  3. Sending image-data over the MySensors network.
27 Posts 9 Posters 19.3k Views 11 Watching
  • OitzuO
    OitzuO
    Oitzu
    Just if anyone is interested in sending image-data over the mysensors network:
    I now have some sort of working proof on concept.
    I'm able to take a picture with a serial camera connected to a arduino nano and transmit it over my MySensors network.
    The transmitting of the taken picture takes about 40 seconds, has a resolution of 640x320 and a size of 50kb.
      Cool! You should post parts needed and example code :)
      • OitzuO
        OitzuO
        Oitzu
        wrote on last edited by Oitzu
        The Perl-Script i'm using instead of a controller, because obviously no controller supports this yet.
        #!/usr/bin/perl
        use Device::SerialPort;
        use POSIX qw(strftime);
        use Data::Dumper;
        use Time::HiRes qw (sleep);
        use Time::HiRes qw(time);
        my $port = Device::SerialPort->new("/dev/ttyUSB1");
        $| = 1;
        $port->baudrate(115200);
        $port->databits(8);
        $port->parity("none");
        $port->stopbits(1);
        my $buffer;
        my %transfers;
        print "Waiting for incoming transfers...\n";
        while (1) {
        	my ($count,$saw)=$port->read(256);
        	if($count > 0 || length($buffer) > 0)
        		$buffer .= $saw;
        		my ($cmd, $rest) = split(/\n/, $buffer, 2);
        		if(defined($rest))
        			if(@m = $cmd =~ /([0-9]*);([0-9]*);([0-9]*);([0-9]*);([0-9]*);(.*)/g)
        				my ($node_id, $child_sensor_id, $message_type, $ack, $sub_type, $payload) = @m;
        		#		print "node_id: $node_id, child_sensor_id: $child_sensor_id, message_type: $child_sensor_id, ack: $ack, sub_type: $sub_type, payload: $payload \n";
        				if($sub_type eq "25")
        					if($payload eq "START" && $transfers{$node_id}{'state'} == 0)
        						print "New transfer incoming from node $node_id.\n";
        						$transfers{$node_id}{'start_time'} = time();
        						$transfers{$node_id}{'state'} = 1;
        						$transfers{$node_id}{'count'} = 0;
        						my $time = strftime("%Y-%m-%d-%H-%M-%S", localtime);
        						open ($transfers{$node_id}{'FH'}, ">>node-".$node_id."-".$time.".jpg");
        						binmode($transfers{$node_id}{'FH'});
        					if($payload eq "END" && $transfers{$node_id}{'state'} == 1)
        						close($transfers{$node_id}{'FH'});
        						$transfers{$node_id}{'state'} = 0;
        						my $duration = time() - $transfers{$node_id}{'start_time'};
        						my $bps = $transfers{$node_id}{'count'} * 24 / $duration;
        						my $pps = $transfers{$node_id}{'count'} / $duration;
        						print "Transfer from $node_id finished.\n";
        						print "$duration seconds, $bps Bytes/s, $pps Packets/s\n";
        				elsif($sub_type eq "24")
        					if($transfers{$node_id}{'state'} == 1)
        						$transfers{$node_id}{'count'}++;
        						print { $transfers{$node_id}{'FH'} } pack('H*',$payload);
        			$buffer = $rest;
                #Check for timeout
                while(($node_id) = each %transfers)
                       	if($duration > 120 && $transfers{$node_id}{'state'} == 1)
                                print "Warning: Timeout from node $node_id. Transfer cancelled.\n";
        	sleep (0.001);
        The sketch:
        #include <Adafruit_VC0706.h>
        #include <SoftwareSerial.h>
        #undef DEBUG
        SoftwareSerial cameraConnection = SoftwareSerial(6,7);
        Adafruit_VC0706 cam = Adafruit_VC0706(&cameraConnection);
        #define CHILD_ID 3
        MyMessage msg(CHILD_ID,V_VAR1);
        MyMessage msg2(CHILD_ID,V_VAR2);
          gw.begin();
          gw.present(CHILD_ID, S_CUSTOM);
          if (cam.begin()){}
          else { return; } //Abort the transfer if camera does not initialize
          cam.setImageSize(VC0706_640x480);
          delay(3000);
          snapAndSend();
          cam.reset();
        //Do nothing.
        void snapAndSend()
          cam.takePicture();
          uint16_t jpgLen = cam.frameLength();
          Serial.print("Sending Picture of ");
          Serial.print(jpgLen, DEC);
          Serial.println(" Bytes.");
          gw.send(msg2.set("START"));
          while (jpgLen > 0)
          {                     //Send off 24 bytes of data at a time
            uint8_t *buffer;
            uint8_t bytesToRead = min(24, jpgLen);
            buffer = cam.readPicture(bytesToRead);
            gw.send(msg.set(buffer, bytesToRead));
            jpgLen -= bytesToRead;
          Serial.println("Done.");
          gw.send(msg2.set("END"));
        Hardware:
        Typical MySensors-Node and a Serial TTL Camera like this:
        http://aliexpress.com/item/NEW-RS232-TTL-JPEG-Digital-Serial-Port-CCTV-Camera-Module-SCB-1-with-video-out-Support/1975852463.html
        tekkaT G 2 Replies Last reply
          Awesome! Really simple and clean example (and perl script!).
          • OitzuO
            OitzuO
            Oitzu
            Thanks. :)
            There was much try and error involved to get this running.
            But i'm still looking forward for suggestions/discussion about the implementation of a STREAM feature.
            What do you guys think about a fixed routing while streaming?
            The init of the stream could be started by a special payload, when the gateway receives this message it generates a "stream-id". It would link this stream-id to the node-id and sensor-id and send the stream-id back to the sensor. Repeaters in the middle of the way, to the node, would also remember the link betweend stream-id and node-id.
            After this point the node would begin to stream its content only with the stream-id assigned, which would free up to 30bytes per package.
            The gateway itself could reverse this process and send out "normal" looking "commands".
            The stream-id will be freed at the moment the stream is completed or a timeout occurs.
            This ist just a suggestion by me.
              Yes, would be nice to free up some payload space for this type of data.
              Just a bit worried about allocating things (dynamically or statically) for the stream information (beside the extra code). Pretty cramped already.
              What happens if you just increase the RF24 datarate in MyConfig? Do you lose much data?
              • OitzuO Oitzu
                #!/usr/bin/perl
                use Data::Dumper;
                $| = 1;
                $port->databits(8);
                $port->stopbits(1);
                my $buffer;
                my %transfers;
                while (1) {
                		$buffer .= $saw;
                		if(defined($rest))
                			$buffer = $rest;
                        #Check for timeout
                	sleep (0.001);
                The sketch:
                #undef DEBUG
                #define CHILD_ID 3
                  gw.begin();
                  if (cam.begin()){}
                  delay(3000);
                  snapAndSend();
                  cam.reset();
                //Do nothing.
                void snapAndSend()
                  cam.takePicture();
                  while (jpgLen > 0)
                    uint8_t *buffer;
                Hardware:
                tekkaT
                tekkaT
                tekka
                @Oitzu nice, I'll think about implementing this in MYSController for testing purposes.
                • OitzuO
                  OitzuO
                  Oitzu
                  I think by deactivating not used features with pre-compile directives this problem could be solved. Need to look into this again. But i remember there are large chunks of unused code compiled in if you, by example, only want to use the lib for a "pure" node.
                  Didn't tried yet. The target for this application is a long range communication. So i keeped the datarate low in my tests.
                  BUT i need to note: Most of the 40 seconds, at this moment, is probably a result of the slow UART connection to the camera. The camera-chip has spi but it isn't breaked out on the board. There are boards out there with the same chip + SPI! Users reported the transfer over SPI to the MCU takes about 1 second!
                  @tekka nice to hear. :) Let me know if i can support somehow.
                  • OitzuO
                    OitzuO
                    Oitzu
                    Update!
                    I changed the camera to a faster SPI model.
                    http://de.aliexpress.com/item/ArduCAM-M-2MP-Camera-Shield-OV2640-2MP-SPI-Camera-module/32307177889.html?ws_ab_test=201407_5,201444_5,201409_3
                    The camera delivers a 2MP picture in under 1 seconds over SPI.
                    But i'm running in a dead end, with MySensors not supporting proper streams.
                    A 2MP (100kb) takes about 20 seconds with MySensors.
                    Main problem atm is IMHO with the mysensors transmitting style:
                    	rf24.powerUp();
                    	rf24.stopListening();
                    	rf24.openWritingPipe(TO_ADDR(to));
                    	bool ok = rf24.write(data, len, to == BROADCAST_ADDRESS);
                    	rf24.startListening();
                    	return ok;
                    would be more effective to do something like:
                    	rf24.powerUp();
                    ///loop here over more than 1 packet
                    rf24.writeFast(data, len, to == BROADCAST_ADDRESS);
                    //end of loop
                    	return ok;
                    The stopListening -> openWritingPipe -> startListening just takes to much time.
                    Unfortunately i failed a try to implement this... it seems i'm just not experienced enough.
                    • T
                      thomas1412
                      I'm currently trying to use your solution, @Oitzu.
                      The Node-part is working fine. Have a little problem on the Pi-side.
                      The RF-device is directly connected to the Pi, so I'm using a Serial Gateway script on the Pi (https://github.com/mysensors/Raspberry). The serial data is then send over /dev/ttyUSB20, that is working fine.
                      I know that I need to adjust the following lines of the Perl script:
                      use Data::Dumper;
                      But it seems I'm just to stupid to do this by myself :grin:
                      I would suggest that I can delete the first line and change the last line to something like this:
                      my $port = "/dev/ttyUSB20";
                      Can someone help me with the right syntax?
                      • OitzuO
                        OitzuO
                        Oitzu
                        use Data::Dumper;
                        The RPi Serial Gateway creates a symlink "/dev/ttyMySensorsGateway" you should use that as Device for more consistent results.
                        I srsly don't know why you would delete the first line. I'm pretty sure you need to use the Device::Serialport Perl-Module. ;)
                        Also try to run the script as root. The created device files tend to have root-only access rights.
                        • T
                          thomas1412
                          thanks for the quick reply and your help
                          It turned out my problem was the not installed serialport perl library.. Now I'm a step further.
                          Unfortunately there's another problem now.. :smile:
                          After sending three or four packages the next six packages are failing to send. And this over and over again.
                          Seems that the SerialGateway is too slow in some way..
                          send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                          send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                          sensor started, id=254, parent=0, distance=1
                          send: 254-254-0-0 s=3,c=0,t=23,pt=0,l=0,sg=0,st=ok:
                          Sending Picture of 13048 Bytes.
                          send: 254-254-0-0 s=3,c=1,t=25,pt=0,l=5,sg=0,st=ok:START
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=ok:FFD8FFFE00244900020D0000000000000000000000000000
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=ok:00F0004001070032120B510451040000FFDB008400020101
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=ok:020101020201020202020203040303020203050404030406
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:0607070606060607080A0907070A080606090C090A0A0B0B
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:0B0B07080C0D0C0B0D0A0B0B0B0102020203020305030305
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:0B0706070B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:0B0B0B0B0B0BFFFE0005000000FFC000110800F001400301
                          send: 254-254-0-0 s=3,c=1,t=24,pt=6,l=24,sg=0,st=fail:2100021101031101FFC401A2000001050101010101010000```
                            Might be a powering issue of the radio. Put a bigger cap on it.
                            • T
                              thomas1412
                              Adding a capacitor hasn't helped.
                              I changed the setup using now a serial gateway on a separate Arduino instead of having it directly on the Pi. This is working fine. So it seems that the serial gateway on the Pi was the problem..
                              OitzuO 1 Reply Last reply
                              • T thomas1412
                                OitzuO
                                OitzuO
                                Oitzu
                                #22
                                I tested this, and yes, the Pi serial gateway seems to be the problem, clogging up on some point and stops.
                                The problem itself seems to be in the pseudo terminal created. If i rewrite the gateway that the data with type 24 (image data) is not written to the pseudo terminal the sending works fine.
                                The Pi serial gateway has atm afaik no maintainer and needs some love.
                                • Zied BEN HAMMOUDZ
                                  Zied BEN HAMMOUDZ
                                  Zied BEN HAMMOUD
                                  Hello, this is my first arduino project: sending a file (jpeg, pdf, txt) from an arduino sd card module to android phone using arduino uno and bluetooth module HC-05
                                  It's possible with this hardware?
                                  If it's possible can someone please send me the source code and android app use it to receive the file
                                  thank you
                                  hekH 1 Reply Last reply
                                  • Zied BEN HAMMOUDZ Zied BEN HAMMOUD
                                    thank you
                                    @Zied-BEN-HAMMOUD
                                    I doubt anyone has the sourcecode ready for an app/sketch shuffling data over bluetooth. The MySensors library doesn't handle bluetooth communication so you should probably look elsewhere.
                                    • D
                                      dimi59
                                      It’s possible to use à esp32-cam and add a module for transmit one photo ?
                                      Thanks a lot
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        I've been looking around a bit, but beside the example Perl script provided by @thomas1412 and the STREAM type usage in the OTA feature, there seems not to exist any working solution using really the stream type message structure. But this is more or less receiving only on the node side afai understood.
                                        As I'm about to do some renovation work on the FHEM integration (also written in Perl), I'd be interested in some guidelines about the best way to transfer e.g. jpeg data as stream from node side.
                                        The sample sketch @thomas1412 provided uses not stream type, but V_VAR1 (data) and V_VAR2 (signalizing start and end).
                                        I'd be happy if someone could provide a sample sketch using the newer (?) stream type sending style or a link to the relevant parts in the MySensors codebase...
                                        • OitzuO Oitzu
                                          #!/usr/bin/perl
                                          use Data::Dumper;
                                          $| = 1;
                                          $port->databits(8);
                                          $port->stopbits(1);
                                          my $buffer;
                                          my %transfers;
                                          while (1) {
                                          		$buffer .= $saw;
                                          		if(defined($rest))
                                          			$buffer = $rest;
                                                  #Check for timeout
                                          	sleep (0.001);
                                          The sketch:
                                          #undef DEBUG
                                          #define CHILD_ID 3
                                            gw.begin();
                                            if (cam.begin()){}
                                            delay(3000);
                                            snapAndSend();
                                            cam.reset();
                                          //Do nothing.
                                          void snapAndSend()
                                            cam.takePicture();
                                            while (jpgLen > 0)
                                              uint8_t *buffer;
                                          Hardware:
                                          G
                                          G
                                          Guillermo Schimmel
                                          @Oitzu Great work. Looking forward to use it. I have a use for this (some remote roof drain that gets clogged with leaves). Thanks!
                                          12.5k
