  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.3k Views 30 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Ok, cool. As you might have noticed, personalization has changed a bit on development. Also, whitelisting works slightly differently/better.
    • Pierre PP
      Pierre PP
      Pierre P
      Isn't blacklisting cool too to use ?
      Like, if we know the "name" of the sensor lost, we push it to the black list and voila ? This way, we don't have to put a long list a agreed sensors if we have only two nodes outside the house.
      ... I think.
      No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
      AnticimexA 1 Reply Last reply
      • Pierre PP Pierre P
        ... I think.
        AnticimexA
        AnticimexA
        Anticimex
        #219
        @Pierre-P because if a node is lost, you no longer control that node. So anyone could reprogram it to have it identify itself in any way possible. We have to assume an attacker has full source code access, so they can rewrite the signing algorithm to use a fake serial as salt for the signature to trick the GW to believe it is a new node. A whitelist mean the attacker has to know the ID/serial of one of the nodes you trust. Which they won't know unless they can get access to that node.
        • Pierre PP
          Pierre PP
          Pierre P
          Thanks for the complet answer !
            AnticimexA
            AnticimexA
            Anticimex
            @Pierre-P you are welcome. Security is best when it is totally open and the implementation is aware of this. That makes it quite difficult to circumvent, and it also allows to be challenged. That way, with many eyes examining it, it gets stronger and stronger :) I welcome all attempts to crack it. White or black hat style.
            • SoloamS
              SoloamS
              Soloam
              Hello all! What would require less flash memory? Signing by ATSHA204A Chip or by software?
              • AnticimexA
                AnticimexA
                Anticimex
                Signing by ATSHA204A require less flash memory, but takes longer to execute (at least on 8MHz AtMega328).
                • SoloamS
                  SoloamS
                  Soloam
                  wrote on last edited by Soloam
                  #224
                  @Anticimex assumed that, but this post on the forum got me confused: http://forum.mysensors.org/topic/2005/software-aes-encryption-for-nrf24/19
                  According to that post, he uses software on the SenseBender with Encryption because, according to him "...encryption and ATSHA204A is to big for the SenseBender... ".
                  I would like to add Signing and encryption to my nodes, but I don't know if it will fit on my Atmega328 flash!
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    Well, how much space you have depend on your sketch and on the features you enable in the library, so it is impossible to predict how your code will fit. I suggest you just try to enable what you want and compile, and you'll know :)
                    • mfalkviddM
                      The easiest way to find out is to look at the output in Arduino IDE when you click "Verify".
                      There are some factors that affect size:
                      • Size of bootloader
                      • MySensors version (different versions of the library have different size requirements)
                      • MySensors features used (software signing, encryption, debug on or off, etc)
                      • Size of other libraries you use in your sketch
                      • Size of your sketch
                      • mfalkviddM
                        ouch, @Anticimex was a bit faster :)
                        oh, and the problem in the thread you quoted @Soloam is encryption. At least at that time, encryption used too much space so there wasn't space to include either hardware or software signing.
                        • SoloamS
                          SoloamS
                          Soloam
                          Yes, encryption and signing! I'll try to order this and test it out! http://www.ebay.com/itm/5PCS-ATSHA204A-STUCZ-T-IC-CRYPTO-4-5KB-SWI-204A-SHA204A-/191782104901?hash=item2ca71aaf45:g:zEQAAOSwwE5WZk9O
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            And on development branch, @tekka has an open PR where he has cut down significantly on the size of the NRF24 driver as well.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              And you might also have read mine and @mfalkvidd's stand on encryption, so don't be discouraged if you find that you can't fit both. Just skip the encryption in that case. It adds far less in security than signing does.
                              • SoloamS
                                SoloamS
                                Soloam
                                Yes, if I have to discard one it would be encryption! Thank you for the help @Anticimex and @mfalkvidd
                                • carlierdC
                                  carlierdC
                                  carlierd
                                  I currently testing various bootloader to measure impact on CPU speed on the power consumption.
                                  I got a lot of nonce error when using 1 MHz configuration.
                                  Is signing feature possible at 1 MHz ?
                                  David.
                                  • carlierdC carlierd
                                    David.
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @carlierd could you specify a bit clearer what you mean by "nonce error"? Signing should work, but the atsha driver is not tested @ 1MHz and might get bad timing. Also, for soft (and hard) signing, if 1MHz is used, performance could degrade to the point that the nonce timeout needs to be increased.
                                    carlierdC 1 Reply Last reply
                                    • AnticimexA Anticimex
                                      carlierdC
                                      carlierdC
                                      carlierd
                                      @Anticimex
                                      Hello.
                                      I am using soft signing.
                                      find parent
                                      send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                      read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      sensor started, id=255, parent=255, distance=255
                                      find parent
                                      read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      parent=0, d=1
                                      req id
                                      read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:9
                                      send: 9-9-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:1
                                      read and drop: 9-9-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
                                      read: 0-0-9 s=255,c=3,t=15,pt=2,l=2,sg=0:1
                                      send: 9-9-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                      nonce tr err
                                      nonce tr err
                                      read and drop: 9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      read: 0-0-9 s=255,c=3,t=17,pt=6,l=25,sg=0:0129D04B64916F5E805EFDF704C34F56B47E547FDDE93805BE
                                      id=9
                                      send: 9-9-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0,st=ok:
                                      send: 9-9-0-0 s=1,c=0,t=30,pt=0,l=0,sg=0,st=fail:
                                      [Setup duration: 9928 ms]
                                      send: 9-9-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                      nonce tr err
                                      send: 9-9-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                      nonce tr err
                                      nonce tr err
                                      Value is 1   Cycle is 1   3.39 v   [753 ms]
                                      David.
                                        @Anticimex
                                        Hello.
                                        find parent
                                        find parent
                                        parent=0, d=1
                                        req id
                                        nonce tr err
                                        nonce tr err
                                        id=9
                                        nonce tr err
                                        nonce tr err
                                        nonce tr err
                                        David.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @carlierd you have a lot of st=fail, so your problem is radio related, not signing related. I also see non nonce related messages fail so you need to stabilize your rf connection before signing can work. And since signing uses the maximum payload size, it has the least probability to succeed to be sent, so you could find that unsigned messages work while nonces and signed messages fail, but this is normal of the rf link is not fully working. If you get st=fail, it is a radio problem. See this discussion for details: http://forum.mysensors.org/topic/3386/mqttclientgateway-broken-after-upgrade-signature-failure
                                          carlierdC
                                          carlierdC
                                          carlierd
                                          @Anticimex Hello. Everything is working at 16 or 8MHz so I am pretty sure it's not an issue with the material.
                                          I will burn the bootloader again and create a new post if it's still not correct. I will also disable signing feature to be sure there is no impact.
                                          David.
