  3. OTA FW on Repeater Nodes???
18 Posts 3 Posters 6.7k Views 5 Watching
  • OitzuO
    OitzuO
    Oitzu
    Hm... can you paste the relevant parts from your sketch?
    And probably the messages send from MYSController right before the messages would help.
    • rvendrameR
      rvendrameR
      rvendrame
      @Oitzu , sure,
      It started like that:
      10/27/2015 14:31:18 INFO FW "myMultiSensor" assigned to node 9
      10/27/2015 14:31:21 TX 9;0;3;0;13;0
      10/27/2015 14:31:21 RX 0;0;3;0;9;send: 0-0-9-9 s=0,c=3,t=13,pt=0,l=1,sg=0,st=ok:0
      10/27/2015 14:31:21 RX 0;0;3;0;9;read: 9-9-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
      10/27/2015 14:31:21 CHILD New child discovered, node id=9, child id=internal
      ... and then gets into the endless loop:
      10/27/2015 14:31:22 DEBUG Update child id=255, type=ARDUINO_RELAY
      10/27/2015 14:31:22 RX 9;255;0;0;18;1.5
      10/27/2015 14:31:22 RX 0;0;3;0;9;read: 9-9-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
      And here's my sketch (the one current in node is a bit different, but not significant):
      #include <IRLib.h>
      //  IO PINS
      #define MOTION 4  // The digital input you attached your motion sensor.
      #define IR_LED 3  // Infrared LED output
      #define DHT11  2  // Temp/Hum sensor
      #define LDR    A0 // LDR (Light sensor) - Pull-down of 10K to GND
      //  Interval between reads (Temp/Hum/Light)
      #define INTERVAL  720000  // 720s = 12min
      DHT dht ;
      IRsend ir;
      // Initialize messages
      MyMessage msg_motion( 1, V_TRIPPED );
      MyMessage msg_Hum( 2, V_HUM );
      MyMessage msg_Temp( 3, V_TEMP) ;
      MyMessage msg_light( 5, V_LIGHT_LEVEL );
      boolean metric = true;
      boolean lastMotion = false;
      float   temp , hum ;
      int     lightLevel ;
      unsigned long lastRun ;
        Serial.println("Device Init...");
        // Init sensors
        pinMode( MOTION , INPUT );
        dht.setup( DHT11 );
        // Init mySensors
        Serial.println("mySensor start...");
        gw.begin( incomingMessage );  //  , AUTO , true );  // Repeater mode
        gw.sendSketchInfo("myMultiSensor", "1.2");
        gw.present( 1 , S_MOTION );
        gw.present( 2 , S_HUM );
        gw.present( 3 , S_TEMP );
        gw.present( 4 , S_SCENE_CONTROLLER );
        gw.present( 5 , S_LIGHT_LEVEL );
        lastRun = 0;
        // mySensors Radio handling
        // Temp/Hum
        if ( lastRun == 0 || ( millis() - lastRun ) > INTERVAL )  {
          ////// Check Temperature
          temp = dht.getTemperature();
          if (!metric) temp = dht.toFahrenheit(temp);
          gw.send(msg_Temp.set( temp , 0 ) , true );
          Serial.print("T: ");
          Serial.println( temp , 0 );
          ////// Check Humidty
          hum  = dht.getHumidity();
          gw.send(msg_Hum.set( hum , 0 ) , true );
          Serial.print("H: ");
          Serial.println( hum , 1 );
          if (isnan( temp ) || isnan( hum ) )
             Serial.println("Failed to read from DHT");
          ////// Check Light Level
          lightLevel = map( analogRead( LDR ) , 0 , 1023 , 0, 100 ) ;
          gw.send( msg_light.set( lightLevel ) , true );
          Serial.print("L: ");
          Serial.println( lightLevel );
          lastRun = millis();
        /////     Motion
        if ( digitalRead( MOTION ) != lastMotion ) {
          gw.send(msg_motion.set( lastMotion? "0" : "1" ) , true ); // Send tripped value to gw
          Serial.print("M: ");
          Serial.println( lastMotion? "0" : "1" );
          lastMotion = !lastMotion;
      ///////////// Scene controller (IR)
      void incomingMessage( const MyMessage &message) {
        // SCENE ON   (Note: SCENE OFF is not supported by compactwall)
        if ( message.type == V_SCENE_ON ) {
          //  Retrieve the scene number
          int scene = atoi( message.data );
          Serial.print( "Scene " );
          Serial.print( scene );
          Serial.println( " ON" ) ;
          // Send comand to scenario compactwall module via Infrared LED
          long ir_command = 0x1380 + scene;
          ir.send( RC5 , ir_command , 32 );
      Thanks a lot!
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • OitzuO
        OitzuO
        Oitzu
        I really can not see why the node keeps rebooting over and over.
        Maybe enable Serial debug directly on the node?
        • rvendrameR
          rvendrameR
          rvendrame
          That will be my last try, after I return from a trip (in two weeks). Thanks anyway!
          Alexa / Google Home
          • OitzuO
            OitzuO
            Oitzu
            After reading the code i maybe have an theorie about your issue.
            The reboot is done with a watchdog timer. The watchdog timer will not unset itself, but is unset after the reboot.
            Using OTA and Relay will probably that much startup time that the watchdog timer will trigger again before it is unset.
            • OitzuO
              OitzuO
              Oitzu
              If you still have access to the node you could try to add wdt_reset(); in the beginning of the setup function.
              rvendrameR 1 Reply Last reply
              • OitzuO Oitzu
                rvendrameR
                rvendrameR
                rvendrame
                @Oitzu , sure I will try it, but only in two weeks. Thanks for the hint!
                Alexa / Google Home
                • rvendrameR rvendrame
                  Hello everyone,
                  I recently enabled repeater function in one of my nodes, and now when I try to update its firmware OTA with MYSController, instead the regular FW update messages, I get thousands of this:
                  The GW is on latest 1.5 master branch version.
                  The repeater node is also on 1.5, but a bit lower (I installed it ~4 month ago I think)
                  I'm using latest 0.1.2.282 MYSController.
                  Any ideia about what can be wrong? I rebooted the node after 20k+ messages, it started normally and is responding fine, tough it still not up-to-date.
                  I'm sure I was able to OTA-update it before switching repeater ON...
                  Help!
                  tekkaT
                  tekkaT
                  tekka
                  @rvendrame said:
                  Hello everyone,
                  Which board / bootloader? Sensebender or regular Arduino with MYSBootloader?
                  • tekkaT tekka
                    @rvendrame said:
                    Hello everyone,
                    rvendrameR
                    rvendrameR
                    rvendrame
                    @tekka , regular Arduino (pro-mini clone) with MYSBootloader.
                    Alexa / Google Home
                    tekkaT 1 Reply Last reply
                      tekkaT
                      tekkaT
                      tekka
                      @rvendrame can you upload the MYSController log?
                      • tekkaT tekka
                        rvendrameR
                        rvendrameR
                        rvendrame
                        wrote on last edited by rvendrame
                        @tekka , the begin of log is like that:
                        ... and from here on, thousands of repetitions of same messages. It only stops by turning off the power of the node.
                        Alexa / Google Home
                          tekkaT
                          tekkaT
                          tekka
                          @rvendrame the node does not seem to reboot upon initiation of the OTA update (bootloader signal is missing). Can you post the rx log when you power-cycle the node?
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            @tekka , I'm currently traveling so only in two weeks from now. I posted the 'Info' from the node at first post, maybe it helps some how? Bootloader is 'N/A' there, could be something in there?
                            Alexa / Google Home
                              tekkaT
                              tekkaT
                              tekka
                              @rvendrame ok, let's wait until your return.
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                @tekka , @Oitzu , I finally managed to have some time for this.
                                This is the serial monitor output from the node, as soon as I request the FW update via MYSController (it is a endless loop):
                                read: 0-0-9 s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                Device Init...
                                ��Sensor start...
                                send: 9-9-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                                Device Init...
                                ��Sensor start...
                                Device Init...
                                And I tried to upload the new FW via FTDI adapter (in order to test with the repeater function off), however I got an error from avrdude (maybe my pro mini is broken somehow?)
                                         User configuration file is "/Users/i007897/.avrduderc"
                                         Using Port                    : /dev/cu.usbserial-A50285BI
                                         Overriding Baud Rate          : 57600
                                avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
                                avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
                                avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
                                avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe6
                                avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x52
                                avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9f
                                avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe5
                                avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd2
                                avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x43
                                avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd7
                                avrdude done.  Thank you.
                                Alexa / Google Home
                                • OitzuO
                                  OitzuO
                                  Oitzu
                                  @rvendrame the mysbootloader doesn't support serial upload.
                                  Use an ISP to upload a new sketch.
                                    Device Init...
                                    ��Sensor start...
                                    Device Init...
                                    ��Sensor start...
                                    Device Init...
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @rvendrame This issue does not seem to be related to MYSBootloader since the log does not show bootloader messages. However, your node seems re-initializing (but not rebooting) over and over. Try changing the hardware (MCU & nRF) and update to the latest (non-dev branch) framework for further testing.
