  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.9k Views 2 Watching
  • BartEB
    BartEB
    BartE
    @vampircik i can help writing a sketch, but what exactly do you want to achieve .
    • Just a 6 times on/off button operated relays?
    • and why adding the shift register the Pro mini should have enough I/O pins?
    But can you send met the exact wiring diagram, than i can give it a try.
    • V
      V
      vampircik
      you did not understand. in the scheme will be 6 switches and relays 6. all these controls one Arduino.
      • V
        V
        vampircik
        • V
          V
          vampircik
          нажали кнопку, включилось реле, потом выключили через телефон это реле. и так в любой последовательности.
          • V
            V
            vampircik
            • BartEB
              BartEB
              BartE
              wrote on last edited by BartE
              @vampircik this code snippet should work.
              The switch 1 till 6 should be connected to pin A0, A1, A2, A3, 4 and 5 and should connect to ground.
              The SN74HC595 should be connected with:
              • pin 14 (DS) to Arduino pin 6
              • pin 12 (LATCH/ST_CP) to Arduino pin 7
              • pin 8 (CLK/SH_CP) to Arduino pin 11
              • pin 16 (Vcc) and pin 10 (MR) to + 5 volt
              • pin 8 (GND) and pin 13 (OE) to ground
              • relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q4) the other relay pins connected to ground
                (note 18/1: fixed pin number error as posted below)
               * Version 1.0 - Henrik Ekblad
               * Version 1.1 - Bart Eversdijk - 6 switch version with Shift Register (SN74HC595)
               * Example sketch showing how to control physical relays.
               * This example will remember relay state after power failure.
               * http://www.mysensors.org/build/relay
              #include <MySigningNone.h>
              #include <MyTransportNRF24.h>
              #include <MyTransportRFM69.h>
              #include <MyHwATMega328.h>
              #define MYS_INIT_DELAY 500
              #define PIN_SR_DATA      6  // shift register data pin   -- data out - 74HC595 (DS) pin 14
              #define PIN_SR_LATCH     7  // shift register latch pin  -- data out - 74HC595 (RCLK) pin 12
              #define PIN_SR_CLOCK     8  // shift register clock pin  -- data out - 74HC595 (CLK) pin 11
              struct SWITCHES {
                  byte      currentStatus;
                  int       SwitchPin;   // To which Arduino pin this switch is connected
                  Bounce    debouncer;
                  MyMessage switchMsg;
              SWITCHES switches[] = {
                        {0, A0, Bounce(), MyMessage(0, V_LIGHT)},    // Arduino pin A0
                        {0, A1, Bounce(), MyMessage(1, V_LIGHT)},    // Arduino pin A1
                        {0, A2, Bounce(), MyMessage(2, V_LIGHT)},    // Arduino pin A2
                        {0, A3, Bounce(), MyMessage(3, V_LIGHT)},    // Arduino pin A3
                        {0,  4, Bounce(), MyMessage(4, V_LIGHT)},    // Arduino pin D4
                        {0,  5, Bounce(), MyMessage(5, V_LIGHT)}     // Arduino pin D5
              #define MAXSWITCHES (sizeof(switches)/sizeof(SWITCHES))
              MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
              //MyTransportRFM69 radio;
              // Message signing driver (none default)
              //MySigningNone signer;
              // Select AtMega328 hardware profile
              MyHwATMega328 hw;
              MySensor gw(radio, hw);
                  gw.sendSketchInfo("RelaySix", "1.1");
                  // Fetch relay status
                  for (int id=0; id < MAXSWITCHES; id++) {
                     pinMode(switches[id].SwitchPin, INPUT);
                     // Activate internal pull-up
                     digitalWrite(switches[id].SwitchPin, HIGH);
                     gw.present( id, S_LIGHT );
                     delay( MYS_INIT_DELAY );
                     // Pull the gateway's current dim level - restore light level upon sendor node power-up
                     gw.request( id, V_STATUS );
                     switches[id].debouncer.attach(switches[id].SwitchPin);
                     switches[id].debouncer.interval(5);
                  // Set shift register pins
                  pinMode(PIN_SR_DATA,     OUTPUT);
                  pinMode(PIN_SR_LATCH,    OUTPUT);
                  pinMode(PIN_SR_CLOCK,    OUTPUT);
                  digitalWrite(PIN_SR_LATCH, HIGH);
                  // Switch off all relays
                  sendRelayValues();
                  for (byte id = 0; id < MAXSWITCHES; id++) {
                      // Button change detected
                      if (switches[id].debouncer.update()) {
                         Serial.print (F("Switch #"));
                         Serial.print (id);
                         Serial.print (F(" to "));
                         Serial.println (switches[id].debouncer.read());
                         // Button release detected toggle relay
                         if (!switches[id].debouncer.read()) {
                           // Toggle relay status
                           switches[id].currentStatus = (switches[id].currentStatus ? 0 : 1);
                           // Set the actual relay status (all 6 at once)
                           sendRelayValues();
                           // Inform the gateway of the current switch status...
                           gw.send(switches[id].switchMsg.set(switches[id].currentStatus));
              void sendRelayValues() {
                  // Actually send the valve bits
                  digitalWrite(PIN_SR_LATCH, LOW);
                  // Shift out all station bit values
                  // from the highest bit to the lowest
                  for(int id = 0; id < 8; id++)  {
                      digitalWrite(PIN_SR_CLOCK, LOW);
                      if (id < MAXSWITCHES) {
                        digitalWrite(PIN_SR_DATA, (switches[id].currentStatus > 0 ? HIGH : LOW));
                        digitalWrite(PIN_SR_DATA, LOW);
                      digitalWrite(PIN_SR_CLOCK, HIGH);
                  // Set new data active
                if (message.isAck()) {
                   byte id = (message.sensor % MAXSWITCHES);
                   // Store new value
                   switches[id].currentStatus = message.getBool() ? 1 : 0;
                   sendRelayValues();
              About your "willing to pay" remark in the original post, just make a donation to the MySensors project
              • V
                V
                vampircik
                Thank you. Today I will try. according to the results let you know.
                • V
                  V
                  vampircik
                  @BartE said:
                  pin 8 (CLK) to Arduino pin 11
                  pin 16 (Vcc) to + 5 volt
                  pin 8 (GND) to ground
                  Arduino pin 11 = (GND) ?
                  • V
                    V
                    vampircik
                    contrary
                    • V
                      V
                      vampircik
                      relay 1-6 to pin 14 (Qa)
                      • V
                        V
                        vampircik
                        • V
                          V
                          vampircik
                          relay 1-6 to pin 14 (Qa),
                          • korttomaK
                            korttomaK
                            korttoma
                            Maybe it should be like this:
                            relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5)
                            • Tomas
                            • V
                              V
                              vampircik
                              and with the contact what to do?
                              korttomaK 1 Reply Last reply
                              • V
                                V
                                vampircik
                                Arduino pin 11 = MOSI NRF24
                                • V
                                  V
                                  vampircik
                                  it seems to me must be so connected. except for the screen?
                                  • V vampircik
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    Looking att the code @BartE posted it seems like it was supposed to be
                                    pin 11 (CLK) to Arduino pin 8
                                    • Tomas
                                    • V
                                      V
                                      vampircik
                                      ok try. ...............
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        So the correct instructions should have been:
                                        pin 12 (RCLK) to Arduino pin 7
                                        relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5) the other relay pins connected to ground
                                        Please @BartE correct me if I'm wrong since I have no personal experience from this kind of setup.
                                        • Tomas
                                        • V
                                          V
                                          vampircik
                                          collected is not working. the controller displays the switch, but it does not control the Arduino.
