  3. Floating Point
Floating Point
floating point
41 Posts 4 Posters 25.4k Views 1 Watching
  • YveauxY Yveaux
    @hek said:
    Does anyone want to help on the fixed point stuff?
    I can try to put some skeleton together to get the interface right, as this is probably the hardest part.
    Super.
    • Z
      Z
      Zeph
      wrote on last edited by Zeph
      @hek @Yveaux
      Let me see if I am understanding.
      The payload types would be enhanced.
      typedef enum {
          P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM
      } payload;
      to add an 8:8 and/or 16:16 fixed point formats, eg: P_FIX8P8 or P_FIX16P16. I'm guessing only signed fixed point, no unsigned?
      And to add a 4 byte binary floating point P_FLOAT32?
      One small suggestion: put P_CUSTOM first, so its numeric code doesn't change when you add additional formats. Or if it's too late for that, we can skip over P_CUSTOM for these new formats.
      And also the payload setters:
      MyMessage& set(const char* value);
      MyMessage& set(uint8_t value);
      MyMessage& set(double value, uint8_t decimals);
      MyMessage& set(unsigned long value);
      MyMessage& set(long value);
      MyMessage& set(unsigned int value);
      MyMessage& set(int value);
      would be enhanced to support these types.
      could be unchanged as seen by the user even if the underlying OTA representation became binary. But we might add something like:
      MyMessage& set(fix8p8 value, uint8_t: decimals);
      MyMessage& set(fix16p16 value, uint8_t: decimals);
      (the decimals parameter is needed for this like for floats, as described earlier)
      This implies creating new C++ types, in this example "fix8p8", which is basically a int16_t with an implicit radix point in the middle.
      Adding is simple. Multiply of fix8p8 is easy because you can use a long as temp before renormalizing, but multiply of fix16p16 gets trickier, of course.
      Another discussion to have before it's set in stone...
      Adding fixed point support both OTA and within library code has value, so I'm not against it. Getting the library right and educating users is going to be some work, tho. I use fixed point math fairly often, but it definitely has some gotchas that we are biting off.
      The concept of having a scaling factor (see a few messages back) may be an easier step to implement and educate. It's an easy concept: every integer step represents X units, so the integer value must be multiplied by the scaling factor to get the real value in units. Default = 1.0 with both the same, as now.
      The simplest version just scales by factors of 10, and could be implemented by adding a second integer to the set() function. In this version to send -12.5 you use set(-125,1), or to send 0.14 you use set(14,2). This can be interpreted into a string without even using floating point math, you just adjust where to insert a decimal point in a printed integer.
      (The slightly more complex version would use an arbitrary floating point factor as the scale, so you could use 0.1 or 3.56 or whatever).
      (Aside: from the viewpoint of the gateway, the fixed point enhancement is equivalent to having a fixed scaling factor of 2*-8 or 2^-16)
      These enhancements are not mutually exclusive, but I would think that one of the scaled integer version might be easier to implement and understand as a first step.
      hekH 1 Reply Last reply
      • YveauxY
        I don't see why the decimals parameter is needed. Currently it is used for the amount of decimals converted to textual presentation. This is not required for fixed point presentation (unless you want a scaling factor).
        IMHO scaling just complicates things too much -- you also need to exchange the scaling factor with the gateway.
        My idea is to just wrap the new types in a class library, which allows for easy conversion and maths with these new fixedpt types.
        The library should shield regular users from the internals and pitfalls of fixed point. Most sketches just get a value from a sensor library and pass it on to MySensors, without modifying the value.
        As part of this exercise we also have to modify these libraries which return their values in float-format, as it doesn't make sense to keeps floats in partly...
        Z 1 Reply Last reply
        • Z Zeph
          @hek @Yveaux
          typedef enum {
          } payload;
          typedef enum {
          } payload;
          Darn, just realized we only got 3 bits to describe payload type. We need another one to fit the new ones.
          Shouldn't this be set(float, uint8_t). Wouldn't it be confusing to have double-argument when only sending 32-bit float?
          YveauxY JohnJ Z 3 Replies Last reply
            typedef enum {
            } payload;
            @hek
            Do you really need the unsigned versions UINT16 and UINT32 ?
            I would say stick to the signed ones -- this frees 2 values for float and fixed point.
              typedef enum {
              } payload;
              JohnJ
              JohnJ
              John
              @hek
              Also the Atmega based boards do not support double, well they do in naming but are float precisions
              • JohnJ John
                @hek
                @John then let's call them float, for clarity
                JohnJ 1 Reply Last reply
                • YveauxY Yveaux
                  JohnJ
                  JohnJ
                  John
                  Agree
                    wrote on last edited by hek
                    #23
                    Just pushed the float changes.
                    To free up some bits in header for the new fixed point types (and simplify things) I'm considering reducing the commandTypes to just 3 values (SET, REQ, INTERNAL) the rest (PRESENTATION, STREAM) will be moved to be INTERNAL messages.
                    I could make serial interface unaffected by this change. But I'd rather remove it there as well.
                    @Yveaux . Regarding remove the unsigned variant (e.g. ULONG). It is actually good to keep this. As there actually are some sensors reporting large numbers like meter-ticks which can be huge.
                    YveauxY JohnJ 2 Replies Last reply
                      @hek Maybe not for 1.4, but you should consider removing a lot of the data from the header and leave only the routing info & message type in.
                      Depending on message type you then get a 'nested' header which tells you about the message-type specifics.
                      This also will help in the struggle to store data format types, for which you've now reserved 3 bits. They are always sent, also when there's no SET/GET data present in the message. Then you simply reserve e.g. a byte which will go a long way...
                      • YveauxY Yveaux
                        Darn... you are so right..
                          @hek Hey, its my job ;-)
                          • YveauxY Yveaux
                            Z
                            Z
                            Zeph
                            I was think of when packets are converted to the comma separated textual representation for the API.
                            Convert 25.7 degrees to fixed point at the node, then at the gateway convert the fixed point it to a text string, and you'll see what I mean. It's not for the scaling option.
                            There are tradeoffs either way. In the current architecture, to support scaling you'd need to at least tell the gateway the scaling factor as part of the one-time presentation configuration. (Alternately, the gateway could retrieve the scaling factor along with type and name from local configuration, rather than receiving all of those OTA, but that's another discussion)
                            Beyond that there's no need for new libraries, and it's easy to explain.
                            However, I understand that you are excited by the fixed point functionality (which could be useful for more than just OTA encoding). I don't want to discourage that exploration. I look forward to some examples of encoding at the node end, and decoding at the gateway end, for some sensors like the DHT-22 or 18B20.
                            Yes, that was what I was guessing. Go for it!
                            Agreed. It would be nice if we rarely needed to even link the floating point library in nodes. (And it would make an ATtiny based node more feasible someday).
                              typedef enum {
                              } payload;
                              Z
                              Z
                              Zeph
                              I was quoting an excerpt of the current system. I would tend to agree with changing that to float, just for clarity of intent, even though they are the same in GCC for the AVR
                              • Z Zeph
                                This method (and the same holds for the decimals-parameter) seems attrictive, but has a few drawbacks:
                                • The presentation message currently has no 'guaranteed' delivery; we would need to change that as without this info the gateway cannot interpret the incoming data
                                • It also has to be sent to the sensor (actuator actually) nodes from the gateway when data goes the other way. No 'presentation' mechanism from gateway to sensor currently exists.
                                • It places an administration burden on the gateway, and possibly on actuators
                                Possibly, but when you start mixing up values with different scaling factors or want to do (simple) maths on them the story changes completely...
                                • YveauxY
                                  I've been google'ing around looking for existing fixed point c++ libraries which fit the ATMega and tend to try out the following: https://code.google.com/p/libfixmath
                                  It has regular updates, a unit test suite, impressive performance advantages (especially addition/substract, see https://code.google.com/p/libfixmath/wiki/Benchmarks), has been tested on ATMega and uses an MIT license.
                                  It only supports 16.16, but other derivates like 8.8 seems doable.
                                  Rolling my own from start is too much work for me, as implementation is tricky at some points (unit tests are a requirement IMHO)
                                  Anyone has a better suggestion?
                                  • YveauxY Yveaux
                                    @Yveaux
                                    First impression: looks good!
                                      JohnJ
                                      JohnJ
                                      John
                                      @hek
                                      Just used the updated lib. I Can confirm the floats.
                                      • YveauxY
                                        I 'ported' libfixmath to the Arduino (see https://github.com/Yveaux/Arduino_fixpt)
                                        Ran into a lot of internal compiler error issues and had to convert the unittests to C++ variants (no need to test C-implementation only) which revealed some issues in the C++ wrapper.
                                        Anyway, stuff is running now and I have some preliminary benchmark results.
                                        I create a benchmark sketch which runs a number of multiplications/divisions/additions/subtractions/sqrt.
                                        Code size results:
                                        Bare (no float/fix16)    450
                                        double                   2514
                                        fix16                    2956
                                        So code size slightly increases with fixed point calculations.
                                        Calculation performance results:
                                        with overflow detection and rounding:
                                        Op      double	fixpt      speed improvement fixpt over double
                                        Mult    870448    1708304	50.95%
                                        Div     2303348   2986484	77.13%
                                        Add     858280	296760     289.22%
                                        Sub     858108	296644     289.27%
                                        Sqrt    13164     15444      85.24%
                                        without overflow detection and rounding (FIXMATH_NO_OVERFLOW & FIXMATH_NO_ROUNDING defined)
                                        Mult    870452    1699392	51.22%
                                        Div     2303348   4794636    48.04%
                                        Add     858280	82568	  1039.48%
                                        Sub     858108	72776	  1179.11%
                                        Sqrt    13168     15528	  84.80%
                                        So additions & subtractions are significantly faster using Fix16 (we can probably live without overflow detection & rounding) and mul/div/sqrt are slower...
                                        First conclusion: we don't gain in flash code space and don't gain (on average) in code execution speed. Maybe very specific applications can benefit from Fix16 implementation on AVR, but I seriously doubt if it's worth all the effort....
                                        Seems like the AVR floating point library is very efficient, both in code size and execution speed.
                                        Please review my code as I might be missing something...
                                        • YveauxY Yveaux
                                          Code size results:
                                          double                   2514
                                          fix16                    2956
                                          @Yveaux
                                          Ok, good investigation! As you say. It might not be worth it with this small gain.
