  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    #357
    If the Si7021 is exposed to high humidity for a prolonged period, the RH% measurement will shift upwards, according to the datasheet, page 15, section 4.3
    Extract from Datasheet:
    4.3. Prolonged Exposure to High Humidity
    Prolonged exposure to high humidity will result in a gradual upward drift of the RH reading. The shift in sensor
    reading resulting from this drift will generally disappear slowly under normal ambient conditions. The amount of
    shift is proportional to the magnitude of relative humidity and the length of exposure. In the case of lengthy
    exposure to high humidity, some of the resulting shift may persist indefinitely under typical conditions. It is generally
    possible to substantially reverse this affect by baking the device (see Section “4.6. Bake/Hydrate Procedure” ).
    nivocN 1 Reply Last reply
    • Z
      Z
      Zeph
      wrote on last edited by Zeph
      #358
      @petoulachi said:
      BTW, what is the F() function ? instead of Serial.print("Sensebender Micro FW "); why using Serial.print(F("Sensebender Micro FW ")); ?
      It's a way to save some RAM. A simple string constant like "Hello" takes up 6 bytes of RAM and also 6 bytes of Flash (program) memory (6 bytes includes a single "hidden" byte of binary zero as an end-of-text marker). At startup and before your code executes, that bit of program memory is copied to RAM. The F() thing is a "macro" which causes the compiler save only the 6 bytes of Flash (no Ram used). The print function can (through C++ typing) fetch those 6 bytes from Flash at runtime for printing. If you have long or many text constants in your program, this can add up to some useful savings,when you only have 2K of RAM.
      See the "F() Macro" on this page: https://www.arduino.cc/en/Reference/PROGMEM
      • tbowmoT tbowmo
        nivocN
        nivocN
        nivoc
        @tbowmo Good hint. But it is happening to all three sensbeners for at least one month now. (different orders). I now got 4 more so I will test again soon.
        Over xmas I tested also with magnesium chloride hexahydrate. magnesium chloride hexahydrate produces exactly 33%rel.
        All 3 sensbenders report exactly 39% or 40%. So they are also here 7% off. But almost the same value and very reproducible - so thats great!
        upload-6b1782fc-cf3e-45b8-ad15-890b7eef84a0
        • nivocN nivoc
          nivocN
          nivocN
          nivoc
          wrote on last edited by nivoc
          #360
          @tbowmo I'm now almost sure that my test-setup has no faults very reproducable and read many articles - I plan to verify my findings with someone who has a professional calibrated device.
          I saw in a museum nearby that they have professional calibrated devices :-)
          upload-4464b273-5525-48b2-a940-10826e61f030
          So I will test against those :-)
          • tbowmoT
            tbowmoT
            tbowmo
            @nivoc
            Have you tried to "bake" your sensebenders, in case they have been exposed to high humidity for a longer time?
            They are, as far as I know, produced in a part of China, which are known to have very high humidity. (been traveling there a lot some years ago)
            • HeinzH
              HeinzH
              Heinz
              wrote on last edited by Heinz
              #362
              @nivoc
              I can confirm your results: I am running two different sensors in the same room next to each other. The sensebender is always above the dht-22. Right now it is
              52% to 47.8% rel. humidity, while the temperature is 17.8 to 17.9 (which is nearly equal).
              • nivocN
                nivocN
                nivoc
                @tbowmo No I haven't baked yet. I will try that but not in the next two weeks. But I will report back.
                • nivocN
                  nivocN
                  nivoc
                  But I tested tonight with distilled water - so should be exactly 100%. And again (I didn't know that thats possible) I got 104 and 107% so slightly above (still increasing). Thats great b/c that means all values are about 7-8% too high.
                  At 33% the reading was about 40%
                  At 75% the reading was about 83%
                  At 100% the reading was about 106%
                  So reading minus 8% gives a pretty accurate result. In the next few days i will test 3 more sensbender.
                  Distilled Water (100% expected):
                  upload-c0364fcd-876d-4701-a3ec-b0c55efc04a6
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    #365
                    Read the spec for the humidity sensor used in the sensebender (Si7021 integrated humidity / temperature sensor.)
                    Precision Relative Humidity Sensor: ± 3% RH (max), 0–80% RH
                    To my reading this is actually 6% wrong reading to one of the sides - so when you are measuring yours to be 8% off, is caused that you are using the device outside of humidity range 100% and max is 80%
                    Link to spec:
                    https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
                    What I want you to know, if your device is reading within 6 % of the value - it's still reading correct. and when you compare ex DHT22 that device also have some reading variation error. Do not expect to get 100% perfect value for 2 devices...
                    • nivocN
                      nivocN
                      nivoc
                      #366
                      @bjacobse Yes and no :-)
                      Yes 100% is outside of the spec.
                      And no. 33% with Magnesium Chloride Hexahydrate is inside the spec and I get 40% instead of 33-34%.
                      Max off should be 3% above or? Means 37% - but fair enough. Should be ok for household use.
                      M bjacobseB 2 Replies Last reply
                      • nivocN nivoc
                        mvader
                        I hope the Temp measurements are not off by that much.
                        i don't need .00001 accuracy or anything. but i feel a big difference between 70 and 72 in my house.
                        bjacobseB nivocN 2 Replies Last reply
                        • M mvader
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @mvader
                          Spec is: High Accuracy Temperature Sensor ±0.4 °C (max), –10 to 85 °C
                          So the temp accuracy is quite good
                          • nivocN nivoc
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @nivoc
                            Yes you are right, +-3 from your humidity solution on 33%, then the reading could be in the interval 33-3=30% or up to 33+3=36% and should not show 40%
                            did you get same false readings from other sensebender humidity sensors?
                            • bjacobseB bjacobse
                              @nivoc
                              nivocN
                              nivocN
                              nivoc
                              @bjacobse Yes I have 3 sensbener running from 2 different orders. All 3 are very near by each other. So at 33% they all read something near to 40%.
                              I have 4 more sensbenders to build. However I continue to test tonight with a Boveda-Pack that claims to bring the hum in a containter to exactly 69%. I did 4 test's so far and also used different technics. So i get more and more confident.
                              But the very good thing is - it looks every reproducible. So the value may be off but reproducable accurate off by about 8%. When I completed my test it will be very easy to correct it within the software.
                              • M mvader
                                nivocN
                                nivocN
                                nivoc
                                @mvader I haven't made any very accurate temp testings. But the readings are exactly the same than other non-sensbender devices in my home. I started researching the humidity b/c I had different readings between different devices.
                                Temp looks fine to me.
                                • T
                                  tcontrada
                                  What is the current consumption of the Sensebender during sleep and active modes?
                                  Tony
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @tcontrada
                                    there are some measurements in the old design thread here http://forum.mysensors.org/topic/510/minimal-design-thoughts
                                    • N
                                      N
                                      nikos1671
                                      Hi. What case you all using for the sensebender ?Any good idea.
                                      • F
                                        F
                                        filipq
                                        3_1456326631089_IMG_20160224_150344.jpg 2_1456326631089_IMG_20160224_150314.jpg 1_1456326631089_IMG_20160224_150303.jpg 0_1456326631088_IMG_20160224_150237.jpg
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @filipq
                                          Where did you find that box?
