  3. Antenna 101
Antenna 101
27 Posts 9 Posters 23.6k Views 3 Watching
  • A
    a-lurker
    wrote on last edited by a-lurker
    There are all sorts of magical antenna shapes - a few examples here:
    http://www.ti.com/lit/an/swra351a/swra351a.pdf
    The PCBs with the zigzag shape
    http://www.barefootelectronics.com/nordicc.png
    are probably a "meandering inverted F antenna" similar to this one:
    http://www.ti.com/lit/an/swra117d/swra117d.pdf
    The PCBs with the seven shaped antenna is probably just a 1/4 wave monopole bent to make it less sensitive to polarization?
    http://www.barefootelectronics.com/NordicA.jpg
    Hard to say what the rubber ducks use unless pulled apart. It's easy to just assume they are all interchangeable. They aren't - they are designed specifically for the frequency to be used. This one is a dipole with the associated doughnut radiation pattern:
    http://martybugs.net/wireless/rubberducky.cgi
    DammeD 1 Reply Last reply
    • A a-lurker
      DammeD
      DammeD
      Damme
      Code Contributor
      wrote on last edited by Damme
      @a-lurker Nice post!
      I can report that I changed the SMA antenna that came with the songle with a +8db gain 2.4ghz wlan antenna and the signal died out completly, I think I'll will dissect the original antenna just to look why the bigger one didnt work at all..
      maybe that's your problem @clippermiami ? try the old module but with the working antenna.
      clippermiamiC Z 2 Replies Last reply
      • DammeD Damme
        clippermiamiC
        clippermiamiC
        clippermiami
        @Damme Possible. But now I have another problem, the USB port has died so I no longer have access to the Gateway :-) Yet another opportunity :-)
        • DammeD Damme
          Z
          Z
          Zeph
          I don't know why it didn't work, but even it it had, I'd be wary of a +8db gain antenna in this application. The gain comes with the tradeoff of a narrower beam and more directionality, and for home automation I don't want that.
          • DammeD
            DammeD
            Damme
            Code Contributor
            I have started building up lots of nodes and don't even use a cap any longer. The problem I had with reception is purely because long cables. now I'm using <2cm and have no problems at all.
            • DammeD Damme
              You mean the SPI connection between MPU & nRF24 I assume?
              • YveauxY Yveaux
                DammeD
                DammeD
                Damme
                Code Contributor
                @Yveaux yep!
                • petewillP
                  petewillP
                  petewill
                  I posted about this earlier but I think it was lost.
                  Disclaimer: I am no expert but this seems to be working for me... I have been experimenting with adding a wire to my regular nRF24L01 radio chips. I have the chips with the zig zag patteren. Based on some limited reading the wavelength is of 2.4 GHz is 4.92 inches (http://www.antenna-theory.com/definitions/2p4GHzAntenna.php). I did some rough measurements of the zig zag pattern with micrometer and found that the length is about 1.64 inches. So, based on that I soldered a 3.28 inch piece of CAT5e to the end of the zig zag pattern.
                  I had a new node that I installed on Sunday night that wasn't communicating with the gateway at all. I replaced the nRF24L01 with my modified one on Monday night and it has been communicating perfectly all night.
                  I should probably note that my new node had the radio zig zag pattern parallel to the ground which may have also caused some of the communication problems. I wasn't able to easily move the orientation because of how it was mounted, so the antenna was a quick test that appears to have solved the problem.
                  I have another node in which I have achieved similar results in a totally different part of my house.
                  Note: this also seems to be working for other people. See the comments of this blog post:http://harizanov.com/2013/06/nrf24l01-range-testing/
                  Based on the above post the PA+SMA antenna still has better range, but the CAT5 hack is much cheaper :)
                  I'd be interested to hear if this works for anyone else.
                  Pete
                  Z 1 Reply Last reply
                  • petewillP petewill
                    Pete
                    Z
                    Z
                    Zeph
                    wrote on last edited by Zeph
                    @petewill
                    I'm glad you resurfaced that lost discussion.
                    Did you take a look at the references posted by @a-lurker about magical antenna shapes? A device similar to the zig-zag nRF was well measured in different planes and polarization and it'a all over the board - peaks and nulls in all sorts of directions.
                    But the zigzag isn't a random thing, it's carefully computed for a given wavelength and impedance. When you are bending and splitting and changing trace widths, the linear length for best matching is no longer as simple to compute as with a simple wire antenna. It's not that they forgot to add the last 3.28 inches, it's that their computations told them they had already reached a good compromise for coverage and making it longer would make it worse.
                    It's still surprising that soldering a loose wire to some location along the zig-zag so substantially improved your antenna performance. I still suspect some luck was involved, and I would not suggest it unless other solutions didn't work or were not available (eg: changing the antenna orientation). But if it works sometimes (not rarely), then it's useful on the practical level (and a fun puzzle on the theoretic level).
                    And I'd love to hear the take that better antenna experts than I have on your experience.
                    I am reminded of my youth, when people would hang aluminum foil fragments on the coat hanger substituting for the broken half of rabbit ears for the TV, and then try all sorts of positions for both ears, seeking better reception. :-) To the degree that this worked (vs just giving a perception of doing something) it was based on doing all that random adjustment while watching the picture and stopping in the best configuration.
                    petewillP epierreE 2 Replies Last reply
                    • Z Zeph
                      @petewill
                      petewillP
                      petewillP
                      petewill
                      @Zeph Yeah, I'm definitely open to the possibility of dumb luck. I feel that's how I've built my whole sensor network. :) I hope that I will get a better understanding of things as I keep learning but for now it is mostly trial and error.
                      I have a feeling the bad signal could probably have been corrected by changing the orientation of the radio but soldering one wire was MUCH faster so I thought I'd give it a shot. It has been working flawlessly since I made that change. Luck or whatever, I'm happy... :)
                      • Z Zeph
                        @petewill
                        epierreE
                        epierreE
                        epierre
                        @Zeph a zigzag with 10dB and mesured 2 km range: Long range RF link using NRF24L01+ RF Transceiver
                        z-wave - Vera -> Domoticz
                        • DammeD Damme
                          Hello guys!
                          I am no expert at antennas but I realize some of you have really bad reception.
                          I got ~450 meters between my nrf24l01+ap and a regular nrf24l01, and this through the house (concrete + wood) and through a forest.
                          There are some things to take in count;
                          Antenna orientation, if your gateway (with external antenna) is pointing straight up you have a vertical polarization of your transmission, this basically means that your nodes will work best if they also are vertical.
                          The radiation-pattern from the external antenna looks like this: http://commons.wikimedia.org/wiki/File:Short_dipole_radiation_pattern.gif
                          This means in a ideal location with no walls and you were floating in space you basically don't have any reception at all straight above or below the gateway. but since radio waves also reflect from objects you just have very poor reception in the real world.
                          And looking at the radiation-pattern you'll see that you have the best reception in the blue circles. (and the antennas on your internet router should be pointing straight up if you dont have a multi floor building.)
                          And because the radio waves reflect, the distance to cables, metal and ground-plane on a pcb matters a lot, if you have wrong distance, you can cancel out the signal almost completely, and you could actually amplify the signal in one direction by having the correct distance. (1/2 wave length = ~61mm if I'm not totally lost today) This is how parabolics works.
                          Well this is just a very short beginners knowledge and please, correct me and fill in missing facts. I just wanted to get the topic started.. :)
                          //Damme
                          DammeD
                          DammeD
                          Damme
                          Code Contributor
                          Lol
                          I just realized why my wlan-antenna didn't work..:+1: IMG_20140805_153548.jpg
                          • DammeD Damme
                            Lol
                            @Damme ;-)
                            • DammeD Damme
                              Hello guys!
                              //Damme
                              DammeD
                              DammeD
                              Damme
                              Code Contributor
                              I did some testing and analyzing of my microwave RF band.. (hehe)
                              Channel 76 which is 2476Mhz. and is between wlan channel 13 and 14.
                              My microwave oven destroys channel 7 - 13 almost completely (2462 - 2472) and affects 6 and 14 too. so a total of 2437 - 2484 mhz is mangled up (Surprises me a bit. And this is no cheap brand, its a quality micro wave, and the cheap one I have in the trash is even worse..)
                              Me myself uses wlan 802.11n (40mhz channels) on ch1. so freq 2400 - 2442 is full also., so the best choice is actually using nrf24 channel above ch 85 in my case (and probobly others too). Could be good to know in future choice of default channel.
                              • DammeD Damme
                                #25
                                @Damme Or stay away from the microwave; better for you health too :feelsgood:
                                Post #200 -- Yeah baby !
                                • daulagariD
                                  daulagariD
                                  daulagari
                                  wrote on last edited by daulagari
                                  #26
                                  @Damme Just wondering, how did you analyze your 2.4 GHz band?
                                  Here I read the typical levels of radiation leakage from microwave ovens is about 0.2 mW/cm², which is roughly equivalent to a point source of 6 dBm.
                                  Is your microwave oven maybe leaking? According to this site you can test it placing your laptop in the microwave oven, close the door ... (do not turn the microwave on) and see if you can still ping it ;-)
                                  • daulagariD daulagari
                                    DammeD
                                    DammeD
                                    Damme
                                    Code Contributor
                                    @daulagari I had the chance of borrowing a hand held RF spectrum analyzer for a very short while (2h) I would love to do some more scientific measurements on all my transmitting apparatus.. :)
