  3. message for V_tripped
3 Posts 2 Posters 1.4k Views 2 Watching
  • C Offline
    C Offline
    chdid
    I use this code for detect water leak.
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    #define SKETCH_NAME "Debordement Eau"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MySensor sensor_node;
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    int oldValue=-1;
    int oldValue2=-1;
      sensor_node.begin();
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT );
      pinMode(SECONDARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
      digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
      sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      sensor_node.present(PRIMARY_CHILD_ID, S_WATER_LEAK);
      sensor_node.present(SECONDARY_CHILD_ID, S_WATER_LEAK);
      sensor_node.process();
      int value;
      //sensor_node.wait(5);
      value = digitalRead(PRIMARY_BUTTON_PIN);
      if (value != oldValue) {
         // Value has changed from last transmission, send the updated value
         sensor_node.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      value = digitalRead(SECONDARY_BUTTON_PIN);
      if (value != oldValue2) {
         sensor_node.send(msg2.set(value==HIGH ? 1 : 0));
         oldValue2 = value;
      // Sleep until something happens with the sensor
      sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    But the value received with sensor_node.send(msg.set(value==HIGH ? 1 : 0)); are not 0 or 1 but 1073741824 or 1073741825.
    What is wrong ?
    Thank you.
    Chdid
    • H Offline
      H Offline
      What version/type of gateway are you running?
      Seems like the type sent isn't interpreted correctly. Are you running beta on the gw?
      Quick-fix .. Send "1" or "0".
      • C Offline
        C Offline
        chdid
        I'am running a gateway on an ESP8266.
        I take the last version of the ESP8266 gateway. It's OK.
        Thank you
        Chdid
        12.1k
