  3. ๐Ÿ’ฌ Easy/Newbie PCB for MySensors
716 Posts 111 Posters 703.2k Views 93 Watching
  • sundberg84S
    sundberg84S
    Hi @BastienVH
    Do you use 3.3 or 5v arduino?
    How do you power it?
    Did you solder the pinheader / jumper?
    I have rev7 myself, and those works great for me.
    • B
      B
      BastienVH
      I have a 3.3v arduino.
      At the moment it's powered the FTDI232 connected to my computer.
      I will transfer to battery once I'm done.
      Do you mean the "BAT" / "REG"?
      I haven't soldered that. I'm guessing that's necessary?
      Also, while I have you hear ;-) , if I want to use the battery measuring, do I have to add the 0.1uF capacitor?
      What advantage does it provide?
      Thanks for your help!
      • sundberg84S
        sundberg84S
        #33
        If you use the FTDI connector, make sure its the 3.3v and connect it to Gnd/Pwr on the PCB and not Arduino FDTI connector.
        You could just exclude those pins and connect a battery directly and use that as power and the FDTI as programmer/serial debug only
        Bat or Reg is nessecary!
        See this picture for battery use: https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
        https://www.openhardware.io/uploads/568ed84b60aa3f8965fbf095/image/3.jpg
        All components in the image is needed (except battery measurment).
        If you dont want to use booster you need to bypass that one with a wire/jumper (or set the jumper on REG instead of BAT but that kills the logic).
        The battery doesnt "need" the 0,1uF but see here:https://www.mysensors.org/build/battery
        "The tap point could be bypassed with a 0.1 uF capacitor to keep the noise level low, at this otherwise high impedance point. "
        B 2 Replies Last reply
        • sundberg84S sundberg84
          B
          B
          BastienVH
          @sundberg84
          Thanks for the explanation!
          I think I've got it now.
          Will test and get back with the results when I've gotten my hands on some more solder wire!
          B 1 Reply Last reply
          • AnticimexA
            AnticimexA
            Anticimex
            #35
            I see you use CERN OHL but I do not find the required files.
            Where do you store those?
            According to the CERN OHL 1.2 howto, you need to provide the following documentation with your project:
            LICENSE.PDF
            cern_ohl_v_1_2_howto.pdf
            PRODUCT.TXT
            CHANGES.TXT
            Please check the howto closely for how to use the license, or pick another license. If it is not used according to spec, others don't need to follow it either since it is invalid, so you won't be "protected" by it.
            • B BastienVH
              @sundberg84
              B
              B
              BastienVH
              @BastienVH
              Replying to myself to follow up on my assembly-issues.
              I have been able to get the board to work.
              I don't have my 0.1ยตF caps yet, so I just put a little blob of solder in the holes so the current could run through.
              Now I've got myself 2 working board. I just have to find a good way to attach my PIR, dallas temp, ... to them.
              Thanks for the work and help!
              • ErrKE
                ErrKE
                ErrK
                I'am now finnish with my first rev7 node.
                It is a Arduino 5V with DHT-22 and a HC-SR501 sensor.
                Good work @sundberg84 for the PCB
                • sundberg84S
                  sundberg84S
                  @BastienVH Good to hear - its not essential to have to 0.1uF cap on the voltage retulator, it will work without but its good to keep noice out.
                  @ErrK Nice, I see you run through RAW pin and using the internal voltage regulator on the arduino - I have not tested that much, does it work ok?
                  B ErrKE 2 Replies Last reply
                    B
                    B
                    BastienVH
                    @sundberg84
                    When I get the caps, I'll place them on the board.
                    I did notice alot of noise when I was reading battery state on a breadboard in an earlier build, so I will get that sorted.
                    Only problem is I can't find them locally, so have to get them from China.
                    Will take a while...
                      ErrKE
                      ErrKE
                      ErrK
                      @sundberg84 yes it's working good. But the problem is that it's eating up the batteries :)
                      It was up for only 15days.
                      I will now test with a arduino that i have removed the led and volt regulator.
                      • sundberg84S
                        sundberg84S
                        Sounds good @ErrK - dont forget to power it through REG and not RAW on the PCB and add a jumper on REG since it wont work if you use the same setup as in the images and remove voltage regulator.
                        ErrKE 1 Reply Last reply
                          ErrKE
                          ErrKE
                          ErrK
                          Thank you @sundberg84. I will think of that.
                          • BarnaB
                            BarnaB
                            Barna
                            Why have you redesigned from rev7 to rev8?
                            When will the rev8 be tested ?
                            • sundberg84S
                              sundberg84S
                              @Barna - I just wanted to make it smaller, with the radio not sticking out so much.
                              I ordered them a while ago, so if they made it out of china before their new year I think it will be tested soon.
                                A Former User
                                Just received Rev 8 :
                                I'll test it asap :smiley:
                                • sundberg84S
                                  sundberg84S
                                  #46
                                  Nice. @dark-nico
                                  The main concern is the new placement of caps and voltage divider - I hope they fit in between the radio and screw terminal. Should not be a problem - but you know, always nice to see it IRL. Might be good to solder them first before radio, arduino and screw terminal.
                                    A Former User
                                    Ok, I'll do that.
                                    My main problem is that I haven't received both my booster and my 5->3.3 reg. :disappointed:
                                    So I can test Batt version by bypassing the booster, but it will not tell us if the reg placement is ok.
                                    I'll dig in my "donor harware" if I can find a reg.
                                      A Former User
                                      Looks good!
                                      and works fine!
                                      Perfect, thanks again :thumbsup:
                                      I'll test the batt version as soon as I receive the boosters.
                                      • sundberg84S
                                        sundberg84S
                                        #49
                                        @dark-nico - You know its easy to cut the PCB to make it smaller? Using it as 5v you can remove the right battery part:
                                        Either cut with a knife and brake:
                                        https://www.youtube.com/watch?v=SiC-_g3iNb8
                                        Or sometimes i just use a saw (before components are added) - might not be recommended ;)
                                        ? 1 Reply Last reply
                                          A Former User
                                          @sundberg84 - Yes I know that I can cut that part, but I think this one will be my test board with all this option, including the battery parts.
                                          However I'll keep the video method in mind, I was thinking about using a dremel, but, it seems cleaner.
                                          With your input, this post could be even better ๐Ÿ’—
