  3. Vera
  4. Battery status in all sensors?
5 Posts 4 Posters 3.0k Views 1 Watching
  • TmasterT Offline
    TmasterT Offline
    Tmaster
    wrote on last edited by Tmaster
    i'm running my sensor in a beta mode :P and i have this question:
    battery icon shoudn't apear in all sensors from a nodes?
    I only have it on node number but not in other 3 sensors (PART OF SAME NODE) connected to this node(arduino). it that normal?
    Ps:Running sketch example gateway and custom sketch from battery and light sensors example.
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
    H 1 Reply Last reply
    • TmasterT Tmaster
      H Offline
      H Offline
      Yes, that is by design. Hopefully one node (=arduino) only has one battery to report status on.
      • TmasterT Offline
        TmasterT Offline
        Tmaster
        But then i don't have any way to trigger a scene when the battery reach a discharge value. I only can select scenes on sensors ,not nodes. Any way to set an alarm ,send an email or something like that to notice a empty battery ?
        Because i'm using Imperihome to control Vera and i pass many days without go to vera gw directly.
        A 1 Reply Last reply
        • TmasterT Tmaster
          A Offline
          A Offline
          AWI
          @Tmaster You can create a special "sensor" which reports the actual battery voltage (S_MULTIMETER, V_VOLTAGE) and do whatever you want with it. I do this with all my battery operated sensors (node's) to get a grasp on battery performance.
          • K Offline
            K Offline
            korttoma
            If your using PLEG you can add the BatteryLevel of the node as a device property input an use that to specify a condition for a notification.
            • Tomas
            12.1k
