  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.6k Views 69 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Sorry for asking the same questions over and over but I have just used the files linked at the top of this thread.
    apm96.upload.tool=avrdude
    apm96.upload.protocol=arduino
    apm96.upload.speed=9600
    apm96.bootloader.tool=avrdude
    apm96.build.mcu=atmega328p
    apm96.build.f_cpu=1000000L
    apm96.build.core=arduino
    apm96.build.variant=standard
      ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      @Cliff-Karlsson
        Ok, finaly succeded in burning the bootloader. Now comes next part. Fuses and lockbits, I have no idea what this means but is this what I need to do?
        m26872M
        m26872M
        m26872
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          @m26872 I am fairly sure that all methods work in normal cases but nothing worked for me fore some reason :) .
          m26872M bjacobseB 2 Replies Last reply
            m26872M
            m26872M
            m26872
            @Cliff-Karlsson
            :thumbsup:
              bjacobseB
              bjacobseB
              bjacobse
              @Cliff-Karlsson
              • rsachocR
                rsachocR
                rsachoc
                Hi all, I'm seeing replies, but I'm not sure if any are aimed at my question? I think not?
                m26872M 1 Reply Last reply
                • rsachocR rsachoc
                  m26872M
                  m26872M
                  m26872
                  @rsachoc
                    meddie
                    it would be nice when a atsha204 a an a flash rom where placed to pcb for signing and ota
                    • M meddie
                      m26872M
                      m26872M
                      m26872
                      wrote on last edited by m26872
                      #227
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        @m26872: slowly getting there: http://forum.mysensors.org/topic/3043/new-nrf24l01-smd/14
                          meddie
                          What i like on this node is the great idea with the casing. To use a cable duct is a great idea. We have wooden windows and i found in a diy market cable ducts in wooden look
                          like this:
                          wooden look cable duct
                          • M meddie
                            like this:
                            m26872M
                            m26872M
                            m26872
                            • GertSandersG GertSanders
                              m26872M
                              m26872M
                              m26872
                                meddie
                                oh, yes. You have right, the battery fits in it, but its a little bit too big so i cant close the cover. Damn i didnt try it before.
                                • AWIA
                                  AWIA
                                  AWI
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    • m26872M m26872
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      #235
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        A couple of more questions. In one of the pictures at the top the electrulyte 4,.7 uf capacitator is placed closer to the atmel chip and the 0.1 uf (c5) is placed closest to the edge does it matter witch capacitator goes where?
                                        AWIA 1 Reply Last reply
                                        • AWIA AWI
                                          #237
                                          @AWI said:
                                          panelized design
                                          AWIA ahmedadelhosniA 2 Replies Last reply
