  3. [SOLVED] Can't upload any sketch after battery modifications
8 Posts 3 Posters 5.1k Views 1 Watching
  • ErrKE
    ErrKE
    ErrK
    wrote on last edited by ErrK
    Hi.
    I have begin to make battery modifications to my Arduino pro mini 5v to make them last longer.
    They looks like this.
    I started to desolder the power LED and voltage converter beside the LED, then the VDC regulator.
    Now i can't upload any sketch to it.
    I have tried to upload a empty sketch and then ClearEepromConfig and always get the same error message
    Arduino: 1.6.5 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    Sketch uses 1,922 bytes (6%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 266 bytes (12%) of dynamic memory, leaving 1,782 bytes for local variables. Maximum is 2,048 bytes.
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbd
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xaf
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0b
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x39
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3b
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3a
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0a
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7f
    I got the tip from @sundberg84 that the bootloader maybe is broke.
    So i tried to burn/flash the bootloader but got this error message.
    Arduino: 1.6.5 (Mac OS X), Board: "Arduino/Genuino Uno"
    Can i have broke the arduino when i desolder the LED?
    I am thinking of the components in the red circle. (it's a img before my modifications)
    • mfalkviddM
      Are you providing power to the Vcc pin? With the regulator unsoldered you can no longer use the raw pin.
      • ErrKE
        ErrKE
        ErrK
        Yes.
        I'm using the power from the FTDI VCC to the VCC pin on the arduino.
        • OitzuO
          OitzuO
          Oitzu
          @ErrK do you have a "after modification" picture?
          Preferable one that isn't taken with a potato cam. :P
          ErrKE 1 Reply Last reply
          • OitzuO Oitzu
            ErrKE
            ErrKE
            ErrK
            @Oitzu
            Here you can see some picture. on my drive
            I have made the modifications on two arduinos. One that have the VDC regulator.
            OitzuO 1 Reply Last reply
            • ErrKE ErrK
              @Oitzu
              OitzuO
              OitzuO
              Oitzu
              @ErrK said:
              @Oitzu
              Hm... strange! Damage on the srrounding parts should not have this effect.
              What you could try: Hold down reset while die ide is compiling and release it on upload start. Maybe the DTR line is damaged.
              • OitzuO Oitzu
                @ErrK said:
                @Oitzu
                ErrKE
                ErrKE
                ErrK
                @Oitzu
                Thanks for the tips.
                After a many attempts it worked.
                I hold the reset down while it was compiling and first it failed.
                Then i tried again just after it failed and did it a few times. Then suddenly it did't fail and the sketch was uploaded.
                • OitzuO
                  OitzuO
                  Oitzu
                  To explain this: Normally the DTR line is pulled down to reset the arduino.
                  After the reset the arduino starts the bootloader and accepts the serial upload.
                  If the DTR line is broken you can manually reset the arduino, you just need the right timing.
