  3. Newbie: RFM69 serial gateway
16 Posts 6 Posters 11.3k Views 5 Watching
  • carlierdC carlierd
    The code for the transmitter:
    /* Simple sketch to check RFM69 is correctly connected to the Arduino.                */
    /*        Part of the Global Home Automation System GHAS.                             */
    /* Version: 0.0.5        */
    /* Date   : 28/12/2015        */
    /* Author : David Carlier                                                             */
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            TX  |   ARDUINO   |  A3                                 */
    /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
    /*                            D3  |             |  A1                                 */
    /*                            D4  | ATMEGA 328p |  A0                                 */
    /*            +3.3v --------- VCC |             | GND --------- GND                   */
    /*              GND --------- GND |  8MHz int.  | REF                                 */
    /*                            OSC |             | VCC --------- +3.3v                 */
    /*                            OSC |             | D13 --------- RFM69 (SCK)           */
    /*                            D5  |             | D12 --------- RFM69 (MISO)          */
    /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
    /*                            D7  |             | D10 --------- RFM69 (NSS)           */
    /*                            D8  |             |  D9                                 */
    /* Used library:        */
    /*     RFM69  : https://github.com/LowPowerLab/RFM69                                  */
    /*     Jeelib : http://jeelabs.net/projects/jeelib/wiki                               */
    //Include low power library
    #include <JeeLib.h>
    //Include RFM69 library
    #include <RFM69.h>
    //Active mode debug.
    #define DEBUG
    //Define RFM69 settings
    #define GATEWAYID   50
    #define NODEID      35
    #define NETWORKID   5
    #define FREQUENCY   RF69_868MHZ
    #define ENCRYPTKEY  "1234567890123456"	//Encrypt key must be 16 characters
    #define IS_RFM69HW
    //Setup the watchdog
    ISR(WDT_vect) {Sleepy::watchdogEvent();}
    //Declare RFM69 driver
    RFM69 radio;
    //Declare local constants
    #define LOOP_DELAY   58000
    //Data table
    typedef struct
      float    rfmTemp;      //Temperature (°C)
      float    humidity;     //Humidity (%)
      float    voltage;      //Voltage of battery capacity (v)
      byte     measure;      //Measure number (from 0 to 250, +1 each new measurement)
      } Payload;
    Payload dataToSend;
    //Misc.
    const char VERSION[] = "GHAS RFM69 test (transmitter) v0.0.5";
    /* Initialization        */
      //Open a serial connection to display values
      #ifdef DEBUG
        Serial.print("Starting ");
        Serial.println(VERSION);
      //Initialize data
      dataToSend.measure = 0;
      //Initialize RFM69 driver
      radio.initialize(FREQUENCY, NODEID, NETWORKID);
      radio.setHighPower();
      radio.encrypt(ENCRYPTKEY);
      #ifdef DEBUG
        radio.readAllRegs();
        Serial.flush();
      delay(1000);
    /* Main loop        */
      //Get informations
      dataToSend.voltage = getVoltage() / 100.0;
      dataToSend.rfmTemp = radio.readTemperature(0);
      //Insert number of measure
      dataToSend.measure++;
      if (dataToSend.measure > 250) {dataToSend.measure = 0;}
      //Send data on serial link
      #ifdef DEBUG
        Serial.print(dataToSend.rfmTemp, 1);
        Serial.print(" degC");
        Serial.print("   ");
        Serial.print(dataToSend.voltage);
        Serial.print(" v");
        Serial.print("   (");
        Serial.print(dataToSend.measure);
        Serial.println(")");
        Serial.flush();
      //Send data
      if (radio.sendWithRetry(GATEWAYID, (const void*)(&dataToSend), sizeof(dataToSend)))
        #ifdef DEBUG
          Serial.println("Transmission done without problem !");
          Serial.flush();
        #ifdef DEBUG
          Serial.println("Error with transmission !");
          Serial.flush();
      //Waiting time before next measurement (minimum 3 seconds)
      radio.sleep();
      //delay(LOOP_DELAY);
      Sleepy::loseSomeTime(LOOP_DELAY);
    /* Allows to get the real Vcc (return value * 100).                                   */
    int getVoltage()
      const long InternalReferenceVoltage = 1056L;
      ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
      delay(50);  // Let mux settle a little to get a more stable A/D conversion
      //Start a conversion
      ADCSRA |= _BV( ADSC );
      //Wait for it to complete
      while (((ADCSRA & (1<<ADSC)) != 0));
      //Scale the value
      int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
      return result;
    As you can see, some debug informations are displayed in the console.
    The code for the receiver:
    /* Version: 0.0.1        */
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            D3  |             |  A1                                 */
    /*                            D8  |             |  D9                                 */
    /* Used library:        */
    #include <JeeLib.h>
    #include <RFM69.h>
    #define DEBUG
    #define NODEID      50
    #define NETWORKID   5
    #define IS_RFM69HW
    RFM69 radio;
    //Data table
    typedef struct
      } Payload;
    Payload dataReceived;
    //Misc.
    const char VERSION[] = "GHAS RFM69 test (receiver) v0.0.1";
      #ifdef DEBUG
      radio.promiscuous(true);
      #ifdef DEBUG
        char buff[50];
        sprintf(buff, "Listening at %d Mhz...\n", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
        Serial.println(buff);
        Serial.flush();
      delay(1000);
    /* Main loop        */
      //Check if data have been received
      if (radio.receiveDone())
        int dataValid = 0;
        if (radio.DATALEN != sizeof(dataReceived))
          dataValid = 0;
          #ifdef DEBUG
            Serial.print("Invalid payload received, not matching Payload struct!");
          dataValid = 1;
          dataReceived = *(Payload*)radio.DATA;
        //Send an ACK if required by the node
        if (radio.ACKRequested())
          //radio.SENDERID = NODEID;
          radio.sendACK();
          #ifdef DEBUG
            Serial.print("[ACK-sent]");
        //Display information on serial line if required
        #ifdef DEBUG
          Serial.print("[RSSI:");
          Serial.print(radio.RSSI, DEC);
          Serial.print("]");
          Serial.print("[TEMP:");
          Serial.print(dataReceived.rfmTemp, DEC);
          Serial.print("]");
          Serial.print("[VOLTAGE:");
          Serial.print(dataReceived.voltage);
          Serial.print(" v]");
          Serial.print("[MEASURE:");
          Serial.print(dataReceived.measure);
          Serial.print("] ");
          Serial.println();
    Hope it helps !
    David.
    chrilleC
    chrilleC
    chrille
    @carlierd Thanks for providing the test code. I am trying to set up RFM69 modules for the first time and have issues, and your code is very welcome. I have the two RFM69C modules connected to an Arduino Pro Mini each. Both Arduinos are able to read all the registers, and the TX node reads temperate and VCC and sends them off to the RX node
    Most measurements are received several times, but some goes missing
    [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:1]
    [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:1]
    [ACK-sent][RSSI:-89][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:2]
    [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:2]
    [ACK-sent][RSSI:-88][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:3]
    [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:3]
    [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:4]
    [ACK-sent][RSSI:-89][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:4]
    [ACK-sent][RSSI:-86][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
    [ACK-sent][RSSI:-87][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
    [ACK-sent][RSSI:-88][TEMP:22.0000000000][VOLTAGE:3.31 v][MEASURE:7]
    Notice 5 and 6 are missing
    On the sending side it looks like
    22.0 degC   3.31 v   (1)
    22.0 degC   3.31 v   (2)
    22.0 degC   3.31 v   (3)
    22.0 degC   3.31 v   (4)
    22.0 degC   3.31 v   (5)
    22.0 degC   3.31 v   (6)
    22.0 degC   3.31 v   (7)
    Both RFM69's have a 4.7uF capacitor across GND+VCC and both modules are powered from the Arduino VCC pin, and the Arduinos are USB powered. Any suggestions on why this isn't working reliable is much appreciated!
    The modules have external antennas and are 1 meter apart
    • carlierdC
      carlierdC
      carlierd
      I think that the RSSI is very low especially with external antennas and at 1 meter each other !
      You have the good antenna length ? You could try to increase the caps to 10uF.
      It's a pro mini at 3v ? you have not resistor divider for the RFM ?
      David.
      chrilleC 1 Reply Last reply
        David.
        chrilleC
        chrilleC
        chrille
        @carlierd The antennes are 868 MHz rubber antennas with SMA connectors and supposed to be 2dBi gain. They are connected to a SMA connector wired to the RFM69 with as short wires as possible. The Arduinos are 3.3V, so no level converter is required
        The low RSSI values made me think about if the antennas were faulty (I did buy them from China!), and replaced the antennas with jumper wires and suddenly things started to work, although with -90 dbm RSSI. I replaced the jumper wires with the antennas, one at a time, and still things are OK, but RSSI values are still bad (-84 to -78 dbm). Later today I will try to replace the SMA connectors with a wire soldered directly to the module to rule out bad connectors. Also I will try to change the decouple cap to 10 uF
        I assume I can rule out any issues with the wiring between the module and the Arduinos, since both now sends and receive
        I am right to assume that in my scenario I should expect at least -50 dbm RSSI, even with a non-H version of the RFM69?
        • carlierdC
          carlierdC
          carlierd
          Arf ! Remove the cable between RFM and SMA connector. Use only RF cables. You can do the job with a cable of 17,3 cm directly connected to the antenna pin of the RFM. It's very good for testing and you can reach more than 100 meters with it.
          David.
          • chrilleC
            chrilleC
            chrille
            I think I am missing something very basic about how RFM69 modules work with MySensors!
            Still have 2x Pro Mini 3.3V each with a RFM69CW module. If I install the following sketches on two modules, everything is fine
            Sending:
            https://github.com/LowPowerLab/RFM69/blob/master/Examples/Node/Node.ino
            Receiving:
            https://github.com/LowPowerLab/RFM69/blob/master/Examples/Gateway/Gateway.ino
            One module receives data, and acks go back. RSSI is great and now I feel very confident about the hardware being OK
            I pulled the latest 2.0 beta from github and opened the DallasTemperatureSensor sketch and connected a DS18B20 to pin 3 of the sensor Arduino. Changed MY_RADIO_NRF24 to MY_RADIO_RFM69 and enabled MY_DEBUG. The default values for MySensors seems to be network ID 100 and 868 Mhz, so I should be good to go. Sketch builds and installs and I see messages in the serial debug window - but nothing is seen on the node running the Gateway sketch - even in promiscuous mode
            What am I missing?
            hekH 1 Reply Last reply
            • chrilleC chrille
              Sending:
              Receiving:
              What am I missing?
              wrote on last edited by hek
              @chrille
              Strange. What does the log say? Wish I could help you more. Can't access my RF69 rig tonight here.
              Also, I'm only having the RFM69W what are the differences compared to RFM69CW?
              chrilleC 2 Replies Last reply
                @chrille
                chrilleC
                chrilleC
                chrille
                @hek This what I'm seeing in the log on the sensor side
                Starting sensor (RRNNA-, 2.0.0-beta)
                Radio init successful.
                find parent
                send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                find parent
                find parent
                find parent
                Init complete, id=255, parent=255, distance=255
                find parent
                The RFM69C/RFM69CW are a version, that's pin compatible with the RFM12. It happened to be version available from China when I ordered the modules. As I understand it's 100% compatible with the non-C version, except for the pinout
                I think it would be useful if the radio driver could output some info when debugging is turned on, like node id, network id, frequency, pin mappings etc
                  @chrille
                  chrilleC
                  chrilleC
                  chrille
                  @hek I am still trying to get this to work. Can you confirm that you the following gateway combination working:
                  • ESP8266 based gateway (telnet or MQTT)
                  • RFM69 (H- or non-H)
                  • Mysensors 2.0 beta code
                  What version of the board manager do you use? (2.0 or 2.1RC)
                  How did you wire the RFM radio to the ESP?
                  Could you share the actual sketch you're using (feel free to remove IP/SSID stuff)
                  It seems that at least some of my issues were related to my USB Serial adaptor not being able to provide sufficient power to the radio (even with a -13dbm/non-H radio). However I still see crashes of the gateway as soon as the node sends traffic.
                  • Jan
                    Sorry, I haven't rigged ESP with RFM69 myself yet.
                    • chrilleC chrille
                      • Jan
                      @chrille this thread might help you, I finally got an esp8266 gateway working tonight.
