  3. Guide: Setting up and testing MQTT Client Gateway
78 Posts 18 Posters 64.6k Views 18 Watching
    Not the same type of ack. This is the one sent automatically by the NRF radio. You can't disable it in sketch.
      Mike Cayouette
      I have tried a few things but without success, I keep getting the following output on the gateway when I try to send a message to a sensor
      0;0;3;0;9;send: 0-0-0-106 s=3,c=1,t=2,pt=0,l=1,sg=0,st=fail:0
      Oddly the sensors have no problem sending a message to the gateway. For example when I reset my dimmer the serial output on the gateway is the following
      ;0;3;0;9;read: 106-106-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
      0;0;3;0;9;Sending message on topic: mygateway1-out/106/255/0/0/17
      0;0;3;0;9;read: 106-106-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
      0;0;3;0;9;Sending message on topic: mygateway1-out/106/255/3/0/6
      I have used an external power supply rather than connect the radio to the 3.3v pin on the nodemcu breakout board but that did not change anything, I also added the following but without luck
      The only thing I have not done was compile the sensor with the library in the dev branch, but I was under the impression I did not need to.
      Thank you,
      Mike
      • M Mike Cayouette
        Thank you,
        Mike
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @Mike-Cayouette Can you check what I have found and tell me whether it temporary solved your problem or not ? http://forum.mysensors.org/topic/2193/gatewayesp8266mqttclient-in-development-branch/11
          Mike Cayouette
          wrote on last edited by Mike Cayouette
          @ahmedadelhosni That worked, I can now send messages from my gateway.
          Thank you for your help
          Mike
          • M Mike Cayouette
            Mike
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @Mike-Cayouette Glad that it worked. Please note that these would be temporary workarounds for MQTT support only. I guess that won't work if the sensor node is far away from the gateway and needs a repeater in the middle, because in that workaround you don't check your look up table.
              Mike Cayouette
              @ahmedadelhosni I have not had to add any repeaters to my network yet so I should be good until a more permanent solution is worked into the library. Thank you again for you solution.
              @hek Do you expect a more permanent fix for this solution to be pushed to the dev branch?
              Thank you,
              Mike
                Ok, verified sending a message to a node here now when repeater mode is enabled. Works fine and message is received.
                Here is the change I made. Soon merged into development.
                https://github.com/mysensors/Arduino/pull/251
                • L
                  L
                  Lars65
                  Great work. I use an ESP8266 12E, and it works just fine. :)
                  • JohnJ
                    JohnJ
                    John
                    All though this topic is related to the development branch, has the topic structure been fixed (except for prefix)?
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      @hek What about the first issue which I reported about ? Still returns TRUE and returns.
                      if (strcmp_P(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0) {
                      	// Message not for us or malformed!
                             	return;
                      Is it reproducible at your side ?
                      hekH 1 Reply Last reply
                               	return;
                        @ahmedadelhosni
                        No, I couldn't reproduce any problems with topic naming.
                        I use the default subscribe/publish prefix in the sketch and can send messages without any problem.
                          (this post currently applies to the development branch)
                          You can run the MQTT gateway on an Arduino+W5100 ethernet module or the ESP8266. Connect radio and ethernet module exactly like for the normal gateway.
                          Download and install the MySensors development branch
                          The use one of the following sketches depending on the hardware you use:
                          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
                          or
                          The topic resembles the serial protocol. You must define you preferred subscribe and publish prefix in the sketch. The topic is build like this:
                          MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
                          Read more about the serial protocol here. An example topic for data received from your gateway could look like this:
                          mygateway1-out/2/1/1/0/49
                          If you want to send data to your sensors use MY_MQTT_SUBSCRIBE_TOPIC_PREFIX defined in your sketch. Should be looking like this (using default sketch):
                          mygateway1-in/2/1/1/0/49
                          You can test your gateway using mosquitto as broker.
                          Make sure to set MY_IP_GATEWAY_ADDRESS in gateway pointing to you computers ip-number (on the same lan).
                          Start the broker (leave this running):
                          > mosquitto
                          Now start your gateway and you should see something like this in the gateway log. Note that I have a GPS sensor running in my radio network which send data to the gateway all the time:
                          0;0;3;0;9;MQTT connected
                          0;0;3;0;9;read: 2-2-0 s=1,c=1,t=49,pt=0,l=22,sg=0:55.722519;13.018120
                          0;0;3;0;9;Sending message on topic: mygateway1-out/2/1/1/0/49
                          0;0;3;0;9;read: 2-2-0 s=1,c=1,t=49,pt=0,l=22,sg=0:55.722519;13.018121
                          Subscribe to messages (in another shell on your computer)
                          > mosquitto_sub -v -t 'mygateway1-out/#'
                          You should see the messages like you saw in the gateway-log showing up like this:
                          mygateway1-out/2/1/1/0/49 55.722519;13.018121;13
                          mygateway1-out/2/1/1/0/49 55.722519;13.018114;12
                          mygateway1-out/2/1/1/0/49 55.722527;13.018120;11
                          mygateway1-out/2/1/1/0/49 55.722534;13.018122;10
                          Sending (publishing) messages to your sensor network:
                          > mosquitto_pub -t 'mygateway1-in/2/1/1/0/49' -m '0,29'
                          Samuel235
                          Have we managed to get a MQTT Gateway working on a Arduino with an ENC28J60 module rather than a w5100?
                          MySensors 2.1.1
                          hekH ahmedadelhosniA 2 Replies Last reply
                          • S Samuel235
                            @samuel235
                            I didn't bother trying. The ENC-library is gigantic and the MQTT implementation used does not support the ENC-module.
                            S 2 Replies Last reply
                            • S Samuel235
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @samuel235 I don't really encourage you to use ENC. I spent months trying to make it stable and I failed. There are several manufactures and as far as I know that there are several software workarounds to fix problem in the silicon chips. I turned to use W5100 and it is much better till now.
                              N.B.: Some people managed to run ENC with good stability but as I have said, there may be different manufacturers so I got confused and tried the W5100.
                                Samuel235
                                @ahmedadelhosni I have now turned to the W5100 shield myself. Works a charm, super smooth!
                                MySensors 2.1.1
                                • V
                                  V
                                  vickey
                                  I tried to make MQTT client gateway but it is giving following error while compiling
                                  C:\Users\Ahmed\AppData\Local\Temp\build8359488613260197686.tmp/arduino.ar(core_esp8266_postmortem.c.o): In function `abort':
                                  C:\Users\Ahmed\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.0.0-rc2\cores\esp8266/core_esp8266_postmortem.c:177: multiple definition of `abort'
                                  GatewayESP8266MQTTClient.cpp.o:C:\Users\Ahmed\Documents\Arduino\libraries\MySensors/core/MyMainESP8266.cpp:46: first defined here
                                  Error compiling.
                                  Any suggestions @hek ?
                                    @vickey
                                    Sorry haven't seen this error. Which ESP board version do you have installed in the IDE? (See Board manager).
                                    Please do no double post on the forum! Only creates annoyance.
                                    • V
                                      V
                                      vickey
                                      @hek I am using Stable ESP8266 version 2.0.0 from stable release
                                      • C
                                        C
                                        ciprian
                                        If it helps:
                                        in ESP8266 ver. 2.0.0 was added abort in
                                        here
                                        cores/esp8266/core_esp8266_postmortem.c:
                                        void abort() __attribute__((noreturn));
                                        void abort(){
                                            // cause exception
                                            s_abort_called = true;
                                            do {
                                                *((int*)0) = 0;
                                            } while(true);
                                        i comment the lines in MySensors/core/MyMainESP8266.cpp and it compiled ok.
                                          @ciprian
                                          This has been fixed since a while back.
