  3. 1.6 gateway possible error
16 Posts 5 Posters 5.6k Views 3 Watching
  • mfalkviddM
    Yes, it seems related to node problems, not gateway. Sorry.
      Mihai
      I explain here what I see myself, may be I am wrong, I am not an expert in MySensors.
      So, I add sensors to the gateway - MySensors 1.6, the gateway is the only powered module, the Serial Monitor shows the incoming message to be ON, OFF then ONF and it does not work anymore for the switch.
      Power up a node and check it: it works fine, the messages are the right ones.
      I have change the message for active state from ON to ONN to be the same length with the off state and it works for the gateway.
        Mihai
        Problem solved in the version 2.0.0-beta.
          Mihai
          Problem found in 2.0.0-beta: the LED pins seems to be active on nodes even I didn't enable MY_LEDS_BLINKING_FEATURE in MyConfig.h, so I expect them to be unavailable and do not interfere with my sketch, but they did. How to disable them and keep the pins for my program?
          In 1.6 they are not active.
            There was a related PR merged a couple of days ago... could be some new bug introduced perhaps. Are you running the absolutely latest?
            https://github.com/mysensors/Arduino/pull/323
            Ping @tbowmo
              Mihai
              I use the development version downloaded about one hour before posting, then check several times with 1.6 and 2.0 versions. I change the LED pin to 2 for all three LEDs (Rx, Tx, Err) and then my switches that use old LED PINs works fine, while a LED connected to the PIN 2 was blinking.
              • tbowmoT
                tbowmoT
                tbowmo
                I made a change, so that if any of the LED's where defined, then it will enable MY_LED_BLINKING_FEATURE
                Could it be that you have a define for some of the LED's somewhere?
                look for MY_DEFAULT_xx_LED defines..
                Or are they set as default somewhere in the library @hek?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  yes.. I see the problem now.. My bad :(
                  Didn't see that we set the MY_DEFAULT_xx_LED defines for different archs if they are not defined by the user..
                  I'll make the appropriate changes tonight (I'm not at my dev machine now)
                  S 1 Reply Last reply
                  • tbowmoT tbowmo
                    Samuel235
                    @tbowmo, so does this mean that we no longer have to enable/uncomment the "MY_LED_BLINKING_FEATURE" in config.h? We are able to just assign the pins inside of the sketch (like the default sketch of the development branch shows) without touching out config file?
                    MySensors 2.1.1
                    tbowmoT 1 Reply Last reply
                    • S Samuel235
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @samuel235
                      That was the initial thought, but I now see that it will not work, as the Leds are defined in the core, if they are missing, so they will always be defined when we reach the logic that enables MY_BLINKING_LED_FEATURE. And then that will always be enabled.
                        Mihai
                        The LEDs are still active. I solve it by set all LEDs PIN no to 200 into MyConfig.h . Not a PRO solution, but I need the PINs and now I can use them.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Mihai
                          I have fixed this today on development, so could you try updating from github (The stuff I made last night, had some build errors on ESP platform, so that's why it first came in tonight)
                            Mihai
                            Yes, it works fine now, thank you!
