  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    Ok, great. We need to increase timeout then.
    #23
    Better add a yield() call in those blocking wait loops.
    When quiclkly looking over the code of the RF69 driver, the RFM69::initialize call could in theory block for 1.5 sec...
    That's a watchdog reset waiting to happen!
      Yep,
      https://github.com/mysensors/Arduino/pull/287
        Yep,
        @hek :+1:
          Mersing
          This is working great !
          Tx for this !
          • chrilleC
            chrilleC
            chrille
            I am seeing something similar with RFM69 (specifically RFM69CW) and ESP8266. I have build an ESP8266 gateway based on the GatewayESP8266 sketch and this is what I changed
            #define MY_RADIO_RFM69
            #define MY_GATEWAY_ESP8266
            #define MY_RF69_IRQ_PIN 4
            #define MY_RF69_SPI_CS 15
            #define MY_RF69_IRQ_NUM 4
            I build a sensor node with the DallasTemperatureSensor sketch on an Arduino Mini Pro and defined
            When I start up the gateway I see
            0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0-beta)
            ....scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 8
            cnt
            connected with AP, channel 1
            ip:62.x.x.x,mask:255.255.255.128,gw:62.x.x.x
            .IP: 62.x.x.x
            So far so good - I assume all the radio wiring is OK, since the radio init is successful
            On the sensor node I see
            Starting sensor (RRNNA-, 2.0.0-beta)
            find parent
            send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            find parent
            find parent
            Init complete, id=255, parent=255, distance=255
            As soon as the sensor node is started the ESP8266 crashes with a WDT reset
            Soft WDT reset
            ctx: cont
            sp: 3ffef370 end: 3ffef630 offset: 01b0
            >>>stack>>>
            3ffef520:  00000001 3ffef6d4 3ffef964 00000000
            3ffef530:  00000024 3ffef6d4 3ffef964 40202436
            3ffef540:  3ffe8432 00000000 3ffef6d4 402024bc
            3ffef550:  3ffe8432 00000000 3ffef6d4 402026a7
            3ffef560:  3ffef6f2 00000001 3ffef6d4 40202b87
            3ffef570:  3fffdae0 00000000 3ffee600 3ffef6ac
            3ffef580:  3fffdae0 3ffef6f1 3ffef6d4 40202cf4
            3ffef590:  3fff1210 00000000 3ffee600 402042b4
            3ffef5a0:  00000000 00000002 3ffef82c 40203d20
            3ffef5b0:  00000000 3ffef6d4 3ffef964 4020247c
            3ffef5c0:  401057ff 00000400 00000103 3ffef5f0
            3ffef5d0:  3ffef5e0 00000004 3ffef6cd 4020249c
            3ffef5e0:  3ffe8920 00000000 00000000 3ffee608
            3ffef5f0:  3fffdae0 00000000 3ffee600 3ffee608
            3ffef600:  3fffdae0 00000000 3ffee600 40203e6c
            3ffef610:  feefeffe feefeffe 3ffee600 402045b4
            3ffef620:  feefeffe feefeffe 3ffee610 40100114
            <<<stack<<<
            The libraries are 2.0 beta as from a few days ago. I consider the power to the ESP8266 to be OK, since I use the same for en NRF24 based gateway and also for several other ESP modules.
            From the thread I understand that known issues should be fixed in the current beta. Any ideas on how to move on?
            • chrilleC chrille
              ....scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 8
              cnt
              .IP: 62.x.x.x
              find parent
              find parent
              find parent
              Soft WDT reset
              ctx: cont
              >>>stack>>>
              <<<stack<<<
              @chrille Try adding the following line to your setup() function:
              ESP.wdtDisable();
              It should disable the (software) watchdog on ESP. See if it continues, or if it will now just hang.
              chrilleC 1 Reply Last reply
              • YveauxY Yveaux
                ESP.wdtDisable();
                chrilleC
                chrilleC
                chrille
                @Yveaux Just tried that. The change removed the watchdog message and the stack trace, but the module still reboots
                chrilleC YveauxY 2 Replies Last reply
                • chrilleC chrille
                  chrilleC
                  chrilleC
                  chrille
                  ...I also tried to change TIME_OUT in rfm69.cpp to 500 as suggested by Fabien. Doesn't make any difference
                  • chrilleC chrille
                    Probably the hardware watchdog kicks in then...
                    chrilleC 2 Replies Last reply
                    • YveauxY Yveaux
                      chrilleC
                      chrilleC
                      chrille
                      @Yveaux I did some further tests and it may be related to the inclusion mode feature. At least disabling this makes things more stable - but I still haven't got the radio side working reliable. When this is working I will go back to the gateway and see if I can find out what triggers the crash
                      • YveauxY Yveaux
                        chrilleC
                        chrilleC
                        chrille
                        @Yveaux I think I have narrowed down the issue now to this code in RFM69.cpp
                        void RFM69::sendACK(const void* buffer, byte bufferSize) {
                        debug(PSTR("RFM69: void sendACK\n"));
                          byte sender = SENDERID;
                          debug(PSTR("RFM69: sendACK - entering while()\n"));
                          while (!canSend()) receiveDone();
                          sendFrame(sender, buffer, bufferSize, false, true);
                        (The debug lines are added by me)
                        Most of the time the WDT kicks in, after logging "entering while()" - occasionally it will reach sendFrame() and log a "read: " line but then the WDT kicks in when it gets to the while() loop again.
                        sendAck is called from sendFrame, that disables interrupts, by calling select()
                        With a bunch of additional debug turned on, this is what I get on the console
                        chg_B:-60
                        chg_B:-120
                        0;255;3;0;9;RFM69: interruptHandler
                        0;255;3;0;9;RFM69: IRQ handler - select chip
                        0;255;3;0;9;RFM69: IRQ handler - release chip
                        0;255;3;0;9;RFM69: IRQ handler - read RSSI
                        0;255;3;0;9;RFM69: receiveDone() - payload
                        0;255;3;0;9;RFM69: void sendACK
                        chg_B:-60
                        0;255;3;0;9;RFM69: sendACK - entering while()
                        0;255;3;0;9;RFM69: sendFrame()
                        0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                        Soft WDT reset
                        ctx: cont
                        sp: 3ffefa70 end: 3ffefd30 offset: 01b0
                        >>>stack>>>
                        3ffefc20:  00000001 3ffefdd4 3ffeffdc 000000ff
                        3ffefc30:  00000024 3ffefdd4 3ffeffdc 402022da
                        3ffefc40:  3ffe8496 00000000 3ffefdd4 40202360
                        3ffefc50:  00000000 00000000 3ffefdd4 4020254b
                        3ffefc60:  3ffefdf2 00000000 3ffefdd4 402037f9
                        3ffefc70:  3fffdc20 00000000 3ffefdd4 3ffefdac
                        3ffefc80:  3fffdc20 3ffefdf1 3ffefdd4 4020385c
                        3ffefc90:  00000003 00000000 3ffeecf8 40204035
                        3ffefca0:  00000003 00000000 00000000 00000000
                        3ffefcb0:  3ffefd58 3ffefdd4 3ffeffdc 3ffeed00
                        3ffefcc0:  3ffefe00 00000000 3ffefe98 40203aec
                        3ffefcd0:  00000003 00000000 000000ff 00000000
                        3ffefce0:  000000ff 00000002 00000000 00000000
                        3ffefcf0:  3fffdc20 00000000 3ffeecf8 3ffeed00
                        3ffefd00:  3fffdc20 00000000 3ffeecf8 40203c06
                        3ffefd10:  00000000 00000000 3ffeecf8 4020432c
                        3ffefd20:  00000000 00000000 3ffeed10 40100114
                        <<<stack<<<
                        Any ideas on how to fix this, would be greatly appreciated!
                        • chrilleC chrille
                          chg_B:-60
                          chg_B:-120
                          chg_B:-60
                          Soft WDT reset
                          ctx: cont
                          >>>stack>>>
                          <<<stack<<<
                          @chrille I'm not familiar with rfm implementation, but you could try adding a call to yield() inside the while loop.
                          • YveauxY Yveaux
                            chrilleC
                            chrilleC
                            chrille
                            @Yveaux Thank you very much. This seems to have fixed the issue now!
                            • chrilleC chrille
                              @chrille Could you create a pull-request (or a bug report) for this fix in MySensors' github repo ?
                              • YveauxY Yveaux
                                chrilleC
                                chrilleC
                                chrille
                                @Yveaux I already did! https://github.com/mysensors/Arduino/pull/396
