  3. message for V_tripped
3 Posts 2 Posters 1.5k Views 2 Watching
  • C
    C
    chdid
    I use this code for detect water leak.
    #define SKETCH_NAME "Debordement Eau"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    MySensor sensor_node;
    int oldValue=-1;
    int oldValue2=-1;
      sensor_node.begin();
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT );
      // Activate internal pull-ups
      sensor_node.present(PRIMARY_CHILD_ID, S_WATER_LEAK);
      sensor_node.present(SECONDARY_CHILD_ID, S_WATER_LEAK);
      sensor_node.process();
      int value;
      //sensor_node.wait(5);
      if (value != oldValue) {
         oldValue = value;
      if (value != oldValue2) {
         oldValue2 = value;
    But the value received with sensor_node.send(msg.set(value==HIGH ? 1 : 0)); are not 0 or 1 but 1073741824 or 1073741825.
    What is wrong ?
    Thank you.
    Chdid
      What version/type of gateway are you running?
      Seems like the type sent isn't interpreted correctly. Are you running beta on the gw?
      Quick-fix .. Send "1" or "0".
      • C
        C
        chdid
        I'am running a gateway on an ESP8266.
        I take the last version of the ESP8266 gateway. It's OK.
        Thank you
        Chdid
