  3. How To - Doorbell Automation Hack
106 Posts 29 Posters 129.0k Views 26 Watching
  • TD22057T TD22057
    FYI for anyone who wants to make a more complicated version of this, take a look at LowPowerLabs door bell controller. There is some good docs there (and in the follow up articles) if you want to try and tap the door bell power source to power the arduino. There is also a nice explanation of how to detect when another circuit activates which might be handy for another application.
    DrJeffD
    DrJeffD
    DrJeff
    @TD22057 This was the route I was heading with adding the doorbell to my HA, but @petewill is awesome in doing this with the video. Me and my daughter where just trying to decide what would be the best way to hack the bell. We added a Ring.com Doorbell (trial period) and trying to decide if we like it or not. The notifications are 2 way so that is nice with video and audio. But they do not have an API. I think I will try to sniff out the Motion detection or use it from my notifications to tie into my HA.
    • TD22057T
      TD22057T
      TD22057
      @DrJeff Very cool. I have 2 HikVision cameras covering the front of my house so I think I'm going to try the DIY version of Ring.com. Both of the cameras have "alarm" input and output wires (12V signal) that you can use to start recording video using an external PIR or do something when the camera detects motion. One camera has an external Bosch PIR sensor that works really well. It's a 12 V NC signal wire connected to the camera and it has eliminated virtually all of the false motion alarms. The other camera is above the door and has a built in PIR sensor.
      Reading this thread made me realize that I should tap into the door bell signal and the alarm output wire on the camera above to the door and send that out as a MySensor message which will send an MQTT message to a script which can grab the camera feed and email me still images (or send me a link to a web page w/ the images) of who is coming up to the house.
      • BigDogB
        BigDogB
        BigDog
        great! i am going to add this to my home domoticz! Thanks
        1x Raspberry With Domoticz V2.3011 [Linux version 4.1.6+]
        PiRack With
        -1X PiFace Digital
        -1X RaZberry - OpenZWave
        1X RFXtrx433 USB Firmware: 183
        5X Arduino: mysensors V1.5(including)
        • First DoorBel Project -> WORKS! :)
          6x ESP8266: easy firmware(Testing)
        • D
          drock1985
          Going to install one of these very soon.
          How hard would it be to modify the sketch for a two door bell system?
          My Projects
          2 Door Chime Sensor
          Washing Machine Monitor
          petewillP 1 Reply Last reply
          • D drock1985
            petewillP
            petewillP
            petewill
            @drock1985 Sorry for the delayed reply! It shouldn't be too hard. You will just have to create another button input and relay output in the sketch. I haven't looked at the code but you should be able to duplicate what's in there just changing the names and pins where appropriate.
            D 1 Reply Last reply
            • petewillP petewill
              drock1985
              @petewill
              Awesome, thanks.I have the parts on order, minus the power supply (will power from AA batteries for now until I get in a DC-DC step down regulator).
              Just need to find a half decent chime now. lol
              My Projects
              2 Door Chime Sensor
              • D
                drock1985
                Hey @petewill
                Started working on the project this weekend. Didn't get the parts in this week due to the holiday. Did what I could though, and I have a schematic/drawing made up for the system. This is my first drawing in fritzing, so it's a little crude. I couldn't figure out how to add a 'T' section/junction in the wire, but it all lines up for reference anyways.
                I'll start working on the Arduino code next.
                My Projects
                2 Door Chime Sensor
                  Why don't you send over the signal wirelessly between the two doorbells?
                  • D
                    drock1985
                    Hi @hek
                    I'm not too sure I understand what you are referring to. If you are referring to the buttons themselves outside being wireless, I thought about it but wasn't too sure how long a battery would last and didn't want to be changing batteries. The way I plan to do this now, I can use the existing wiring for the doorbells that are already there, and splice into the power for the door bell to power the MySensors node.
                    Plus, both chimes are in the same spot, one relay sets off one set of the three contacts (Wtih a common ground I believe) and the other will chime the second.
                    My Projects
                    2 Door Chime Sensor
                    hekH 1 Reply Last reply
                    • D drock1985
                      Hi @hek
                      @drock1985
                      Ahh. nice. Thought you might have to run some new wires around the house.
                        @drock1985
                        drock1985
                        @hek lol, no. Just hooking up everything to the internet that I can.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          petewillP
                          petewillP
                          petewill
                          @drock1985 Nice! Does your doorbell use DC so you can steal power from it? I wish mine did. That would have made things easier for me. Mine uses 16VAC... :(
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @petewill
                            Convert it!!!
                            you have the power
                            you have the technology
                            diode bridge
                            • D
                              drock1985
                              Hey @petewill
                              They vary. Some of the more expensive ones I've noticed use DC (ex play custom songs/tones), while the cheaper ones use AC.
                              I built the project around the idea the wife would want something more elaborate than a simple ding sound, but I was wrong lol. So I picked up one that she looked last night, and I believe it uses AC, so I will be making a slight change to my design.
                              I'll end up putting in one of these I figure, just haven't quite figured out what size smoothing capacitor I will need.
                              Also, I'm not 100% sure yet (at work, hard to do research) but I may be able to get away with a simple 5v regulator once the power is converted to DC, in lieu of a variable buck converter.
                              http://m.wikihow.com/Make-an-AC-DC-Converter
                              My Projects
                              2 Door Chime Sensor
                              DrJeffD 1 Reply Last reply
                                @petewill
                                Convert it!!!
                                you have the power
                                diode bridge
                                petewillP
                                petewillP
                                petewill
                                @BulldogLowell Haha, I just took the easy way out and ran a 5V line :)
                                @drock1985
                                Yeah, that's happened to me as well on other projects :)
                                • D drock1985
                                  Hey @petewill
                                  DrJeffD
                                  DrJeffD
                                  DrJeff
                                  Add a cap .1uf input side of the 5V regulator and a 47-220uf on the regulated 5V . High freq and a low freq ripple.
                                  That should do the trick same thing I was planning on doing. I bought the Ring Doorbell but still want to be notified of the actual ring into HA.
                                  • D
                                    drock1985
                                    Hi @petewill
                                    I finally got the parts in to do the project. I've been working on the code, but I seem to be running into an issue. I have the four devices show up in Domoticz, but I'm not getting any feedback from the sensor. Would you mind looking at the code for me please? This is the first program I have ever worked on, and not much of a programmer mentality yet.
                                     * 2 Door Chime
                                     * Version 1.0 - ResentedPoet
                                     * Original idea/concept by PeteWill. Modified code to add second actuator (relay)
                                     * door chimes with 2 doors. This will allow your home automation system to differentiate
                                     * between front and back door. As well, this allows current 2 door chimes to still have
                                     * their individual chimes. Pins 3 and 4 are used for door bell 1 and relay/chime 1
                                     * respectively, and digital pins 5 and 6 for door bell 2 and relay/chime 2.
                                    #define NODE_ID AUTO // or set a manual ID in place of AUTO
                                    #define DOORBELL1_PIN  3      // Arduino Digital I/O pin number for the doorbell button
                                    #define RELAY1_PIN  4         // Arduino Digital I/O pin number for the relay
                                    #define DOORBELL1_CHILD_ID 0  //ID of the front doorbell
                                    #define SWITCH1_CHILD_ID 1    // Id of the switch that will control front doorbell sound
                                    #define RELAY1_ON 1
                                    #define RELAY1_OFF 0
                                    #define DOORBELL2_PIN  5      // Arduino Digital I/O pin number for the doorbell button
                                    #define RELAY2_PIN  6         // Arduino Digital I/O pin number for the relay
                                    #define DOORBELL2_CHILD_ID 2  //ID of the back doorbell
                                    #define SWITCH2_CHILD_ID 3    // Id of the switch that will control back doorbell sound
                                    #define RELAY2_ON 1
                                    #define RELAY2_OFF 0
                                    Bounce debouncer = Bounce();
                                    MyMessage switchMsg1(SWITCH1_CHILD_ID, V_LIGHT);
                                    MyMessage switchMsg2(SWITCH2_CHILD_ID, V_LIGHT);
                                    MyMessage doorbellMsg1(DOORBELL1_CHILD_ID, V_TRIPPED);
                                    MyMessage doorbellMsg2(DOORBELL2_CHILD_ID, V_TRIPPED);
                                    unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
                                    unsigned int ringTime = 700; //How long the doorbell relay is on (in milliseconds)
                                    unsigned long doorbell1Millis;  //Used to keep track of the last front doorbell button press
                                    unsigned long doorbell1Timer;  //Used to keep track of front doorbell ring time
                                    unsigned long doorbell2Millis;  //Used to keep track of the last back doorbell button press
                                    unsigned long doorbell2Timer;  //Used to keep track of back doorbell ring time
                                    byte doorbell1PreviousVal;  //Used to keep track of front doorbell button pressed state
                                    byte doorbell2PreviousVal;  //Used to keep track of back doorbell button pressed state
                                    boolean ringDoorbell1;  //Used to initiate the ring front doorbell if statement
                                    boolean doorbell1Sound; //Used to keep track if the front doorbell should sound or be silent.  Value recieved from doorbell on/off switch
                                    boolean doorbell1Off = true;  //Used to keep track of front doorbell ring state
                                    boolean ringDoorbell2;  //Used to initiate the ring front doorbell if statement
                                    boolean doorbell2Sound; //Used to keep track if the front doorbell should sound or be silent.  Value recieved from doorbell on/off switch
                                    boolean doorbell2Off = true;  //Used to keep track of front doorbell ring state
                                      gw.begin(incomingMessage, NODE_ID);
                                      gw.sendSketchInfo("2 Doorbell Monitor", "1.0");
                                      // Setup the button and activate internal pull-up
                                      pinMode(DOORBELL1_PIN, INPUT_PULLUP);
                                      pinMode(DOORBELL2_PIN, INPUT_PULLUP);
                                      debouncer.attach(DOORBELL1_PIN);
                                      debouncer.attach(DOORBELL2_PIN);
                                      debouncer.interval(5);
                                      gw.present(SWITCH1_CHILD_ID, S_LIGHT);
                                      gw.present(DOORBELL1_CHILD_ID, S_MOTION);
                                      gw.present(SWITCH2_CHILD_ID, S_LIGHT);
                                      gw.present(DOORBELL2_CHILD_ID, S_MOTION);
                                      digitalWrite(RELAY1_PIN, RELAY1_OFF);
                                      digitalWrite(RELAY2_PIN, RELAY2_OFF);
                                      pinMode(RELAY1_PIN, OUTPUT);
                                      pinMode(RELAY2_PIN, OUTPUT);
                                      // Set doorbellSound to last known state (using eeprom storage)
                                      doorbell1Sound = gw.loadState(SWITCH1_CHILD_ID);
                                      doorbell2Sound = gw.loadState(SWITCH2_CHILD_ID);
                                        unsigned long current1Millis = millis();
                                      //Check to see if front doorbell button was pushed.
                                      if (current1Millis - doorbell1Millis > doorbellDelay) //used to stop doorbell from being pressed too frequently
                                        debouncer.update();
                                        // Read front doorbell button value
                                        byte doorbell1Detect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
                                        if (doorbell1Detect != doorbell1PreviousVal)
                                          //Serial.print("doorbell1Detect Value: ");
                                          //Serial.println(doorbell1Detect);
                                          if (doorbell1Detect == 1)
                                            ringDoorbell1 = true;
                                            doorbell1Timer = current1Millis;
                                          doorbell1Millis = current1Millis;
                                          doorbell1PreviousVal = doorbell1Detect;
                                      if (ringDoorbell1)
                                        if (doorbell1Sound)
                                          if (doorbell1Off)
                                            digitalWrite(RELAY1_PIN, RELAY1_ON);
                                            //Serial.println("Front Doorbell sounded.");
                                            doorbell1Off = false;
                                            if (current1Millis - doorbell1Timer > ringTime)
                                              ringDoorbell1 = false;
                                              //Serial.println("Front Doorbell off.");
                                    //Check to see if back doorbell button was pushed.
                                    unsigned long current2Millis = millis();
                                        if (current2Millis - doorbell2Millis > doorbellDelay) //used to stop doorbell from being pressed too frequently
                                        debouncer.update();
                                        // Read back doorbell button value
                                        byte doorbell2Detect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
                                        if (doorbell2Detect != doorbell2PreviousVal)
                                          //Serial.print("doorbell2Detect Value: ");
                                          //Serial.println(doorbell2Detect);
                                          if (doorbell2Detect == 1)
                                            ringDoorbell2 = true;
                                            doorbell2Timer = current2Millis;
                                          doorbell2Millis = current2Millis;
                                          doorbell2PreviousVal = doorbell2Detect;
                                      if (ringDoorbell2)
                                        if (doorbell2Sound)
                                          if (doorbell2Off)
                                            digitalWrite(RELAY2_PIN, RELAY2_ON);
                                            //Serial.println("Back Doorbell sounded.");
                                            doorbell2Off = false;
                                            if (current2Millis - doorbell2Timer > ringTime)
                                              ringDoorbell2 = false;
                                              //Serial.println("Back Doorbell off.");
                                      void incomingMessage(const MyMessage & message) {
                                        if (message.isAck()) {
                                          // Change relay state
                                          doorbell1Sound = message.getBool();
                                          // Store state in eeprom
                                          gw.saveState(SWITCH1_CHILD_ID, doorbell1Sound);
                                    My Projects
                                    2 Door Chime Sensor
                                      @drock1985
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @petewill
                                      that may be the easy way, but not as fun :(
                                      • D drock1985
                                        Hi @petewill
                                         * 2 Door Chime
                                        #define RELAY1_ON 1
                                        #define RELAY2_ON 1
                                            debouncer.update();
                                          if (ringDoorbell1)
                                            if (doorbell1Sound)
                                              if (doorbell1Off)
                                            debouncer.update();
                                          if (ringDoorbell2)
                                            if (doorbell2Sound)
                                              if (doorbell2Off)
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        @drock1985
                                        I think your code is a little hard to get through, but you need two instances of the Bounce library if you want to manage two buttons:
                                        do this instead:
                                        Bounce debouncePin1 = Bounce();
                                        Bounce debouncePin2 = Bounce();
                                          debouncePin1.attach(DOORBELL1_PIN);
                                          debouncePin1.interval(5);
                                          debouncePin2.attach(DOORBELL2_PIN);
                                          debouncePin2.interval(5);
                                        and update the state with:
                                        debouncerPin1.update();
                                        get it?
                                        alternatively you could use an array:
                                        Bounce debouncer[2] = Bounce();
                                        it would make your code a lot easier, but you have to understand arrays and Classes or you will be a little lost.
                                          @petewill
                                          petewillP
                                          petewillP
                                          petewill
                                          @BulldogLowell
                                          I know huh? It seems my opportunity for fun has been getting less and less these days :( I still need to finish the PhoneyTV project...
