  3. Installing MySensors and Arduino IDE on OSX
6 Posts 4 Posters 3.3k Views 1 Watching
  • P
    P
    patrick schaerer
    Hi
    I Installed Arduino IDE 1.0.6 and it works fine. I've compiled and uploaded sketches.
    I installed all the mysensors libraries from 1.5 release and this error happens when I compile and upload (HuniditySensor is just an example it happens on other sketches too):
    In file included from HumiditySensor.ino:31:
    /Users/patrickschaerer/Documents/Arduino/libraries/MySensors/MySensor.h:158: error: expected type-specifier before 'MyHwDriver'
    /Users/patrickschaerer/Documents/Arduino/libraries/MySensors/MySensor.h:158: error: default argument for parameter of type 'MyHw&' has type 'int'
    /Users/patrickschaerer/Documents/Arduino/libraries/MySensors/MySensor.h:158: error: expected ',' before 'MyHwDriver'
    I deleted all the libraries an installed mysensor libraries from 1.4 release. Compiling and uploading works fine on 1.4 release.
    Is there a bug in the 1.5 release or is something wrong with my installation?
    • mfalkviddM
      The 1.5 release should work.
      When you install 1.5, did you first remove all old libraries (for 1.4)? If not, try that.
      • P
        P
        patrick schaerer
        1.5 was a clean install. After that I deleted all libraries and installed 1.4 and it worked with 1.4.
        I tried to install 1.5 libraries over 1.4 but this did not help.
        I took mysensor.h from codebender, but that got even more errors :(
        • GertSandersG
          GertSandersG
          GertSanders
          I use the Arduino 1.6.5 IDE and the development build. Works perfectly for me on El Capitan.
          • P
            P
            patrick schaerer
            ok I installed Arduino IDE 1.6.6 and mysensors 1.5
            Now I can compile, but that IDE version doesn't work with my arduinos :-(
            avrdude: ser_open(): can't open device "/dev/cu.wchusbserial1420": Resource busy
            it seems a known problem with osx and serial bus ... I think I'll compile and upload with the windows pc
            • ErrKE
              ErrKE
              ErrK
              wrote on last edited by ErrK
              I first tried with 1.6.6 but it did not work so now i use 1.6.5.
