  3. Video How To - Monitor your Refrigerator
37 Posts 16 Posters 46.2k Views 14 Watching
  • YveauxY
    @petewill Again, another classic! :+1:
    Thanks for the project!
    • R
      R
      robosensor
      @petewill every 425 seconds your door sensors will be blind up to 750 ms because of you using blocking call to dallasTemp.requestTemperatures(). It is very unlikely that this will happen, but it can be :) Safer way is to use non-blocking access to dallas sensors: https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
      petewillP 1 Reply Last reply
      • R robosensor
        petewillP
        petewillP
        petewill
        @robosensor Cool, thanks for pointing that out. I'll check it out!
        • L
          L
          lagore
          Another nice project, you to also put in a check for millis() rolling over to zero otherwise in about 50 days the temperature will no longer be updated as the current millis() will be less then your temp stored last time check.
          • YveauxY
            Wrong, not required. Pete's code is essentially:
              unsigned long tempMillis;
              if (currentMillis - tempMillis > tempDelay) {
                // .. do something..
                tempMillis = currentMillis;
            Substracting two unsigned type values will return the modulo of the maximum value of that type, e.g.:
            #include <iostream>
            using namespace std;
            int main() {
            	unsigned long a = 0xFFFFFF10;
            	unsigned long b = 0x00000010;
            	cout << b - a << endl;
            	return 0;
            Will print 256. Pete will be safe when the millis() counter wraps.
            Try it here if you don't believe it :smile:
            • B
              B
              bruster999
              Nice project! I particularly like the switch you designed. Very simple and yet functional.
              Do you have a video/instruction on how to set up the phone app part of this project. I'm new to MySensors but have been looking for a way to monitor/control sensors from my iPhone for quite some time without success.
              B
              • B bruster999
                B
                petewillP
                petewillP
                petewill
                The app is actually part of Vera (my home automation controller). What controller are you using?
                • H
                  H
                  hyla
                  Well done, thanks Pete!
                  The freezer actually was one of my reasons for starting with the homeautomation stuff: Left the door open twice and was literally "fed up" with having to eat all the stuff :)
                  But guess which project I haven't finished yet. Yeah, You've got it ...
                  One thing I realized with the tests I've done so far: even the small wires I've used for
                  the internal temperature sensors will keep the silicone isolation in the door frame from sealing off the freezer. So after some time there's always some condensation around the entry point of the wires which can't be good. Something I'll have to look into yet. And I still haven't quite reached the cellar with my MySensors network (maximum distance, 2 and a half floors below) :)
                  Christoph
                  • H hyla
                    Christoph
                    petewillP
                    petewillP
                    petewill
                    @hyla Thankfully our freezer wasn't left open that long but it was long enough to warrant a sensor :)
                    I have had my internal temp sensors installed for over a month and haven't had any condensation yet. Maybe I just had lucky placement of the wires? I used the wires from a usb cable (I actually cut it off a broken computer mouse). They are incredibly thin. Maybe you can try that?
                    As for the distance, can you place a relay (repeater) node somewhere in the middle? http://www.mysensors.org/download/sensor_api_15#create-repeating-nodes
                      sneaksneak
                      Thanks for a nice project.
                      I am trying this but I always get Fahrenheit temperatuers in Domoticz.
                      I have change this line in the code.
                      From
                      boolean metric = false;
                      To
                      boolean metric = true;
                      Something else I should do?
                      • mfalkviddM
                        That should be enough. What value does the gatway log say it received from the sensor?
                        • IgorI
                          IgorI
                          Igor
                          Thank you for one more interesting solution. Just want to suggest useful thing which might be more simple and durable as contact pair. I mean "Switch Reed" http://www.ebay.com/itm/1PC-Recessed-Magnetic-Window-Door-Contact-Security-Safety-Alarm-Switch-Reed-/310770552546?hash=item485b5e4ee2:g:eGcAAOSwNSxU2BfU
                          Best regards!
                          • IgorI Igor
                            Best regards!
                            petewillP
                            petewillP
                            petewill
                            @Igor The reason I didn't use these is because most of the time my fridge door would stay open just slightly but enough that a reed switch would still register it as closed. Normally I like to use reed switches though.
                              mbj
                              A nice project.
                              I had a similar problem with a freezer located in the garage.
                              As I already had other temperature sensors and an energy meter running there (based on MySensors stuff) I just added one of these waterproof DS18B to the setup, drilled a hole through the fridge wall and stuck it in.
                              I use OpenHab and can see the temperature on any browser or at the cell phone client. OpenHab also emails me when temperature raises above a certain temperature.
                              Not as sophisticated as your solution but it works :-)
                                sneaksneak
                                I have now solved this problem with Fahrenheit instead of Celcius.
                                I had to change to this --->
                                float temperature = static_cast<float>(static_cast<int>((dallasTemp.getTempCByIndex(i)) * 10.)) / 10.;
                                From this --->
                                float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? dallasTemp.getTempC(dallasAddresses[i]) : dallasTemp.getTempF(dallasAddresses[i])) * 10.)) / 10.;
                                Now it gives me celcius.
                                Thanks for nice example.
                                • petewillP
                                  petewillP
                                  petewill
                                  @mbj Cool, thanks for sharing. I'd love to check out OpenHAB some day.
                                  @sneaksneak Interesting. I wonder why you had to do that...? Oh well, glad it's working for you now!
                                    Stric
                                    When I arrived at work today and started checking mails, I had received a bunch of them saying that the temperature in the fridge was too high, so I had to drive home and close the door. I would have gotten a notification earlier through jabber if the server software we use for jabber wasn't acting up :(.
                                    MySensors stuff was not involved in that particular sensor (esic sensor + tellstick + perl + perl), but the need to monitor this stuff was definitely there.
                                    • S Stric
                                      petewillP
                                      petewillP
                                      petewill
                                      @Stric Dang. Glad you caught it in time! The need to monitor is definitely real. I also want to get my house outfitted with leak detectors at some point...
                                      • KrieghundK
                                        KrieghundK
                                        Krieghund
                                        I'm sorry to ask a seemingly dumb question, but what do I need to do to get a third Dallas sensor to work? (I have a top/bottom fridge and a deep freezer).
                                        I edited the following lines:
                                        DeviceAddress dallasAddresses[] = {
                                        {0x28, 0x29, 0x4F, 0x1, 0x0, 0x0, 0x80, 0xBB}, //Freezer Address -- Modify for your sensors
                                        {0x28, 0x22, 0x53, 0x1, 0x0, 0x0, 0x80, 0x1E}, //Fridge Address -- Modify for your sensors
                                        ** {0x28, 0xA6, 0x58, 0x1, 0x0, 0x0, 0x80, 0x58} //Deep Freezer I added**
                                        // set the temp resolution
                                        for (uint8_t i = 0; i < 3; i++) { //i changed from 2
                                        // Present temp sensors to controller
                                        ** for (int i = 0; i < 3; i++) { // i changed from 2**
                                        gw.present(i, S_TEMP);
                                        ** for (int i = 0; i < 3; i++) { //i changed from 2**
                                        I'm not sure what I'm missing. Thank you in advance for your help and great project!!!
                                        KrieghundK 1 Reply Last reply
                                        • KrieghundK Krieghund
                                          KrieghundK
                                          KrieghundK
                                          Krieghund
                                          @Krieghund
                                          Ok, I think I found it. I needed to have the door sensors start at a higher ID:
                                          int doorChildren[] = {3, 4}; //i changed from 2,3
                                          Thank you
