  3. MyController.org
  4. MyController+Domoticz at same time?
Scheduled Pinned Locked Moved MyController.org
33 Posts 9 Posters 18.2k Views 12 Watching
  • mfalkviddM
    Is anyone using MyController + Domoticz (or some other controller) at the same time?
    I really want to try OTA firmware, and for that MyController seems great. But I have all my sensors in Domoticz and I don't want to lose that functionality until I know MyController works well.
    I saw this request but I'm unable to understand if it already works or if it still needs development.
    J fetsF 2 Replies Last reply
      J
      J
      jkandasa
      wrote on last edited by jkandasa
      @mfalkvidd MyController supports OTA update via MQTT from this release https://github.com/mycontroller-org/mycontroller/releases/tag/0.0.2-alpha6 with MySensors 1.6 development branch.
      MyController has it's own inbuilt MQTT broker. You can use inbuilt broker or you use your favorite MQTT broker. Broker settings can be changed form here in your installation it will be in
      mycontroller/conf/mycontroller.properties
        fetsF
        fetsF
        fets
        @mfalkvidd if you are on linux and able to run node-red here what you can do (thanks @tbowmo)
        • mfalkviddM
          That sounds great, thanks a lot! I'll see if I can start off the new year with a dual setup :)
          petewillP 1 Reply Last reply
            petewillP
            petewillP
            petewill
            @mfalkvidd I have run MYSController and Vera both connected to my Ethernet gateway at the same time with no issues. I ran it for days (400,000+ tx/rx entries). I mainly use MYSController for monitoring/troubleshooting as well as testing OTA. Vera is doing all the control for now.
            • AnticimexA
              AnticimexA
              Anticimex
              I also use multiple controllers. Vera, domoticz and myscontroller. Node-red acts as transport which also permit me to do special management for certain controllers as well as injecting/extracting specific messages in the flow (the pushbullet plugin in node-red is especially nice).
              I also use all controllers for "input" and at least for nodes that send ACK it works just fine. That is, doing an action in one controller causes the other controllers to update as well when the ACK is returned to all of them.
              • mfalkviddM
                Thought I'd report back.
                I have spent approximately 3 hours experimenting, googling and learning but not much luck so far.
                MyController is installed on my Raspberry Pi. The installation was simple (great work @jkandasa!) and I am able to receive MySensor traffic if I configure MyController to read directly from /dev/ttyMySensorsGateway (with the gateway disabled in Domoticz).
                I have been able to configure Domoticz to send all events to Domoticz/out on the mosquitto broker that's installed with Domoticz. MyController is then able to read from the topic, but it is unable to parse the messages since Domoticz's message format differs from what MyController expects.
                I have tried fets/tbowmo's suggestion but was unable to figure out how to install the serial port plugin. On the way I learned that npm search is useless unless you have >16GB ram which my raspberry pi does not - use the website search instead (npm search is a pile of smoldering debris). I also learned that the URL parsing function in npm was broken in the version I was running but that was fixed after an upgrade and that the --unsafe-perm parameter sometimes is required when using sudo due to a bug in node-gyp.
                I have learned to use NodeRed and I really like it (as long as I don't need to mess with npm). I am unable to get npm to install packages in /usr/lib/node_modules/node-red/node_modules (where node-read reads) though, npm wants to install them in /usr/local/lib/node_modules/ Does anyone know why this is? I created symlinks for the packages I installed which worked for node-red-contrib-mysensors but node-red-node-serialport doesn't show up in the NodeRed UI.
                It looks like I should build myself an ethernet gateway to be able to proceed. I have a few ESPs, but they keep rebooting which I have seen several other people having problems with as well so I am a bit hesitant to go that route. Maybe buying a W5100 or ENC28J60 module is the way to go instead?
                So it's been an evening with lots of learning, which is great. I don't have a working system yet though. Suggestions are welcome, I'll sleep on the problem and try again later.
                fetsF 1 Reply Last reply
                  wrote on last edited by hek
                  npm install <package> -g perhaps?
                  And avoid the ENC28J60 ...
                    fetsF
                    fetsF
                    fets
                    wrote on last edited by fets
                    @mfalkvidd : sudo apt-get install socat
                    Then to execute, command line : socat PTY,link=/dev/ttyS80,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB20,mode=666,group=dialout,raw &
                    Then on node-red, I configure serial com (to and from domoticz) using /dev/ttyS80.
                    On Domoticz, the serial gateway is configure using port /dev/ttyUSB20
                    That's all folks
                    How do you "I have been able to configure Domoticz to send all events to Domoticz/out" ?
                      Yes, that's what I am using.
                      Thanks. I 'll stay away from it.
                      • fetsF fets
                        That's all folks
                        Sorry for being unclear. Installing socat is not a problem. The problem is that I don't have a serial input/output block in nodered.
                          fetsF
                          fetsF
                          fets
                          @mfalkvidd sorry my misunderstanding.
                          For serial, I think it was : npm install node-red-node-serialport
                          Thanks for MQTT domoticz, I thought it was an input for domoticz :(
                          • mfalkviddM
                            @fets you're welcome. It is a bit hidden :)
                            I have also found out that cloudmqtt offers a free personal mqtt broker. That might be useful.
                            I have installed node-red-node-serialport:
                            npm install -g --unsafe-perm node-red-node-serialport
                            ln -s /usr/local/lib/node_modules/node-red-node-serialport /usr/lib/node_modules/node-red/node_modules
                            (exactly what I did with node-red-contrib-mysensors) and restarted nodered and restarted my browser, but there's still no Serial port building block.
                            • fetsF
                              fetsF
                              fets
                              Did you check logs at node-red startup for errors, or try to run with -v flag
                              • mfalkviddM
                                I thought I did :blush: but now I'm getting something suspicious:
                                Welcome to Node-RED
                                5 Jan 21:38:44 - [info] Node-RED version: v0.10.6
                                5 Jan 21:38:44 - [info] Node.js  version: v0.12.1
                                5 Jan 21:38:44 - [info] Loading palette nodes
                                5 Jan 21:38:51 - [warn] ------------------------------------------
                                5 Jan 21:38:51 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
                                5 Jan 21:38:51 - [warn] [serial] Error: Cannot find module '/usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v14-linux-arm/serialport.node'
                                5 Jan 21:38:51 - [warn] [redisout] Error: Cannot find module 'redis'
                                5 Jan 21:38:51 - [warn] [mongodb] Error: Cannot find module 'mongodb'
                                5 Jan 21:38:51 - [warn] [serialport] serial in already registered
                                5 Jan 21:38:51 - [info] User Directory : /home/pi/.node-red
                                5 Jan 21:38:51 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
                                5 Jan 21:38:51 - [info] Server now running at http://127.0.0.1:1880/
                                5 Jan 21:38:51 - [info] Starting flows
                                5 Jan 21:38:52 - [info] Started flows
                                5 Jan 21:38:52 - [mqtt] [e7f85c03.1807a] connected to broker tcp://localhost:1883
                                pi@raspberrypi ~ $ ls -laR /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/
                                /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/:
                                total 12
                                drwxr-xr-x 3 root root 4096 Jun 13  2015 .
                                drwxr-xr-x 3 root root 4096 Jun 13  2015 ..
                                drwxr-xr-x 2 root root 4096 Jun 13  2015 node-v11-linux-arm
                                /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v11-linux-arm:
                                total 52
                                drwxr-xr-x 2 root root  4096 Jun 13  2015 .
                                -rwxr-xr-x 1 root root 44841 Jun 13  2015 serialport.node
                                • fetsF
                                  fetsF
                                  fets
                                  I think your issue comes from your nodejs version.
                                  I'm now running v4.2.4.
                                  Check node-red-serial , Install section.
                                  Maybe this will solve your issue
                                  • mfalkviddM
                                    I'll try that. My gcc version is <4.8 so I need to use the alternative version.
                                    Do I need to remove the other packages? I seem unable to do that:
                                    pi@raspberrypi ~ $ gcc -v
                                    Using built-in specs.
                                    COLLECT_GCC=gcc
                                    COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.7/lto-wrapper
                                    Target: arm-linux-gnueabihf
                                    Configured with: ../src/configure -v --with-pkgversion='Debian 4.7.2-5+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
                                    Thread model: posix
                                    gcc version 4.7.2 (Debian 4.7.2-5+rpi1)
                                    pi@raspberrypi ~ $ sudo npm uninstall --unsafe-perm node-red-node-serialport
                                    - ansi-regex@2.0.0 node_modules/ansi-regex
                                    - ansi-styles@2.1.0 node_modules/ansi-styles
                                    - asn1@0.2.3 node_modules/asn1
                                    - assert-plus@0.1.5 node_modules/assert-plus
                                    - async@0.9.0 node_modules/async
                                    - aws-sign2@0.6.0 node_modules/aws-sign2
                                    - bindings@1.2.1 node_modules/bindings
                                    - bl@1.0.0 node_modules/bl
                                    - boom@2.10.1 node_modules/boom
                                    - caseless@0.11.0 node_modules/caseless
                                    - chalk@1.1.1 node_modules/chalk
                                    - combined-stream@1.0.5 node_modules/combined-stream
                                    - commander@2.9.0 node_modules/commander
                                    - core-util-is@1.0.2 node_modules/core-util-is
                                    - cryptiles@2.0.5 node_modules/cryptiles
                                    - dashdash@1.11.0 node_modules/dashdash
                                    - debug@2.2.0 node_modules/debug
                                    - delayed-stream@1.0.0 node_modules/delayed-stream
                                    - ecc-jsbn@0.1.1 node_modules/ecc-jsbn
                                    - escape-string-regexp@1.0.4 node_modules/escape-string-regexp
                                    - extend@3.0.0 node_modules/extend
                                    - extsprintf@1.0.2 node_modules/extsprintf
                                    - forever-agent@0.6.1 node_modules/forever-agent
                                    - form-data@1.0.0-rc3 node_modules/form-data
                                    - async@1.5.1 node_modules/form-data/node_modules/async
                                    - generate-function@2.0.0 node_modules/generate-function
                                    - generate-object-property@1.2.0 node_modules/generate-object-property
                                    - github@0.2.4 node_modules/github
                                    - graceful-readlink@1.0.1 node_modules/graceful-readlink
                                    - har-validator@2.0.3 node_modules/har-validator
                                    - has-ansi@2.0.0 node_modules/has-ansi
                                    - hawk@3.1.2 node_modules/hawk
                                    - hoek@2.16.3 node_modules/hoek
                                    - http-signature@1.1.0 node_modules/http-signature
                                    - inherits@2.0.1 node_modules/inherits
                                    - is-my-json-valid@2.12.3 node_modules/is-my-json-valid
                                    - is-property@1.0.2 node_modules/is-property
                                    - is-typedarray@1.0.0 node_modules/is-typedarray
                                    - isarray@0.0.1 node_modules/isarray
                                    - isstream@0.1.2 node_modules/isstream
                                    - jodid25519@1.0.2 node_modules/jodid25519
                                    - jsbn@0.1.0 node_modules/jsbn
                                    - json-schema@0.2.2 node_modules/json-schema
                                    - json-stringify-safe@5.0.1 node_modules/json-stringify-safe
                                    - jsonpointer@2.0.0 node_modules/jsonpointer
                                    - jsprim@1.2.2 node_modules/jsprim
                                    - mime@1.3.4 node_modules/mime
                                    - mime-db@1.20.0 node_modules/mime-db
                                    - mime-types@2.1.8 node_modules/mime-types
                                    - minimist@0.0.10 node_modules/minimist
                                    - ms@0.7.1 node_modules/ms
                                    - nan@2.0.9 node_modules/nan
                                    - node-red-node-serialport@0.1.0 node_modules/node-red-node-serialport
                                    - node-uuid@1.4.7 node_modules/node-uuid
                                    - oauth-sign@0.8.0 node_modules/oauth-sign
                                    - optimist@0.6.1 node_modules/optimist
                                    - pinkie@2.0.1 node_modules/pinkie
                                    - pinkie-promise@2.0.0 node_modules/pinkie-promise
                                    - process-nextick-args@1.0.6 node_modules/process-nextick-args
                                    - qs@5.2.0 node_modules/qs
                                    - readable-stream@2.0.5 node_modules/readable-stream
                                    - request@2.67.0 node_modules/request
                                    - serialport@2.0.5 node_modules/serialport
                                    - node-pre-gyp@0.6.13 node_modules/serialport/node_modules/node-pre-gyp
                                    - node-pre-gyp-github@1.0.5 node_modules/serialport/node_modules/node-pre-gyp-github
                                    - mkdirp@0.5.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp
                                    - minimist@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist
                                    - nopt@3.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt
                                    - abbrev@1.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/node_modules/abbrev
                                    - npmlog@1.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog
                                    - ansi@0.3.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/ansi
                                    - are-we-there-yet@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet
                                    - delegates@0.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/delegates
                                    - readable-stream@1.1.13 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream
                                    - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/core-util-is
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/inherits
                                    - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/isarray
                                    - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/string_decoder
                                    - gauge@1.2.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge
                                    - has-unicode@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/has-unicode
                                    - lodash.pad@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad
                                    - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._basetostring
                                    - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding
                                    - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding/node_modules/lodash.repeat
                                    - lodash.padleft@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft
                                    - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._basetostring
                                    - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding
                                    - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding/node_modules/lodash.repeat
                                    - lodash.padright@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright
                                    - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._basetostring
                                    - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding
                                    - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding/node_modules/lodash.repeat
                                    - rc@1.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
                                    - deep-extend@0.2.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/deep-extend
                                    - ini@1.3.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/ini
                                    - minimist@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist
                                    - strip-json-comments@0.1.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/strip-json-comments
                                    - request@2.65.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
                                    - aws-sign2@0.6.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/aws-sign2
                                    - bl@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl
                                    - readable-stream@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream
                                    - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/core-util-is
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/inherits
                                    - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/isarray
                                    - process-nextick-args@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/process-nextick-args
                                    - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/string_decoder
                                    - util-deprecate@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/util-deprecate
                                    - caseless@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/caseless
                                    - combined-stream@1.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream
                                    - delayed-stream@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
                                    - extend@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/extend
                                    - forever-agent@0.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/forever-agent
                                    - form-data@1.0.0-rc3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data
                                    - async@1.4.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/node_modules/async
                                    - har-validator@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator
                                    - chalk@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk
                                    - ansi-styles@2.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
                                    - escape-string-regexp@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
                                    - has-ansi@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
                                    - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
                                    - strip-ansi@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
                                    - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
                                    - supports-color@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
                                    - commander@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander
                                    - graceful-readlink@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
                                    - is-my-json-valid@2.12.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
                                    - generate-function@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
                                    - generate-object-property@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
                                    - is-property@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
                                    - jsonpointer@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
                                    - xtend@4.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/xtend
                                    - pinkie-promise@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
                                    - pinkie@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
                                    - hawk@3.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk
                                    - boom@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/boom
                                    - cryptiles@2.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/cryptiles
                                    - hoek@2.16.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/hoek
                                    - sntp@1.0.9 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/sntp
                                    - http-signature@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                                    - asn1@0.1.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/asn1
                                    - assert-plus@0.1.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/assert-plus
                                    - ctype@0.5.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/ctype
                                    - isstream@0.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/isstream
                                    - json-stringify-safe@5.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringify-safe
                                    - mime-types@2.1.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types
                                    - mime-db@1.19.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types/node_modules/mime-db
                                    - node-uuid@1.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/node-uuid
                                    - oauth-sign@0.8.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/oauth-sign
                                    - qs@5.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs
                                    - stringstream@0.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/stringstream
                                    - tough-cookie@2.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie
                                    - tunnel-agent@0.4.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tunnel-agent
                                    - rimraf@2.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf
                                    - glob@5.0.15 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob
                                    - inflight@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight
                                    - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight/node_modules/wrappy
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inherits
                                    - minimatch@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch
                                    - brace-expansion@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion
                                    - balanced-match@0.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/balanced-match
                                    - concat-map@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/concat-map
                                    - once@1.3.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once
                                    - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once/node_modules/wrappy
                                    - path-is-absolute@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/path-is-absolute
                                    - semver@5.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/semver
                                    - tar@2.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar
                                    - tar-pack@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
                                    - debug@0.7.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug
                                    - fstream@0.1.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream
                                    - fstream-ignore@0.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/inherits
                                    - minimatch@0.2.14 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch
                                    - lru-cache@2.7.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/lru-cache
                                    - sigmund@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/sigmund
                                    - graceful-fs@3.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/graceful-fs
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/inherits
                                    - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/graceful-fs
                                    - once@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once
                                    - readable-stream@1.0.33 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream
                                    - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/core-util-is
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/inherits
                                    - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/isarray
                                    - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/string_decoder
                                    - rimraf@2.2.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/rimraf
                                    - tar@0.1.20 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar
                                    - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/block-stream
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/inherits
                                    - uid-number@0.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/uid-number
                                    - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/block-stream
                                    - fstream@1.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream
                                    - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/node_modules/graceful-fs
                                    - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/inherits
                                    - sf@0.1.7 node_modules/sf
                                    - sntp@1.0.9 node_modules/sntp
                                    - sshpk@1.7.1 node_modules/sshpk
                                    - assert-plus@0.2.0 node_modules/sshpk/node_modules/assert-plus
                                    - string_decoder@0.10.31 node_modules/string_decoder
                                    - stringstream@0.0.5 node_modules/stringstream
                                    - strip-ansi@3.0.0 node_modules/strip-ansi
                                    - supports-color@2.0.0 node_modules/supports-color
                                    - tough-cookie@2.2.1 node_modules/tough-cookie
                                    - tunnel-agent@0.4.2 node_modules/tunnel-agent
                                    - tweetnacl@0.13.2 node_modules/tweetnacl
                                    - util-deprecate@1.0.2 node_modules/util-deprecate
                                    - verror@1.3.6 node_modules/verror
                                    - wordwrap@0.0.3 node_modules/wordwrap
                                    - xtend@4.0.1 node_modules/xtend
                                    npm WARN enoent ENOENT, open '/home/pi/package.json'
                                    npm WARN pi No description
                                    npm WARN pi No repository field.
                                    npm WARN pi No README data
                                    npm WARN pi No license field.
                                    • mfalkviddM
                                      pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport
                                      (>32kB output)
                                      pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport@0.1.0; sudo npm uninstall --unsafe-perm node-red-node-serialport@0.1.0
                                      - node-pre-gyp node_modules/serialport/node_modules/node-pre-gyp
                                      - rc node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
                                      - request node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
                                      - tar-pack node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
                                      npm WARN enoent ENOENT, open '/home/pi/node_modules/serialport/package.json'
                                      pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm serialport@2.0.5; sudo npm uninstall --unsafe-perm serialport@2.0.5
                                      pi@raspberrypi ~ $ sudo npm -g list
                                      /usr/local/lib
                                      ├─┬ mdns@2.2.11
                                      │ ├── bindings@1.2.1
                                      │ └── nan@2.1.0
                                      ├── node-red-contrib-mysensors@0.7.5
                                      ├─┬  error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json
                                      │ └──  extraneous error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json
                                      ├─┬ npm@3.5.3
                                      │ ├── abbrev@1.0.7
                                      │ ├── ansi-regex@2.0.0
                                      │ ├── ansicolors@0.3.2
                                      │ ├── ansistyles@0.1.3
                                      │ ├── aproba@1.0.1
                                      │ ├── archy@1.0.0
                                      │ ├── async-some@1.0.2
                                      │ ├── chownr@1.0.1
                                      │ ├─┬ cmd-shim@2.0.1
                                      │ │ └── graceful-fs@3.0.8
                                      │ ├─┬ columnify@1.5.2
                                      │ │ └─┬ wcwidth@1.0.0
                                      │ │   └─┬ defaults@1.0.3
                                      │ │     └── clone@1.0.2
                                      │ ├─┬ config-chain@1.1.9
                                      │ │ └── proto-list@1.2.4
                                      │ ├── debuglog@1.0.1
                                      │ ├─┬ dezalgo@1.0.3
                                      │ │ └── asap@2.0.3
                                      │ ├── editor@1.0.0
                                      │ ├── fs-vacuum@1.2.7
                                      │ ├── fs-write-stream-atomic@1.0.5
                                      │ ├── fstream@1.0.8
                                      │ ├─┬ fstream-npm@1.0.7
                                      │ │ └─┬ fstream-ignore@1.0.3
                                      │ │   └─┬ minimatch@3.0.0
                                      │ │     └─┬ brace-expansion@1.1.1
                                      │ │       ├── balanced-match@0.2.1
                                      │ │       └── concat-map@0.0.1
                                      │ ├─┬ glob@5.0.15
                                      │ │ ├─┬ minimatch@3.0.0
                                      │ │ │ └─┬ brace-expansion@1.1.1
                                      │ │ │   ├── balanced-match@0.2.0
                                      │ │ │   └── concat-map@0.0.1
                                      │ │ └── path-is-absolute@1.0.0
                                      │ ├── graceful-fs@4.1.2
                                      │ ├── has-unicode@1.0.1
                                      │ ├── hosted-git-info@2.1.4
                                      │ ├── iferr@0.1.5
                                      │ ├── imurmurhash@0.1.4
                                      │ ├── inflight@1.0.4
                                      │ ├── inherits@2.0.1
                                      │ ├── ini@1.3.4
                                      │ ├─┬ init-package-json@1.9.1
                                      │ │ └── promzard@0.3.0
                                      │ ├── lockfile@1.0.1
                                      │ ├── lodash._baseindexof@3.1.0
                                      │ ├── lodash._baseuniq@3.0.3
                                      │ ├── lodash._bindcallback@3.0.1
                                      │ ├── lodash._cacheindexof@3.0.2
                                      │ ├── lodash._createcache@3.1.2
                                      │ ├── lodash._getnative@3.9.1
                                      │ ├─┬ lodash.clonedeep@3.0.2
                                      │ │ └─┬ lodash._baseclone@3.3.0
                                      │ │   ├── lodash._arraycopy@3.0.0
                                      │ │   ├── lodash._arrayeach@3.0.0
                                      │ │   ├─┬ lodash._baseassign@3.2.0
                                      │ │   │ └── lodash._basecopy@3.0.1
                                      │ │   └── lodash._basefor@3.0.2
                                      │ ├── lodash.isarguments@3.0.4
                                      │ ├── lodash.isarray@3.0.4
                                      │ ├── lodash.keys@3.1.2
                                      │ ├── lodash.restparam@3.6.1
                                      │ ├─┬ lodash.union@3.1.0
                                      │ │ └── lodash._baseflatten@3.1.4
                                      │ ├─┬ lodash.uniq@3.2.2
                                      │ │ ├─┬ lodash._basecallback@3.3.1
                                      │ │ │ ├─┬ lodash._baseisequal@3.0.7
                                      │ │ │ │ └── lodash.istypedarray@3.0.2
                                      │ │ │ └── lodash.pairs@3.0.1
                                      │ │ └── lodash._isiterateecall@3.0.9
                                      │ ├─┬ lodash.without@3.2.1
                                      │ │ └── lodash._basedifference@3.0.3
                                      │ ├─┬ mkdirp@0.5.1
                                      │ │ └── minimist@0.0.8
                                      │ ├─┬ node-gyp@3.2.1
                                      │ │ ├─┬ glob@4.5.3
                                      │ │ │ └─┬ minimatch@2.0.10
                                      │ │ │   └─┬ brace-expansion@1.1.2
                                      │ │ │     ├── balanced-match@0.3.0
                                      │ │ ├─┬ minimatch@1.0.0
                                      │ │ │ ├── lru-cache@2.7.3
                                      │ │ │ └── sigmund@1.0.1
                                      │ │ ├─┬ npmlog@1.2.1
                                      │ │ │ ├── ansi@0.3.0
                                      │ │ │ ├─┬ are-we-there-yet@1.0.4
                                      │ │ │ │ ├── delegates@0.1.0
                                      │ │ │ │ └─┬ readable-stream@1.1.13
                                      │ │ │ │   ├── core-util-is@1.0.2
                                      │ │ │ │   ├── isarray@0.0.1
                                      │ │ │ │   └── string_decoder@0.10.31
                                      │ │ │ └─┬ gauge@1.2.2
                                      │ │ │   ├─┬ lodash.pad@3.1.1
                                      │ │ │   │ ├── lodash._basetostring@3.0.1
                                      │ │ │   │ └─┬ lodash._createpadding@3.6.1
                                      │ │ │   │   └── lodash.repeat@3.0.1
                                      │ │ │   ├─┬ lodash.padleft@3.1.1
                                      │ │ │   └─┬ lodash.padright@3.1.1
                                      │ │ └─┬ path-array@1.0.0
                                      │ │   └─┬ array-index@0.1.1
                                      │ │     └─┬ debug@2.2.0
                                      │ │       └── ms@0.7.1
                                      │ ├── nopt@3.0.6
                                      │ ├── normalize-git-url@3.0.1
                                      │ ├─┬ normalize-package-data@2.3.5
                                      │ │ └─┬ is-builtin-module@1.0.0
                                      │ │   └── builtin-modules@1.1.0
                                      │ ├── npm-cache-filename@1.0.2
                                      │ ├─┬ npm-install-checks@2.0.1
                                      │ │ └─┬ npmlog@1.2.1
                                      │ │   ├── ansi@0.3.0
                                      │ │   │   ├── core-util-is@1.0.1
                                      │ │   └─┬ gauge@1.2.2
                                      │ ├── npm-package-arg@4.1.0
                                      │ ├─┬ npm-registry-client@7.0.9
                                      │ │ └─┬ concat-stream@1.5.1
                                      │ │   ├─┬ readable-stream@2.0.4
                                      │ │   │ ├── process-nextick-args@1.0.3
                                      │ │   │ ├── string_decoder@0.10.31
                                      │ │   │ └── util-deprecate@1.0.2
                                      │ │   └── typedarray@0.0.6
                                      │ ├── npm-user-validate@0.1.2
                                      │ ├─┬ npmlog@2.0.0
                                      │ │ ├── ansi@0.3.0
                                      │ │ └─┬ gauge@1.2.2
                                      │ ├── once@1.3.3
                                      │ ├── opener@1.4.1
                                      │ ├─┬ osenv@0.1.3
                                      │ │ ├── os-homedir@1.0.1
                                      │ │ └── os-tmpdir@1.0.1
                                      │ ├── path-is-inside@1.0.1
                                      │ ├─┬ read@1.0.7
                                      │ │ └── mute-stream@0.0.5
                                      │ ├── read-cmd-shim@1.0.1
                                      │ ├─┬ read-installed@4.0.3
                                      │ │ └── util-extend@1.0.1
                                      │ ├─┬ read-package-json@2.0.2
                                      │ │ └─┬ json-parse-helpfulerror@1.0.3
                                      │ │   └── jju@1.2.1
                                      │ ├── read-package-tree@5.1.2
                                      │ ├── readdir-scoped-modules@1.0.2
                                      │ ├── realize-package-specifier@3.0.1
                                      │ ├─┬ request@2.67.0
                                      │ │ ├── aws-sign2@0.6.0
                                      │ │ ├─┬ bl@1.0.0
                                      │ │ │ └─┬ readable-stream@2.0.4
                                      │ │ │   ├── process-nextick-args@1.0.6
                                      │ │ ├── caseless@0.11.0
                                      │ │ ├─┬ combined-stream@1.0.5
                                      │ │ │ └── delayed-stream@1.0.0
                                      │ │ ├── extend@3.0.0
                                      │ │ ├── forever-agent@0.6.1
                                      │ │ ├─┬ form-data@1.0.0-rc3
                                      │ │ │ └── async@1.5.0
                                      │ │ ├─┬ har-validator@2.0.3
                                      │ │ │ ├─┬ chalk@1.1.1
                                      │ │ │ │ ├── ansi-styles@2.1.0
                                      │ │ │ │ ├── escape-string-regexp@1.0.3
                                      │ │ │ │ ├── has-ansi@2.0.0
                                      │ │ │ │ └── supports-color@2.0.0
                                      │ │ │ ├─┬ commander@2.9.0
                                      │ │ │ │ └── graceful-readlink@1.0.1
                                      │ │ │ ├─┬ is-my-json-valid@2.12.3
                                      │ │ │ │ ├── generate-function@2.0.0
                                      │ │ │ │ ├─┬ generate-object-property@1.2.0
                                      │ │ │ │ │ └── is-property@1.0.2
                                      │ │ │ │ ├── jsonpointer@2.0.0
                                      │ │ │ │ └── xtend@4.0.1
                                      │ │ │ └─┬ pinkie-promise@2.0.0
                                      │ │ │   └── pinkie@2.0.1
                                      │ │ ├─┬ hawk@3.1.2
                                      │ │ │ ├── boom@2.10.1
                                      │ │ │ ├── cryptiles@2.0.5
                                      │ │ │ ├── hoek@2.16.3
                                      │ │ │ └── sntp@1.0.9
                                      │ │ ├─┬ http-signature@1.1.0
                                      │ │ │ ├── assert-plus@0.1.5
                                      │ │ │ ├─┬ jsprim@1.2.2
                                      │ │ │ │ ├── extsprintf@1.0.2
                                      │ │ │ │ ├── json-schema@0.2.2
                                      │ │ │ │ └── verror@1.3.6
                                      │ │ │ └─┬ sshpk@1.7.1
                                      │ │ │   ├── asn1@0.2.3
                                      │ │ │   ├── assert-plus@0.2.0
                                      │ │ │   ├─┬ dashdash@1.10.1
                                      │ │ │   │ └── assert-plus@0.1.5
                                      │ │ │   ├── ecc-jsbn@0.1.1
                                      │ │ │   ├── jodid25519@1.0.2
                                      │ │ │   ├── jsbn@0.1.0
                                      │ │ │   └── tweetnacl@0.13.2
                                      │ │ ├── is-typedarray@1.0.0
                                      │ │ ├── isstream@0.1.2
                                      │ │ ├── json-stringify-safe@5.0.1
                                      │ │ ├─┬ mime-types@2.1.8
                                      │ │ │ └── mime-db@1.20.0
                                      │ │ ├── node-uuid@1.4.7
                                      │ │ ├── oauth-sign@0.8.0
                                      │ │ ├── qs@5.2.0
                                      │ │ ├── stringstream@0.0.5
                                      │ │ ├── tough-cookie@2.2.1
                                      │ │ └── tunnel-agent@0.4.2
                                      │ ├── retry@0.8.0
                                      │ ├── rimraf@2.4.4
                                      │ ├── semver@5.1.0
                                      │ ├─┬ sha@2.0.1
                                      │ │ └─┬ readable-stream@2.0.2
                                      │ ├── slide@1.1.6
                                      │ ├── sorted-object@1.0.0
                                      │ ├── strip-ansi@3.0.0
                                      │ ├─┬ tar@2.2.1
                                      │ │ └── block-stream@0.0.8
                                      │ ├── text-table@0.2.0
                                      │ ├── uid-number@0.0.6
                                      │ ├── umask@1.1.0
                                      │ ├─┬ unique-filename@1.1.0
                                      │ │ └── unique-slug@2.0.0
                                      │ ├── unpipe@1.0.0
                                      │ ├─┬ validate-npm-package-license@3.0.1
                                      │ │ ├─┬ spdx-correct@1.0.1
                                      │ │ │ └── spdx-license-ids@1.0.2
                                      │ │ └─┬ spdx-expression-parse@1.0.0
                                      │ │   └── spdx-exceptions@1.0.3
                                      │ ├─┬ validate-npm-package-name@2.2.2
                                      │ │ └── builtins@0.0.7
                                      │ ├─┬ which@1.2.0
                                      │ │ └─┬ is-absolute@0.1.7
                                      │ │   └── is-relative@0.1.3
                                      │ ├── wrappy@1.0.1
                                      │ └── write-file-atomic@1.1.4
                                      └─┬ serialport@2.0.5
                                        ├── async@0.9.0
                                        ├── bindings@1.2.1
                                        ├─┬ debug@2.2.0
                                        │ └── ms@0.7.1
                                        ├── nan@2.0.9
                                        ├─┬ node-pre-gyp@0.6.18
                                        │ ├─┬ mkdirp@0.5.1
                                        │ ├─┬ nopt@3.0.6
                                        │ │ └── abbrev@1.0.7
                                        │ ├─┬ npmlog@2.0.0
                                        │ │ ├── ansi@0.3.0
                                        │ │ ├─┬ are-we-there-yet@1.0.5
                                        │ │ │ └─┬ readable-stream@2.0.5
                                        │ │ │   ├── inherits@2.0.1
                                        │ │ └─┬ gauge@1.2.2
                                        │ │   ├── has-unicode@1.0.1
                                        │ ├─┬ rc@1.1.5
                                        │ │ ├── deep-extend@0.4.0
                                        │ │ ├── ini@1.3.4
                                        │ │ ├── minimist@1.2.0
                                        │ │ └── strip-json-comments@1.0.4
                                        │ │ ├─┬ bl@1.0.0
                                        │ │ │ │ ├─┬ has-ansi@2.0.0
                                        │ │ │ │ │ └── ansi-regex@2.0.0
                                        │ │ │ │ ├─┬ strip-ansi@3.0.0
                                        │ │ ├─┬ hawk@3.1.2
                                        │ │ ├── qs@5.2.0
                                        │ ├─┬ rimraf@2.4.4
                                        │ │ └─┬ glob@5.0.15
                                        │ │   ├─┬ inflight@1.0.4
                                        │ │   │ └── wrappy@1.0.1
                                        │ │   ├─┬ once@1.3.3
                                        │ ├── semver@5.1.0
                                        │ ├─┬ tar@2.2.1
                                        │ │ ├── block-stream@0.0.8
                                        │ │ ├─┬ fstream@1.0.8
                                        │ │ │ └── graceful-fs@4.1.2
                                        │ │ └── inherits@2.0.1
                                        │ └─┬ tar-pack@3.1.2
                                        │   ├── debug@0.7.4
                                        │   ├─┬ fstream@1.0.8
                                        │   │ ├── graceful-fs@4.1.2
                                        │   ├─┬ fstream-ignore@1.0.3
                                        │   ├── once@1.1.1
                                        │   ├─┬ readable-stream@2.0.5
                                        │   └── uid-number@0.0.3
                                        ├─┬ node-pre-gyp-github@1.0.4 invalid (git://github.com/jacobrosenthal/node-pre-gyp-github.git#8f8b71c6111230d6535ccd21ffbb725aaa068cf0)
                                        │ ├── github@0.2.4
                                        │ ├── mime@1.3.4
                                        │ └─┬ request@2.65.0
                                        │   ├─┬ bl@1.0.0
                                        │   │ └─┬ readable-stream@2.0.3
                                        │   ├── extend@3.0.0
                                        │   │ └── async@1.5.0
                                        │   ├─┬ har-validator@2.0.2
                                        │   │ ├─┬ chalk@1.1.1
                                        │   │ ├─┬ is-my-json-valid@2.12.2
                                        │   │ │ └── xtend@4.0.0
                                        │   │ └─┬ pinkie-promise@1.0.0
                                        │   │   └── pinkie@1.0.0
                                        │   ├─┬ hawk@3.1.0
                                        │   │ ├── boom@2.10.0
                                        │   │ ├── hoek@2.16.3
                                        │   │ └── sntp@1.0.9
                                        │   ├─┬ http-signature@0.11.0
                                        │   │ ├── asn1@0.1.11
                                        │   │ └── ctype@0.5.3
                                        │   ├─┬ mime-types@2.1.7
                                        │   │ └── mime-db@1.19.0
                                        │   ├── node-uuid@1.4.3
                                        │   ├── qs@5.2.0
                                        │   ├── tough-cookie@2.2.0
                                        │   └── tunnel-agent@0.4.1
                                        ├─┬ optimist@0.6.1
                                        │ ├── minimist@0.0.10
                                        │ └── wordwrap@0.0.3
                                        └── sf@0.1.7
                                      npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json'
                                      npm ERR! extraneous: serialport /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
                                      npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json'
                                      npm ERR! invalid: node-pre-gyp-github@1.0.4 /usr/local/lib/node_modules/serialport/node_modules/node-pre-gyp-github
                                      • mfalkviddM
                                        pi@raspberrypi ~ $ sudo npm -g install node-red-node-serialport@0.0.5
                                        npm WARN lifecycle serialport@1.7.4~install: cannot run in wd %s %s (wd=%s) serialport@1.7.4 node-pre-gyp install --fallback-to-build /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
                                        /usr/local/lib
                                        └─┬ node-red-node-serialport@0.0.5
                                          └─┬ serialport@1.7.4
                                            ├── async@0.9.0
                                            ├── bindings@1.2.1
                                            ├─┬ debug@2.2.0
                                            │ └── ms@0.7.1
                                            ├── nan@1.8.4
                                            ├─┬ node-pre-gyp@0.6.7
                                            │ ├─┬ mkdirp@0.5.0
                                            │ ├─┬ nopt@3.0.1
                                            │ │ └── abbrev@1.0.5
                                            │ ├─┬ npmlog@1.2.0
                                            │ │ ├── ansi@0.3.0
                                            │ │ └─┬ gauge@1.2.0
                                            │ │   ├── has-unicode@1.0.0
                                            │ │   ├─┬ lodash.pad@3.1.0
                                            │ │   │ ├── lodash._basetostring@3.0.0
                                            │ │   │ └─┬ lodash._createpadding@3.6.0
                                            │ │   │   └── lodash.repeat@3.0.0
                                            │ ├─┬ rc@1.0.1
                                            │ │ ├── deep-extend@0.2.11
                                            │ │ ├── ini@1.3.3
                                            │ │ ├── minimist@0.0.10
                                            │ │ └── strip-json-comments@0.1.3
                                            │ ├─┬ request@2.55.0
                                            │ │ ├── aws-sign2@0.5.0
                                            │ │ ├─┬ bl@0.9.4
                                            │ │ │ └─┬ readable-stream@1.0.33
                                            │ │ ├── caseless@0.9.0
                                            │ │ ├─┬ combined-stream@0.0.7
                                            │ │ │ └── delayed-stream@0.0.5
                                            │ │ ├─┬ form-data@0.2.0
                                            │ │ │ └── async@0.9.0
                                            │ │ ├─┬ har-validator@1.7.0
                                            │ │ │ ├── bluebird@2.9.25
                                            │ │ │ ├─┬ chalk@1.0.0
                                            │ │ │ │ ├── ansi-styles@2.0.1
                                            │ │ │ │ ├─┬ has-ansi@1.0.3
                                            │ │ │ │ │ ├── ansi-regex@1.1.1
                                            │ │ │ │ │ └── get-stdin@4.0.1
                                            │ │ │ │ ├─┬ strip-ansi@2.0.1
                                            │ │ │ │ │ └── ansi-regex@1.1.1
                                            │ │ │ │ └── supports-color@1.3.1
                                            │ │ │ ├─┬ commander@2.8.1
                                            │ │ │ └─┬ is-my-json-valid@2.10.1
                                            │ │ │   ├─┬ generate-object-property@1.1.1
                                            │ │ │   ├── jsonpointer@1.1.0
                                            │ │ ├─┬ hawk@2.3.1
                                            │ │ │ ├── boom@2.7.1
                                            │ │ │ ├── cryptiles@2.0.4
                                            │ │ │ ├── hoek@2.13.0
                                            │ │ ├─┬ http-signature@0.10.1
                                            │ │ │ ├── asn1@0.1.11
                                            │ │ │ └── ctype@0.5.3
                                            │ │ ├── json-stringify-safe@5.0.0
                                            │ │ ├─┬ mime-types@2.0.10
                                            │ │ │ └── mime-db@1.8.0
                                            │ │ ├── node-uuid@1.4.3
                                            │ │ ├── oauth-sign@0.6.0
                                            │ │ ├── qs@2.4.1
                                            │ │ ├── stringstream@0.0.4
                                            │ │ ├── tough-cookie@1.1.0
                                            │ │ └── tunnel-agent@0.4.0
                                            │ ├─┬ rimraf@2.3.3
                                            │ │ └─┬ glob@4.5.3
                                            │ │   ├─┬ minimatch@2.0.7
                                            │ │   │ └─┬ brace-expansion@1.1.0
                                            │ │   └─┬ once@1.3.1
                                            │ ├── semver@4.3.3
                                            │ ├─┬ tar@2.1.0
                                            │ │ ├── block-stream@0.0.7
                                            │ │ ├─┬ fstream@1.0.4
                                            │ │ │ └── graceful-fs@3.0.6
                                            │ └─┬ tar-pack@2.0.0
                                            │   ├── debug@0.7.4
                                            │   ├─┬ fstream@0.1.31
                                            │   │ ├── graceful-fs@3.0.6
                                            │   ├─┬ fstream-ignore@0.0.7
                                            │   │ └─┬ minimatch@0.2.14
                                            │   │   ├── lru-cache@2.6.2
                                            │   │   └── sigmund@1.0.0
                                            │   ├── graceful-fs@1.2.3
                                            │   ├── once@1.1.1
                                            │   ├─┬ readable-stream@1.0.33
                                            │   ├── rimraf@2.2.8
                                            │   ├─┬ tar@0.1.20
                                            ├─┬ optimist@0.6.1
                                            └── sf@0.1.7
                                        • fetsF
                                          fetsF
                                          fets
                                          Sorry, I don't understand why it doen'twork. This is beyond my capabilities.
                                          May be you should erase all directories name serial and node-serial in /usr/lib/node_modules/node-red/node_modules and your local node_modules in case of conflits with previous attempts
