  3. OTA FW on Repeater Nodes???
18 Posts 3 Posters 6.3k Views 5 Watching
  • R Offline
    R Offline
    rvendrame
    Hello everyone,
    I recently enabled repeater function in one of my nodes, and now when I try to update its firmware OTA with MYSController, instead the regular FW update messages, I get thousands of this:
    The GW is on latest 1.5 master branch version.
    The repeater node is also on 1.5, but a bit lower (I installed it ~4 month ago I think)
    I'm using latest 0.1.2.282 MYSController.
    Any ideia about what can be wrong? I rebooted the node after 20k+ messages, it started normally and is responding fine, tough it still not up-to-date.
    I'm sure I was able to OTA-update it before switching repeater ON...
    Help!
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • O Offline
      O Offline
      Oitzu
      Hm... can you paste the relevant parts from your sketch?
      And probably the messages send from MYSController right before the messages would help.
      • R Offline
        R Offline
        rvendrame
        @Oitzu , sure,
        It started like that:
        10/27/2015 14:31:18 INFO FW "myMultiSensor" assigned to node 9
        10/27/2015 14:31:21 TX 9;0;3;0;13;0
        10/27/2015 14:31:21 RX 0;0;3;0;9;send: 0-0-9-9 s=0,c=3,t=13,pt=0,l=1,sg=0,st=ok:0
        10/27/2015 14:31:21 RX 0;0;3;0;9;read: 9-9-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
        10/27/2015 14:31:21 CHILD New child discovered, node id=9, child id=internal
        ... and then gets into the endless loop:
        10/27/2015 14:31:22 DEBUG Update child id=255, type=ARDUINO_RELAY
        10/27/2015 14:31:22 RX 9;255;0;0;18;1.5
        10/27/2015 14:31:22 RX 0;0;3;0;9;read: 9-9-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
        And here's my sketch (the one current in node is a bit different, but not significant):
        #include <IRLib.h>
        //  IO PINS
        #define MOTION 4  // The digital input you attached your motion sensor.
        #define IR_LED 3  // Infrared LED output
        #define DHT11  2  // Temp/Hum sensor
        #define LDR    A0 // LDR (Light sensor) - Pull-down of 10K to GND
        //  Interval between reads (Temp/Hum/Light)
        #define INTERVAL  720000  // 720s = 12min
        DHT dht ;
        IRsend ir;
        // Initialize messages
        MyMessage msg_motion( 1, V_TRIPPED );
        MyMessage msg_Hum( 2, V_HUM );
        MyMessage msg_Temp( 3, V_TEMP) ;
        MyMessage msg_light( 5, V_LIGHT_LEVEL );
        boolean metric = true;
        boolean lastMotion = false;
        float   temp , hum ;
        int     lightLevel ;
        unsigned long lastRun ;
          Serial.println("Device Init...");
          // Init sensors
          pinMode( MOTION , INPUT );
          dht.setup( DHT11 );
          // Init mySensors
          Serial.println("mySensor start...");
          gw.begin( incomingMessage );  //  , AUTO , true );  // Repeater mode
          gw.sendSketchInfo("myMultiSensor", "1.2");
          gw.present( 1 , S_MOTION );
          gw.present( 2 , S_HUM );
          gw.present( 3 , S_TEMP );
          gw.present( 4 , S_SCENE_CONTROLLER );
          gw.present( 5 , S_LIGHT_LEVEL );
          lastRun = 0;
          // mySensors Radio handling
          // Temp/Hum
          if ( lastRun == 0 || ( millis() - lastRun ) > INTERVAL )  {
            ////// Check Temperature
            temp = dht.getTemperature();
            if (!metric) temp = dht.toFahrenheit(temp);
            gw.send(msg_Temp.set( temp , 0 ) , true );
            Serial.print("T: ");
            Serial.println( temp , 0 );
            ////// Check Humidty
            hum  = dht.getHumidity();
            gw.send(msg_Hum.set( hum , 0 ) , true );
            Serial.print("H: ");
            Serial.println( hum , 1 );
            if (isnan( temp ) || isnan( hum ) )
               Serial.println("Failed to read from DHT");
            ////// Check Light Level
            lightLevel = map( analogRead( LDR ) , 0 , 1023 , 0, 100 ) ;
            gw.send( msg_light.set( lightLevel ) , true );
            Serial.print("L: ");
            Serial.println( lightLevel );
            lastRun = millis();
          /////     Motion
          if ( digitalRead( MOTION ) != lastMotion ) {
            gw.send(msg_motion.set( lastMotion? "0" : "1" ) , true ); // Send tripped value to gw
            Serial.print("M: ");
            Serial.println( lastMotion? "0" : "1" );
            lastMotion = !lastMotion;
        ///////////// Scene controller (IR)
        void incomingMessage( const MyMessage &message) {
          // SCENE ON   (Note: SCENE OFF is not supported by compactwall)
          if ( message.type == V_SCENE_ON ) {
            //  Retrieve the scene number
            int scene = atoi( message.data );
            Serial.print( "Scene " );
            Serial.print( scene );
            Serial.println( " ON" ) ;
            // Send comand to scenario compactwall module via Infrared LED
            long ir_command = 0x1380 + scene;
            ir.send( RC5 , ir_command , 32 );
        Thanks a lot!
        Alexa / Google Home
        • O Offline
          O Offline
          Oitzu
          I really can not see why the node keeps rebooting over and over.
          Maybe enable Serial debug directly on the node?
          • R Offline
            R Offline
            rvendrame
            That will be my last try, after I return from a trip (in two weeks). Thanks anyway!
            Alexa / Google Home
            • O Offline
              O Offline
              Oitzu
              After reading the code i maybe have an theorie about your issue.
              The reboot is done with a watchdog timer. The watchdog timer will not unset itself, but is unset after the reboot.
              Using OTA and Relay will probably that much startup time that the watchdog timer will trigger again before it is unset.
              • O Offline
                O Offline
                Oitzu
                If you still have access to the node you could try to add wdt_reset(); in the beginning of the setup function.
                R 1 Reply Last reply
                • O Oitzu
                  R Offline
                  R Offline
                  rvendrame
                  @Oitzu , sure I will try it, but only in two weeks. Thanks for the hint!
                  Alexa / Google Home
                  • R rvendrame
                    Hello everyone,
                    Help!
                    T Offline
                    T Offline
                    tekka
                    @rvendrame said:
                    Hello everyone,
                    Which board / bootloader? Sensebender or regular Arduino with MYSBootloader?
                    • T tekka
                      @rvendrame said:
                      Hello everyone,
                      R Offline
                      R Offline
                      rvendrame
                      @tekka , regular Arduino (pro-mini clone) with MYSBootloader.
                      Alexa / Google Home
                      • R rvendrame
                        T Offline
                        T Offline
                        tekka
                        @rvendrame can you upload the MYSController log?
                        • T tekka
                          R Offline
                          R Offline
                          rvendrame
                          wrote on last edited by rvendrame
                          @tekka , the begin of log is like that:
                          ... and from here on, thousands of repetitions of same messages. It only stops by turning off the power of the node.
                          Alexa / Google Home
                          • R rvendrame
                            T Offline
                            T Offline
                            tekka
                            @rvendrame the node does not seem to reboot upon initiation of the OTA update (bootloader signal is missing). Can you post the rx log when you power-cycle the node?
                            • R Offline
                              R Offline
                              rvendrame
                              @tekka , I'm currently traveling so only in two weeks from now. I posted the 'Info' from the node at first post, maybe it helps some how? Bootloader is 'N/A' there, could be something in there?
                              Alexa / Google Home
                              • R rvendrame
                                T Offline
                                T Offline
                                tekka
                                @rvendrame ok, let's wait until your return.
                                • R Offline
                                  R Offline
                                  rvendrame
                                  @tekka , @Oitzu , I finally managed to have some time for this.
                                  This is the serial monitor output from the node, as soon as I request the FW update via MYSController (it is a endless loop):
                                  read: 0-0-9 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                  Device Init...
                                  ��Sensor start...
                                  send: 9-9-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                                  Device Init...
                                  ��Sensor start...
                                  Device Init...
                                  And I tried to upload the new FW via FTDI adapter (in order to test with the repeater function off), however I got an error from avrdude (maybe my pro mini is broken somehow?)
                                           User configuration file is "/Users/i007897/.avrduderc"
                                           Using Port                    : /dev/cu.usbserial-A50285BI
                                           Overriding Baud Rate          : 57600
                                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
                                  avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
                                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
                                  avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe6
                                  avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x52
                                  avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9f
                                  avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe5
                                  avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd2
                                  avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x43
                                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd7
                                  avrdude done.  Thank you.
                                  Alexa / Google Home
                                  • O Offline
                                    O Offline
                                    Oitzu
                                    @rvendrame the mysbootloader doesn't support serial upload.
                                    Use an ISP to upload a new sketch.
                                    • R rvendrame
                                      Device Init...
                                      ��Sensor start...
                                      Device Init...
                                      ��Sensor start...
                                      Device Init...
                                      T Offline
                                      T Offline
                                      tekka
                                      @rvendrame This issue does not seem to be related to MYSBootloader since the log does not show bootloader messages. However, your node seems re-initializing (but not rebooting) over and over. Try changing the hardware (MCU & nRF) and update to the latest (non-dev branch) framework for further testing.
                                      12.1k
