NO version stuff added (really strange your seeing this!)
                                        I made a test sketch, and this is the output:
                                        Starting...
                                        send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
                                        send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        send: 254-254-0-0 s=1,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                                        send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:DimmableLED /w button
                                        send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.2
                                        sensor started, id=254, parent=0, distance=1
                                        read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                        send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                                        V_LIGHT received: 0
                                        read: 0-0-254 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                        send: 254-254-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                                        V_LIGHT received: 1
                                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:43
                                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
                                        V_DIMMER received: 43
                                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=2,sg=0:86
                                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
                                        V_DIMMER received: 86
                                        read: 0-0-254 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                                        send: 254-254-0-0 s=1,c=1,t=3,pt=0,l=3,sg=0,st=ok:100
                                        V_DIMMER received: 100
                                        All perfect
                                        Sketch:
                                        // Enable debug prints
                                        #define MY_NODE_ID 254
                                        #define SN "DimmableLED /w button"
                                        #define SV "1.2"
                                        #define CHILD_ID_LIGHT 1
                                        MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
                                        Serial.println("Ready to receive messages...");
                                        present(CHILD_ID_LIGHT, S_DIMMER);
                                        sendSketchInfo(SN, SV);
                                        Serial.print("V_LIGHT received: ");
                                        } else if (message.type == V_DIMMER) {
                                        Serial.print("V_DIMMER received: ");
                                        else {
                                        Serial.print("Unhandled message received: ");
                                          @GizMoCuz
                                          How do you terminate the strings in Domoticz? Only \n or both \n and \r?
                                          Does the controller have exactly the same behaviour when communicating with an ethernet gateway as serial gateway?
