  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.9k Views 2 Watching
  • V
    V
    vampircik
    Thank you. Today I will try. according to the results let you know.
    • V
      V
      vampircik
      @BartE said:
      pin 8 (CLK) to Arduino pin 11
      pin 16 (Vcc) to + 5 volt
      pin 8 (GND) to ground
      Arduino pin 11 = (GND) ?
      • V
        V
        vampircik
        contrary
        • V
          V
          vampircik
          pin 14 (DS) to Arduino pin 6
          relay 1-6 to pin 14 (Qa)
          • V
            V
            vampircik
            • V
              V
              vampircik
              relay 1-6 to pin 14 (Qa),
              • korttomaK
                korttomaK
                korttoma
                Maybe it should be like this:
                relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5)
                • Tomas
                • V
                  V
                  vampircik
                  and with the contact what to do?
                  korttomaK 1 Reply Last reply
                  • V
                    V
                    vampircik
                    Arduino pin 11 = MOSI NRF24
                    • V
                      V
                      vampircik
                      it seems to me must be so connected. except for the screen?
                      • V vampircik
                        korttomaK
                        korttomaK
                        korttoma
                        Looking att the code @BartE posted it seems like it was supposed to be
                        pin 11 (CLK) to Arduino pin 8
                        • Tomas
                        • V
                          V
                          vampircik
                          ok try. ...............
                          • korttomaK
                            korttomaK
                            korttoma
                            So the correct instructions should have been:
                            pin 12 (RCLK) to Arduino pin 7
                            relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5) the other relay pins connected to ground
                            Please @BartE correct me if I'm wrong since I have no personal experience from this kind of setup.
                            • Tomas
                            • V
                              V
                              vampircik
                              collected is not working. the controller displays the switch, but it does not control the Arduino.
                              • V
                                V
                                vampircik
                                includes buttons, it is displayed on the controller, with only relay nothing happens
                                • V
                                  V
                                  vampircik
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Do you get anything in the serial monitor for your Relay Node?
                                    • Tomas
                                    • V
                                      V
                                      vampircik
                                      send: 18-18-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
                                      send: 18-18-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                      read: 0-0-18 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      repeater started, id=18, parent=0, distance=1
                                      send: 18-18-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:RelaySix
                                      send: 18-18-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                      send: 18-18-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=0,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=2,c=2,t=2,pt=0,l=0,sg=0,st=ok:
                                      send: 18-18-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                      send: 18-18-0-0 s=3,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                      send: 18-18-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                      send: 18-18-0-0 s=4,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                      send: 18-18-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=fail:
                                      send: 18-18-0-0 s=5,c=2,t=2,pt=0,l=0,sg=0,st=fail:
                                      find parent
                                      send: 18-18-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                      read: 0-0-18 s=0,c=1,t=2,pt=0,l=1,sg=0:0
                                      send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                      Incoming change for sensor:0, New status: 0
                                      read: 0-0-18 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                      send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                      Incoming change for sensor:1, New status: 0
                                      read: 0-0-18 s=2,c=1,t=2,pt=0,l=1,sg=0:0
                                      send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                                      Incoming change for sensor:2, New status: 0
                                      read: 0-0-18 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      parent=0, d=1
                                      Switch #1 to 1
                                      Switch #2 to 1
                                      Switch #3 to 1
                                      Switch #4 to 1
                                      Switch #5 to 1
                                      Switch #1 to 0
                                      send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #1 to 1
                                      Switch #2 to 0
                                      send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #2 to 1
                                      Switch #0 to 1
                                      Switch #0 to 0
                                      send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #3 to 0
                                      send: 18-18-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #3 to 1
                                      Switch #4 to 0
                                      send: 18-18-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #4 to 1
                                      Switch #5 to 0
                                      send: 18-18-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
                                      Switch #5 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #5 to 0
                                      Switch #5 to 1
                                      Switch #5 to 0
                                      Switch #5 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #5 to 0
                                      Switch #5 to 1
                                      Switch #3 to 0
                                      Switch #3 to 1
                                      Switch #3 to 0
                                      Switch #3 to 1
                                      Switch #3 to 0
                                      Switch #3 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #4 to 0
                                      Switch #4 to 1
                                      Switch #5 to 0
                                      Switch #5 to 1
                                      Switch #0 to 1
                                      Switch #0 to 0
                                      Switch #0 to 1
                                      Switch #0 to 0
                                      Switch #2 to 0
                                      Switch #2 to 1
                                      Switch #2 to 0
                                      Switch #2 to 1
                                      Switch #1 to 0
                                      Switch #1 to 1
                                      Switch #1 to 0
                                      Switch #1 to 1
                                      • V
                                        V
                                        vampircik
                                        this is what I have now happened. includes a button, turn on the relay, reclosing button, there is no result
                                        • V
                                          V
                                          vampircik
                                          individual libraries should be shipped to the chip?
