  2. Bug Reports
  3. ESP8266: MCU seems to be busy with the WiFi and stops receiving messages from NRF24
8 Posts 4 Posters 3.7k Views
  • nikil511N Offline
    nikil511N Offline
    nikil511
    wrote on last edited by nikil511
    Hello everyone,
    I am using ESP8266 to forward data to the cloud, as described here:
    http://forum.mysensors.org/topic/1973/esp8266-as-wifi-gateway-controller-node/
    My problem is that if I trigger the HTTP post from function incomingMessage() it seems the MCU is busy with the WiFi and it stops receiving messages from nRF. The first, second msg are handled then the others get a fail status. Any advice on how to handle this ? is there a more proper way than what i am doing?
    or is it normal, hence I should manually buffer the messages and do the http post later ?
    here is my code:
    void incomingMessage(const MyMessage & message) {
      Serial.print("Sensor:");
      serial(PSTR("%d;%d;%d;%d;%d;%s\n"), message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type, message.getString(convBuf));
      if (message.type == V_TEMP) {
        sendStrXY(message.getString(convBuf), 3, 10);
      //  thingspeak("3", message.getString(convBuf));
      else if (message.type == V_HUM) {
        sendStrXY(message.getString(convBuf), 4, 10);
      //  thingspeak("4" , message.getString(convBuf));
      else if (message.type == V_PRESSURE) {
        sendStrXY(message.getString(convBuf), 5, 10);
      //  thingspeak("5", message.getString(convBuf));
      else if (message.type == V_WIND) {
        sendStrXY(message.getString(convBuf), 6, 5);
       // thingspeak("6", message.getString(convBuf));
        else if (message.type == V_RAINRATE) {
        sendStrXY(message.getString(convBuf), 6, 12);
      //  thingspeak("7", message.getString(convBuf));
      else if (message.type == V_VAR1) {
       // sendStrXY(message.getString(convBuf), 7, 0);
       // thingspeak("8", message.getString(convBuf));
        else if (message.type == V_VAR2) {
       // sendStrXY(message.getString(convBuf), 7, 5);
        else if (message.type == V_VAR3) {
       // sendStrXY(message.getString(convBuf), 7, 10);
    thingspeak function does a WiFiClient print to url...
    Y 1 Reply Last reply
    • nikil511N nikil511
      Hello everyone,
      here is my code:
      Y Offline
      Y Offline
      @nikil511 I think fail is reported when hardware ack is not received. @hek is this correct?
      If this is the case, ESP is not involved at all...
      Maybe interference between ESP & nRF?
      • H Offline
        H Offline
        Yes, correct.
        • nikil511N Offline
          nikil511N Offline
          nikil511
          so can the GW nRF receive and aknowledge if the GW MCU is busy doing something else ?
          eitherway I will update to latest dev branch, test again with modules on different locations and come back.
            Y Offline
            Y Offline
            Yes! You've built yourself a multi-core system!
            O 1 Reply Last reply
            • Y Yveaux
              O Offline
              O Offline
              Oitzu
              wrote on last edited by Oitzu
              Correct me if i'm wrong but isn't the ack handled in the nrf24l01+ hardware and therefore a busy mcu shouldn't be a problem?
              • O Oitzu
                Y Offline
                Y Offline
                @Oitzu isn't that the same as I'm saying?
                • Y Yveaux
                  O Offline
                  O Offline
                  Oitzu
                  Yes... i misread your post in a way that you suggest he needs to built a multicore system to achive that... i'm sorry. :/
                  12.0k
