  3. Turn On/Off relay in windows 7
11 Posts 5 Posters 4.4k Views 1 Watching
  • ch3b7C Offline
    ch3b7C Offline
    ch3b7
    Any know how i can turn off/on a relay sensor sending a command from windows to the gw connected with usb? Using a program, script, etc? I cant buy a Rpi or Vera =( im use 1.4b
    Thanks all!
    J J 2 Replies Last reply
    • ch3b7C ch3b7
      Thanks all!
      J Offline
      J Offline
      jendrush
      wrote on last edited by jendrush
      @ch3b7 Send command by serial monitor. In serial monitor window (at the bottom) choose NL(New Line), type something like this 15;1;1;0;2;1(radio id 15, child id, and sensor number 1) in input field, and push send. At the end of the command 1 means relay on, 0 means relay off.
      ch3b7C 1 Reply Last reply
      • J jendrush
        ch3b7C Offline
        ch3b7C Offline
        ch3b7
        @jendrush thanks for reply! I know this method but i need not use the arduino serial monitor im try to make a program send throught serial but the gateway dont listen the serial input from the usb
        • E Offline
          E Offline
          epierre
          @ch3b7 you need to set 115200 and se parameters. check my mysensors-gw. pl on that
          https://github.com/empierre
          z-wave - Vera -> Domoticz
          • ch3b7C ch3b7
            Thanks all!
            J Offline
            J Offline
            John
            @ch3b7
            First need to find out which com port it is set. and then enter the following at the command line:
            mode com[NUMBER] BAUD=115200 PARITY=n DATA=8 STOP=1
            Replace [NUMBER] with the number used.
            The enter the next to send something:
            echo "[LINETOSEND]\n" > COM[NUMBER]
            Replace [LINETOSEND] with what you want to send.
            Havn't tried it myself, but the above should work... I think.
            • ch3b7C Offline
              ch3b7C Offline
              ch3b7
              no work =( i send "2;1;1;3;2;1\n" (turn on relay)
              J 1 Reply Last reply
              • ch3b7C ch3b7
                J Offline
                J Offline
                John
                @ch3b7
                shouldn't it be "2;1;1;0;2;1\n" or "2;1;1;1;2;1\n" ?
                • J John
                  @ch3b7
                  J Offline
                  J Offline
                  jendrush
                  @jendrush said:
                  15;1;1;0;2;1
                  I agree, and i did write sample message 15;1;1;0;2;1. This 0 is for not requesting ACK.
                  • ch3b7C Offline
                    ch3b7C Offline
                    ch3b7
                    I need change something in the gateway? The gw read the serial imput from the usb? I try with the 0 but nothing
                    H 1 Reply Last reply
                    • ch3b7C ch3b7
                      H Offline
                      H Offline
                      @ch3b7
                      Are you running the SerialGateway.ino on the Arduino connected to your computer?
                      Does the commands work when you type them into Serial Monitor of Arduino IDE?
                      If so, open the same com-port (port speed/stop bits settings described by in this thread) in your own script and send the same command. Remember newline.
                      • ch3b7C Offline
                        ch3b7C Offline
                        ch3b7
                        Im install the gateway sketch and Yes if i put.the.command.in the serial monitor work turning on off a led in the sensor i have but without a 0 for ack like this "2;1;1;3;2;1\n" Im use the example this "echo " (command)\n" > comXX and this config
                        12.1k
