  3. The library should check for radio definition in the sketch
3 Posts 2 Posters 986 Views 2 Watching
  • A Offline
    A Offline
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    Five hours ago I decided to try the signing feature but I had some troubles so I decided to return to my old code without signing. I used #if 0 so as not to compile the part regarding signing in my code. But I have been trying for 4 hours to let the GW and nodes work again without signing.
    Finally I figured out that MY_RADIO_NRF24 define was under the #if 0 and the code was compiled successfully although no radio is defined.
    If I am not mistaken but I guess months ago if I did so it wouldn't compile,, not sure. But in all cases I guess the config.h may check for this and throw #error if no radio is defined.
    @hek Can you check this please ?
    • H Offline
      H Offline
      Not defining a radio drives is and should be ok.
      The gateway can be used standalone with sensors attached without any sub radio network.
      • A Offline
        A Offline
        ahmedadelhosni
        Well I tested again not defining a radio for a sensor node (relayactuator) and it didn't compile. OK
        But my issue was with GatewayW5100, if I didn't define the NRF radio, nothing work at all and nodes are not communicating with the GW.
        In all cases, I just needed to highlight that this may save someone's else time :D
        12.1k
