  3. Porting MySensors to work with the RadioHead library
portingradiohead
288 Posts 24 Posters 254.8k Views 12 Watching
    I would definitely be interested in your findings. This types of things would be interesting for the next (1.5/2.0?) version of the library where we also will look closer look at the protocol again.
    I must prepare documentations and new example sketches for the 1.4 release so my time is somewhat limited right now. But I always have time for questions if you run into problems when doing your tests.
    K
    K
    kolaf
    @hek Great, I will give it a shot, then.
    I have started playing around with the source code and I'm beginning to think that the only thing that we need to keep from the MySensors part of the library is the message format (mostly), the inclusion mode with automatic node ID assignment, as well as the API on both the sensor side and the server side.
    Route discovery, acknowledgements, and CRC is handled by the radio library and can therefore be removed from MySensors.
    Most of this looks to be pretty straightforward, but I am faced with two immediate challenges.
    1. I'm not sure whether the new radio library handles replacing node IDs. It looks like you set a default node ID upon initialisation, and then later replace this when you get a response back from the server with an updated ID. I assume the node ID used in the MySensors is identical to the one used by the radio library for addressing, routing, et cetera. Related to this, how do you know on the Gateway/server side which device you are communicating with? If the ID is dynamically assigned you will just have to infer it from the sensor type which seems quite unreliable. How is this handled?
    2. Each radio type supported by the new library requires a different driver, which in turn requires different include statements. I must admit that I am not sure how to solve this in a dynamic fashion. There is a global driver class from which all the drivers are derived, so setting up the pointer should be relatively easy. The difficulty comes when you tried to reduce the size of the application by including only the relevant headers. There are also some driver specific options in the initialisation such as setting output power, frequency, and modem modulation. I think most of this is exposed through a unified API, but there might be some peculiarities I have to deal with.
    Anyway, what I am proposing to do as a start is the following:
    1. Change the packet format to remove the CRC.
    2. Remove the logic that handles acknowledgements. Whether this is a smart thing to do depends on whether the acknowledgements in your library are "application level" or "link level" acknowledgements. If they are "application level" (i.e. end-to-end) acknowledgements, then I should better leave them in.
    3. Remove any references to routing nodes (this is handled by the new radio library)
    4. Remove everything related to learning, storing, and restoring routes. I think storing of routes is not supported in the new radio library, but is this a big deal? It allows for a more dynamic network, and other sensor nodes expected to shutdown often? It is possible to put the radio (at least some of the radios) in very low power modes so that it would not have to completely shut off the node. I guess route discovery can be a bit power consuming since it involves a broadcast that visits every node once.
    5. Replace radio initialisation, send, and receive mechanisms to use the new library. The initial version of this will support just a single radio type (RFM69*) until I have figured out the solution to problem number two.
    6. Modify the sleeping routines.
    7. I will leave the automatic node ID discovery as is in the hopes that I will solve problem number one.
    Broadly speaking this requires a small change in MyMessage, and significant changes in MySensors and possibly MyGateway. The upside is that the server side and library API should remain unchanged so that it can benefit from all the existing examples and server side scripts to get things integrated with home control systems.
    Until now I have spent a few hours starting to rewrite the radio specific portions of the code. It is slow going since I have to read up on both the new radio library and how MySensors is supposed to work :-). A few updated examples on the library usage would be helpful, but not critical.
    Comments are very welcome.
    hekH 1 Reply Last reply
    • K kolaf
      First of all, I hope you are looking at the 1.4 version of the library
      https://github.com/mysensors/Arduino/tree/development/libraries/MySensors
      (the reason for asking is that you are talking about CRC which has been removed)
      The temporary id (while a sensor requests a new unique id) is 255. Therefore you shouldn't include more than one new sensor at the time. This is usually not a problem.
      Ok, I've tried to simplify things for the end user as much as possible (often none-programmers). Have this in mind when you think of a setup with the drivers. The less boilerplate code in the examples the better :)
      There are both end-to-end acks and node-node acks .The later uses the build in hardware acking of the nrf-chip.
      K 1 Reply Last reply
        K
        K
        kolaf
        I am looking at the development branch of the github repository. My reference to the CRC probably comes from reading the documentation, not from reading the source code :-).
        Based on your comments about the acknowledgements I assume that the code I see to handle ack messages relates to the end to end acknowledgements. In that case I will leave them in.
        I definitely agree that you don't want boilerplate code. My goal is to reach a point where your radio choice is simply a parameter to the constructor. I might have to have the radio choice as a define in order to filter out unnecessary code, though.
        As a disclaimer I should also mention that my C++ is a bit rusty, so I hope someone has time to review my changes at some point. Also, do not expect any significant results for many weeks to a few months.
        • K kolaf
          @kolaf
          No worries. Don't tell me about rusty c++ knowledge. This is the first c++ program in 10+ years. But it´s slowly getting back... and why I left it for other languages long ago ;)
          • K
            K
            kolaf
            Until I get everything set up and working I am committing stuff to a branch in my own repository. It is located here if anyone wants to see the progress :-).
            https://github.com/kolaf/mysensors
            Currently it is just a big mess...
            • Z
              Z
              Zeph
              wrote on last edited by Zeph
              I've been lightly following the RF69 family of wireless sensors (jeenode (modified), moteino, anarduino) and noticed the appearance of the hardware agnostic radiohead library, so I'll be very interested in your progress.
              MySensors and the underlying nRF library is fairly well optimized to take advantage of the nRF24l01+, eg: ESB. It will be interesting to see how the more hardware abstracted radiohead library works in this role.
              If I understand correctly (always a question), the current MySensors library uses a hybrid between hardware link-level ack and end to end software ack. A packet from hub directly to leaf node uses ESB hardware for the ack. A packet from hub to repeater to leaf node involves "end to end" ack from the repeater to the hub, but ESB from the repeater to the leaf node. In other words, it's the next to last node in the sequence which handles network ack (and with a direct link with no relay, the "next to last node" is actually the originator). @hek and other more knowledgable folks can correct if this is wrong.
              RadioHead would presumably do network acks from the leaf node back to the hub. (a more pure network ack, rather than a hybrid using ESB for the final link).
              • K
                K
                kolaf
                wrote on last edited by kolaf
                As far as I have been able to figure out the RF69 radio uses link level acknowledgements, i.e. an acknowledgement per hop through the network. When using the RMesh manager which I am basing my port on (since this will handle everything related to routing for me) the initial send message function returns after the first of acknowledgement has been received, and the receive function of the final receiving end sends a link level acknowledgement.
                When doing the port I am therefore leaving in the end-to-end acknowledgements and replacing anything related to the original RF24 acknowledgements.
                Status update:
                I have completed an initial rewrite of everything except the MQTTGateway code and I have reached a point where everything compiles correctly. This is with a hardcoded RF69 driver, which means that we do not get the radio agnostic version just yet. However, there is more to coding than just compiling, so I will now start the tedious task of getting this thing to actually run. I spent five minutes this morning testing it and nothing seemed to happen. I got one message from the gateway over the serial link looking something like this: "0;0;3;2;#@" where the two last symbols in the string were some weird ASCII characters. I was expecting to see some kind of initialisation message here as per the serial gateway source code.
                I will continue testing and fixing over the next few days, I hope. Once I have everything running I will probably build a few sketches of my own before I start adding support for the other radio drivers.
                DammeD 1 Reply Last reply
                • K kolaf
                  Status update:
                  DammeD
                  DammeD
                  Damme
                  Code Contributor
                  wrote on last edited by Damme
                  @kolaf that sound to me as a sram overflow. There are ways to see in runtime how much free sram there is in runtime. I think there is a commented out version of it in the code..
                  last lines in mysensor.cpp
                  int MySensor::freeRam (void) {
                    extern int __heap_start, *__brkval;
                    int v;
                    return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
                  K 2 Replies Last reply
                  • DammeD Damme
                      int v;
                    K
                    K
                    kolaf
                    @Damme Thanks for your input. I have had a chance to debug a bit more this evening and it turned out that I was not initialising the radio correctly.
                    I now have a version which is working with the RF 69 radio soldered to my Arduinos. Currently it should be easy to change the radio driver by changing the driver that is initialised and changing the appropriate include files.
                    I have achieved a successful communication from a sensor implementation to the serial gateway implementation where it requests a node ID. This is using the RHMesh manager implementation which handles a dynamic mesh network in the background.
                    I have not tested return communication yet because am frankly not quite sure what the correct command would be to assign a node ID. I guess all figure this out tomorrow, unless someone cares to give me an example?
                    With the debug enabled the gateway and simple sensor (simply sending a message every five seconds) amounts to the following when building..
                    Gateway:
                    Sketch uses 22,674 bytes (70%) of program storage space. Maximum is 32,256 bytes.
                    Global variables use 1,424 bytes (69%) of dynamic memory, leaving 624 bytes for local variables. Maximum is 2,048 bytes.
                    Sensor:
                    Sketch uses 19,854 bytes (61%) of program storage space. Maximum is 32,256 bytes.
                    Global variables use 1,141 bytes (55%) of dynamic memory, leaving 907 bytes for local variables. Maximum is 2,048 bytes.
                    Z 1 Reply Last reply
                      Great, sounds like your doing real progress.
                      • K kolaf
                        Gateway:
                        Sensor:
                        Z
                        Z
                        Zeph
                        @kolaf
                        How big is the flash and RAM footprint of an equivalently limited nRF24L01+ implementation? The RadioHead library sounds heavier.
                        As I'm understanding you, a node is using the RadioHead RF69 mesh network to send a request to the hub for a MySensors node id. Doesn't the mesh network have its own equivalent node id? How are you integrating those two? (eg: does your node use id 255 temporarily within the RadioHead addressing, then change it a hub assigned ID, or...?)
                        I'm not really clear enough about the logical layering of the two networks, and how you are mixing and matching the layers.
                        • DammeD Damme
                            int v;
                          K
                          K
                          kolaf
                          @Damme @Zeph I took a quick stab at dumping the free run by uncommenting the serial.write command in debugPrint. I didn't get anything, so I will look into it later.
                          Anyway, I was finally able to send a node ID response from the serial gateway back to the sensor, and is responded with a bunch of interesting data :-). This means that every thing seems to work, and I think the implementation is in a state where I can actually use it to build sensors. The challenge now is to have the self-discipline to generalise this so that others may use it to ;).
                          Based on all your comments and worries about flash and RAM space, I have been thinking that maybe my approach was not the best. I have ripped out everything related to routing so that I rely completely on the RadioHead for anything related to the link and network level. This means that we get support for quite a complex dynamic sensor networks at the cost of reduced available memory for useful stuff. May be a hybrid approach would have been better, relying on the reliable datagram manager from the library and using the mysensors routing functionality. Perhaps this would yield a smaller footprint, I don't know.
                          As for node addressing, there is a function in the new radio library that allows me to set the node address. I can therefore use the existing node address discovery to set everything up. I've included the message sequence I get when performing this initialisation below. The first line is the node assignment sent from the gateway to the sensor. There is some extra debug garbage in the printout which I had to add when trying to get this to work.
                          255;255;4;0;3;1
                          0;0;3;9;send: 0-255 s=255,c=3,t=4,pt=0,l=1,st=302:1
                          0;0;3;9;sent: 0-255 s=255,c=3,t=4,pt=0,l=1,st=295:1
                          0;0;3;9;Available
                          0;0;3;9;read: 1 s=255,c=3,t=11,pt=0,l=11:Dust Sensor
                          1;255;3;11;Dust Sensor
                          0;0;3;9;Available
                          0;0;3;9;read: 1 s=255,c=3,t=12,pt=0,l=3:1.1
                          1;255;3;12;1.1
                          0;0;3;9;Available
                          0;0;3;9;read: 1 s=3,c=0,t=0,pt=0,l=15:1.4b1 (18848a2)
                          1;3;0;0;1.4b1 (18848a2)
                          0;0;3;9;Available
                          0;0;3;9;read: 1 s=3,c=1,t=16,pt=2,l=2:1
                          1;3;1;16;1
                          0;0;3;9;Available
                          1;3;1;16;1
                          I'm wondering since we now have a working prototype version, perhaps I could be allowed to push my branch to your repository? Of course we don't merge anything yet, but it will allow others more easy access to it for further testing. By only changing a few lines to account for different radios the current version should support most of the moteino and anarduino variations with our different radio chipsets, I think.
                          • K
                            K
                            kolaf
                            I'm getting a bunch of errors when I compile the mqtt gateway source related to the initial list of constants. The error messages look like this:
                            D:\Home control\Arduino\libraries\MySensors\MyMQTT.cpp:14:15: error: variable 'broker' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
                             char broker[] PROGMEM = MQTT_BROKER_PREFIX;
                            D:\Home control\Arduino\libraries\MySensors\MyMQTT.cpp:16:12: error: variable 'S_0' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
                             char S_0[] PROGMEM = "Temperature"; //V_TEMP
                            D:\Home control\Arduino\libraries\MySensors\MyMQTT.cpp:17:12: error: variable 'S_1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
                             char S_1[] PROGMEM = "Humidity"; //V_HUM
                            My current solution is to just delete these two files since I only care about the serial gateway, but it would be good to have everything working :-).
                            • K kolaf
                              Hi guys,
                              I have received my Moteinos and anarduinos with RFM69HW radios. The anarduino webpage recommends a radio library called RadioHead which supports multiple radio tips and provides a common API for communication. http://www.airspayce.com/mikem/arduino/RadioHead/
                              It even supports quite complex things such as mesh networks. It currently supports the following radios:
                              • RH_RF22 Works with Hope-RF RF22B and RF23B based transceivers, and compatible chips and modules, including the RFM22B transceiver module. Supports GFSK, FSK and OOK. Access to other chip features such as on-chip temperature measurement, analog-digital converter, transmitter power control etc is also provided.
                              • RH_RF69 Works with Hope-RF RF69B based radio modules, such as the RFM69 module, (as used on the excellent Moteino and Moteino-USB boards from LowPowerLab http://lowpowerlab.com/moteino/) and compatible chips and modules such as RFM69W, RFM69HW, RFM69CW, RFM69HCW (Semtech SX1231, SX1231H). Also works with Anarduino MiniWireless -CW and -HW boards http://www.anarduino.com/miniwireless/ including the marvellous high powered MinWireless-HW (with 20dBm output for excelent range). Supports GFSK, FSK.
                              • RH_NRF24 Works with Nordic nRF24 based 2.4GHz radio modules, such as nRF24L01 and others. Also works with Hope-RF RFM73 and compatible devices (such as BK2423). nRF24L01 and RFM73 can interoperate with each other.
                              • RH_NRF905 Works with Nordic nRF905 based 433/868/915 MHz radio modules.
                              • RH_RF95 Works with Semtech SX1276/77/78 and HopeRF RFM95/96/97/98 and other similar LoRa capable radios. Supports Long Range (LoRa) with spread spectrum frequency hopping, large payloads etc. FSK/GFSK/OOK modes are not (yet) supported.
                              • RH_ASK Works with a range of inexpensive ASK (amplitude shift keying) RF transceivers such as RX-B1 (also known as ST-RX04-ASK) receiver; TX-C1 transmitter and DR3100 transceiver; FS1000A/XY-MK-5V transceiver; HopeRF RFM83C / RFM85. Supports ASK (OOK).
                              • RH_Serial Works with RS232, RS422, RS485, RS488 and other point-to-point and multidropped serial connections, or with TTL serial UARTs such as those on Arduino and many other processors, or with data radios with a serial port interface. RH_Serial23 provides packetization and error detection over any hardware or virtual serial connection.
                              • RH_TCP For use with simulated sketches compiled and running on Linux. Works with tools/etherSimulator.pl to pass messages between simulated sketches, allowing testing of Manager classes on Linux and without need for real radios or other transport hardware.
                              Seeing as the radio that is currently supported by MySensors is also supported by RadioHead I was wondering if anyone was interested in helping me porting MySensors to work with the RadioHead library. This will greatly increase the versatility of the MySensors library and magically allow it to work with a range of different radios :-).
                              I have briefly looked at the MySensors source code and it looks like most of the changes have to be done in MySensors.h and .cpp files.
                              I am willing to take a stab at it, but as everyone else I am limited on time. Still, it looks like it should not be a very difficult task. As discussed in another thread, it should be sufficient either to subclass the new radio library and replace a bunch of function calls, or drop the subclassing altogether and simply use the radio library as a regular included library.
                              The obvious difficulty comes soon as MySensors requires a function that is not available in the new radio library. However, seeing as MySensors is a pretty high-level library, and the API support from radioHead seems quite good, I suspect it should be possible to get around any such problems.
                              Anyway, I'm thinking of creating a branch of the library and spending a few hours trying to port it and get some basic functionality to work. Is anyone else is any value in this it would be great to have some help :-)
                              K
                              K
                              kolaf
                              I am also happy to report that I just tried to compile the secret knock sensor without any difficulties :-)
                              Sketch uses 22,074 bytes (68%) of program storage space. Maximum is 32,256 bytes.
                              Global variables use 1,241 bytes (60%) of dynamic memory, leaving 807 bytes for local variables. Maximum is 2,048 bytes.
                              DammeD YveauxY 2 Replies Last reply
                              • K kolaf
                                DammeD
                                DammeD
                                Damme
                                Code Contributor
                                #26
                                @kolaf What version of arduino IDE do you use? you should really use 1.5+
                                (But I'll fix so it works in older version)
                                • DammeD Damme
                                  K
                                  K
                                  kolaf
                                  1.5.7
                                  • K
                                    K
                                    kolaf
                                    I have been thinking on how to extend the library to support different radios. As far as I can see there are two options.
                                    1. Have a generic radio driver pointer (of the superclass type RHGenericDriver) and initialise this depending on an input parameter to the Gateway constructor. The trouble with this approach is that we have to static_cast every access to this variable to its appropriate subclass in order to access radio specific functions to set transmit power, et cetera. We also have to include a bunch of header files so that everything is available during runtime. This obviously increases footprint and complexity for the maintainer.
                                    2. Use a define in the sensor application and Gateway application to determine which radio is to be used, e.g. "#define DRH_RF69" to select the radio I am using. With an include #ifdef directives in the header and my sensor source files to include only the necessary driver headers and choose the correct set of initialisation functions for the radio. Most of this would go into the setupRadio function.
                                    I think that the second approach is the easiest to implement. It also requires a single addition to any client application, namely the correct define at the top of the configurations header file. We can leave this as a default radio value, and the knowledgeable user can change this if he uses a different chipset. Does this make sense?
                                    • K kolaf
                                      @kolaf
                                      Tried to open a chat (see the icon at the bottom of the screen)
                                        @kolaf
                                        Agree. Pointers to instances makes more sense when radios have to be switched dynamically or when multiple radios have to be supported.
                                        For this application having a #define in a configuration file makes perfect sense.
                                        • K kolaf
                                          These are very acceptable numbers IMHO.
                                          No need to worry about flash/ram usage!
