  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.9k Views 2 Watching
  • V
    V
    vampircik
    @BartE said:
    pin 8 (CLK) to Arduino pin 11
    pin 16 (Vcc) to + 5 volt
    pin 8 (GND) to ground
    Arduino pin 11 = (GND) ?
    • V
      V
      vampircik
      contrary
      • V
        V
        vampircik
        pin 14 (DS) to Arduino pin 6
        relay 1-6 to pin 14 (Qa)
        • V
          V
          vampircik
          • V
            V
            vampircik
            relay 1-6 to pin 14 (Qa),
            • korttomaK
              korttomaK
              korttoma
              Maybe it should be like this:
              relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5)
              • Tomas
              • V
                V
                vampircik
                and with the contact what to do?
                korttomaK 1 Reply Last reply
                • V
                  V
                  vampircik
                  Arduino pin 11 = MOSI NRF24
                  • V
                    V
                    vampircik
                    it seems to me must be so connected. except for the screen?
                    • V vampircik
                      korttomaK
                      korttomaK
                      korttoma
                      Looking att the code @BartE posted it seems like it was supposed to be
                      pin 11 (CLK) to Arduino pin 8
                      • Tomas
                      • V
                        V
                        vampircik
                        ok try. ...............
                        • korttomaK
                          korttomaK
                          korttoma
                          So the correct instructions should have been:
                          pin 12 (RCLK) to Arduino pin 7
                          relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5) the other relay pins connected to ground
                          Please @BartE correct me if I'm wrong since I have no personal experience from this kind of setup.
                          • Tomas
                          • V
                            V
                            vampircik
                            collected is not working. the controller displays the switch, but it does not control the Arduino.
                            • V
                              V
                              vampircik
                              includes buttons, it is displayed on the controller, with only relay nothing happens
                              • V
                                V
                                vampircik
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Do you get anything in the serial monitor for your Relay Node?
                                  • Tomas
                                  • V
                                    V
                                    vampircik
                                    send: 18-18-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                                    send: 18-18-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                    read: 0-0-18 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    repeater started, id=18, parent=0, distance=1
                                    send: 18-18-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:RelaySix
                                    send: 18-18-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                    send: 18-18-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=0,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=2,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                    send: 18-18-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                    send: 18-18-0-0 s=3,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                    send: 18-18-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                    send: 18-18-0-0 s=4,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                    send: 18-18-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                    send: 18-18-0-0 s=5,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                    find parent
                                    send: 18-18-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                    read: 0-0-18 s=0,c=1,t=2,pt=0,l=1,sg=0:0
                                    send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                    Incoming change for sensor:0, New status: 0
                                    read: 0-0-18 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                    send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                    Incoming change for sensor:1, New status: 0
                                    read: 0-0-18 s=2,c=1,t=2,pt=0,l=1,sg=0:0
                                    send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                    Incoming change for sensor:2, New status: 0
                                    read: 0-0-18 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    parent=0, d=1
                                    Switch #1 to 1
                                    Switch #2 to 1
                                    Switch #3 to 1
                                    Switch #4 to 1
                                    Switch #5 to 1
                                    Switch #1 to 0
                                    send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #1 to 1
                                    Switch #2 to 0
                                    send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #2 to 1
                                    Switch #0 to 1
                                    Switch #0 to 0
                                    send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #3 to 0
                                    send: 18-18-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #3 to 1
                                    Switch #4 to 0
                                    send: 18-18-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #4 to 1
                                    Switch #5 to 0
                                    send: 18-18-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                    Switch #5 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #5 to 0
                                    Switch #5 to 1
                                    Switch #5 to 0
                                    Switch #5 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #5 to 0
                                    Switch #5 to 1
                                    Switch #3 to 0
                                    Switch #3 to 1
                                    Switch #3 to 0
                                    Switch #3 to 1
                                    Switch #3 to 0
                                    Switch #3 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #4 to 0
                                    Switch #4 to 1
                                    Switch #5 to 0
                                    Switch #5 to 1
                                    Switch #0 to 1
                                    Switch #0 to 0
                                    Switch #0 to 1
                                    Switch #0 to 0
                                    Switch #2 to 0
                                    Switch #2 to 1
                                    Switch #2 to 0
                                    Switch #2 to 1
                                    Switch #1 to 0
                                    Switch #1 to 1
                                    Switch #1 to 0
                                    Switch #1 to 1
                                    • V
                                      V
                                      vampircik
                                      this is what I have now happened. includes a button, turn on the relay, reclosing button, there is no result
                                      • V
                                        V
                                        vampircik
                                        individual libraries should be shipped to the chip?
                                        • V
                                          V
                                          vampircik
