Sensor reading incorrect
Having a strange problem - got a NodeMCU running with a ESP8266 as the gateway. For a sensor I have a Arduino mini pro with a MQ-2 Gas sensor. The controller is a domoticz.
For the past 12 hours the sensor has been logging fine, 30 mins ago it stopped logged. I then did a update to domoticz after which the gateway started logging data again but the value is incorrect.
Sensor output on com port:
LPG:0ppm CO:0ppm SMOKE:0ppm send: 2-2-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0If I telnet to the esp8266 gateway on port 5003 I can see the data being logged to it but the value is wrong. Its constantly logging 536870912
2;0;1;0;37;536870912This has happened a few times now - restarting the sensor fixes the issue.
After sensor restart:
2;255;3;0;11;Air Quality Sensor 2;255;3;0;12;1.0 2;0;1;0;37;0If the sensor reboot fixes the issue it looks like this is the problem. But looking at the com port info the correct data is being sent.
Any ideas on this one?
Could be a power issue. I've had it with one of my sensor. When I powered the sensors directly from the adapter (instead of the Arduino) my problems were solved.
Tried powering the sensor from a seperate supply. I seem to be having endless stability issues with getting this working.
LPG:0ppm CO:0ppm SMOKE:0ppm send: 2-2-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0 0 LPG:0ppm CO:0ppm SMOKE:0ppm send: 2-2-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0 0 LPG:0ppm CO:0ppm SMOKE:0ppm send: 2-2-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0 0 LPG:0ppm CO:0ppm SMOKE:0ppm send: 2-2-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0The sensor starts of ok - logs to the gateway and onto Domoticz. After a random time it just stops logging now. I'm still seeing the st=ok from the sensor. Does this mean its been successfully sent to the gateway? Could the issue be from the gateway to domoticz?
Something similar was discussed in this thread regarding integers passing from arduino to ESP. I don't know if it was resolved. I do not use ESP myself.
I found the ESP8266 rock stable - been running for around 2 weeks so far. No issues.
The issue above also seems to be fixed - been about 24 hours now, no crashes, no odd values.
Update: Just done a update to Domoticz and now the value is incorrect and seems to be stuck there.
Sensor debug:
0 LPG:0ppm CO:0ppm SMOKE:0ppm send: 1-1-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0Controller log:
subtype = Voltcraft CO-20 CO2 = 536870912 ppm Quality = Bad 2015-11-08 21:29:09.177 (ESP8266 Gateway) Air Quality (Air Quality1)This is the 2nd time its happened right after a domoticz update (I'm running the dev build)
Could this be a issue with domoticz? Its weird how it only does it now after a update. To fix it however I need to reset the sensor.
