  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    Yep,
    https://github.com/mysensors/Arduino/pull/287
      Yep,
      @hek :+1:
        Mersing
        This is working great !
        Tx for this !
        • chrilleC
          chrilleC
          chrille
          I am seeing something similar with RFM69 (specifically RFM69CW) and ESP8266. I have build an ESP8266 gateway based on the GatewayESP8266 sketch and this is what I changed
          #define MY_RADIO_RFM69
          #define MY_GATEWAY_ESP8266
          #define MY_RF69_IRQ_PIN 4
          #define MY_RF69_SPI_CS 15
          #define MY_RF69_IRQ_NUM 4
          I build a sensor node with the DallasTemperatureSensor sketch on an Arduino Mini Pro and defined
          When I start up the gateway I see
          0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0-beta)
          ....scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 8
          cnt
          connected with AP, channel 1
          ip:62.x.x.x,mask:255.255.255.128,gw:62.x.x.x
          .IP: 62.x.x.x
          So far so good - I assume all the radio wiring is OK, since the radio init is successful
          On the sensor node I see
          Starting sensor (RRNNA-, 2.0.0-beta)
          find parent
          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
          find parent
          find parent
          Init complete, id=255, parent=255, distance=255
          As soon as the sensor node is started the ESP8266 crashes with a WDT reset
          Soft WDT reset
          ctx: cont
          sp: 3ffef370 end: 3ffef630 offset: 01b0
          >>>stack>>>
          3ffef520:  00000001 3ffef6d4 3ffef964 00000000
          3ffef530:  00000024 3ffef6d4 3ffef964 40202436
          3ffef540:  3ffe8432 00000000 3ffef6d4 402024bc
          3ffef550:  3ffe8432 00000000 3ffef6d4 402026a7
          3ffef560:  3ffef6f2 00000001 3ffef6d4 40202b87
          3ffef570:  3fffdae0 00000000 3ffee600 3ffef6ac
          3ffef580:  3fffdae0 3ffef6f1 3ffef6d4 40202cf4
          3ffef590:  3fff1210 00000000 3ffee600 402042b4
          3ffef5a0:  00000000 00000002 3ffef82c 40203d20
          3ffef5b0:  00000000 3ffef6d4 3ffef964 4020247c
          3ffef5c0:  401057ff 00000400 00000103 3ffef5f0
          3ffef5d0:  3ffef5e0 00000004 3ffef6cd 4020249c
          3ffef5e0:  3ffe8920 00000000 00000000 3ffee608
          3ffef5f0:  3fffdae0 00000000 3ffee600 3ffee608
          3ffef600:  3fffdae0 00000000 3ffee600 40203e6c
          3ffef610:  feefeffe feefeffe 3ffee600 402045b4
          3ffef620:  feefeffe feefeffe 3ffee610 40100114
          <<<stack<<<
          The libraries are 2.0 beta as from a few days ago. I consider the power to the ESP8266 to be OK, since I use the same for en NRF24 based gateway and also for several other ESP modules.
          From the thread I understand that known issues should be fixed in the current beta. Any ideas on how to move on?
          • chrilleC chrille
            ....scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 8
            cnt
            .IP: 62.x.x.x
            find parent
            find parent
            find parent
            Soft WDT reset
            ctx: cont
            >>>stack>>>
            <<<stack<<<
            @chrille Try adding the following line to your setup() function:
            ESP.wdtDisable();
            It should disable the (software) watchdog on ESP. See if it continues, or if it will now just hang.
            chrilleC 1 Reply Last reply
            • YveauxY Yveaux
              ESP.wdtDisable();
              chrilleC
              chrilleC
              chrille
              @Yveaux Just tried that. The change removed the watchdog message and the stack trace, but the module still reboots
              chrilleC YveauxY 2 Replies Last reply
              • chrilleC chrille
                chrilleC
                chrilleC
                chrille
                ...I also tried to change TIME_OUT in rfm69.cpp to 500 as suggested by Fabien. Doesn't make any difference
                • chrilleC chrille
                  Probably the hardware watchdog kicks in then...
                  chrilleC 2 Replies Last reply
                  • YveauxY Yveaux
                    chrilleC
                    chrilleC
                    chrille
                    @Yveaux I did some further tests and it may be related to the inclusion mode feature. At least disabling this makes things more stable - but I still haven't got the radio side working reliable. When this is working I will go back to the gateway and see if I can find out what triggers the crash
                    • YveauxY Yveaux
                      chrilleC
                      chrilleC
                      chrille
                      @Yveaux I think I have narrowed down the issue now to this code in RFM69.cpp
                      void RFM69::sendACK(const void* buffer, byte bufferSize) {
                      debug(PSTR("RFM69: void sendACK\n"));
                        byte sender = SENDERID;
                        debug(PSTR("RFM69: sendACK - entering while()\n"));
                        while (!canSend()) receiveDone();
                        sendFrame(sender, buffer, bufferSize, false, true);
                      (The debug lines are added by me)
                      Most of the time the WDT kicks in, after logging "entering while()" - occasionally it will reach sendFrame() and log a "read: " line but then the WDT kicks in when it gets to the while() loop again.
                      sendAck is called from sendFrame, that disables interrupts, by calling select()
                      With a bunch of additional debug turned on, this is what I get on the console
                      chg_B:-60
                      chg_B:-120
                      0;255;3;0;9;RFM69: interruptHandler
                      0;255;3;0;9;RFM69: IRQ handler - select chip
                      0;255;3;0;9;RFM69: IRQ handler - release chip
                      0;255;3;0;9;RFM69: IRQ handler - read RSSI
                      0;255;3;0;9;RFM69: receiveDone() - payload
                      0;255;3;0;9;RFM69: void sendACK
                      chg_B:-60
                      0;255;3;0;9;RFM69: sendACK - entering while()
                      0;255;3;0;9;RFM69: sendFrame()
                      0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                      Soft WDT reset
                      ctx: cont
                      sp: 3ffefa70 end: 3ffefd30 offset: 01b0
                      >>>stack>>>
                      3ffefc20:  00000001 3ffefdd4 3ffeffdc 000000ff
                      3ffefc30:  00000024 3ffefdd4 3ffeffdc 402022da
                      3ffefc40:  3ffe8496 00000000 3ffefdd4 40202360
                      3ffefc50:  00000000 00000000 3ffefdd4 4020254b
                      3ffefc60:  3ffefdf2 00000000 3ffefdd4 402037f9
                      3ffefc70:  3fffdc20 00000000 3ffefdd4 3ffefdac
                      3ffefc80:  3fffdc20 3ffefdf1 3ffefdd4 4020385c
                      3ffefc90:  00000003 00000000 3ffeecf8 40204035
                      3ffefca0:  00000003 00000000 00000000 00000000
                      3ffefcb0:  3ffefd58 3ffefdd4 3ffeffdc 3ffeed00
                      3ffefcc0:  3ffefe00 00000000 3ffefe98 40203aec
                      3ffefcd0:  00000003 00000000 000000ff 00000000
                      3ffefce0:  000000ff 00000002 00000000 00000000
                      3ffefcf0:  3fffdc20 00000000 3ffeecf8 3ffeed00
                      3ffefd00:  3fffdc20 00000000 3ffeecf8 40203c06
                      3ffefd10:  00000000 00000000 3ffeecf8 4020432c
                      3ffefd20:  00000000 00000000 3ffeed10 40100114
                      <<<stack<<<
                      Any ideas on how to fix this, would be greatly appreciated!
                      • chrilleC chrille
                        chg_B:-60
                        chg_B:-120
                        chg_B:-60
                        Soft WDT reset
                        ctx: cont
                        >>>stack>>>
                        <<<stack<<<
                        @chrille I'm not familiar with rfm implementation, but you could try adding a call to yield() inside the while loop.
                        • YveauxY Yveaux
                          chrilleC
                          chrilleC
                          chrille
                          @Yveaux Thank you very much. This seems to have fixed the issue now!
                          • chrilleC chrille
                            @chrille Could you create a pull-request (or a bug report) for this fix in MySensors' github repo ?
                            • YveauxY Yveaux
                              chrilleC
                              chrilleC
                              chrille
                              @Yveaux I already did! https://github.com/mysensors/Arduino/pull/396
