  3. SI7021 boards
SI7021 boards
22 Posts 9 Posters 10.4k Views 11 Watching
  • G Offline
    G Offline
    GertSanders
    I found this compact board:
    I plan to combine this with a narrow board:
    Spares me the grief of trying to solder the SI7021 chip itself.
    Time to make an EAGLE library part :-)
    • T Offline
      T Offline
      TimO
      I'm using those HTU21D breakout boards, work like a charm.
      If you've finished the design I will order some boards too!
      • G Offline
        G Offline
        GertSanders
        @TimO said:
        HTU21D
        I also like the HTU21D boards, but I prefer the really small SI7021.
        I was wondering which other options there are.
        I also use a breakout board with power converters on it:
        So the question is, are there any other small options ?
        • G GertSanders
          M Offline
          M Offline
          m26872
          @GertSanders Where did you find it?
          • G Offline
            G Offline
            GertSanders
            @m26872 I found both SI7021 on Aliexpress.com
            • G GertSanders
              M Offline
              M Offline
              m26872
              @GertSanders Link?
              A 1 Reply Last reply
              • E Offline
                E Offline
                emc2
                Not SI7021 directly, but there are a lot of small sized I2C sensors.
                I use a BME280 board on my gateway and on a node.
                I also use a BH1750 (slightly bigger) outside to track plants sun exposure.
                If you end up with a design where the I2C bus is included I can definitively see a lot of uses for it!
                • A Offline
                  A Offline
                  AWI
                  wrote on last edited by AWI
                  Another off-topic.. I use these bmp180 boards to power the low power nodes from a 4.1 volt rechargeable Li cell. The LDO is broken out on the connection
                  • M m26872
                    @GertSanders Link?
                    A Offline
                    A Offline
                    AWI
                    @m26872 Industrial High Precision Si7021 Humidity Sensor Module With I2C Interface link
                    • G Offline
                      G Offline
                      GertSanders
                      Without LDO, but with pull up resistors (smallest board I could find):
                      http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32524005324.html
                      With LDO:
                      http://www.aliexpress.com/item/Si7021-Industrial-High-Precision-Humidity-Sensor-with-I2C-Interface-for-Arduino/32529522264.html
                      • G GertSanders
                        With LDO:
                        M Offline
                        M Offline
                        m26872
                        @GertSanders and @AWI Thanks!
                        • Carl HC Offline
                          Carl HC Offline
                          Carl H
                          Your plan is it to change your narrow board with SDL/SDA pad. maybe a jumper to change D2/D3 pin to SDL/SDA?
                          • G Offline
                            G Offline
                            gloob
                            It`s a mess that the pinout of both modules is different.
                            • G Offline
                              G Offline
                              GertSanders
                              @Carl-H it's a possibility. No plans yet, other projects ongoing.
                              • F Offline
                                F Offline
                                fleinze
                                I just received some si7021 boards from china. They are with LDO and level shifter, similar to
                                (the original offer went offline, it was from a reseller named "home boutique", no idea why they sold this item)
                                If I use them with a battery node, is it sufficient to remove (and short-cut) the LDO or do I need to remove the level shifter too?
                                A ? M 3 Replies Last reply
                                • F fleinze
                                  A Offline
                                  A Offline
                                  AWI
                                  @fleinze I would suggest to leave these as they are and measure the consumption. Removing the LDO didn't give me a noticeable difference. It could depend on the board however.
                                  • F fleinze
                                    ? Offline
                                    ? Offline
                                    A Former User
                                    @fleinze I am using ATmega328 with 1Mhz and with LDO i have 15uA in standby mode. I have removed the LDO and measured 8uA. You should try it yourself.
                                    • F fleinze
                                      M Offline
                                      M Offline
                                      m26872
                                      @fleinze I wrote a few words about it over here http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example/
                                      • F Offline
                                        F Offline
                                        fleinze
                                        wrote on last edited by fleinze
                                        @m26872 @kenci @AWI Thank you very much for your answers!
                                        I will go for removing the LDO but letting the level-shifter in place, because it is a pain in the ass to bypass the levelshifter.
                                        Bypassing the desoldered LDO is very easy. Just connect the following point on the resistor-array:
                                        • F fleinze
                                          A Offline
                                          A Offline
                                          AWI
                                          @fleinze The 662k on this board has a typical drop-out of 250mV and power consumption of only 1uA... and takes care of a stable power supply. I doubt if there is any advantage in bridging or removing the LDO.
                                          662k
                                          0_1456149818998_upload-5b22a252-988a-4acd-b4d8-15be0500a58c
                                          si7021
                                          0_1456149758981_upload-6a1d2eb3-c0c8-4556-a701-7d2e5db8608c
                                          G 1 Reply Last reply
