  3. Newbie: RFM69 serial gateway
16 Posts 6 Posters 10.6k Views 5 Watching
  • E Offline
    E Offline
    EJ3359113
    I'll tried to create a RFM69 Serial Gateway with RFM69HC module
    In a first step, i have only compiled the default sketch with RFM69 options and loaded on an arduino nano but i have no message on the console of the IDE.
    With the NRF24 options, i have the standard message (impossible to initialize radio).
    How to make to have debug message with the RFM69 options?
    Best regards
    • carlierdC Offline
      carlierdC Offline
      carlierd
      There is no debug message with RFM69.
      If I am right the RFM lib used is not up-to-date and there is some blocking code if the connection is not correctly done.
      Have you tried the hardware with simple code (without MySensors) ?
      David.
      • E Offline
        E Offline
        EJ3359113
        Thanks for the response
        No, i have not tried with a simple code.
        Do you have an example?
        Regards
        • carlierdC Offline
          carlierdC Offline
          carlierd
          The code for the transmitter:
          /* Simple sketch to check RFM69 is correctly connected to the Arduino.                */
          /*        Part of the Global Home Automation System GHAS.                             */
          /* Version: 0.0.5        */
          /* Date   : 28/12/2015        */
          /* Author : David Carlier                                                             */
          /*                            RST |             |  A5                                 */
          /*                            RX  |             |  A4                                 */
          /*                            TX  |   ARDUINO   |  A3                                 */
          /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
          /*                            D3  |             |  A1                                 */
          /*                            D4  | ATMEGA 328p |  A0                                 */
          /*            +3.3v --------- VCC |             | GND --------- GND                   */
          /*              GND --------- GND |  8MHz int.  | REF                                 */
          /*                            OSC |             | VCC --------- +3.3v                 */
          /*                            OSC |             | D13 --------- RFM69 (SCK)           */
          /*                            D5  |             | D12 --------- RFM69 (MISO)          */
          /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
          /*                            D7  |             | D10 --------- RFM69 (NSS)           */
          /*                            D8  |             |  D9                                 */
          /* Used library:        */
          /*     RFM69  : https://github.com/LowPowerLab/RFM69                                  */
          /*     Jeelib : http://jeelabs.net/projects/jeelib/wiki                               */
          //Include low power library
          #include <JeeLib.h>
          //Include RFM69 library
          #include <RFM69.h>
          //Active mode debug.
          #define DEBUG
          //Define RFM69 settings
          #define GATEWAYID   50
          #define NODEID      35
          #define NETWORKID   5
          #define FREQUENCY   RF69_868MHZ
          #define ENCRYPTKEY  "1234567890123456"	//Encrypt key must be 16 characters
          #define IS_RFM69HW
          //Setup the watchdog
          ISR(WDT_vect) {Sleepy::watchdogEvent();}
          //Declare RFM69 driver
          RFM69 radio;
          //Declare local constants
          #define LOOP_DELAY   58000
          //Data table
          typedef struct
            float    rfmTemp;      //Temperature (°C)
            float    humidity;     //Humidity (%)
            float    voltage;      //Voltage of battery capacity (v)
            byte     measure;      //Measure number (from 0 to 250, +1 each new measurement)
            } Payload;
          Payload dataToSend;
          //Misc.
          const char VERSION[] = "GHAS RFM69 test (transmitter) v0.0.5";
          /* Initialization        */
            //Open a serial connection to display values
            #ifdef DEBUG
              Serial.print("Starting ");
              Serial.println(VERSION);
            //Initialize data
            dataToSend.measure = 0;
            //Initialize RFM69 driver
            radio.initialize(FREQUENCY, NODEID, NETWORKID);
            radio.setHighPower();
            radio.encrypt(ENCRYPTKEY);
            #ifdef DEBUG
              radio.readAllRegs();
              Serial.flush();
            delay(1000);
          /* Main loop        */
            //Get informations
            dataToSend.voltage = getVoltage() / 100.0;
            dataToSend.rfmTemp = radio.readTemperature(0);
            //Insert number of measure
            dataToSend.measure++;
            if (dataToSend.measure > 250) {dataToSend.measure = 0;}
            //Send data on serial link
            #ifdef DEBUG
              Serial.print(dataToSend.rfmTemp, 1);
              Serial.print(" degC");
              Serial.print("   ");
              Serial.print(dataToSend.voltage);
              Serial.print(" v");
              Serial.print("   (");
              Serial.print(dataToSend.measure);
              Serial.println(")");
              Serial.flush();
            //Send data
            if (radio.sendWithRetry(GATEWAYID, (const void*)(&dataToSend), sizeof(dataToSend)))
              #ifdef DEBUG
                Serial.println("Transmission done without problem !");
                Serial.flush();
              #ifdef DEBUG
                Serial.println("Error with transmission !");
                Serial.flush();
            //Waiting time before next measurement (minimum 3 seconds)
            radio.sleep();
            //delay(LOOP_DELAY);
            Sleepy::loseSomeTime(LOOP_DELAY);
          /* Allows to get the real Vcc (return value * 100).                                   */
          int getVoltage()
            const long InternalReferenceVoltage = 1056L;
            ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
            delay(50);  // Let mux settle a little to get a more stable A/D conversion
            //Start a conversion
            ADCSRA |= _BV( ADSC );
            //Wait for it to complete
            while (((ADCSRA & (1<<ADSC)) != 0));
            //Scale the value
            int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
            return result;
          As you can see, some debug informations are displayed in the console.
          The code for the receiver:
          /* Version: 0.0.1        */
          /*                            RST |             |  A5                                 */
          /*                            RX  |             |  A4                                 */
          /*                            D3  |             |  A1                                 */
          /*                            D8  |             |  D9                                 */
          /* Used library:        */
          #include <JeeLib.h>
          #include <RFM69.h>
          #define DEBUG
          #define NODEID      50
          #define NETWORKID   5
          #define IS_RFM69HW
          RFM69 radio;
          //Data table
          typedef struct
            } Payload;
          Payload dataReceived;
          //Misc.
          const char VERSION[] = "GHAS RFM69 test (receiver) v0.0.1";
            #ifdef DEBUG
            radio.promiscuous(true);
            #ifdef DEBUG
              char buff[50];
              sprintf(buff, "Listening at %d Mhz...\n", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
              Serial.println(buff);
              Serial.flush();
            delay(1000);
          /* Main loop        */
            //Check if data have been received
            if (radio.receiveDone())
              int dataValid = 0;
              if (radio.DATALEN != sizeof(dataReceived))
                dataValid = 0;
                #ifdef DEBUG
                  Serial.print("Invalid payload received, not matching Payload struct!");
                dataValid = 1;
                dataReceived = *(Payload*)radio.DATA;
              //Send an ACK if required by the node
              if (radio.ACKRequested())
                //radio.SENDERID = NODEID;
                radio.sendACK();
                #ifdef DEBUG
                  Serial.print("[ACK-sent]");
              //Display information on serial line if required
              #ifdef DEBUG
                Serial.print("[RSSI:");
                Serial.print(radio.RSSI, DEC);
                Serial.print("]");
                Serial.print("[TEMP:");
                Serial.print(dataReceived.rfmTemp, DEC);
                Serial.print("]");
                Serial.print("[VOLTAGE:");
                Serial.print(dataReceived.voltage);
                Serial.print(" v]");
                Serial.print("[MEASURE:");
                Serial.print(dataReceived.measure);
                Serial.print("] ");
                Serial.println();
          Hope it helps !
          David.
          chrilleC 1 Reply Last reply
          • E Offline
            E Offline
            EJ3359113
            Thank's for all
            • W Offline
              W Offline
              Wijbe.Fryslan
              Did the last post from @carlierd helps? I.g. have you tried?
              • carlierdC carlierd
                /*                            RST |             |  A5                                 */
                /*                            RX  |             |  A4                                 */
                /*                            D3  |             |  A1                                 */
                /*                            D8  |             |  D9                                 */
                /* Used library:        */
                #include <JeeLib.h>
                #include <RFM69.h>
                #define DEBUG
                #define NODEID      35
                #define NETWORKID   5
                #define IS_RFM69HW
                RFM69 radio;
                //Data table
                typedef struct
                  } Payload;
                Payload dataToSend;
                //Misc.
                  #ifdef DEBUG
                  //Initialize data
                  #ifdef DEBUG
                    Serial.flush();
                  delay(1000);
                /* Main loop        */
                  //Get informations
                  #ifdef DEBUG
                    Serial.print("   ");
                    Serial.print(" v");
                    Serial.print("   (");
                    Serial.flush();
                  //Send data
                    #ifdef DEBUG
                      Serial.flush();
                    #ifdef DEBUG
                      Serial.flush();
                  radio.sleep();
                int getVoltage()
                  //Scale the value
                  return result;
                /*                            RST |             |  A5                                 */
                /*                            RX  |             |  A4                                 */
                /*                            D3  |             |  A1                                 */
                /*                            D8  |             |  D9                                 */
                /* Used library:        */
                #include <JeeLib.h>
                #include <RFM69.h>
                #define DEBUG
                #define NODEID      50
                #define NETWORKID   5
                #define IS_RFM69HW
                RFM69 radio;
                //Data table
                typedef struct
                  } Payload;
                //Misc.
                  #ifdef DEBUG
                  #ifdef DEBUG
                    char buff[50];
                    Serial.flush();
                  delay(1000);
                /* Main loop        */
                    int dataValid = 0;
                      dataValid = 0;
                      #ifdef DEBUG
                      dataValid = 1;
                      radio.sendACK();
                      #ifdef DEBUG
                    #ifdef DEBUG
                      Serial.print("]");
                      Serial.print("]");
                      Serial.print("] ");
                      Serial.println();
                Hope it helps !
                David.
                chrilleC Offline
                chrilleC Offline
                chrille
                @carlierd Thanks for providing the test code. I am trying to set up RFM69 modules for the first time and have issues, and your code is very welcome. I have the two RFM69C modules connected to an Arduino Pro Mini each. Both Arduinos are able to read all the registers, and the TX node reads temperate and VCC and sends them off to the RX node
                Most measurements are received several times, but some goes missing
                [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:1]
                [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:1]
                [ACK-sent][RSSI:-89][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:2]
                [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:2]
                [ACK-sent][RSSI:-88][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:3]
                [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:3]
                [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:4]
                [ACK-sent][RSSI:-89][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:4]
                [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
                [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
                [ACK-sent][RSSI:-88][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
                Notice 5 and 6 are missing
                On the sending side it looks like
                22.0 degC   3.31 v   (1)
                22.0 degC   3.31 v   (2)
                22.0 degC   3.31 v   (3)
                22.0 degC   3.31 v   (4)
                22.0 degC   3.31 v   (5)
                22.0 degC   3.31 v   (6)
                22.0 degC   3.31 v   (7)
                Both RFM69's have a 4.7uF capacitor across GND+VCC and both modules are powered from the Arduino VCC pin, and the Arduinos are USB powered. Any suggestions on why this isn't working reliable is much appreciated!
                The modules have external antennas and are 1 meter apart
                • carlierdC Offline
                  carlierdC Offline
                  carlierd
                  I think that the RSSI is very low especially with external antennas and at 1 meter each other !
                  You have the good antenna length ? You could try to increase the caps to 10uF.
                  It's a pro mini at 3v ? you have not resistor divider for the RFM ?
                  David.
                    David.
                    chrilleC Offline
                    chrilleC Offline
                    chrille
                    @carlierd The antennes are 868 MHz rubber antennas with SMA connectors and supposed to be 2dBi gain. They are connected to a SMA connector wired to the RFM69 with as short wires as possible. The Arduinos are 3.3V, so no level converter is required
                    The low RSSI values made me think about if the antennas were faulty (I did buy them from China!), and replaced the antennas with jumper wires and suddenly things started to work, although with -90 dbm RSSI. I replaced the jumper wires with the antennas, one at a time, and still things are OK, but RSSI values are still bad (-84 to -78 dbm). Later today I will try to replace the SMA connectors with a wire soldered directly to the module to rule out bad connectors. Also I will try to change the decouple cap to 10 uF
                    I assume I can rule out any issues with the wiring between the module and the Arduinos, since both now sends and receive
                    I am right to assume that in my scenario I should expect at least -50 dbm RSSI, even with a non-H version of the RFM69?
                    • carlierdC Offline
                      carlierdC Offline
                      carlierd
                      Arf ! Remove the cable between RFM and SMA connector. Use only RF cables. You can do the job with a cable of 17,3 cm directly connected to the antenna pin of the RFM. It's very good for testing and you can reach more than 100 meters with it.
                      David.
                      • chrilleC Offline
                        chrilleC Offline
                        chrille
                        I think I am missing something very basic about how RFM69 modules work with MySensors!
                        Still have 2x Pro Mini 3.3V each with a RFM69CW module. If I install the following sketches on two modules, everything is fine
                        Sending:
                        https://github.com/LowPowerLab/RFM69/blob/master/Examples/Node/Node.ino
                        Receiving:
                        https://github.com/LowPowerLab/RFM69/blob/master/Examples/Gateway/Gateway.ino
                        One module receives data, and acks go back. RSSI is great and now I feel very confident about the hardware being OK
                        I pulled the latest 2.0 beta from github and opened the DallasTemperatureSensor sketch and connected a DS18B20 to pin 3 of the sensor Arduino. Changed MY_RADIO_NRF24 to MY_RADIO_RFM69 and enabled MY_DEBUG. The default values for MySensors seems to be network ID 100 and 868 Mhz, so I should be good to go. Sketch builds and installs and I see messages in the serial debug window - but nothing is seen on the node running the Gateway sketch - even in promiscuous mode
                        What am I missing?
                        hekH 1 Reply Last reply
                        • chrilleC chrille
                          Sending:
                          Receiving:
                          What am I missing?
                          hekH Offline
                          hekH Offline
                          wrote on last edited by hek
                          @chrille
                          Strange. What does the log say? Wish I could help you more. Can't access my RF69 rig tonight here.
                          Also, I'm only having the RFM69W what are the differences compared to RFM69CW?
                          chrilleC 2 Replies Last reply
                            @chrille
                            chrilleC Offline
                            chrilleC Offline
                            chrille
                            @hek This what I'm seeing in the log on the sensor side
                            Starting sensor (RRNNA-, 2.0.0-beta)
                            Radio init successful.
                            find parent
                            send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                            find parent
                            find parent
                            find parent
                            Init complete, id=255, parent=255, distance=255
                            find parent
                            The RFM69C/RFM69CW are a version, that's pin compatible with the RFM12. It happened to be version available from China when I ordered the modules. As I understand it's 100% compatible with the non-C version, except for the pinout
                            I think it would be useful if the radio driver could output some info when debugging is turned on, like node id, network id, frequency, pin mappings etc
                              @chrille
                              chrilleC Offline
                              chrilleC Offline
                              chrille
                              @hek I am still trying to get this to work. Can you confirm that you the following gateway combination working:
                              • ESP8266 based gateway (telnet or MQTT)
                              • RFM69 (H- or non-H)
                              • Mysensors 2.0 beta code
                              What version of the board manager do you use? (2.0 or 2.1RC)
                              How did you wire the RFM radio to the ESP?
                              Could you share the actual sketch you're using (feel free to remove IP/SSID stuff)
                              It seems that at least some of my issues were related to my USB Serial adaptor not being able to provide sufficient power to the radio (even with a -13dbm/non-H radio). However I still see crashes of the gateway as soon as the node sends traffic.
                              • Jan
                              • hekH Offline
                                hekH Offline
                                Sorry, I haven't rigged ESP with RFM69 myself yet.
                                • chrilleC chrille
                                  • Jan
                                  @chrille this thread might help you, I finally got an esp8266 gateway working tonight.
                                  11.9k
                                  113.3k
