  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    Ok, great. We need to increase timeout then.
    • F
      F
      Fabien
      @hek Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?
        @Fabien said:
        MY_RF26_IRQ_PIN
        I cannot find this defined anywhere...
        • F
          F
          Fabien
          sorry MY_RF69_IRQ_PIN ...
          • F
            F
            Fabien
            Work with 51ms timeout with my config. I set 60ms to be "secure"
              #23
              Better add a yield() call in those blocking wait loops.
              When quiclkly looking over the code of the RF69 driver, the RFM69::initialize call could in theory block for 1.5 sec...
              That's a watchdog reset waiting to happen!
                Yep,
                https://github.com/mysensors/Arduino/pull/287
                  Yep,
                  @hek :+1:
                    Mersing
                    This is working great !
                    Tx for this !
                    • chrilleC
                      chrilleC
                      chrille
                      I am seeing something similar with RFM69 (specifically RFM69CW) and ESP8266. I have build an ESP8266 gateway based on the GatewayESP8266 sketch and this is what I changed
                      #define MY_RADIO_RFM69
                      #define MY_GATEWAY_ESP8266
                      #define MY_RF69_IRQ_PIN 4
                      #define MY_RF69_SPI_CS 15
                      #define MY_RF69_IRQ_NUM 4
                      I build a sensor node with the DallasTemperatureSensor sketch on an Arduino Mini Pro and defined
                      When I start up the gateway I see
                      0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0-beta)
                      ....scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 8
                      cnt
                      connected with AP, channel 1
                      ip:62.x.x.x,mask:255.255.255.128,gw:62.x.x.x
                      .IP: 62.x.x.x
                      So far so good - I assume all the radio wiring is OK, since the radio init is successful
                      On the sensor node I see
                      Starting sensor (RRNNA-, 2.0.0-beta)
                      find parent
                      send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                      find parent
                      find parent
                      Init complete, id=255, parent=255, distance=255
                      As soon as the sensor node is started the ESP8266 crashes with a WDT reset
                      Soft WDT reset
                      ctx: cont
                      sp: 3ffef370 end: 3ffef630 offset: 01b0
                      >>>stack>>>
                      3ffef520:  00000001 3ffef6d4 3ffef964 00000000
                      3ffef530:  00000024 3ffef6d4 3ffef964 40202436
                      3ffef540:  3ffe8432 00000000 3ffef6d4 402024bc
                      3ffef550:  3ffe8432 00000000 3ffef6d4 402026a7
                      3ffef560:  3ffef6f2 00000001 3ffef6d4 40202b87
                      3ffef570:  3fffdae0 00000000 3ffee600 3ffef6ac
                      3ffef580:  3fffdae0 3ffef6f1 3ffef6d4 40202cf4
                      3ffef590:  3fff1210 00000000 3ffee600 402042b4
                      3ffef5a0:  00000000 00000002 3ffef82c 40203d20
                      3ffef5b0:  00000000 3ffef6d4 3ffef964 4020247c
                      3ffef5c0:  401057ff 00000400 00000103 3ffef5f0
                      3ffef5d0:  3ffef5e0 00000004 3ffef6cd 4020249c
                      3ffef5e0:  3ffe8920 00000000 00000000 3ffee608
                      3ffef5f0:  3fffdae0 00000000 3ffee600 3ffee608
                      3ffef600:  3fffdae0 00000000 3ffee600 40203e6c
                      3ffef610:  feefeffe feefeffe 3ffee600 402045b4
                      3ffef620:  feefeffe feefeffe 3ffee610 40100114
                      <<<stack<<<
                      The libraries are 2.0 beta as from a few days ago. I consider the power to the ESP8266 to be OK, since I use the same for en NRF24 based gateway and also for several other ESP modules.
                      From the thread I understand that known issues should be fixed in the current beta. Any ideas on how to move on?
                      • chrilleC chrille
                        ....scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 8
                        cnt
                        .IP: 62.x.x.x
                        find parent
                        find parent
                        find parent
                        Soft WDT reset
                        ctx: cont
                        >>>stack>>>
                        <<<stack<<<
                        @chrille Try adding the following line to your setup() function:
                        ESP.wdtDisable();
                        It should disable the (software) watchdog on ESP. See if it continues, or if it will now just hang.
                        chrilleC 1 Reply Last reply
                        • YveauxY Yveaux
                          ESP.wdtDisable();
                          chrilleC
                          chrilleC
                          chrille
                          @Yveaux Just tried that. The change removed the watchdog message and the stack trace, but the module still reboots
                          chrilleC YveauxY 2 Replies Last reply
                          • chrilleC chrille
                            chrilleC
                            chrilleC
                            chrille
                            ...I also tried to change TIME_OUT in rfm69.cpp to 500 as suggested by Fabien. Doesn't make any difference
                            • chrilleC chrille
                              Probably the hardware watchdog kicks in then...
                              chrilleC 2 Replies Last reply
                              • YveauxY Yveaux
                                chrilleC
                                chrilleC
                                chrille
                                @Yveaux I did some further tests and it may be related to the inclusion mode feature. At least disabling this makes things more stable - but I still haven't got the radio side working reliable. When this is working I will go back to the gateway and see if I can find out what triggers the crash
                                • YveauxY Yveaux
                                  chrilleC
                                  chrilleC
                                  chrille
                                  @Yveaux I think I have narrowed down the issue now to this code in RFM69.cpp
                                  void RFM69::sendACK(const void* buffer, byte bufferSize) {
                                  debug(PSTR("RFM69: void sendACK\n"));
                                    byte sender = SENDERID;
                                    debug(PSTR("RFM69: sendACK - entering while()\n"));
                                    while (!canSend()) receiveDone();
                                    sendFrame(sender, buffer, bufferSize, false, true);
                                  (The debug lines are added by me)
                                  Most of the time the WDT kicks in, after logging "entering while()" - occasionally it will reach sendFrame() and log a "read: " line but then the WDT kicks in when it gets to the while() loop again.
                                  sendAck is called from sendFrame, that disables interrupts, by calling select()
                                  With a bunch of additional debug turned on, this is what I get on the console
                                  chg_B:-60
                                  chg_B:-120
                                  0;255;3;0;9;RFM69: interruptHandler
                                  0;255;3;0;9;RFM69: IRQ handler - select chip
                                  0;255;3;0;9;RFM69: IRQ handler - release chip
                                  0;255;3;0;9;RFM69: IRQ handler - read RSSI
                                  0;255;3;0;9;RFM69: receiveDone() - payload
                                  0;255;3;0;9;RFM69: void sendACK
                                  chg_B:-60
                                  0;255;3;0;9;RFM69: sendACK - entering while()
                                  0;255;3;0;9;RFM69: sendFrame()
                                  0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                                  Soft WDT reset
                                  ctx: cont
                                  sp: 3ffefa70 end: 3ffefd30 offset: 01b0
                                  >>>stack>>>
                                  3ffefc20:  00000001 3ffefdd4 3ffeffdc 000000ff
                                  3ffefc30:  00000024 3ffefdd4 3ffeffdc 402022da
                                  3ffefc40:  3ffe8496 00000000 3ffefdd4 40202360
                                  3ffefc50:  00000000 00000000 3ffefdd4 4020254b
                                  3ffefc60:  3ffefdf2 00000000 3ffefdd4 402037f9
                                  3ffefc70:  3fffdc20 00000000 3ffefdd4 3ffefdac
                                  3ffefc80:  3fffdc20 3ffefdf1 3ffefdd4 4020385c
                                  3ffefc90:  00000003 00000000 3ffeecf8 40204035
                                  3ffefca0:  00000003 00000000 00000000 00000000
                                  3ffefcb0:  3ffefd58 3ffefdd4 3ffeffdc 3ffeed00
                                  3ffefcc0:  3ffefe00 00000000 3ffefe98 40203aec
                                  3ffefcd0:  00000003 00000000 000000ff 00000000
                                  3ffefce0:  000000ff 00000002 00000000 00000000
                                  3ffefcf0:  3fffdc20 00000000 3ffeecf8 3ffeed00
                                  3ffefd00:  3fffdc20 00000000 3ffeecf8 40203c06
                                  3ffefd10:  00000000 00000000 3ffeecf8 4020432c
                                  3ffefd20:  00000000 00000000 3ffeed10 40100114
                                  <<<stack<<<
                                  Any ideas on how to fix this, would be greatly appreciated!
                                  • chrilleC chrille
                                    chg_B:-60
                                    chg_B:-120
                                    chg_B:-60
                                    Soft WDT reset
                                    ctx: cont
                                    >>>stack>>>
                                    <<<stack<<<
                                    @chrille I'm not familiar with rfm implementation, but you could try adding a call to yield() inside the while loop.
                                    • YveauxY Yveaux
                                      chrilleC
                                      chrilleC
                                      chrille
                                      @Yveaux Thank you very much. This seems to have fixed the issue now!
                                      • chrilleC chrille
                                        @chrille Could you create a pull-request (or a bug report) for this fix in MySensors' github repo ?
                                        • YveauxY Yveaux
                                          chrilleC
                                          chrilleC
                                          chrille
                                          @Yveaux I already did! https://github.com/mysensors/Arduino/pull/396
