  3. MyController.org
  4. MyController+Domoticz at same time?
Scheduled Pinned Locked Moved MyController.org
33 Posts 9 Posters 18.2k Views 12 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    I also use multiple controllers. Vera, domoticz and myscontroller. Node-red acts as transport which also permit me to do special management for certain controllers as well as injecting/extracting specific messages in the flow (the pushbullet plugin in node-red is especially nice).
    I also use all controllers for "input" and at least for nodes that send ACK it works just fine. That is, doing an action in one controller causes the other controllers to update as well when the ACK is returned to all of them.
    • mfalkviddM
      Thought I'd report back.
      I have spent approximately 3 hours experimenting, googling and learning but not much luck so far.
      MyController is installed on my Raspberry Pi. The installation was simple (great work @jkandasa!) and I am able to receive MySensor traffic if I configure MyController to read directly from /dev/ttyMySensorsGateway (with the gateway disabled in Domoticz).
      I have been able to configure Domoticz to send all events to Domoticz/out on the mosquitto broker that's installed with Domoticz. MyController is then able to read from the topic, but it is unable to parse the messages since Domoticz's message format differs from what MyController expects.
      I have tried fets/tbowmo's suggestion but was unable to figure out how to install the serial port plugin. On the way I learned that npm search is useless unless you have >16GB ram which my raspberry pi does not - use the website search instead (npm search is a pile of smoldering debris). I also learned that the URL parsing function in npm was broken in the version I was running but that was fixed after an upgrade and that the --unsafe-perm parameter sometimes is required when using sudo due to a bug in node-gyp.
      I have learned to use NodeRed and I really like it (as long as I don't need to mess with npm). I am unable to get npm to install packages in /usr/lib/node_modules/node-red/node_modules (where node-read reads) though, npm wants to install them in /usr/local/lib/node_modules/ Does anyone know why this is? I created symlinks for the packages I installed which worked for node-red-contrib-mysensors but node-red-node-serialport doesn't show up in the NodeRed UI.
      It looks like I should build myself an ethernet gateway to be able to proceed. I have a few ESPs, but they keep rebooting which I have seen several other people having problems with as well so I am a bit hesitant to go that route. Maybe buying a W5100 or ENC28J60 module is the way to go instead?
      So it's been an evening with lots of learning, which is great. I don't have a working system yet though. Suggestions are welcome, I'll sleep on the problem and try again later.
      fetsF 1 Reply Last reply
        wrote on last edited by hek
        npm install <package> -g perhaps?
        And avoid the ENC28J60 ...
          fetsF
          fetsF
          fets
          wrote on last edited by fets
          @mfalkvidd : sudo apt-get install socat
          Then to execute, command line : socat PTY,link=/dev/ttyS80,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB20,mode=666,group=dialout,raw &
          Then on node-red, I configure serial com (to and from domoticz) using /dev/ttyS80.
          On Domoticz, the serial gateway is configure using port /dev/ttyUSB20
          That's all folks
          How do you "I have been able to configure Domoticz to send all events to Domoticz/out" ?
            Yes, that's what I am using.
            Thanks. I 'll stay away from it.
            • fetsF fets
              That's all folks
              Sorry for being unclear. Installing socat is not a problem. The problem is that I don't have a serial input/output block in nodered.
                fetsF
                fetsF
                fets
                @mfalkvidd sorry my misunderstanding.
                For serial, I think it was : npm install node-red-node-serialport
                Thanks for MQTT domoticz, I thought it was an input for domoticz :(
                • mfalkviddM
                  @fets you're welcome. It is a bit hidden :)
                  I have also found out that cloudmqtt offers a free personal mqtt broker. That might be useful.
                  I have installed node-red-node-serialport:
                  npm install -g --unsafe-perm node-red-node-serialport
                  ln -s /usr/local/lib/node_modules/node-red-node-serialport /usr/lib/node_modules/node-red/node_modules
                  (exactly what I did with node-red-contrib-mysensors) and restarted nodered and restarted my browser, but there's still no Serial port building block.
                  • fetsF
                    fetsF
                    fets
                    Did you check logs at node-red startup for errors, or try to run with -v flag
                    • mfalkviddM
                      I thought I did :blush: but now I'm getting something suspicious:
                      Welcome to Node-RED
                      5 Jan 21:38:44 - [info] Node-RED version: v0.10.6
                      5 Jan 21:38:44 - [info] Node.js  version: v0.12.1
                      5 Jan 21:38:44 - [info] Loading palette nodes
                      5 Jan 21:38:51 - [warn] ------------------------------------------
                      5 Jan 21:38:51 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
                      5 Jan 21:38:51 - [warn] [serial] Error: Cannot find module '/usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v14-linux-arm/serialport.node'
                      5 Jan 21:38:51 - [warn] [redisout] Error: Cannot find module 'redis'
                      5 Jan 21:38:51 - [warn] [mongodb] Error: Cannot find module 'mongodb'
                      5 Jan 21:38:51 - [warn] [serialport] serial in already registered
                      5 Jan 21:38:51 - [info] User Directory : /home/pi/.node-red
                      5 Jan 21:38:51 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
                      5 Jan 21:38:51 - [info] Server now running at http://127.0.0.1:1880/
                      5 Jan 21:38:51 - [info] Starting flows
                      5 Jan 21:38:52 - [info] Started flows
                      5 Jan 21:38:52 - [mqtt] [e7f85c03.1807a] connected to broker tcp://localhost:1883
                      pi@raspberrypi ~ $ ls -laR /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/
                      /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/:
                      total 12
                      drwxr-xr-x 3 root root 4096 Jun 13  2015 .
                      drwxr-xr-x 3 root root 4096 Jun 13  2015 ..
                      drwxr-xr-x 2 root root 4096 Jun 13  2015 node-v11-linux-arm
                      /usr/lib/node_modules/node-red/node_modules/serialport/build/serialport/v1.4.10/Release/node-v11-linux-arm:
                      total 52
                      drwxr-xr-x 2 root root  4096 Jun 13  2015 .
                      -rwxr-xr-x 1 root root 44841 Jun 13  2015 serialport.node
                      • fetsF
                        fetsF
                        fets
                        I think your issue comes from your nodejs version.
                        I'm now running v4.2.4.
                        Check node-red-serial , Install section.
                        Maybe this will solve your issue
                        • mfalkviddM
                          I'll try that. My gcc version is <4.8 so I need to use the alternative version.
                          Do I need to remove the other packages? I seem unable to do that:
                          pi@raspberrypi ~ $ gcc -v
                          Using built-in specs.
                          COLLECT_GCC=gcc
                          COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.7/lto-wrapper
                          Target: arm-linux-gnueabihf
                          Configured with: ../src/configure -v --with-pkgversion='Debian 4.7.2-5+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
                          Thread model: posix
                          gcc version 4.7.2 (Debian 4.7.2-5+rpi1)
                          pi@raspberrypi ~ $ sudo npm uninstall --unsafe-perm node-red-node-serialport
                          - ansi-regex@2.0.0 node_modules/ansi-regex
                          - ansi-styles@2.1.0 node_modules/ansi-styles
                          - asn1@0.2.3 node_modules/asn1
                          - assert-plus@0.1.5 node_modules/assert-plus
                          - async@0.9.0 node_modules/async
                          - aws-sign2@0.6.0 node_modules/aws-sign2
                          - bindings@1.2.1 node_modules/bindings
                          - bl@1.0.0 node_modules/bl
                          - boom@2.10.1 node_modules/boom
                          - caseless@0.11.0 node_modules/caseless
                          - chalk@1.1.1 node_modules/chalk
                          - combined-stream@1.0.5 node_modules/combined-stream
                          - commander@2.9.0 node_modules/commander
                          - core-util-is@1.0.2 node_modules/core-util-is
                          - cryptiles@2.0.5 node_modules/cryptiles
                          - dashdash@1.11.0 node_modules/dashdash
                          - debug@2.2.0 node_modules/debug
                          - delayed-stream@1.0.0 node_modules/delayed-stream
                          - ecc-jsbn@0.1.1 node_modules/ecc-jsbn
                          - escape-string-regexp@1.0.4 node_modules/escape-string-regexp
                          - extend@3.0.0 node_modules/extend
                          - extsprintf@1.0.2 node_modules/extsprintf
                          - forever-agent@0.6.1 node_modules/forever-agent
                          - form-data@1.0.0-rc3 node_modules/form-data
                          - async@1.5.1 node_modules/form-data/node_modules/async
                          - generate-function@2.0.0 node_modules/generate-function
                          - generate-object-property@1.2.0 node_modules/generate-object-property
                          - github@0.2.4 node_modules/github
                          - graceful-readlink@1.0.1 node_modules/graceful-readlink
                          - har-validator@2.0.3 node_modules/har-validator
                          - has-ansi@2.0.0 node_modules/has-ansi
                          - hawk@3.1.2 node_modules/hawk
                          - hoek@2.16.3 node_modules/hoek
                          - http-signature@1.1.0 node_modules/http-signature
                          - inherits@2.0.1 node_modules/inherits
                          - is-my-json-valid@2.12.3 node_modules/is-my-json-valid
                          - is-property@1.0.2 node_modules/is-property
                          - is-typedarray@1.0.0 node_modules/is-typedarray
                          - isarray@0.0.1 node_modules/isarray
                          - isstream@0.1.2 node_modules/isstream
                          - jodid25519@1.0.2 node_modules/jodid25519
                          - jsbn@0.1.0 node_modules/jsbn
                          - json-schema@0.2.2 node_modules/json-schema
                          - json-stringify-safe@5.0.1 node_modules/json-stringify-safe
                          - jsonpointer@2.0.0 node_modules/jsonpointer
                          - jsprim@1.2.2 node_modules/jsprim
                          - mime@1.3.4 node_modules/mime
                          - mime-db@1.20.0 node_modules/mime-db
                          - mime-types@2.1.8 node_modules/mime-types
                          - minimist@0.0.10 node_modules/minimist
                          - ms@0.7.1 node_modules/ms
                          - nan@2.0.9 node_modules/nan
                          - node-red-node-serialport@0.1.0 node_modules/node-red-node-serialport
                          - node-uuid@1.4.7 node_modules/node-uuid
                          - oauth-sign@0.8.0 node_modules/oauth-sign
                          - optimist@0.6.1 node_modules/optimist
                          - pinkie@2.0.1 node_modules/pinkie
                          - pinkie-promise@2.0.0 node_modules/pinkie-promise
                          - process-nextick-args@1.0.6 node_modules/process-nextick-args
                          - qs@5.2.0 node_modules/qs
                          - readable-stream@2.0.5 node_modules/readable-stream
                          - request@2.67.0 node_modules/request
                          - serialport@2.0.5 node_modules/serialport
                          - node-pre-gyp@0.6.13 node_modules/serialport/node_modules/node-pre-gyp
                          - node-pre-gyp-github@1.0.5 node_modules/serialport/node_modules/node-pre-gyp-github
                          - mkdirp@0.5.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp
                          - minimist@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/mkdirp/node_modules/minimist
                          - nopt@3.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt
                          - abbrev@1.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/nopt/node_modules/abbrev
                          - npmlog@1.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog
                          - ansi@0.3.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/ansi
                          - are-we-there-yet@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet
                          - delegates@0.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/delegates
                          - readable-stream@1.1.13 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream
                          - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/core-util-is
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/inherits
                          - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/isarray
                          - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/readable-stream/node_modules/string_decoder
                          - gauge@1.2.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge
                          - has-unicode@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/has-unicode
                          - lodash.pad@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad
                          - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._basetostring
                          - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding
                          - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.pad/node_modules/lodash._createpadding/node_modules/lodash.repeat
                          - lodash.padleft@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft
                          - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._basetostring
                          - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding
                          - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padleft/node_modules/lodash._createpadding/node_modules/lodash.repeat
                          - lodash.padright@3.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright
                          - lodash._basetostring@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._basetostring
                          - lodash._createpadding@3.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding
                          - lodash.repeat@3.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/npmlog/node_modules/gauge/node_modules/lodash.padright/node_modules/lodash._createpadding/node_modules/lodash.repeat
                          - rc@1.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
                          - deep-extend@0.2.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/deep-extend
                          - ini@1.3.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/ini
                          - minimist@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/minimist
                          - strip-json-comments@0.1.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc/node_modules/strip-json-comments
                          - request@2.65.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
                          - aws-sign2@0.6.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/aws-sign2
                          - bl@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl
                          - readable-stream@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream
                          - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/core-util-is
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/inherits
                          - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/isarray
                          - process-nextick-args@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/process-nextick-args
                          - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/string_decoder
                          - util-deprecate@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/util-deprecate
                          - caseless@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/caseless
                          - combined-stream@1.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream
                          - delayed-stream@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
                          - extend@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/extend
                          - forever-agent@0.6.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/forever-agent
                          - form-data@1.0.0-rc3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data
                          - async@1.4.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/form-data/node_modules/async
                          - har-validator@2.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator
                          - chalk@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk
                          - ansi-styles@2.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
                          - escape-string-regexp@1.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
                          - has-ansi@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
                          - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
                          - strip-ansi@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
                          - ansi-regex@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
                          - supports-color@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
                          - commander@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander
                          - graceful-readlink@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
                          - is-my-json-valid@2.12.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
                          - generate-function@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
                          - generate-object-property@1.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
                          - is-property@1.0.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
                          - jsonpointer@2.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
                          - xtend@4.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/xtend
                          - pinkie-promise@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
                          - pinkie@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
                          - hawk@3.1.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk
                          - boom@2.9.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/boom
                          - cryptiles@2.0.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/cryptiles
                          - hoek@2.16.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/hoek
                          - sntp@1.0.9 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/hawk/node_modules/sntp
                          - http-signature@0.11.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature
                          - asn1@0.1.11 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/asn1
                          - assert-plus@0.1.5 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/assert-plus
                          - ctype@0.5.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-signature/node_modules/ctype
                          - isstream@0.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/isstream
                          - json-stringify-safe@5.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/json-stringify-safe
                          - mime-types@2.1.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types
                          - mime-db@1.19.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/mime-types/node_modules/mime-db
                          - node-uuid@1.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/node-uuid
                          - oauth-sign@0.8.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/oauth-sign
                          - qs@5.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/qs
                          - stringstream@0.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/stringstream
                          - tough-cookie@2.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tough-cookie
                          - tunnel-agent@0.4.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/tunnel-agent
                          - rimraf@2.4.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf
                          - glob@5.0.15 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob
                          - inflight@1.0.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight
                          - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inflight/node_modules/wrappy
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/inherits
                          - minimatch@3.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch
                          - brace-expansion@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion
                          - balanced-match@0.2.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/balanced-match
                          - concat-map@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/minimatch/node_modules/brace-expansion/node_modules/concat-map
                          - once@1.3.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once
                          - wrappy@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/once/node_modules/wrappy
                          - path-is-absolute@1.0.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/rimraf/node_modules/glob/node_modules/path-is-absolute
                          - semver@5.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/semver
                          - tar@2.2.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar
                          - tar-pack@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
                          - debug@0.7.4 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/debug
                          - fstream@0.1.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream
                          - fstream-ignore@0.0.7 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/inherits
                          - minimatch@0.2.14 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch
                          - lru-cache@2.7.0 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/lru-cache
                          - sigmund@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream-ignore/node_modules/minimatch/node_modules/sigmund
                          - graceful-fs@3.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/graceful-fs
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/fstream/node_modules/inherits
                          - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/graceful-fs
                          - once@1.1.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/once
                          - readable-stream@1.0.33 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream
                          - core-util-is@1.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/core-util-is
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/inherits
                          - isarray@0.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/isarray
                          - string_decoder@0.10.31 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/readable-stream/node_modules/string_decoder
                          - rimraf@2.2.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/rimraf
                          - tar@0.1.20 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar
                          - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/block-stream
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/tar/node_modules/inherits
                          - uid-number@0.0.3 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack/node_modules/uid-number
                          - block-stream@0.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/block-stream
                          - fstream@1.0.8 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream
                          - graceful-fs@4.1.2 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/fstream/node_modules/graceful-fs
                          - inherits@2.0.1 node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar/node_modules/inherits
                          - sf@0.1.7 node_modules/sf
                          - sntp@1.0.9 node_modules/sntp
                          - sshpk@1.7.1 node_modules/sshpk
                          - assert-plus@0.2.0 node_modules/sshpk/node_modules/assert-plus
                          - string_decoder@0.10.31 node_modules/string_decoder
                          - stringstream@0.0.5 node_modules/stringstream
                          - strip-ansi@3.0.0 node_modules/strip-ansi
                          - supports-color@2.0.0 node_modules/supports-color
                          - tough-cookie@2.2.1 node_modules/tough-cookie
                          - tunnel-agent@0.4.2 node_modules/tunnel-agent
                          - tweetnacl@0.13.2 node_modules/tweetnacl
                          - util-deprecate@1.0.2 node_modules/util-deprecate
                          - verror@1.3.6 node_modules/verror
                          - wordwrap@0.0.3 node_modules/wordwrap
                          - xtend@4.0.1 node_modules/xtend
                          npm WARN enoent ENOENT, open '/home/pi/package.json'
                          npm WARN pi No description
                          npm WARN pi No repository field.
                          npm WARN pi No README data
                          npm WARN pi No license field.
                          • mfalkviddM
                            pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport
                            (>32kB output)
                            pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm node-red-node-serialport@0.1.0; sudo npm uninstall --unsafe-perm node-red-node-serialport@0.1.0
                            - node-pre-gyp node_modules/serialport/node_modules/node-pre-gyp
                            - rc node_modules/serialport/node_modules/node-pre-gyp/node_modules/rc
                            - request node_modules/serialport/node_modules/node-pre-gyp/node_modules/request
                            - tar-pack node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack
                            npm WARN enoent ENOENT, open '/home/pi/node_modules/serialport/package.json'
                            pi@raspberrypi ~ $ sudo npm uninstall -g --unsafe-perm serialport@2.0.5; sudo npm uninstall --unsafe-perm serialport@2.0.5
                            pi@raspberrypi ~ $ sudo npm -g list
                            /usr/local/lib
                            ├─┬ mdns@2.2.11
                            │ ├── bindings@1.2.1
                            │ └── nan@2.1.0
                            ├── node-red-contrib-mysensors@0.7.5
                            ├─┬  error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json
                            │ └──  extraneous error: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json
                            ├─┬ npm@3.5.3
                            │ ├── abbrev@1.0.7
                            │ ├── ansi-regex@2.0.0
                            │ ├── ansicolors@0.3.2
                            │ ├── ansistyles@0.1.3
                            │ ├── aproba@1.0.1
                            │ ├── archy@1.0.0
                            │ ├── async-some@1.0.2
                            │ ├── chownr@1.0.1
                            │ ├─┬ cmd-shim@2.0.1
                            │ │ └── graceful-fs@3.0.8
                            │ ├─┬ columnify@1.5.2
                            │ │ └─┬ wcwidth@1.0.0
                            │ │   └─┬ defaults@1.0.3
                            │ │     └── clone@1.0.2
                            │ ├─┬ config-chain@1.1.9
                            │ │ └── proto-list@1.2.4
                            │ ├── debuglog@1.0.1
                            │ ├─┬ dezalgo@1.0.3
                            │ │ └── asap@2.0.3
                            │ ├── editor@1.0.0
                            │ ├── fs-vacuum@1.2.7
                            │ ├── fs-write-stream-atomic@1.0.5
                            │ ├── fstream@1.0.8
                            │ ├─┬ fstream-npm@1.0.7
                            │ │ └─┬ fstream-ignore@1.0.3
                            │ │   └─┬ minimatch@3.0.0
                            │ │     └─┬ brace-expansion@1.1.1
                            │ │       ├── balanced-match@0.2.1
                            │ │       └── concat-map@0.0.1
                            │ ├─┬ glob@5.0.15
                            │ │ ├─┬ minimatch@3.0.0
                            │ │ │ └─┬ brace-expansion@1.1.1
                            │ │ │   ├── balanced-match@0.2.0
                            │ │ │   └── concat-map@0.0.1
                            │ │ └── path-is-absolute@1.0.0
                            │ ├── graceful-fs@4.1.2
                            │ ├── has-unicode@1.0.1
                            │ ├── hosted-git-info@2.1.4
                            │ ├── iferr@0.1.5
                            │ ├── imurmurhash@0.1.4
                            │ ├── inflight@1.0.4
                            │ ├── inherits@2.0.1
                            │ ├── ini@1.3.4
                            │ ├─┬ init-package-json@1.9.1
                            │ │ └── promzard@0.3.0
                            │ ├── lockfile@1.0.1
                            │ ├── lodash._baseindexof@3.1.0
                            │ ├── lodash._baseuniq@3.0.3
                            │ ├── lodash._bindcallback@3.0.1
                            │ ├── lodash._cacheindexof@3.0.2
                            │ ├── lodash._createcache@3.1.2
                            │ ├── lodash._getnative@3.9.1
                            │ ├─┬ lodash.clonedeep@3.0.2
                            │ │ └─┬ lodash._baseclone@3.3.0
                            │ │   ├── lodash._arraycopy@3.0.0
                            │ │   ├── lodash._arrayeach@3.0.0
                            │ │   ├─┬ lodash._baseassign@3.2.0
                            │ │   │ └── lodash._basecopy@3.0.1
                            │ │   └── lodash._basefor@3.0.2
                            │ ├── lodash.isarguments@3.0.4
                            │ ├── lodash.isarray@3.0.4
                            │ ├── lodash.keys@3.1.2
                            │ ├── lodash.restparam@3.6.1
                            │ ├─┬ lodash.union@3.1.0
                            │ │ └── lodash._baseflatten@3.1.4
                            │ ├─┬ lodash.uniq@3.2.2
                            │ │ ├─┬ lodash._basecallback@3.3.1
                            │ │ │ ├─┬ lodash._baseisequal@3.0.7
                            │ │ │ │ └── lodash.istypedarray@3.0.2
                            │ │ │ └── lodash.pairs@3.0.1
                            │ │ └── lodash._isiterateecall@3.0.9
                            │ ├─┬ lodash.without@3.2.1
                            │ │ └── lodash._basedifference@3.0.3
                            │ ├─┬ mkdirp@0.5.1
                            │ │ └── minimist@0.0.8
                            │ ├─┬ node-gyp@3.2.1
                            │ │ ├─┬ glob@4.5.3
                            │ │ │ └─┬ minimatch@2.0.10
                            │ │ │   └─┬ brace-expansion@1.1.2
                            │ │ │     ├── balanced-match@0.3.0
                            │ │ ├─┬ minimatch@1.0.0
                            │ │ │ ├── lru-cache@2.7.3
                            │ │ │ └── sigmund@1.0.1
                            │ │ ├─┬ npmlog@1.2.1
                            │ │ │ ├── ansi@0.3.0
                            │ │ │ ├─┬ are-we-there-yet@1.0.4
                            │ │ │ │ ├── delegates@0.1.0
                            │ │ │ │ └─┬ readable-stream@1.1.13
                            │ │ │ │   ├── core-util-is@1.0.2
                            │ │ │ │   ├── isarray@0.0.1
                            │ │ │ │   └── string_decoder@0.10.31
                            │ │ │ └─┬ gauge@1.2.2
                            │ │ │   ├─┬ lodash.pad@3.1.1
                            │ │ │   │ ├── lodash._basetostring@3.0.1
                            │ │ │   │ └─┬ lodash._createpadding@3.6.1
                            │ │ │   │   └── lodash.repeat@3.0.1
                            │ │ │   ├─┬ lodash.padleft@3.1.1
                            │ │ │   └─┬ lodash.padright@3.1.1
                            │ │ └─┬ path-array@1.0.0
                            │ │   └─┬ array-index@0.1.1
                            │ │     └─┬ debug@2.2.0
                            │ │       └── ms@0.7.1
                            │ ├── nopt@3.0.6
                            │ ├── normalize-git-url@3.0.1
                            │ ├─┬ normalize-package-data@2.3.5
                            │ │ └─┬ is-builtin-module@1.0.0
                            │ │   └── builtin-modules@1.1.0
                            │ ├── npm-cache-filename@1.0.2
                            │ ├─┬ npm-install-checks@2.0.1
                            │ │ └─┬ npmlog@1.2.1
                            │ │   ├── ansi@0.3.0
                            │ │   │   ├── core-util-is@1.0.1
                            │ │   └─┬ gauge@1.2.2
                            │ ├── npm-package-arg@4.1.0
                            │ ├─┬ npm-registry-client@7.0.9
                            │ │ └─┬ concat-stream@1.5.1
                            │ │   ├─┬ readable-stream@2.0.4
                            │ │   │ ├── process-nextick-args@1.0.3
                            │ │   │ ├── string_decoder@0.10.31
                            │ │   │ └── util-deprecate@1.0.2
                            │ │   └── typedarray@0.0.6
                            │ ├── npm-user-validate@0.1.2
                            │ ├─┬ npmlog@2.0.0
                            │ │ ├── ansi@0.3.0
                            │ │ └─┬ gauge@1.2.2
                            │ ├── once@1.3.3
                            │ ├── opener@1.4.1
                            │ ├─┬ osenv@0.1.3
                            │ │ ├── os-homedir@1.0.1
                            │ │ └── os-tmpdir@1.0.1
                            │ ├── path-is-inside@1.0.1
                            │ ├─┬ read@1.0.7
                            │ │ └── mute-stream@0.0.5
                            │ ├── read-cmd-shim@1.0.1
                            │ ├─┬ read-installed@4.0.3
                            │ │ └── util-extend@1.0.1
                            │ ├─┬ read-package-json@2.0.2
                            │ │ └─┬ json-parse-helpfulerror@1.0.3
                            │ │   └── jju@1.2.1
                            │ ├── read-package-tree@5.1.2
                            │ ├── readdir-scoped-modules@1.0.2
                            │ ├── realize-package-specifier@3.0.1
                            │ ├─┬ request@2.67.0
                            │ │ ├── aws-sign2@0.6.0
                            │ │ ├─┬ bl@1.0.0
                            │ │ │ └─┬ readable-stream@2.0.4
                            │ │ │   ├── process-nextick-args@1.0.6
                            │ │ ├── caseless@0.11.0
                            │ │ ├─┬ combined-stream@1.0.5
                            │ │ │ └── delayed-stream@1.0.0
                            │ │ ├── extend@3.0.0
                            │ │ ├── forever-agent@0.6.1
                            │ │ ├─┬ form-data@1.0.0-rc3
                            │ │ │ └── async@1.5.0
                            │ │ ├─┬ har-validator@2.0.3
                            │ │ │ ├─┬ chalk@1.1.1
                            │ │ │ │ ├── ansi-styles@2.1.0
                            │ │ │ │ ├── escape-string-regexp@1.0.3
                            │ │ │ │ ├── has-ansi@2.0.0
                            │ │ │ │ └── supports-color@2.0.0
                            │ │ │ ├─┬ commander@2.9.0
                            │ │ │ │ └── graceful-readlink@1.0.1
                            │ │ │ ├─┬ is-my-json-valid@2.12.3
                            │ │ │ │ ├── generate-function@2.0.0
                            │ │ │ │ ├─┬ generate-object-property@1.2.0
                            │ │ │ │ │ └── is-property@1.0.2
                            │ │ │ │ ├── jsonpointer@2.0.0
                            │ │ │ │ └── xtend@4.0.1
                            │ │ │ └─┬ pinkie-promise@2.0.0
                            │ │ │   └── pinkie@2.0.1
                            │ │ ├─┬ hawk@3.1.2
                            │ │ │ ├── boom@2.10.1
                            │ │ │ ├── cryptiles@2.0.5
                            │ │ │ ├── hoek@2.16.3
                            │ │ │ └── sntp@1.0.9
                            │ │ ├─┬ http-signature@1.1.0
                            │ │ │ ├── assert-plus@0.1.5
                            │ │ │ ├─┬ jsprim@1.2.2
                            │ │ │ │ ├── extsprintf@1.0.2
                            │ │ │ │ ├── json-schema@0.2.2
                            │ │ │ │ └── verror@1.3.6
                            │ │ │ └─┬ sshpk@1.7.1
                            │ │ │   ├── asn1@0.2.3
                            │ │ │   ├── assert-plus@0.2.0
                            │ │ │   ├─┬ dashdash@1.10.1
                            │ │ │   │ └── assert-plus@0.1.5
                            │ │ │   ├── ecc-jsbn@0.1.1
                            │ │ │   ├── jodid25519@1.0.2
                            │ │ │   ├── jsbn@0.1.0
                            │ │ │   └── tweetnacl@0.13.2
                            │ │ ├── is-typedarray@1.0.0
                            │ │ ├── isstream@0.1.2
                            │ │ ├── json-stringify-safe@5.0.1
                            │ │ ├─┬ mime-types@2.1.8
                            │ │ │ └── mime-db@1.20.0
                            │ │ ├── node-uuid@1.4.7
                            │ │ ├── oauth-sign@0.8.0
                            │ │ ├── qs@5.2.0
                            │ │ ├── stringstream@0.0.5
                            │ │ ├── tough-cookie@2.2.1
                            │ │ └── tunnel-agent@0.4.2
                            │ ├── retry@0.8.0
                            │ ├── rimraf@2.4.4
                            │ ├── semver@5.1.0
                            │ ├─┬ sha@2.0.1
                            │ │ └─┬ readable-stream@2.0.2
                            │ ├── slide@1.1.6
                            │ ├── sorted-object@1.0.0
                            │ ├── strip-ansi@3.0.0
                            │ ├─┬ tar@2.2.1
                            │ │ └── block-stream@0.0.8
                            │ ├── text-table@0.2.0
                            │ ├── uid-number@0.0.6
                            │ ├── umask@1.1.0
                            │ ├─┬ unique-filename@1.1.0
                            │ │ └── unique-slug@2.0.0
                            │ ├── unpipe@1.0.0
                            │ ├─┬ validate-npm-package-license@3.0.1
                            │ │ ├─┬ spdx-correct@1.0.1
                            │ │ │ └── spdx-license-ids@1.0.2
                            │ │ └─┬ spdx-expression-parse@1.0.0
                            │ │   └── spdx-exceptions@1.0.3
                            │ ├─┬ validate-npm-package-name@2.2.2
                            │ │ └── builtins@0.0.7
                            │ ├─┬ which@1.2.0
                            │ │ └─┬ is-absolute@0.1.7
                            │ │   └── is-relative@0.1.3
                            │ ├── wrappy@1.0.1
                            │ └── write-file-atomic@1.1.4
                            └─┬ serialport@2.0.5
                              ├── async@0.9.0
                              ├── bindings@1.2.1
                              ├─┬ debug@2.2.0
                              │ └── ms@0.7.1
                              ├── nan@2.0.9
                              ├─┬ node-pre-gyp@0.6.18
                              │ ├─┬ mkdirp@0.5.1
                              │ ├─┬ nopt@3.0.6
                              │ │ └── abbrev@1.0.7
                              │ ├─┬ npmlog@2.0.0
                              │ │ ├── ansi@0.3.0
                              │ │ ├─┬ are-we-there-yet@1.0.5
                              │ │ │ └─┬ readable-stream@2.0.5
                              │ │ │   ├── inherits@2.0.1
                              │ │ └─┬ gauge@1.2.2
                              │ │   ├── has-unicode@1.0.1
                              │ ├─┬ rc@1.1.5
                              │ │ ├── deep-extend@0.4.0
                              │ │ ├── ini@1.3.4
                              │ │ ├── minimist@1.2.0
                              │ │ └── strip-json-comments@1.0.4
                              │ │ ├─┬ bl@1.0.0
                              │ │ │ │ ├─┬ has-ansi@2.0.0
                              │ │ │ │ │ └── ansi-regex@2.0.0
                              │ │ │ │ ├─┬ strip-ansi@3.0.0
                              │ │ ├─┬ hawk@3.1.2
                              │ │ ├── qs@5.2.0
                              │ ├─┬ rimraf@2.4.4
                              │ │ └─┬ glob@5.0.15
                              │ │   ├─┬ inflight@1.0.4
                              │ │   │ └── wrappy@1.0.1
                              │ │   ├─┬ once@1.3.3
                              │ ├── semver@5.1.0
                              │ ├─┬ tar@2.2.1
                              │ │ ├── block-stream@0.0.8
                              │ │ ├─┬ fstream@1.0.8
                              │ │ │ └── graceful-fs@4.1.2
                              │ │ └── inherits@2.0.1
                              │ └─┬ tar-pack@3.1.2
                              │   ├── debug@0.7.4
                              │   ├─┬ fstream@1.0.8
                              │   │ ├── graceful-fs@4.1.2
                              │   ├─┬ fstream-ignore@1.0.3
                              │   ├── once@1.1.1
                              │   ├─┬ readable-stream@2.0.5
                              │   └── uid-number@0.0.3
                              ├─┬ node-pre-gyp-github@1.0.4 invalid (git://github.com/jacobrosenthal/node-pre-gyp-github.git#8f8b71c6111230d6535ccd21ffbb725aaa068cf0)
                              │ ├── github@0.2.4
                              │ ├── mime@1.3.4
                              │ └─┬ request@2.65.0
                              │   ├─┬ bl@1.0.0
                              │   │ └─┬ readable-stream@2.0.3
                              │   ├── extend@3.0.0
                              │   │ └── async@1.5.0
                              │   ├─┬ har-validator@2.0.2
                              │   │ ├─┬ chalk@1.1.1
                              │   │ ├─┬ is-my-json-valid@2.12.2
                              │   │ │ └── xtend@4.0.0
                              │   │ └─┬ pinkie-promise@1.0.0
                              │   │   └── pinkie@1.0.0
                              │   ├─┬ hawk@3.1.0
                              │   │ ├── boom@2.10.0
                              │   │ ├── hoek@2.16.3
                              │   │ └── sntp@1.0.9
                              │   ├─┬ http-signature@0.11.0
                              │   │ ├── asn1@0.1.11
                              │   │ └── ctype@0.5.3
                              │   ├─┬ mime-types@2.1.7
                              │   │ └── mime-db@1.19.0
                              │   ├── node-uuid@1.4.3
                              │   ├── qs@5.2.0
                              │   ├── tough-cookie@2.2.0
                              │   └── tunnel-agent@0.4.1
                              ├─┬ optimist@0.6.1
                              │ ├── minimist@0.0.10
                              │ └── wordwrap@0.0.3
                              └── sf@0.1.7
                            npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/package.json'
                            npm ERR! extraneous: serialport /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
                            npm ERR! error in /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport: ENOENT, open '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/package.json'
                            npm ERR! invalid: node-pre-gyp-github@1.0.4 /usr/local/lib/node_modules/serialport/node_modules/node-pre-gyp-github
                            • mfalkviddM
                              pi@raspberrypi ~ $ sudo npm -g install node-red-node-serialport@0.0.5
                              npm WARN lifecycle serialport@1.7.4~install: cannot run in wd %s %s (wd=%s) serialport@1.7.4 node-pre-gyp install --fallback-to-build /usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport
                              /usr/local/lib
                              └─┬ node-red-node-serialport@0.0.5
                                └─┬ serialport@1.7.4
                                  ├── async@0.9.0
                                  ├── bindings@1.2.1
                                  ├─┬ debug@2.2.0
                                  │ └── ms@0.7.1
                                  ├── nan@1.8.4
                                  ├─┬ node-pre-gyp@0.6.7
                                  │ ├─┬ mkdirp@0.5.0
                                  │ ├─┬ nopt@3.0.1
                                  │ │ └── abbrev@1.0.5
                                  │ ├─┬ npmlog@1.2.0
                                  │ │ ├── ansi@0.3.0
                                  │ │ └─┬ gauge@1.2.0
                                  │ │   ├── has-unicode@1.0.0
                                  │ │   ├─┬ lodash.pad@3.1.0
                                  │ │   │ ├── lodash._basetostring@3.0.0
                                  │ │   │ └─┬ lodash._createpadding@3.6.0
                                  │ │   │   └── lodash.repeat@3.0.0
                                  │ ├─┬ rc@1.0.1
                                  │ │ ├── deep-extend@0.2.11
                                  │ │ ├── ini@1.3.3
                                  │ │ ├── minimist@0.0.10
                                  │ │ └── strip-json-comments@0.1.3
                                  │ ├─┬ request@2.55.0
                                  │ │ ├── aws-sign2@0.5.0
                                  │ │ ├─┬ bl@0.9.4
                                  │ │ │ └─┬ readable-stream@1.0.33
                                  │ │ ├── caseless@0.9.0
                                  │ │ ├─┬ combined-stream@0.0.7
                                  │ │ │ └── delayed-stream@0.0.5
                                  │ │ ├─┬ form-data@0.2.0
                                  │ │ │ └── async@0.9.0
                                  │ │ ├─┬ har-validator@1.7.0
                                  │ │ │ ├── bluebird@2.9.25
                                  │ │ │ ├─┬ chalk@1.0.0
                                  │ │ │ │ ├── ansi-styles@2.0.1
                                  │ │ │ │ ├─┬ has-ansi@1.0.3
                                  │ │ │ │ │ ├── ansi-regex@1.1.1
                                  │ │ │ │ │ └── get-stdin@4.0.1
                                  │ │ │ │ ├─┬ strip-ansi@2.0.1
                                  │ │ │ │ │ └── ansi-regex@1.1.1
                                  │ │ │ │ └── supports-color@1.3.1
                                  │ │ │ ├─┬ commander@2.8.1
                                  │ │ │ └─┬ is-my-json-valid@2.10.1
                                  │ │ │   ├─┬ generate-object-property@1.1.1
                                  │ │ │   ├── jsonpointer@1.1.0
                                  │ │ ├─┬ hawk@2.3.1
                                  │ │ │ ├── boom@2.7.1
                                  │ │ │ ├── cryptiles@2.0.4
                                  │ │ │ ├── hoek@2.13.0
                                  │ │ ├─┬ http-signature@0.10.1
                                  │ │ │ ├── asn1@0.1.11
                                  │ │ │ └── ctype@0.5.3
                                  │ │ ├── json-stringify-safe@5.0.0
                                  │ │ ├─┬ mime-types@2.0.10
                                  │ │ │ └── mime-db@1.8.0
                                  │ │ ├── node-uuid@1.4.3
                                  │ │ ├── oauth-sign@0.6.0
                                  │ │ ├── qs@2.4.1
                                  │ │ ├── stringstream@0.0.4
                                  │ │ ├── tough-cookie@1.1.0
                                  │ │ └── tunnel-agent@0.4.0
                                  │ ├─┬ rimraf@2.3.3
                                  │ │ └─┬ glob@4.5.3
                                  │ │   ├─┬ minimatch@2.0.7
                                  │ │   │ └─┬ brace-expansion@1.1.0
                                  │ │   └─┬ once@1.3.1
                                  │ ├── semver@4.3.3
                                  │ ├─┬ tar@2.1.0
                                  │ │ ├── block-stream@0.0.7
                                  │ │ ├─┬ fstream@1.0.4
                                  │ │ │ └── graceful-fs@3.0.6
                                  │ └─┬ tar-pack@2.0.0
                                  │   ├── debug@0.7.4
                                  │   ├─┬ fstream@0.1.31
                                  │   │ ├── graceful-fs@3.0.6
                                  │   ├─┬ fstream-ignore@0.0.7
                                  │   │ └─┬ minimatch@0.2.14
                                  │   │   ├── lru-cache@2.6.2
                                  │   │   └── sigmund@1.0.0
                                  │   ├── graceful-fs@1.2.3
                                  │   ├── once@1.1.1
                                  │   ├─┬ readable-stream@1.0.33
                                  │   ├── rimraf@2.2.8
                                  │   ├─┬ tar@0.1.20
                                  ├─┬ optimist@0.6.1
                                  └── sf@0.1.7
                              • fetsF
                                fetsF
                                fets
                                Sorry, I don't understand why it doen'twork. This is beyond my capabilities.
                                May be you should erase all directories name serial and node-serial in /usr/lib/node_modules/node-red/node_modules and your local node_modules in case of conflits with previous attempts
                                • mfalkviddM
                                  Thanks a lot for your help @fets
                                  I got it working, finally! Not sure exactly what I did to get it working (I tried literally hundreds of things) but if someone has a similar problem, this might help:
                                  • Don't ever use npm -g. It is discouraged by the npm people, it is really broken when run with sudo and it is probably not what you want anyway.
                                  • For the node-red shipped with Domoticz's Raspberry pi image, run npm as the pi user when standing in the /usr/lib/node_modules/node-red folder
                                  • npm rebuild seems to be useful
                                  • npm ls is useful for troubleshooting. It shouldn't report any errors if everything is alright, but things seem to seldom be alright.
                                  • Have a lot of patience, npm is seriously slow on a Raspberry Pi
                                  Anyway, now I have Serial as input and output block in nodered. :sparkles:
                                  • crankyC
                                    crankyC
                                    cranky
                                    wrote on last edited by cranky
                                    #22
                                    You'll also probably want node-red-contrib-mysensors and a few other modules on flows.nodered.org
                                    I use TOR extensively for being able to nicely manage and manipulate data on my network securely. The trick is a few things:
                                    TOR: Providing a Hidden Service to SSH and HTTPS
                                    Node-Red: Self-signed certs, HTTPS, and user authentication turned on.
                                    Mosquitto: Providing MQTTSSL. node-red-contrib-mqttssl provides support for that
                                    But hek was gracious to make a "Controller>Node-Red" subforum, so come join me there!
                                    Edit: also, because npm is sometimes really braindead sometimes, try using -debug with whatever you're doing. It will many a times make it work where without debut will just hang forever.
                                      fetsF
                                      fetsF
                                      fets
                                      #23
                                      @mfalkvidd congrats
                                      @cranky thanks I noticed the new subforum and already follow it
                                      • ErrKE
                                        ErrKE
                                        ErrK
                                        wrote on last edited by ErrK
                                        #24
                                        @mfalkvidd do you have both MyController and Domoticz on the same Raspberry Pi?
                                        I will start from the Domoticz Raspberry Pi image and then try to install MyController.
                                        I use a ESP8266 gateway. Do you have any tips before i start?
                                        • mfalkviddM
                                          Yes I use the same raspberry pi for both controllers. You probably need the newer models with 1GB ram.
                                          I'm not really using mycontroller yet, have not spent time working with it.
