  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.8k Views 69 Watching
    @m26872 hmm I see. So i will begin learning Kicad today. Thanks for your effort and support
    m26872M
    m26872M
    m26872
    @ahmedadelhosni
    I uploaded the brd in the v1.4 post above just for completness.
    Happy Kicading! Hope you'll enjoy. I liked it a lot better. There were a few nice youtube tutorials.
    You're welcome.
    • m26872M
      m26872M
      m26872
      First Slim Node board donation from the DirtyPCB board share now sent. $12 to MySensors.org. Thanks to everyone that have ordered.
      Later credit draw will be in probably linger a bit. DirtyPCB seems to be somewhat of a non-profit community with manual attendance to all share credits. I almost got banned in my attempts to get a reply from them. In order to show my appreciation for their great service, I plan to only request further credits in quantities of 50. If the board not's been shared in a year a so, of course I'll make an exception.
        @m26872
        Thanks for the kind donation to the MySensors project. We'll use it to develop new fun things for the community!
        • AWIA
          AWIA
          AWI
          I was out of radio's, only a few "smd" types left which I mounted on the board with some patchwork ;-)
          upload-9bcfc8fe-4f7f-48ba-90dc-31443ed62f89
          Now even more space left in the (small) housing.
          upload-6b158358-0c6f-4983-89d4-16a13f9a87e9
          upload-b3b5aa3b-3e76-4690-a05c-49df931a6df7
          • dakkyD
            dakkyD
            dakky
            Could u show a screen for the lockbits too? I have never set them before and need some guidance :D thanks
            Dakky
            Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
            Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
            Software: MySensors 2.0development
            m26872M bjacobseB 2 Replies Last reply
            • dakkyD dakky
              Dakky
              m26872M
              m26872M
              m26872
              @dakky Done.
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Is this what you used to burn the bootloader?
                USB-programmer-AVRISP-mkII-mk2-clone-ATMEL-AVR-New
                • m26872M
                  m26872M
                  m26872
                  I use this. Maybe not so expensive when I bought it 15 months ago, but still. I remember I was mad after I'd failed a lot with avrdude and cheaper tools (uno).
                    martkrui
                    Just received my boards from DirtyPCB :smile:
                    Enough for 10x3=30 sensors... :scream: The boards look nice. I think I can even skip the R&C's if I use the internal VCC measuring method but I'll have to scan the thread for that.
                    m26872M 1 Reply Last reply
                    • M martkrui
                      m26872M
                      m26872M
                      m26872
                      @martkrui R1 and C2 are mandatory if you intend to use the 6 pin FTDI port (I think you do). C3 (ARef - Gnd) is primarily for when you use Adc external ref, but (if I remember correct) it stabilizes the Adc in general. C1 (Vcc - Gnd) is just the "near chip supply input capacitor" and could probably be left out if there are some other caps near the nRF.
                      • dakkyD dakky
                        Dakky
                        bjacobseB
                        bjacobseB
                        bjacobse
                        Dakky
                        I use ubuntu, and a tiny USB, so after I have flashed my arduino board, I run this avrdude command, that will run until battery is low
                        avrdude -c usbtiny -p m328p -U efuse:w:0x07:m
                        I have bought usbtiny from this guy:
                        http://www.ebay.com/itm/USBtinyISP-V4-AVR-ISP-Programmer-Reliable-Plastic-Enclosure-/330824700564?hash=item4d06b05294
                        • m26872M m26872
                          @ahmedadelhosni
                          I think it's a good idea! And an easy mod, but it's not on priority list atm. Someone else would get a quick start from my already published kicad-files.
                          The thought behind present design is that I didn't want anything to cover the antenna in any direction, but I doubt it would matter much in this suggested case. It'll be worse when it comes to the hight. Look at the photos. The nRF becomes too high for my enclosures if I use a socket, and the 328p with its socket is too high to fit under a nRF without its socket. The solution would be to remove the 328p socket and move the R and Cs to bottom side or somewhere else. And without a 328p socket, the 3x2 AVR ISP pins would become more important to keep. Otherwise the board could have been trimmed even more.
                          ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          wrote on last edited by ahmedadelhosni
                          #96
                          @m26872 Hi again. Just a small update regarding rotating the nrf.
                          I decided that in my designs I'll need the straight and rotated version, thus I'll design a small board to map the pin outputs like the image below. It will be above the ICSP pins but I really don't care about re flashing.
                          I'll order the board as soon as I finish pcb layout of some other boards and ship all at once.
                          upload-dbcd859c-7c4c-4e46-959c-e83314602bcd
                            m26872M
                            m26872M
                            m26872
                            @ahmedadelhosni You know that the nRF pins are not centered? That means if you rotate it like this it will no longer be straight above the "slim node motherboard".
                            What height do you expect it to be?
                            • dakkyD
                              dakkyD
                              dakky
                              wrote on last edited by dakky
                              #98
                              Another "noobish" question:
                              When using this bootloader, one cycle takes 8 seconds? What happens, if for example, a switch is pressed between? does this sensor detect this?
                              • dakkyD dakky
                                m26872M
                                m26872M
                                m26872
                                @dakky Plz correct me... but I guess you're talking about the Avr sleep cycles? I don't know what that's got to do with the bootloader or this thread. I think it's related to interrupt, timers, mysensors and arduino lowpower library. The sleep cycles shouldn't be something to worry about if you're using the "sleep" function as in MySensors API.
                                dakkyD 1 Reply Last reply
                                • m26872M m26872
                                  dakkyD
                                  dakkyD
                                  dakky
                                  #100
                                  @m26872 hmm you're right. maybe this is a too generic question to be discussed here. pardon me.
                                    martkrui
                                    wrote on last edited by martkrui
                                    #101
                                    I had a bit of an issue getting things going as I've never played with the fuses before. Maybe this can save someone else some time. If I'm doing something silly here please correct me. :sweat_smile:
                                    [DISCLAIMER] this worked for me. Use at own risk[DISCLAIMER]
                                    Executed these commands from the subfolder \hardware\tools\avr\bin of my local arduino IDE.
                                    Connected the board ICSP using an USBASP with the latest firmware. Change the "-c usbasp" part if you connect using something else.
                                    Flash bootloader
                                    avrdude -C ../etc/avrdude.conf -c usbasp -B5 -p ATmega328P -U flash:w:..\..\..\arduino\avr\bootloaders\atmega\atmega328_1a.hex
                                    Set fuses
                                    I think the B5 was crucial as it slows things down a bit. The bootloader (atmega328_1a.hex) is the one mentioned in the first post. I also added the part in the boards.txt of the arduino IDE.
                                    Now I can connect the board to the FTDI and upload and run sketches without issues.
                                    On to the next step :smiley: :+1:
                                    • dakkyD
                                      dakkyD
                                      dakky
                                      I am not so really skilled in transferring a wiring diagram to "real live". Is this the correct implementation for battery measuring?
                                      upload-8e188148-e6c0-44ef-9b8c-a01fe9cd1c3a
                                      • dakkyD dakky
                                        m26872M
                                        m26872M
                                        m26872
                                        @dakky First, the "normal" battery monitoring to this node is to use the internal method by, if you like, using the vcc library. Measuring Vcc with external voltage divider makes not a lot of sense. The external voltage divider is useful when measuring e.g. raw battery voltage to some voltage regulator.
                                        Second, I think you've switched A0 and Gnd in your drawing.
                                        • dakkyD
                                          dakkyD
                                          dakky
                                          #104
                                          hurm did i switch them?
                                          Concerning the method: hmm ok. I just thought, that the one recommenced in the build section of mysensors should be the "correct" one.
                                          EDIT: Hrhr @Yveaux vcc lib is cute :D workd out of the box ;) thx
