  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.3k Views 39 Watching
  • R
    R
    robosensor
    @Yveaux thank you for your reply. It is not failing wifi connection, as the same problem exists then I using serial connection to esp8266 (via on-board usb-uart converter on nodemcu board).
    Nothing interesting in the serial logs (with debug mode enabled), just random absence of sensor data. Seems like I should connect sensor node to collect debug logs from node side.
    Also speed is changed - much faster CPU (80 MHz vs 8 MHz) and much faster connection (wifi vs uart 9600 bps). Maybe this affects.
    • R
      R
      robosensor
      Seems like problem with loosing messages is gateway firmware related.
      Then I connect two controllers (my own perl script and MYSController 0.1.2.282) to esp8266 gateway (#define MY_GATEWAY_MAX_CLIENTS 2), both controllers receiving exactly the same data from gateway, but messages lost even more.
      1 on graphs = one controller connected
      2 on graphs = two controllers connected.
      I'm not familiar with esp8266 network programming, but could it be that firmware looses incoming packets from nrf24l01+ due to blocking call to wifi-related network functions? Seems like during sending data to wifi network firmware does not have time to pick up all incoming packets from nrf24l01+ chip.
      • R
        R
        robosensor
        I think I found problem. As I said before, seems like WiFi's clients[i].write() call blocks thread for a very long time.
        I added logging of write() time:
        		// Send message to connected clients
        		#if defined(MY_GATEWAY_ESP8266)
        			unsigned long start_time = hwMillis();
        			for (uint8_t i = 0; i < ARRAY_SIZE(clients); i++)
        				if (clients[i] && clients[i].connected())
        					clients[i].write((uint8_t*)_ethernetMsg, strlen(_ethernetMsg));
        			debug(PSTR("WiFi transaction time: %u ms\n"), hwMillis() - start_time);
        			_ethernetServer.write(_ethernetMsg);
        And got following results:
        For Perl script from FreeBSD server in another country (ping to server is about 55 milliseconds):
        0;0;3;0;9;WiFi transaction time: 141 ms
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=23,pt=2,l=2,sg=0:98
        0;0;3;0;9;read: 2-2-0 s=6,c=1,t=43,pt=3,l=2,sg=0:2
        0;0;3;0;9;WiFi transaction time: 140 ms
        0;0;3;0;9;read: 1-1-0 s=105,c=1,t=0,pt=7,l=5,sg=0:27.5000
        0;0;3;0;9;WiFi transaction time: 136 ms
        0;0;3;0;9;read: 1-1-0 s=106,c=1,t=0,pt=7,l=5,sg=0:52.8750
        0;0;3;0;9;read: 1-1-0 s=107,c=1,t=0,pt=7,l=5,sg=0:45.9375
        0;0;3;0;9;WiFi transaction time: 142 ms
        0;0;3;0;9;read: 1-1-0 s=108,c=1,t=0,pt=7,l=5,sg=0:34.4375
        0;0;3;0;9;WiFi transaction time: 137 ms
        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
        0;0;3;0;9;WiFi transaction time: 143 ms
        Connection from LAN (windows telnet client):
        0;0;3;0;9;read: 3-3-0 s=1,c=1,t=23,pt=2,l=2,sg=0:61
        0;0;3;0;9;WiFi transaction time: 209 ms
        0;0;3;0;9;read: 4-4-0 s=1,c=1,t=24,pt=2,l=2,sg=0:152
        0;0;3;0;9;WiFi transaction time: 201 ms
        0;0;3;0;9;read: 4-4-0 s=2,c=1,t=24,pt=2,l=2,sg=0:43
        0;0;3;0;9;WiFi transaction time: 212 ms
        0;0;3;0;9;read: 4-4-0 s=3,c=1,t=24,pt=2,l=2,sg=0:129
        0;0;3;0;9;read: 4-4-0 s=4,c=1,t=24,pt=2,l=2,sg=0:147
        0;0;3;0;9;WiFi transaction time: 208 ms
        0;0;3;0;9;read: 2-2-0 s=102,c=1,t=0,pt=7,l=5,sg=0:4.2500
        0;0;3;0;9;WiFi transaction time: 221 ms
        0;0;3;0;9;read: 2-2-0 s=103,c=1,t=0,pt=7,l=5,sg=0:27.4375
        0;0;3;0;9;read: 2-2-0 s=104,c=1,t=0,pt=7,l=5,sg=0:23.3750
        0;0;3;0;9;WiFi transaction time: 210 ms
        0;0;3;0;9;read: 2-2-0 s=3,c=1,t=1,pt=7,l=5,sg=0:99.9
        Seems like many packets coming to NRF24L01+ in this time interval (140-200 milliseconds) and this causes NRF buffer overflow and packet loss.
          Damn, 200 msec is a pretty long time.
            @hek Yeah, but is this significantly longer than for a wired connection?
            Only real solution would be to switch to interrupt based message handling for the MySensors network (hopefully the ESP stack can handle this...)
            @robosensor Are these long delays (only) caused by the fact that this is a long distance connection?
            How is your mileage for a server on e.g. the same lan?
            • F
              F
              Fabien
              Exactly same problem here with RFM69W Radio. With 2 clients, i loose more packets. Both controller and ESP are on the same LAN. No probelm with Serial Gateway on Jeelink v3.
              • R
                R
                robosensor
                wrote on last edited by robosensor
                #229
                @Yveaux seems like delays caused by low-level network/tcp code or settings of receiving side (maybe something as TCP ACK packet delays or Nagle algorithm or something like this).
                ESP8266 connected directly to Mikrotik RB2011 router.
                Then I connect from external server (ping to server is about 55 milliseconds, FreeBSD 9.3, Perl), delays about 140 milliseconds.
                Then I connect from windows-based computer, connected directly to router, delays about 200 milliseconds (both windows telnet and PuTTy).
                For 2 parallel above connections delays about 350 milliseconds.
                Then I connect from router's internal telnet client, delays about 1-2 milliseconds
                Then I connect from android-based phone (phone connected to router via wifi, using ConnectBot software), delays vary from 3-5 milliseconds (mostly) to 100-150 milliseconds (less frequently).
                Seems like interrupts for nrf24 is the only solution. Seems like esp8266 gateway with such delays is completely unusable with high packet rates. With ~150 milliseconds delays no more than 6 messages/second packet rate allowed.
                Just to reference: I'm using Arduino 1.6.5 with esp8266 libraries version 2.0.0 installed.
                • R robosensor
                  #230
                  @robosensor @Fabien Please understand that this issue is not related to ESP8266. I expect delays to be nearly identical when using the Ethernet gateway (wired ethernet) and ATMega microcontroller. Of course the serial gateway will not suffer from these delays as it doesn't use ethernet as transport medium -- it is a direct connection.
                  Switching to interrupt-based message handling for the MySensorts stack is not a simple task. It will require locking and buffering, and footprint of the library (especially RAM) will increase.
                  Furthermore I don't know how the ESP's network stack handles interrupts during ethernet processing. Worst case it will just block interrupts or run from a higher-priority interrupt than the nRF and all efforts of making the MySensors library interrupt based will be in vain.
                  I personally would try to reduce the latency in your server connection by choosing a server nearby or by buffering your traffic by a server in your LAN. MQTT for example can easily be buffered by a local broker which then uses the slow connection to sync with another server.
                  Another option is switching to a serial gateway, but again you need a local server inbetween.
                  A simple Raspberry Pi or so could act as a server for these scenarios.
                  Another option would be to implement a retry mechanism on your sensors. If the gateway does not confirm reception of your message, then resend it.
                  • R
                    R
                    robosensor
                    @Yveaux I completely agree with you. Rewriting gateway code to support interrupts is not very easy task and it is not clear what problems you will encounter. Furthermore, rewriting will not solve the problem of delays, this only can solve packet loss problem.
                    Just tried to connect from RPi 2 (connected using WiFi directly to router), average delay is 2-5 milliseconds, sometimes 5-10 ms. Seems like this is good temporary solution.
                    • YveauxY Yveaux
                      @D_dude flush the serial output after each print.
                      The ESP will output the serial data in the background while your programm continues and then it crashes.
                      D_dude
                      Finally was able to get everything working.
                      Ordered a fresh nRF from Itead and started from scratch. everything worked fine first time. seems like the nRF from ebay was causing issues.
                      • R
                        R
                        robosensor
                        Just tried old version of esp8266 libraries (1.6.5-947-g39819f0 instead of 2.0.0) with old version of esp8266 gateway (master branch, commit 9ef2604c81d2fea5d646a9a194f312192833a79b) and got exactly the same results.
                        WiFi write() time is about 150-200 milliseconds for remote server in another country, 200-210 milliseconds for windows7-based computer in local area network and 0-4 milliseconds for Raspberry Pi 2 in local area network.
                        To show transaction times just replace original output function in Esp8266Gateway.ino with following code:
                        void output(const char *fmt, ... )
                          char serialBuffer[MAX_SEND_LENGTH];
                          va_list args;
                          va_start (args, fmt );
                          va_end (args);
                          Serial.print(serialBuffer);
                          unsigned long start_time = millis();
                        //       Serial.print("Client "); Serial.print(i); Serial.println(" write");
                               clients[i].write((uint8_t*)serialBuffer, strlen(serialBuffer));
                          start_time = millis() - start_time;
                          Serial.print("WiFi transaction time: "); Serial.print(start_time); Serial.println("");
                        Also disconnection of client during clients[i].write() call causes reboot by watchdog:
                         ets Jan  8 2013,rst cause:4, boot mode:(3,7)
                        wdt reset
                        tail 0
                        chksum 0x42
                        csum 0x42
                        ~ld
                        • YveauxY
                          So another confirmation of what we knew already.
                          Do you know how many nRF messages are actually sent during this wifi write call?
                          The nRF has a rx buffer for 3 messages -- not sure if MySensors uses all 3 of them.
                          I guess this is ESP core related. Is this fixed in code 2.0.0?
                          • R
                            R
                            robosensor
                            Yes. It seems that I now understand what is happening. WiFiClient::write() blocks thread until TCP ACK packet received or until timeout (5 seconds). Windows sending TCP ACKs after 200ms timeout. That's why write() delayed for ~200 milliseconds for windows-based controller. More information (and link to non-blocking library) is available here: https://github.com/esp8266/Arduino/issues/922
                            Nodes sending 3-7 (sometimes more) messages with 35 ms delay between messages, so in my case 3-packet hardware buffer in nrf24 is overflowed after 105-140 milliseconds of write() call.
                            I did not tried to check this reboots in 2.0.0, but 2.0.0 is much more stable and I never seen any reboots/resets.
                            • YveauxY
                              That sounds promising! I'll have to give the 2.0.0 core a try myself then.
                              • P
                                P
                                patrick schaerer
                                wrote on last edited by patrick schaerer
                                #237
                                Thanks for your work!
                                I made my wifigateway today and added variables for a static IP Adress.
                                I also tried to add an DHT11 to the wifi gateway, but it didn't work. I cannot include those sensors because I need to startup while inclusion and this would restart the gateway.
                                Mabe someone has an Idea how to add a sensor to the wifi gateway. edit: I found this thread on the forum ... http://forum.mysensors.org/topic/1387/sensors-on-gateway
                                 * Version 1.0 - Henrik EKblad
                                 * Contribution by Ivo Pullens (ESP8266 support)
                                 * The EthernetGateway sends data received from sensors to the WiFi link.
                                 * VERA CONFIGURATION:
                                 * LED purposes:
                                 * The ESP8266 however requires different wiring:
                                 * nRF24L01+  ESP8266
                                 * VCC        VCC
                                 * CE         GPIO4
                                 * CSN/CS     GPIO15
                                 * SCK        GPIO14
                                 * MISO       GPIO12
                                 * MOSI       GPIO13
                                  * Inclusion mode button:
                                #define NO_PORTB_PINCHANGES
                                #include <MySigningNone.h>
                                #include <MyTransportNRF24.h>
                                #include <MyTransportRFM69.h>
                                #include <EEPROM.h>
                                #include <MyHwESP8266.h>
                                #include <ESP8266WiFi.h>
                                #include <MyParserSerial.h>
                                #include <stdarg.h>
                                #include "GatewayUtil.h"
                                const char *ssid =  "yourSSID";    // cannot be longer than 32 characters!
                                const char *pass =  "yourPassword"; //
                                IPAddress local_ip(192,168,0,6);
                                IPAddress dns_address(192,168,0,1);
                                IPAddress gateway_ip(192,168,0,1);
                                IPAddress subnet(255,255,255,0);
                                //Code for DHT Temp and Hum
                                /*#include <DHT.h>
                                #define CHILD_ID_HUM 9
                                #define CHILD_ID_TEMP 10
                                #define HUMIDITY_SENSOR_DIGITAL_PIN 1
                                long intervall = 300000; //read Temp and Hum every 5 minutes
                                long last_millis = -300000;
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                boolean metric = true;
                                //End of Temp and Hum */
                                #define INCLUSION_MODE_PIN  5 // Digital pin used for inclusion mode button
                                #define RADIO_CE_PIN        4   // radio chip enable
                                #define RADIO_SPI_SS_PIN    15  // radio SPI serial select
                                #ifdef WITH_LEDS_BLINKING
                                #define RADIO_ERROR_LED_PIN 7  // Error led pin
                                #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
                                //MyTransportRFM69 transport;
                                #ifdef MY_SIGNING_FEATURE
                                MySigningNone signer;
                                // Hardware profile
                                MyHwESP8266 hw;
                                MySensor gw(transport, hw
                                    , signer
                                  , RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN
                                #define IP_PORT 5003         // The port you want to open
                                #define MAX_SRV_CLIENTS 5    // how many clients should be able to telnet to this ESP8266
                                // a R/W server on the port
                                static WiFiServer server(IP_PORT);
                                static WiFiClient clients[MAX_SRV_CLIENTS];
                                static bool clientsConnected[MAX_SRV_CLIENTS];
                                static inputBuffer inputString[MAX_SRV_CLIENTS];
                                #define ARRAY_SIZE(x)  (sizeof(x)/sizeof(x[0]))
                                  va_list args;
                                  va_end (args);
                                  // Setup console
                                  hw_init();
                                  Serial.println(); Serial.println();
                                  Serial.println("ESP8266 MySensors Gateway");
                                  Serial.print("Connecting to "); Serial.println(ssid);
                                  (void)WiFi.begin(ssid, pass);
                                  while (WiFi.status() != WL_CONNECTED)
                                    delay(500);
                                    Serial.print(".");
                                  Serial.println("Connected!");
                                  Serial.print("IP: "); Serial.println(WiFi.localIP());
                                  Serial.flush();
                                  (void)WiFi.config(local_ip, dns_address, gateway_ip, subnet);
                                    delay(500);
                                    Serial.print(".");
                                  Serial.flush();
                                  server.begin();
                                  server.setNoDelay(true);
                                 /* //Code for Temp and Hum
                                  checkInclusionFinished();
                                  // Go over list of clients and stop any that are no longer connected.
                                  // If the server has a new client connection it will be assigned to a free slot.
                                  bool allSlotsOccupied = true;
                                    if (!clients[i].connected())
                                      if (clientsConnected[i])
                                        Serial.print("Client "); Serial.print(i); Serial.println(" disconnected");
                                        clients[i].stop();
                                      //check if there are any new clients
                                      if (server.hasClient())
                                        clients[i] = server.available();
                                        inputString[i].idx = 0;
                                        Serial.print("Client "); Serial.print(i); Serial.println(" connected");
                                        output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                                    bool connected = clients[i].connected();
                                    clientsConnected[i] = connected;
                                    allSlotsOccupied &= connected;
                                  if (allSlotsOccupied && server.hasClient())
                                    //no free/disconnected spot so reject
                                    Serial.println("No free slot available");
                                    WiFiClient c = server.available();
                                    c.stop();
                                  // Loop over clients connect and read available data
                                    while(clients[i].connected() && clients[i].available())
                                      char inChar = clients[i].read();
                                      if ( inputString[i].idx < MAX_RECEIVE_LENGTH - 1 )
                                        // if newline then command is complete
                                        if (inChar == '\n')
                                          // a command was issued by the client
                                          // we will now try to send it to the actuator
                                          inputString[i].string[inputString[i].idx] = 0;
                                          // echo the string to the serial port
                                          Serial.print("Client "); Serial.print(i); Serial.print(": "); Serial.println(inputString[i].string);
                                          parseAndSend(gw, inputString[i].string);
                                          // clear the string:
                                          // Finished with this client's message. Next loop() we'll see if there's more to read.
                                         // add it to the inputString:
                                         inputString[i].string[inputString[i].idx++] = inChar;
                                        Serial.print("Client "); Serial.print(i); Serial.println(": Message too long");
                                  if (millis() >= last_millis + intervall) {
                                    if (isnan(temperature)) {
                                      lastTemp = temperature;
                                    if (!metric) {
                                    Serial.print("T: ");
                                  if (isnan(humidity)) {
                                      lastHum = humidity;
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                  last_millis = millis();
                                • A
                                  Alex B Goode
                                  Any chance to achieve some success using ESP-01 or I really have to buy ESP-07/12?
                                  I just have some ESP-01 modules already and I wonder if I can use them
                                  • A Alex B Goode
                                    @Alex-B-Goode the Spi bus is not available on the esp01 header, so you won't be able to connect the radio then...
                                      But I guess you could use it as a sensor node (mqtt/ethernet).
                                      • YveauxY Yveaux
                                        sdndba
                                        It's late (early morning) I did not want to read over all the last three months posts so my question... is there a solution for this problem? I just downloaded the latest library and found the NodeMCU will reboot when a node initializes. Data below. Just point me to the solution if you would please. Thanks very much.
                                        0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.54
                                        3;1;1;0;0;21.54
                                        0;0;3;0;9;read: 3-3-0 s=2,c=1,t=38,pt=7,l=5,sg=0:3.44
                                        3;2;1;0;38;3.44
                                        0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.76
                                        3;1;1;0;0;21.76
                                        3;2;1;0;38;3.44
                                        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.11
                                        1;1;1;0;0;21.11
                                        0;0;3;0;9;read: 1-1-0 s=2,c=1,t=38,pt=7,l=5,sg=0:3.44
                                        1;2;1;0;38;3.44
                                        3;1;1;0;0;21.76
                                        3;2;1;0;38;3.44
                                        0;0;3;0;9;read: 0-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                                        0;255;0;0;17;1.5.1
                                        0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                        Exception (28):
                                        epc1=0x40203911 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
                                        ctx: cont
                                        sp: 3ffefe50 end: 3fff00e0 offset: 01a0
                                        stack>>>
                                        3ffefff0: 3ffeef14 3ffeee8b 3ffeee84 402037d5
                                        3fff0000: 000000ff 00000003 00000006 00000001
                                        3fff0010: 00000001 00000000 3ffeeed8 00000030
                                        3fff0020: 00000000 3fffdc20 3ffef0ac 00000030
                                        3fff0030: 00000003 00000001 00000001 00000000
                                        3fff0040: 00000000 00000000 000000ff 00000023
                                        3fff0050: 00000006 40209ee1 3ffeee64 3ffeee64
                                        3fff0060: 00000000 00000000 3ffeee84 3ffeee84
                                        3fff0070: 3fffdc20 00000000 3ffef0a4 40202582
                                        3fff0080: 402020cc 3ffeee64 3fff1720 402051e6
                                        3fff0090: 00000000 00ffffff 0100000a 3ffef0ac
                                        3fff00a0: 00000000 00000000 00000016 40101941
                                        3fff00b0: 40205499 1100000a 00000000 3ffef0ac
                                        3fff00c0: 3fffdc20 00000000 3ffef0a4 402054c1
                                        3fff00d0: 00000000 00000000 3ffef0c0 40100114
                                        <<<stack<<<
                                        wdt reset
                                        tail 0
                                        chksum 0x42
                                        csum 0x42
                                        ~ld
                                        Connecting to TESTNETWORK
                                        ....Connected!
                                        IP: 10.0.0.17
                                        0;0;3;0;9;read: 0-0-0 s=6,c=0,t=13,pt=0,l=0,sg=0:
                                        0;6;0;0;13;
                                        0;0;3;0;9;read: 0-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0:0
                                        0;1;1;0;16;0
                                        0;0;3;0;9;read: 0-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0:0
                                        0;4;1;0;2;0
                                        0;0;3;0;9;read: 0-0-0 s=5,c=1,t=2,pt=2,l=2,sg=0:0
                                        0;5;1;0;2;0
                                        3;1;1;0;0;21.76
                                        3;2;1;0;38;3.44
                                        0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.97
                                        3;1;1;0;0;21.97
                                        3;2;1;0;38;3.44
                                        • E
                                          E
                                          emc2
                                          @Yveaux
                                          Is there any specific reason on why CE is plugged on D2?
                                          I'm asking as I want to add a BME280 sensor directly on my gateway and by default the I2C bus is on D2/D1. It can be changed to any pin with Wire.begin(SDA,SCL) so it is not a major problem, but for user friendliness it would be nicer id CE was plugged on D9 or eventually D4 or D3.
                                          If there is no specific reason can I change MyConfig.h line 329 to #define MY_RF24_CE_PIN 3 safely?
                                          Thanks again for this gateway!
