  3. Can not reply on the forum or Locked
forumfirefox
9 Posts 3 Posters 4.1k Views 1 Watching
  • daulagariD
    daulagariD
    daulagari
    I tried to post something on the forum from my Linux machine using Firefox or Konqueror but that is not working out.
    • In Firefox 30 I can type a reply and press submit but nothing happens and no reply is added. Same problem trying Firefox and WinXP.
    • In Konqueror I see an orange line above all threads saying "This thread has been deleted. Only users with thread management privileges can see it." is displayed but I can still see the thread although every items is Locked (Blue box)
    Eventually installed Chromium and that works but ... I am the only one having problem access the forum using Firefox?
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      When you see this reply it means I was able to submit it (Firefox on Mac though and used only for this test).
      Fulltime Servoy Developer
      • daulagariD
        daulagariD
        daulagari
        Still using Chromium I enable "Live HTTP header" while trying using Firefox and I see:
        http://forum.mysensors.org/socket.io/1/?t=1405886010035
        GET /socket.io/1/?t=1405886010035 HTTP/1.1
        Host: forum.mysensors.org
        User-Agent: Mozilla/5.0 (X11; Linux i686; rv:30.0) Gecko/20100101 Firefox/30.0
        Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
        Accept-Language: en-US,en;q=0.5
        Accept-Encoding: gzip, deflate
        Cookie: express.sid=s%3AomLCnc8o2jWjEhxQxplyLt9HFWZwqLOR.5R8%2B4xVScOLLt2D9cAs2BVn%2Bspl3kIGOIop1Ie5sr1U; _ga=GA1.2.1667585123.1404853555
        Connection: keep-alive
        HTTP/1.1 502 Bad Gateway
        Server: nginx/1.4.1 (Ubuntu)
        Date: Sun, 20 Jul 2014 19:53:30 GMT
        Content-Type: text/html
        Content-Length: 181
        I think this has to do with the problems but do not know what to conclude based on it.
          The forum is utilizing websockets. Is your webbroswer complient? If not it should fallback to plain ajax (or long pull dito).
            Hmm.. Searching around for similar issues I found:
            http://stackoverflow.com/questions/3704626/nginx-502-bad-gateway-error-only-in-firefox
            But the ngnix log does not show any "upstream sent too big header while...".
            Instead I see a lot of "upstream prematurely closed connection while reading response header from upstream" in the log. Which leads to believe it has something to do with:
            https://github.com/NodeBB/NodeBB/issues/692
            But this seem to be an issue in all browsers.
            I might try increasing ngnix cookie buffers anyway like suggesten in first link later. I'll contact you @daulagari again when it has been done.
              Buffers has been increased. Could you test with your firefox again?
              • daulagariD
                daulagariD
                daulagari
                Tried once more with Firefox but same behavior as before:
                • I press Reply and the normal editor pops up in the bottom of the screen
                • Type the message left and the preview right looks fine
                • Press Submit and in the top of the screen a turning progress circle is displayed for five seconds and after that it changes into a V
                • But the editor window in the bottom remains open and no message posted
                Made a capture using Wireshark and see quite some 502 Bad Gateway coming by.
                See the site is running nginx and I am running that also on my Cubieboard2 and also had 502 Bad Gateway problems and solved them eventually, see https://domotiga.nl/projects/domotiyii/wiki/Installation#If-things-go-wrong
                The stackoverflow link is for a very old version of Firefox; I doubt if that is still relevant. I this article, http://stackoverflow.com/questions/10470109/error-502-in-nginx-php5-fpm, two year old ;-) maybe helpful?
                  The forum is node.js based (not php). I doubt it's right related. The forum runs inside a dockers container with a ngnix proxy (which has websocket proxying enabled) in front of everything.
                  • daulagariD
                    daulagariD
                    daulagari
                    Tried again with Firefox and now things are working.
                    Problems solved!
