  3. Repeater and motion
Repeater and motion
4 Posts 3 Posters 1.9k Views 1 Watching
  • I
    I
    insomnia
    The sketch works only it is sending the motion every second. I only want the sensor to send if there is motion. Who can help me with the code?
    // Initialize motion message
      // The third argument enables repeater mode.
      gw.begin(NULL, AUTO, true);
      gw.sendSketchInfo("Motion Sensor/Repeater", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      // By calling process() you route messages in the background
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    DwaltD 1 Reply Last reply
    • sundberg84S
      sundberg84S
      Is your sensor giving you a HIGH reading all the time?
      • I insomnia
        DwaltD
        DwaltD
        Dwalt
        wrote on last edited by Dwalt
        @insomnia
        Your sketch has the motion sensor sending its status every time through the loop, add a qualifier to only send when the status changes:
          if (tripped != lastTrippedState)
            Serial.println(tripped? "tripped" : "not tripped");
            gw.send(msg.set(tripped?"1":"0"));// Send tripped value to gw//
            lastTrippedState = tripped
        • I
          I
          insomnia
          @Dwalt That was what i needed. It works now :-)
