  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.9k Views 2 Watching
  • V
    V
    vampircik
    • V
      V
      vampircik
      нажали кнопку, включилось реле, потом выключили через телефон это реле. и так в любой последовательности.
      • V
        V
        vampircik
        • BartEB
          BartEB
          BartE
          wrote on last edited by BartE
          @vampircik this code snippet should work.
          The switch 1 till 6 should be connected to pin A0, A1, A2, A3, 4 and 5 and should connect to ground.
          The SN74HC595 should be connected with:
          • pin 14 (DS) to Arduino pin 6
          • pin 12 (LATCH/ST_CP) to Arduino pin 7
          • pin 8 (CLK/SH_CP) to Arduino pin 11
          • pin 16 (Vcc) and pin 10 (MR) to + 5 volt
          • pin 8 (GND) and pin 13 (OE) to ground
          • relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q4) the other relay pins connected to ground
            (note 18/1: fixed pin number error as posted below)
           * Version 1.0 - Henrik Ekblad
           * Version 1.1 - Bart Eversdijk - 6 switch version with Shift Register (SN74HC595)
           * Example sketch showing how to control physical relays.
           * This example will remember relay state after power failure.
           * http://www.mysensors.org/build/relay
          #include <MySigningNone.h>
          #include <MyTransportNRF24.h>
          #include <MyTransportRFM69.h>
          #include <MyHwATMega328.h>
          #define MYS_INIT_DELAY 500
          #define PIN_SR_DATA      6  // shift register data pin   -- data out - 74HC595 (DS) pin 14
          #define PIN_SR_LATCH     7  // shift register latch pin  -- data out - 74HC595 (RCLK) pin 12
          #define PIN_SR_CLOCK     8  // shift register clock pin  -- data out - 74HC595 (CLK) pin 11
          struct SWITCHES {
              byte      currentStatus;
              int       SwitchPin;   // To which Arduino pin this switch is connected
              Bounce    debouncer;
              MyMessage switchMsg;
          SWITCHES switches[] = {
                    {0, A0, Bounce(), MyMessage(0, V_LIGHT)},    // Arduino pin A0
                    {0, A1, Bounce(), MyMessage(1, V_LIGHT)},    // Arduino pin A1
                    {0, A2, Bounce(), MyMessage(2, V_LIGHT)},    // Arduino pin A2
                    {0, A3, Bounce(), MyMessage(3, V_LIGHT)},    // Arduino pin A3
                    {0,  4, Bounce(), MyMessage(4, V_LIGHT)},    // Arduino pin D4
                    {0,  5, Bounce(), MyMessage(5, V_LIGHT)}     // Arduino pin D5
          #define MAXSWITCHES (sizeof(switches)/sizeof(SWITCHES))
          MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
          //MyTransportRFM69 radio;
          // Message signing driver (none default)
          //MySigningNone signer;
          // Select AtMega328 hardware profile
          MyHwATMega328 hw;
          MySensor gw(radio, hw);
              gw.sendSketchInfo("RelaySix", "1.1");
              // Fetch relay status
              for (int id=0; id < MAXSWITCHES; id++) {
                 pinMode(switches[id].SwitchPin, INPUT);
                 // Activate internal pull-up
                 digitalWrite(switches[id].SwitchPin, HIGH);
                 gw.present( id, S_LIGHT );
                 delay( MYS_INIT_DELAY );
                 // Pull the gateway's current dim level - restore light level upon sendor node power-up
                 gw.request( id, V_STATUS );
                 switches[id].debouncer.attach(switches[id].SwitchPin);
                 switches[id].debouncer.interval(5);
              // Set shift register pins
              pinMode(PIN_SR_DATA,     OUTPUT);
              pinMode(PIN_SR_LATCH,    OUTPUT);
              pinMode(PIN_SR_CLOCK,    OUTPUT);
              digitalWrite(PIN_SR_LATCH, HIGH);
              // Switch off all relays
              sendRelayValues();
              for (byte id = 0; id < MAXSWITCHES; id++) {
                  // Button change detected
                  if (switches[id].debouncer.update()) {
                     Serial.print (F("Switch #"));
                     Serial.print (id);
                     Serial.print (F(" to "));
                     Serial.println (switches[id].debouncer.read());
                     // Button release detected toggle relay
                     if (!switches[id].debouncer.read()) {
                       // Toggle relay status
                       switches[id].currentStatus = (switches[id].currentStatus ? 0 : 1);
                       // Set the actual relay status (all 6 at once)
                       sendRelayValues();
                       // Inform the gateway of the current switch status...
                       gw.send(switches[id].switchMsg.set(switches[id].currentStatus));
          void sendRelayValues() {
              // Actually send the valve bits
              digitalWrite(PIN_SR_LATCH, LOW);
              // Shift out all station bit values
              // from the highest bit to the lowest
              for(int id = 0; id < 8; id++)  {
                  digitalWrite(PIN_SR_CLOCK, LOW);
                  if (id < MAXSWITCHES) {
                    digitalWrite(PIN_SR_DATA, (switches[id].currentStatus > 0 ? HIGH : LOW));
                    digitalWrite(PIN_SR_DATA, LOW);
                  digitalWrite(PIN_SR_CLOCK, HIGH);
              // Set new data active
            if (message.isAck()) {
               byte id = (message.sensor % MAXSWITCHES);
               // Store new value
               switches[id].currentStatus = message.getBool() ? 1 : 0;
               sendRelayValues();
          About your "willing to pay" remark in the original post, just make a donation to the MySensors project
          • V
            V
            vampircik
            Thank you. Today I will try. according to the results let you know.
            • V
              V
              vampircik
              @BartE said:
              pin 8 (CLK) to Arduino pin 11
              pin 16 (Vcc) to + 5 volt
              pin 8 (GND) to ground
              Arduino pin 11 = (GND) ?
              • V
                V
                vampircik
                contrary
                • V
                  V
                  vampircik
                  relay 1-6 to pin 14 (Qa)
                  • V
                    V
                    vampircik
                    • V
                      V
                      vampircik
                      relay 1-6 to pin 14 (Qa),
                      • korttomaK
                        korttomaK
                        korttoma
                        Maybe it should be like this:
                        relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5)
                        • Tomas
                        • V
                          V
                          vampircik
                          and with the contact what to do?
                          korttomaK 1 Reply Last reply
                          • V
                            V
                            vampircik
                            Arduino pin 11 = MOSI NRF24
                            • V
                              V
                              vampircik
                              it seems to me must be so connected. except for the screen?
                              • V vampircik
                                korttomaK
                                korttomaK
                                korttoma
                                Looking att the code @BartE posted it seems like it was supposed to be
                                pin 11 (CLK) to Arduino pin 8
                                • Tomas
                                • V
                                  V
                                  vampircik
                                  ok try. ...............
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    So the correct instructions should have been:
                                    pin 12 (RCLK) to Arduino pin 7
                                    relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5) the other relay pins connected to ground
                                    Please @BartE correct me if I'm wrong since I have no personal experience from this kind of setup.
                                    • Tomas
                                    • V
                                      V
                                      vampircik
                                      collected is not working. the controller displays the switch, but it does not control the Arduino.
                                      • V
                                        V
                                        vampircik
                                        includes buttons, it is displayed on the controller, with only relay nothing happens
                                        • V
                                          V
                                          vampircik
