  3. My Slim 2AA Battery Node
498 Posts 71 Posters 607.9k Views 69 Watching
  • F
    F
    frenchclem
    @GertSanders @m26872
    Thanks guys for the good work I just ordered your boards
    Will definitely let you know how things goes
    GertSanders, did you find a nice box for your board + battery ?
    • GertSandersG
      GertSandersG
      GertSanders
      #27
      @frenchclem Not yet, the height is indeed the limiting factor. I'm now looking for a small box that can hold the sensor on it's side. SO for the moment the sensors are scattered around the house without a box around them (usually in places where the cat does not go or could find them).
      • F
        F
        frenchclem
        @GertSanders thats what I was worried about. What is the height of the sensor + battery ?
        • GertSandersG
          GertSandersG
          GertSanders
          #29
          @frenchclem
          I can not measure that now (at work), but I guess around 35mm if batteries are mounted on he bottom. By using the extrnal (JST connector) power option, the height of PCB, processor and radio is around 22mm I think.
          Most boxes have an internal clearance of around 20-25mm.
          Some boxes have 40mm internal clearance and are good in height, but those are usually also to long and wide for my taste.
          @m26872 's board certainly is lower, since batteries are not on the bottom but in the axis of the board. The radio is also directed away from the processor on his board, so it can be mounted lower (directly on PCB instead of on a header). I really like that concept, since it will fit the plastic cableducts made by Legrand:
          http://www.ecataleg.be/fr/categorie/3020/moulure-et-goulotte-murale-en-pc-abs-sans-halogene
          • GertSandersG
            GertSandersG
            GertSanders
            @frenchclem
            Just to confirm: 35mm is the height with the small radio.
            Using the larger radio (with PA+LNA) you need 41mm height
            Without battery holders, and the small radio, the height is 22 mm
            Width is 25mm for AAA battery holders mounted, 33mm for AA battery holder, and length is 53mm (AAA batteries) and 58mm (AA batteries)
            • m26872M
              m26872M
              m26872
              v1.2 tested and working. But the design of crossing R1 and C2 was a horrible choice - it's impossible to fit both nicely under/inside the uC socket. Perhaps possible with a 1/8W R1, but otherwise R1, C2 or both must be placed on bottom side.
              Good news is that all versions and orders are OK apart from this little inconvenience.
              I'll try to make a better version ASAP.
              AWIA 1 Reply Last reply
              • m26872M m26872
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #32
                @m26872 I have assembled 6 boards now and am very happy with the design. I use strips as a socket for the Atmega. This leaves enough room for components under it. Also made one with SPI connector. Works perfect! Thank you for sharing the design and instructions.upload-422d1df5-f52b-46fd-b28c-67493daa9fdc upload-aea4bc1e-e16a-4881-a378-e609a6c2f0c8
                m26872M 1 Reply Last reply
                • AWIA AWI
                  m26872M
                  m26872M
                  m26872
                  @AWI Great idea with the strips! And thanks for verifying (v1.2?).
                  • m26872M
                    m26872M
                    m26872
                    wrote on last edited by m26872
                    #34
                    I've now ordered yet another prototype version (1.4):
                    http://dirtypcbs.com/view.php?share=13310&accesskey=58c87fe605eb91958938f70b5efc8629
                    Eagle brd-file.
                    Photo here.
                    • m26872M
                      m26872M
                      m26872
                      I bought a few enclosures... "mini trunking" seems to be the correct term. This time it was ABS and a little more clear white colour and glossy finish. I think I spent around 2hrs cutting them nicely into >200pcs. 50% 23cm and 50% 19cm lengths.
                      • DidiD
                        DidiD
                        Didi
                        You want to make your town mysensors :joy:
                          @m26872
                          200pcs!! What the heck are you up to?
                          • m26872M m26872
                            AWIA
                            AWIA
                            AWI
                            @m26872 I think I used version 1.1? Did you change any of the wiring in the newer versions?
                              @m26872
                              m26872M
                              m26872M
                              m26872
                              @hek
                              hehe, I had a hunch it'd be spectacular. Let's just say that I aim to have a few single sensor/purpose sleeping nodes, but probably not 200. At least not in a while.
                              • AWIA AWI
                                m26872M
                                m26872M
                                m26872
                                @AWI Ops sorry, I meant v1.0. I see the larger pads in your pics. The routing is a little different to 1.2 and 1.4. Mostly related components under the uC.
                                • A
                                  ar91
                                  Very nice design. Any video on installation of bootloader with various settings described in the original post?.
                                  • A ar91
                                    m26872M
                                    m26872M
                                    m26872
                                    #42
                                    @ar91 Thx. Sorry no. I don't know of any and I'm too shy to do it myself.
                                    • ahmedadelhosniA
                                      ahmedadelhosniA
                                      ahmedadelhosni
                                      Great idea using this housing.
                                      Why didn't you use CR batteries to decrease size ?
                                      http://www.digikey.com/product-detail/en/CR1220/P033-ND/269740
                                      • mfalkviddM
                                        2AA batteries have approximately 2000mAh capacity. CR1220 has 35mAh. So for the same capacity, more than 50 CR1220 would be needed. That wouldn't save space :)
                                        But CR1220 has lower self-discharge so they can be a good alternative for things that are really low-power, or don't need long battery life.
                                          m26872M
                                          m26872M
                                          m26872
                                          #45
                                          @ahmedadelhosni I've read a few reports from people with radio module issues after some time on CR "coin cell" batteries. The expected battery life time then doesn't match the result. I think you can find references by searching.
                                          12.5k
