  3. Vera Edge
Vera Edge
14 Posts 6 Posters 6.6k Views 2 Watching
  • Dave DanD
    Dave DanD
    Dave Dan
    hey @stevebus,
    I see in your signature you are posting data from your environment to Azure ... can you please share how are you doing that? I was planning investigate this and include PowerBI to 'dashborize' some results :)
    • C
      C
      csa02221862
      Is anyone else having serial gateway issues, this concerns me.
      • stevebusS
        stevebusS
        stevebus
        @Dave-Dan - I actually haven't finished the Azure integration yet :-). I was working on it, but had some distracting other stuff come up. Essentially the short version of how I plan to do it is to is write an app, probably a Windows Universal app to run on a Raspberry PI that leverages the Vera APIs as described here -> http://wiki.micasaverde.com/index.php/UI_Simple. The app will basically do a long poll waiting on events to happen on Vera, capture them, convert them to a canonical JSON format, and post them to Azure IoTHub. From there, I'll probably leverage Azure Steam Analytics for real time alerting, data aggregation, etc, but also to push the data to a PowerBI dashboard. That's my plan, anyway :-). Just gotta find time to write it. I've started the code that calls the APIs, but just haven't finished...
        @csa02221862 - I've asked a few times and have yet to find anyone who has a serial gateway working on the Vera Edge with UI7 specifically (other Vera devices, and UI versions, yes, but not the Edge/UI7 combination). I gave up, even after working with Vera support to make it work, and use an Ethernet gateway. Doesn't mean it can't be done, just wasn't worth the investment after I finally got my Ethernet gateway to be pseudo-stable.
        Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
        Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
        • clio75C
          clio75C
          clio75
          @csa02221862
          I have Vera Edge working with serial Gateway.
          Mainly reading 4 temperature/humidity nodes and turning on and of my bathroom ventilation.
          Mode Nodes to come in near future ;)
          The setup seams find to me
          • stevebusS
            stevebusS
            stevebus
            Thanks @clio75 - that's good to hear. Are you using the Serial GW sketch pretty much unchanged and the UI7 branch of the files? I assume you had to open a ticket with Vera to get the USB port enabled on the Edge? I did that, and was in the process of trying to get the serial GW working, when a Vera update turned right around and disabled my USB port again...
            • Dave DanD
              Dave DanD
              Dave Dan
              I'm using the Serial GW with no change from the web site. Didn't have to call Vera Support for anything. Happy to share version numbers, etc. if you want ( and if you tell me where to find them :P) but sounds little odd you have poblems and I don't.
              I'm starting to think I should be thinking about moving to Ethernet GW ...
                It probably depends on the FTDI chip on the nano. Vera only has support for genuine (or clones presenting themselves as one).
                • stevebusS
                  stevebusS
                  stevebus
                  thanks guys - good discussion.
                  @hek - is there a reliable way to tell if the FTDI chip is genuine? I believe I bought it from the link on the mysensors site, but it's possible I didn't. Are those known to be genuine? if so, maybe I'll rebuy and retry. I'd rather have a serial GW if I can get it working.
                  @Dave-Dan - it seems that a long of the Vera Edge devices (mine included) come with the USB port disabled (because apparently MCV has had trouble making them work). It's a big topic on the MCV forums. I had to engage Vera support to even get my port enabled the first time I tried a serial GW. (it's disabled again right now, after the latest FW update... sigh...)
                    I can't guarantee anything.. The sellers change their sources from time to time. Suggest you search for "Nano FTDI genuine" on ebay/aliexpress.. If they aren't when they arrive just open a dispute with the seller.
                    Or buy a genuine Nano :)
                    Or build an ESP8266 gateway...
                    • stevebusS
                      stevebusS
                      stevebus
                      Thanks Hek - the ESP8266 gateway was already on the list to investigate... so much cool stuff to do, so little time :-)
