  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 124.1k Views 4 Watching
    Pushed a few new changes/bugfixes. Sorry for the slow progress. Had to wait until we got home and had the chance to do some verification.
    • Ack bit in header indicating if message is an ack (see RelayWithButton for an example how to read it out).
    • Sleep functions now takes unsigned long. This allows sensor to sleep for than 30 sec ;)
    • Corrected string termination
    https://github.com/mysensors/Arduino/commits/development
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    Thank you :)
    Fulltime Servoy Developer
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      And thanks again!!!
      • T
        timminater
        wrote on last edited by timminater
        #48
        How do I request information from a node from the gateway?
        I have a relayactuator node with 2 relays that is transmitting its initial state at the startup of the node. This is also received by the gw.
        But after that I cant seem to request the current relay status from the node by sending a message from the gateway.
        I tried lots of combinations, nothing worked.
        I thought this would be correct:
        1;2;2;1;2;0\n
        1=node number
        2=sensor (relay number 2)
        2=request
        1=ack message
        2=light
        0=string??
        Can anyone point me in the correct location?
        maybe a new API page for 1.4 would be handy
        edit: also I can't find anywhere what the debug letters mean
        what is s=,c=,t=,pt=,l=,st= ??
        hekH 1 Reply Last reply
        • T timminater
          1;2;2;1;2;0\n
          1=node number
          2=request
          1=ack message
          2=light
          0=string??
          @timminater
          You cannot request state from a node without programming a little . I answered exactly this question a couple of posts back in this thread.
          http://forum.mysensors.org/topic/168/1-4-beta/34
            mitekg
            @hek
            Could u plz help me
            getting in eth GW. Vera and Libs updated.
            **0;0;3;9;Arduino startup complete.
            0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
            0;0;3;9;version mismatch0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
            • M mitekg
              @hek
              Could u plz help me
              @mitekg
              All the zeroes indicates that something is wrong in radio communication. Check wires.
                mitekg
                • The new MySensors Bootloader supporting Over-the-air sketch updates ("client"-side).
                  • A simple NodeJs Controller to test the OTA stuff ("server"-side).
                    Is any instructions, how to use this?
                    thx.
                  The 1.4 version of the MySenors Arduino library is new open for beta testing.
                  Arduino library and examples
                  https://github.com/mysensors/Arduino/tree/development
                  Vera plugin (1.4)
                  https://github.com/mysensors/Vera/tree/development
                  Here are some of the hi-lights.
                  • Improved communication reliability (now uses hardware acks and resend functionality).
                  • Simplified sketches (only one include needed).
                  • Most common sleep scenarios build in.
                  • Helper for permanently storing values in the Arduinos EEPROM.
                  • Acknowledgments can now be requested from gateway and other sensors in network.
                  • Smaller footprint.
                  • The message structure has been adopted to work better on RPi platform.
                  • Binary payloads supported and used for integers between sensors.
                  • Configuration message (only metric setting in it today).
                  • Allow static parent (no dynamic lookups)
                  • Callbacks for incoming messages and time. No synchronous waiting methods any more -> no missed messages.
                  All examples in the development branch above has been converted to use the new functionality of the library.
                  The new API:
                  * Constructor
                  * Creates a new instance of Sensor class.
                  * @param _cepin The pin attached to RF24 Chip Enable on the RF module (defualt 9)
                  * @param _cspin The pin attached to RF24 Chip Select (default 10)
                  MySensor(uint8_t _cepin=9, uint8_t _cspin=10);
                  * Begin operation of the MySensors library
                  * Call this in setup(), before calling any other sensor net library methods.
                  * @param incomingMessageCallback Callback function for incoming messages from other nodes or controller and request responses. Default is NULL.
                  * @param nodeId The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to fetch an id from controller.
                  * @param repeaterMode Activate repeater mode. This node will forward messages to other nodes in the radio network. Make sure to call process() regularly. Default in false
                  * @param parentNodeId Use this to force node to always communicate with a certain parent node. Default is AUTO which means node automatically tries to find a parent.
                  * @param paLevel Radio PA Level for this sensor. Default RF24_PA_MAX
                  * @param channel Radio channel. Default is channel 76
                  * @param dataRate Radio transmission speed. Default RF24_1MBPS
                  void begin(void (* msgCallback)(const MyMessage &)=NULL, uint8_t nodeId=AUTO, boolean repeaterMode=false, uint8_t parentNodeId=AUTO, rf24_pa_dbm_e paLevel=RF24_PA_LEVEL, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE);
                   * Return the nodes nodeId.
                  uint8_t getNodeId();
                  * Each node must present all attached sensors before any values can be handled correctly by the controller.
                  * It is usually good to present all attached sensors after power-up in setup().
                  * @param sensorId Select a unique sensor id for this sensor. Choose a number between 0-254.
                  * @param sensorType The sensor type. See sensor typedef in MyMessage.h.
                  * @param ack Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                  void present(uint8_t sensorId, uint8_t sensorType, bool ack=false);
                   * Sends sketch meta information to the gateway. Not mandatory but a nice thing to do.
                   * @param name String containing a short Sketch name or NULL  if not applicable
                   * @param version String containing a short Sketch version or NULL if not applicable
                  void sendSketchInfo(const char *name, const char *version, bool ack=false);
                  * Sends a message to gateway or one of the other nodes in the radio network
                  * @param msg Message to send
                  * @return true Returns true if message reached the first stop on its way to destination.
                  bool send(MyMessage &msg, bool ack=false);
                   * Send this nodes battery level to gateway.
                   * @param level Level between 0-100(%)
                  void sendBatteryLevel(uint8_t level, bool ack=false);
                  * Requests a value from gateway or some other sensor in the radio network.
                  * Make sure to add callback-method in begin-method to handle request responses.
                  * @param childSensorId  The unique child id for the different sensors connected to this Arduino. 0-254.
                  * @param variableType The variableType to fetch
                  * @param destination The nodeId of other node in radio network. Default is gateway
                  void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination=GATEWAY_ADDRESS);
                   * Requests time from controller. Answer will be delivered to callback.
                   * @param callback for time request. Incoming argument is seconds since 1970.
                  void requestTime(void (* timeCallback)(unsigned long));
                   * Processes incoming messages to this node. If this is a relaying node it will
                  * Returns true if there is a message addressed for this node just was received.
                  * Use callback to handle incoming messages.
                  boolean process();
                   * Returns the most recent node configuration received from controller
                  ControllerConfig getConfig();
                   * Save a state (in local EEPROM). Good for actuators to "remember" state between
                   * power cycles.
                   * You have 256 bytes to play with. Note that there is a limitation on the number
                   * of writes the EEPROM can handle (~100 000 cycles).
                   * @param pos The position to store value in (0-255)
                   * @param Value to store in position
                  void saveState(uint8_t pos, uint8_t value);
                   * Load a state (from local EEPROM).
                   * @param pos The position to fetch value from  (0-255)
                   * @return Value to store in position
                  uint8_t loadState(uint8_t pos);
                  * Returns the last received message
                  MyMessage& getLastMessage(void);
                   * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer.
                   * @param ms Number of milliseconds to sleep.
                  void sleep(int ms);
                   * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer or pin change.
                   * See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin
                   * is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
                   * @param interrupt Interrupt that should trigger the wakeup
                   * @param mode RISING, FALLING, CHANGE
                   * @param ms Number of milliseconds to sleep or 0 to sleep forever
                   * @return true if wake up was triggered by pin change and false means timer woke it up.
                  bool sleep(int interrupt, int mode, int ms=0);
                   * getInternalTemp
                   * Read temp from internal (ATMEGA328 only) temperature sensor. This reading is very
                   * inaccurate so we round the result to full degrees celsius.
                   * http://playground.arduino.cc/Main/InternalTemperatureSensor
                   * @return Temperature in full degrees Celsius.
                  int getInternalTemp(void);
                  ###To convert an old 1.3 sketch follow this guide:
                  Include section
                  Remove the following includes
                  #include <Sleep_n0m1.h>
                  #include <EEPROM.h>
                  #include <RF24.h>
                  #include <Sensor.h>
                  #include <Relay.h>
                  Add
                  Global variable scope
                  Change the following lines
                  Sensor gw;
                  or
                  Relay gw;
                  To
                  Also message containers for outgoing messages. E.g. Light level message for child sensor id 1.
                  MyMessage msg(1, V_LIGHT_LEVEL);
                  ####Setup()
                  In setup() replace sendPresentation with present.
                  Also note that begin() now allows you to add an function-argument to get callbacks for incoming messages (actuators). begin also controls wether this node should act as an repeater node. See above for full argument list.
                  ####Loop()
                  The sending of values looks a bit different. The old sketches could look like this:
                  gw.sendVariable(CHILD_ID_LIGHT, V_LIGHT_LEVEL, lux);
                  In new code you send a value by using the MyMessage contaner defined in global scope. Fill it with the value to send like this (where lux is light level in this case).
                   gw.send(msg.set(lux));
                  Replace any sleeping with the new build in sleep functions. The old code might have a few lines like this:
                  delay(500);
                  gw.powerDown();
                  sleep.pwrDownMode(); //set sleep mode
                  sleep.sleepDelay(SLEEP_TIME * 1000);
                  Replace those with:
                  gw.sleep(<sleep time in milliseconds>);
                  DammeD
                  DammeD
                  Damme
                  Code Contributor
                  @hek
                  I think BASE_RADIO_ID should be declared in MyCofig.h
                    Vera plugin (1.4)
                    The new API:
                    * Constructor
                    boolean process();
                     * power cycles.
                    void sleep(int ms);
                     * getInternalTemp
                    Include section
                    #include <EEPROM.h>
                    #include <RF24.h>
                    #include <Sensor.h>
                    #include <Relay.h>
                    Add
                    Sensor gw;
                    or
                    Relay gw;
                    To
                    ####Setup()
                    ####Loop()
                    delay(500);
                    gw.powerDown();
                    Replace those with:
                    Z
                    Z
                    Zeph
                    wrote on last edited by Zeph
                    #54
                    @hek @ToSa
                    Could we get a description of how the OTA programming works?
                    (Terminology: the program flash is divided into a bootloader section and an application section; compile sketches go in the application section)
                    One approach is to have a separate flash or eeprom chip which one somehow fills (this could even happen at the application level). When booting, check this flash or eeprom and if valid - load into internal program flash, clear the vallidity of the external flash or eeprom (so you won't loop loading it again) and reboot. When you reboot there will be no valid image to copy from external memory, so you jump to the start of internal application flash. This takes external flash as large or larger than application flash (eg: >= 32 KiB for the 328p)
                    I think you are taking a different route, where the bootloader is somehow given control, after which it receives nRF packets to RAM, periodically writing another page from RAM to the application section of internal flash. When done, reboot.
                    If booting and there is no valid image in external memory and the CRC of the internal application flash section is valid, jump to it as usual.
                    I'm not sure if you can also still use serial programming.
                    This could be all wrong. It implies keeping (at least part of) the nRF library in bootload program flash, to receive packets. I'm putting it out as a hypotheis to help elicit the real description.
                    How big is the OTA bootloader?
                    • DammeD Damme
                      @hek
                      Yes, that's a better place for it.
                      • Z Zeph
                        @hek @ToSa
                        @Zeph, @mitekg
                        Right now the OTA works without any need for external flash. @ToSa will have to answer the details when he's back (like size, building, serial programming).
                        Yes it uses a VERY stripped down rf24 library.
                        https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloaderRF24.h
                        Not much of the MySensors library is needed.
                        https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloader.c
                        • joe.kJ
                          joe.kJ
                          joe.k
                          I am in process of upgrading to 1.4b1 - have most things working. I noticed that my status consistently fails during setup() when presenting sensors AND also never receive a return message from controller after a time request. It's always the same two failures.
                          Everything works after adding a 100ms delay between calls. Not sure if there's a timing problem somewhere.
                          Hek - as always thanks for ALL your contributions. :-)
                          Joe K.
                          SERIAL CONSOLE OUTPUT:
                          sensor started, id 4
                          send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=15,st=ok:1.4b1 (18848a2)
                          send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                          send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=11,st=ok:LCD Display
                          send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                          send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=15,st=ok:1.4b1 (18848a2)
                          send: 4-4-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
                          send: 4-4-0-0 s=2,c=0,t=8,pt=0,l=15,st=ok:1.4b1 (18848a2)
                          send: 4-4-0-0 s=255,c=3,t=1,pt=0,l=15,st=fail:1.4b1 (18848a2)
                          CODE in setup():
                          gw.sendSketchInfo("LCD Display", "1.0");
                          gw.present(CHILD_ID_DHT_HUM, S_HUM, true);
                          delay(100); // needed otherwise status may come back as failed
                          gw.present(CHILD_ID_DHT_TEMP, S_TEMP, true);
                          gw.present(CHILD_ID_BMP085_BARO, S_BARO, true);
                          delay(100); // needed otherwise status may come back as failed & time request doesn't work
                          // request time
                          gw.requestTime(receiveTime);
                            Vera plugin (1.4)
                            The new API:
                            * Constructor
                            boolean process();
                             * power cycles.
                            void sleep(int ms);
                             * getInternalTemp
                            Include section
                            #include <EEPROM.h>
                            #include <RF24.h>
                            #include <Sensor.h>
                            #include <Relay.h>
                            Add
                            Sensor gw;
                            or
                            Relay gw;
                            To
                            ####Setup()
                            ####Loop()
                            delay(500);
                            gw.powerDown();
                            Replace those with:
                            DammeD
                            DammeD
                            Damme
                            Code Contributor
                            @hek Does the gateway use any eeprom?
                            • DammeD Damme
                              @Damme
                              Yes, it uses eeprom for storing routing information.
                              DammeD 1 Reply Last reply
                                @Damme
                                DammeD
                                DammeD
                                Damme
                                Code Contributor
                                @hek ok, how many bytes does it use?
                                • DammeD Damme
                                  @Damme
                                  If you want to store you own data in EEPROM you can use the provided saveState(), loadState(). It makes sure you won't overwrite anything important. If 256 bytes isn't enough you can start writing at position EEPROM_LOCAL_CONFIG_ADDRESS defined in MySensors.h.
                                    Vera plugin (1.4)
                                    The new API:
                                    * Constructor
                                    boolean process();
                                     * power cycles.
                                    void sleep(int ms);
                                     * getInternalTemp
                                    Include section
                                    #include <EEPROM.h>
                                    #include <RF24.h>
                                    #include <Sensor.h>
                                    #include <Relay.h>
                                    Add
                                    Sensor gw;
                                    or
                                    Relay gw;
                                    To
                                    ####Setup()
                                    ####Loop()
                                    delay(500);
                                    gw.powerDown();
                                    Replace those with:
                                    DammeD
                                    DammeD
                                    Damme
                                    Code Contributor
                                    wrote on last edited by Damme
                                    #62
                                    @hek I just cant figure this out:
                                    0;0;3;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
                                    0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=2,st=fail:42
                                    the last one isn't sent.What have I missed?
                                    I have also tried 42 as int (no "")
                                    	msg.destination = 255; 		//NodeID
                                    	msg.sender = GATEWAY_ADDRESS;
                                    	msg.sensor = 255;	  				//SensorID
                                    	msg.type = I_ID_RESPONSE;			//MsgType
                                    	mSetCommand(msg,C_INTERNAL); 		//Subtype
                                    	mSetRequestAck(msg,true);			//Request ack
                                    	mSetAck(msg,false);
                                    	msg.set("42");					//Payload
                                    	sendRoute(msg);
                                      Vera plugin (1.4)
                                      The new API:
                                      * Constructor
                                      boolean process();
                                       * power cycles.
                                      void sleep(int ms);
                                       * getInternalTemp
                                      Include section
                                      #include <EEPROM.h>
                                      #include <RF24.h>
                                      #include <Sensor.h>
                                      #include <Relay.h>
                                      Add
                                      Sensor gw;
                                      or
                                      Relay gw;
                                      To
                                      ####Setup()
                                      ####Loop()
                                      delay(500);
                                      gw.powerDown();
                                      Replace those with:
                                      marceltrapmanM
                                      marceltrapmanM
                                      marceltrapman
                                      @hek Do you know if the ota is something initiated by the controller or do we update the gateway with a new version and will the gateway be responsible?
                                        @marceltrapman
                                        The controller will be responsible for initiating and serving the new sketch version. There is basically no changes in gateway except being able to handle binary data.
                                        • DammeD Damme
                                          	mSetAck(msg,false);
                                          	sendRoute(msg);
                                          @Damme
                                          You should probably not request ack back on a id-response. But I doubt that is the cause for transmission error. What is happening in the sensor node?
                                          DammeD 2 Replies Last reply
