  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 637.7k Views 35 Watching
  • nivocN
    nivocN
    nivoc
    But I tested tonight with distilled water - so should be exactly 100%. And again (I didn't know that thats possible) I got 104 and 107% so slightly above (still increasing). Thats great b/c that means all values are about 7-8% too high.
    At 33% the reading was about 40%
    At 75% the reading was about 83%
    At 100% the reading was about 106%
    So reading minus 8% gives a pretty accurate result. In the next few days i will test 3 more sensbender.
    Distilled Water (100% expected):
    upload-c0364fcd-876d-4701-a3ec-b0c55efc04a6
    • bjacobseB
      bjacobseB
      bjacobse
      #365
      Read the spec for the humidity sensor used in the sensebender (Si7021 integrated humidity / temperature sensor.)
      Precision Relative Humidity Sensor: ± 3% RH (max), 0–80% RH
      To my reading this is actually 6% wrong reading to one of the sides - so when you are measuring yours to be 8% off, is caused that you are using the device outside of humidity range 100% and max is 80%
      Link to spec:
      https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
      What I want you to know, if your device is reading within 6 % of the value - it's still reading correct. and when you compare ex DHT22 that device also have some reading variation error. Do not expect to get 100% perfect value for 2 devices...
      • nivocN
        nivocN
        nivoc
        wrote on last edited by nivoc
        #366
        @bjacobse Yes and no :-)
        Yes 100% is outside of the spec.
        And no. 33% with Magnesium Chloride Hexahydrate is inside the spec and I get 40% instead of 33-34%.
        Max off should be 3% above or? Means 37% - but fair enough. Should be ok for household use.
        M bjacobseB 2 Replies Last reply
        • nivocN nivoc
          mvader
          I hope the Temp measurements are not off by that much.
          i don't need .00001 accuracy or anything. but i feel a big difference between 70 and 72 in my house.
          bjacobseB nivocN 2 Replies Last reply
          • M mvader
            bjacobseB
            bjacobseB
            bjacobse
            @mvader
            Spec is: High Accuracy Temperature Sensor ±0.4 °C (max), –10 to 85 °C
            So the temp accuracy is quite good
            • nivocN nivoc
              bjacobseB
              bjacobseB
              bjacobse
              @nivoc
              Yes you are right, +-3 from your humidity solution on 33%, then the reading could be in the interval 33-3=30% or up to 33+3=36% and should not show 40%
              did you get same false readings from other sensebender humidity sensors?
              nivocN 1 Reply Last reply
              • bjacobseB bjacobse
                @nivoc
                nivocN
                nivocN
                nivoc
                @bjacobse Yes I have 3 sensbener running from 2 different orders. All 3 are very near by each other. So at 33% they all read something near to 40%.
                I have 4 more sensbenders to build. However I continue to test tonight with a Boveda-Pack that claims to bring the hum in a containter to exactly 69%. I did 4 test's so far and also used different technics. So i get more and more confident.
                But the very good thing is - it looks every reproducible. So the value may be off but reproducable accurate off by about 8%. When I completed my test it will be very easy to correct it within the software.
                • M mvader
                  nivocN
                  nivocN
                  nivoc
                  @mvader I haven't made any very accurate temp testings. But the readings are exactly the same than other non-sensbender devices in my home. I started researching the humidity b/c I had different readings between different devices.
                  Temp looks fine to me.
                  • T
                    tcontrada
                    What is the current consumption of the Sensebender during sleep and active modes?
                    Tony
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @tcontrada
                      there are some measurements in the old design thread here http://forum.mysensors.org/topic/510/minimal-design-thoughts
                      • N
                        N
                        nikos1671
                        Hi. What case you all using for the sensebender ?Any good idea.
                        • F
                          F
                          filipq
                          3_1456326631089_IMG_20160224_150344.jpg 2_1456326631089_IMG_20160224_150314.jpg 1_1456326631089_IMG_20160224_150303.jpg 0_1456326631088_IMG_20160224_150237.jpg
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @filipq
                            Where did you find that box?
                            • F
                              F
                              filipq
                              @tbowmo
                              Got it from http://cpc.farnell.com/1/1/57932-evatron-pp42m-case-sensor-ivory-71x71x27mm.html.
                              Not the cheapest, but definitely worth the money as it is very good quality. There are other colours available (white and black) https://www.jprelec.co.uk/store.asp/c=552/Gas-Sensor-Case
                                @tbowmo: I have some of these too, it's nice box. i got these from tme. cheaper :)
                                http://www.tme.eu/fr/details/box-sens-white/boitiers-dappar-dalarme-et-de-capt/supertronic/
                                • ahmedadelhosniA
                                  ahmedadelhosniA
                                  ahmedadelhosni
                                  Hello @tbowmo
                                  Doesn't the atmega328 has only 2 pins which are D2 and D3 from external interrupts ?
                                  I am wondering why do we waste the usage of D2 since the IRQ pin is not used in the library ?
                                  AnticimexA 1 Reply Last reply
                                    Hello @tbowmo
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @ahmedadelhosni because it is not in use by the library <yet>. Would be a shame if the library some day gets updated with support for a radio that can enter low power sleep and still wake when needed.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @ahmedadelhosni
                                      What @Anticimex said.. And at the time when I created the sensebender, I didn't know that the interrupt wasn't used (I was relatively new to the project) so I thought that we had to have it connected..
                                        It is used by the RF69, right @tbowmo? (when using adapter plate...)
                                        • AnticimexA Anticimex
                                          ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          wrote on last edited by ahmedadelhosni
                                          #383
                                          @Anticimex @tbowmo This a valid point which I thought of but I needed two interrupt pins. As far as I knew from fast searching is that external interrupts which react to CHANGE in pin state are only valid for pins 2 and 3. Correct ?
                                          Maybe there is another solution which I missed.
