  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.1k Views 2 Watching
  • V Offline
    V Offline
    vampircik
    PARTS LIST:
    Relays (6 channel)
    NRF24L01 Radio
    Arduino Pro Mini
    Push button (6)
    Shift Register (SN74HC595)
    Hello. Help make this project. I need to control 6 groups of 6 through the controller and buttons that are on the device. I neselen writing sketch. what people can help.
    needs a sketch and a description of how to collect it. I need to control the lighting in the street like a phone and pressing locally on the device itself.
    willing to pay for it, if necessary.
    • V Offline
      V Offline
      vampircik
      • B Offline
        B Offline
        BartE
        @vampircik i can help writing a sketch, but what exactly do you want to achieve .
        • Just a 6 times on/off button operated relays?
        • and why adding the shift register the Pro mini should have enough I/O pins?
        But can you send met the exact wiring diagram, than i can give it a try.
        • V Offline
          V Offline
          vampircik
          you did not understand. in the scheme will be 6 switches and relays 6. all these controls one Arduino.
          • V Offline
            V Offline
            vampircik
            • V Offline
              V Offline
              vampircik
              нажали кнопку, включилось реле, потом выключили через телефон это реле. и так в любой последовательности.
              • V Offline
                V Offline
                vampircik
                • B Offline
                  B Offline
                  BartE
                  wrote on last edited by BartE
                  @vampircik this code snippet should work.
                  The switch 1 till 6 should be connected to pin A0, A1, A2, A3, 4 and 5 and should connect to ground.
                  The SN74HC595 should be connected with:
                  • pin 14 (DS) to Arduino pin 6
                  • pin 12 (LATCH/ST_CP) to Arduino pin 7
                  • pin 8 (CLK/SH_CP) to Arduino pin 11
                  • pin 16 (Vcc) and pin 10 (MR) to + 5 volt
                  • pin 8 (GND) and pin 13 (OE) to ground
                  • relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q4) the other relay pins connected to ground
                    (note 18/1: fixed pin number error as posted below)
                   * Version 1.0 - Henrik Ekblad
                   * Version 1.1 - Bart Eversdijk - 6 switch version with Shift Register (SN74HC595)
                   * Example sketch showing how to control physical relays.
                   * This example will remember relay state after power failure.
                   * http://www.mysensors.org/build/relay
                  #include <MySigningNone.h>
                  #include <MyTransportNRF24.h>
                  #include <MyTransportRFM69.h>
                  #include <MyHwATMega328.h>
                  #define MYS_INIT_DELAY 500
                  #define PIN_SR_DATA      6  // shift register data pin   -- data out - 74HC595 (DS) pin 14
                  #define PIN_SR_LATCH     7  // shift register latch pin  -- data out - 74HC595 (RCLK) pin 12
                  #define PIN_SR_CLOCK     8  // shift register clock pin  -- data out - 74HC595 (CLK) pin 11
                  struct SWITCHES {
                      byte      currentStatus;
                      int       SwitchPin;   // To which Arduino pin this switch is connected
                      Bounce    debouncer;
                      MyMessage switchMsg;
                  SWITCHES switches[] = {
                            {0, A0, Bounce(), MyMessage(0, V_LIGHT)},    // Arduino pin A0
                            {0, A1, Bounce(), MyMessage(1, V_LIGHT)},    // Arduino pin A1
                            {0, A2, Bounce(), MyMessage(2, V_LIGHT)},    // Arduino pin A2
                            {0, A3, Bounce(), MyMessage(3, V_LIGHT)},    // Arduino pin A3
                            {0,  4, Bounce(), MyMessage(4, V_LIGHT)},    // Arduino pin D4
                            {0,  5, Bounce(), MyMessage(5, V_LIGHT)}     // Arduino pin D5
                  #define MAXSWITCHES (sizeof(switches)/sizeof(SWITCHES))
                  MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                  //MyTransportRFM69 radio;
                  // Message signing driver (none default)
                  //MySigningNone signer;
                  // Select AtMega328 hardware profile
                  MyHwATMega328 hw;
                  MySensor gw(radio, hw);
                      gw.sendSketchInfo("RelaySix", "1.1");
                      // Fetch relay status
                      for (int id=0; id < MAXSWITCHES; id++) {
                         pinMode(switches[id].SwitchPin, INPUT);
                         // Activate internal pull-up
                         digitalWrite(switches[id].SwitchPin, HIGH);
                         gw.present( id, S_LIGHT );
                         delay( MYS_INIT_DELAY );
                         // Pull the gateway's current dim level - restore light level upon sendor node power-up
                         gw.request( id, V_STATUS );
                         switches[id].debouncer.attach(switches[id].SwitchPin);
                         switches[id].debouncer.interval(5);
                      // Set shift register pins
                      pinMode(PIN_SR_DATA,     OUTPUT);
                      pinMode(PIN_SR_LATCH,    OUTPUT);
                      pinMode(PIN_SR_CLOCK,    OUTPUT);
                      digitalWrite(PIN_SR_LATCH, HIGH);
                      // Switch off all relays
                      sendRelayValues();
                      for (byte id = 0; id < MAXSWITCHES; id++) {
                          // Button change detected
                          if (switches[id].debouncer.update()) {
                             Serial.print (F("Switch #"));
                             Serial.print (id);
                             Serial.print (F(" to "));
                             Serial.println (switches[id].debouncer.read());
                             // Button release detected toggle relay
                             if (!switches[id].debouncer.read()) {
                               // Toggle relay status
                               switches[id].currentStatus = (switches[id].currentStatus ? 0 : 1);
                               // Set the actual relay status (all 6 at once)
                               sendRelayValues();
                               // Inform the gateway of the current switch status...
                               gw.send(switches[id].switchMsg.set(switches[id].currentStatus));
                  void sendRelayValues() {
                      // Actually send the valve bits
                      digitalWrite(PIN_SR_LATCH, LOW);
                      // Shift out all station bit values
                      // from the highest bit to the lowest
                      for(int id = 0; id < 8; id++)  {
                          digitalWrite(PIN_SR_CLOCK, LOW);
                          if (id < MAXSWITCHES) {
                            digitalWrite(PIN_SR_DATA, (switches[id].currentStatus > 0 ? HIGH : LOW));
                            digitalWrite(PIN_SR_DATA, LOW);
                          digitalWrite(PIN_SR_CLOCK, HIGH);
                      // Set new data active
                    if (message.isAck()) {
                       byte id = (message.sensor % MAXSWITCHES);
                       // Store new value
                       switches[id].currentStatus = message.getBool() ? 1 : 0;
                       sendRelayValues();
                  About your "willing to pay" remark in the original post, just make a donation to the MySensors project
                  • V Offline
                    V Offline
                    vampircik
                    Thank you. Today I will try. according to the results let you know.
                    • V Offline
                      V Offline
                      vampircik
                      @BartE said:
                      pin 8 (CLK) to Arduino pin 11
                      pin 16 (Vcc) to + 5 volt
                      pin 8 (GND) to ground
                      Arduino pin 11 = (GND) ?
                      • V Offline
                        V Offline
                        vampircik
                        contrary
                        • V Offline
                          V Offline
                          vampircik
                          relay 1-6 to pin 14 (Qa)
                          • V Offline
                            V Offline
                            vampircik
                            • V Offline
                              V Offline
                              vampircik
                              relay 1-6 to pin 14 (Qa),
                              • K Offline
                                K Offline
                                korttoma
                                Maybe it should be like this:
                                relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5)
                                • Tomas
                                • V Offline
                                  V Offline
                                  vampircik
                                  and with the contact what to do?
                                  K 1 Reply Last reply
                                  • V Offline
                                    V Offline
                                    vampircik
                                    Arduino pin 11 = MOSI NRF24
                                    • V Offline
                                      V Offline
                                      vampircik
                                      it seems to me must be so connected. except for the screen?
                                      • V vampircik
                                        K Offline
                                        K Offline
                                        korttoma
                                        Looking att the code @BartE posted it seems like it was supposed to be
                                        pin 11 (CLK) to Arduino pin 8
                                        • Tomas
                                        • V Offline
                                          V Offline
                                          vampircik
                                          ok try. ...............
                                          12.0k
